C6678 debug 下载出错,偶尔可以下载,大多数报错
CCS7,使用wintech的XDS560V2,在下载仿真时,偶尔可以下载成功,大多数报如下错误。
Launching Debug Session
Load program Error.
Encountered a problem loading file:
E:\ti\PA_emacExample_exampleProject\Debug\PA_emacExample_exampleProject.out
Could not allocate memory to load the entire file
  • 更详细的信息:
    C66xx_0: GEL Output: Setup_Memory_Map...
    C66xx_0: GEL Output: Setup_Memory_Map... Done.
    Connecting Target...
    C66xx_0: GEL Output: DSP core #0
    C66xx_0: GEL Output: C6678L GEL file Ver is 2.00500011
    C66xx_0: GEL Output: Global Default Setup...
    C66xx_0: GEL Output: Setup Cache...
    C66xx_0: GEL Output: L1P = 32K
    C66xx_0: GEL Output: L1D = 32K
    C66xx_0: GEL Output: L2 = ALL SRAM
    C66xx_0: GEL Output: Setup Cache... Done.
    C66xx_0: GEL Output: Main PLL (PLL1) Setup ...
    C66xx_0: GEL Output: PLL not in Bypass, Enable BYPASS in the PLL Controller...
    C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz.
    C66xx_0: GEL Output: SYSCLK2 = 333.333344 MHz, SYSCLK5 = 200.0 MHz.
    C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz.
    C66xx_0: GEL Output: PLL1 Setup... Done.
    C66xx_0: GEL Output: Power on all PSC modules and DSP domains...
    C66xx_0: GEL Output: Security Accelerator disabled!
    C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done.
    C66xx_0: GEL Output: PA PLL (PLL3) Setup ...
    C66xx_0: GEL Output: PA PLL Setup... Done.
    C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ...
    C66xx_0: GEL Output: DDR3 PLL Setup... Done.
    C66xx_0: GEL Output: DDR3 clock frequency is (666) MHz ...
    C66xx_0: GEL Output: DDR begin (1333)
    C66xx_0: GEL Output: XMC Setup ... Done
    C66xx_0: GEL Output: DDR3 initialization is complete.
    C66xx_0: GEL Output: DDR done
    C66xx_0: GEL Output: DDR3 memory test... Started
    C66xx_0: GEL Output: DDR3 memory test... Passed
    C66xx_0: GEL Output: PLL and DDR Initialization completed(0) ...
    C66xx_0: GEL Output: configSGMIISerdes Setup... Begin
    SGMII SERDES has been configured.
    C66xx_0: GEL Output: Enabling EDC ...
    C66xx_0: GEL Output: L1P error detection logic is enabled.
    C66xx_0: GEL Output: L2 error detection/correction logic is enabled.
    C66xx_0: GEL Output: MSMC error detection/correction logic is enabled.
    C66xx_0: GEL Output: Enabling EDC ...Done
    C66xx_0: GEL Output: Configuring CPSW ...
    C66xx_0: GEL Output: Configuring CPSW ...Done
    C66xx_0: GEL Output: Global Default Setup... Done.
    C66xx_0: GEL Output: Invalidate All Cache...
    C66xx_0: GEL Output: Invalidate All Cache... Done.
    C66xx_0: GEL Output: GE1L Reset...
    C66xx_0: GEL Output: GEL Reset... Done.
    C66xx_0: GEL Output: Disable all EDMA3 interrupts and events.
    C66xx_0: GEL: Encountered a problem loading file: E:\ti\PA_emacExample_exampleProject\Debug\PA_emacExample_exampleProject.out Could not allocate memory to load the entire file
  • 是自己的板子还是EVM板?
    有用过别的仿真器?或者试试ccs v5, v6,看闻亭的仿真器是否能很好的支持。
