请教关于DM8148的HDVPSS子系统采集16bit YUV 4:2:2视频数据的配置问题?
设计使用FPGA+DM8148的视频采集处理方案,使用FPGA采集外部视频进行格式的转换,转换为内嵌同步信号(embedded syncs)的16bit YUV数据,数据输出到DM8148的视频采集的VIP0接口;请问
1)VIP0接口支持内嵌同步的16bit视频输入吗?
2)支持的话,要有哪些部分需要修改?
  • john shi 说:
    2)支持的话,要有哪些部分需要修改?
    可以支持的,你的fpga输出按bt1120协议输出就可以,采集配置capure link 为 VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC 和 VPS_CAPT_VIDEO_IF_MODE_16BIT
     * \brief Video capture operation mode
    typedef enum
        VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_EMBEDDED_SYNC = 0,
        /**< Single Channel non multiplexed mode */
        VPS_CAPT_VIDEO_CAPTURE_MODE_MULTI_CH_LINE_MUX_EMBEDDED_SYNC,
        /**< Multi-channel line-multiplexed mode */
        VPS_CAPT_VIDEO_CAPTURE_MODE_MULTI_CH_PIXEL_MUX_EMBEDDED_SYNC,
        /**< Multi-channel pixel muxed */
        VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_DISCRETE_SYNC_HSYNC_VBLK,
        /**< Single Channel non multiplexed discrete sync mode with HSYNC and
            VBLK as control signals. */
        VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_DISCRETE_SYNC_HSYNC_VSYNC,
            VSYNC as control signals. */
        VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_DISCRETE_SYNC_ACTVID_VBLK,
        /**< Single Channel non multiplexed discrete sync mode with ACTVID and
        VPS_CAPT_VIDEO_CAPTURE_MODE_SINGLE_CH_NON_MUX_DISCRETE_SYNC_ACTVID_VSYNC,
        VPS_CAPT_VIDEO_CAPTURE_MODE_MULTI_CH_LINE_MUX_SPLIT_LINE_EMBEDDED_SYNC,
        /**< Multi-channel line-multiplexed mode - split line mode */
        VPS_CAPT_VIDEO_CAPTURE_MODE_MAX
        /**< Maximum modes */
    } Vps_CaptVideoCaptureMode;
     * \brief Video interface mode
    typedef enum
        VPS_CAPT_VIDEO_IF_MODE_8BIT = 0,
        /**< Embedded sync mode:  8bit - BT656 standard  */
        VPS_CAPT_VIDEO_IF_MODE_16BIT,
        /**< Embedded sync mode:  16bit - BT1120 standard  */
        VPS_CAPT_VIDEO_IF_MODE_24BIT,
        /**< Embedded sync mode:  24bit */
        VPS_CAPT_VIDEO_IF_MODE_MAX
    } Vps_CaptVideoIfMode;
