4.目前遇到的问题
我这边硬件用的beagleboneblack,然后自己做了一个扩展板,具体的东西就是显示器接口和BB_VIEW相同,没有接电阻触摸膜,液晶是TN92硬件已经测试过了基于开发板的镜像显示是没有问题的。这个是基于微雪电子的一个镜像测试的,我想自己用TI的SDK自己做一下,有问题也能跟您这边请教。软件是用的官网的SDK,编译烧录之后的系统,放在SD卡里面。
ti-processor-sdk-linux-am335x-evm-03.02.00.05-Linux-x86-Install.bin |
然后我现在遇到的问题是,看了一下资料是不是beagleboneblack的在开机的时候是不启动界面显示程序的呢?请问我该怎么样做才能让这个SDK在beagleboneblack正常显示程序。
以下是开机显示信息:r node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.279197] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 0.279446] media: Linux media interface: v0.10
[ 0.279510] Linux video capture interface: v2.00
[ 0.279552] pps_core: LinuxPPS API ver. 1 registered
[ 0.279559] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.279581] PTP clock support registered
[ 0.279630] EDAC MC: Ver: 3.0.0
[ 0.280641] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.280944] Advanced Linux Sound Architecture Driver Initialized.
[ 0.281942] clocksource: Switched to clocksource timer1
[ 0.291019] NET: Registered protocol family 2
[ 0.291698] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.291745] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.291782] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.291848] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.291863] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.292055] NET: Registered protocol family 1
[ 0.292426] RPC: Registered named UNIX socket transport module.
[ 0.292438] RPC: Registered udp transport module.
[ 0.292443] RPC: Registered tcp transport module.
[ 0.292449] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.293274] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.294899] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.301580] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.302571] NFS: Registering the id_resolver key type
[ 0.302640] Key type id_resolver registered
[ 0.302647] Key type id_legacy registered
[ 0.302722] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.305848] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.305873] io scheduler noop registered
[ 0.305884] io scheduler deadline registered
[ 0.306010] io scheduler cfq registered (default)
[ 0.307143] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.358984] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.362620] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.970232] console [ttyS0] enabled
[ 0.974632] [drm] Initialized drm 1.1.0 20060810
[ 0.985781] loop: module loaded
[ 0.990906] libphy: Fixed MDIO Bus: probed
[ 1.052009] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.058144] davinci_mdio 4a101000.mdio: detected phy mask fffffffe
[ 1.065184] libphy: 4a101000.mdio: probed
[ 1.069226] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver SMSC LAN8710/LAN8720
[ 1.079122] cpsw 4a100000.ethernet: Detected MACID = 88:c2:55:8f:9c:96
[ 1.085890] cpsw 4a100000.ethernet: cpts: overflow check period 850
[ 1.093770] mousedev: PS/2 mouse device common for all mice
[ 1.099888] i2c /dev entries driver
[ 1.104361] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.111749] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.189069] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.198498] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.206637] mmc0: new high speed SDHC card at address 0007
[ 1.214103] NET: Registered protocol family 10
[ 1.219354] mmcblk0: mmc0:0007 SD16G 14.5 GiB
[ 1.224545] sit: IPv6 over IPv4 tunneling driver
[ 1.229871] NET: Registered protocol family 17
[ 1.235449] Key type dns_resolver registered
[ 1.239890] mmcblk0: p1 p2
[ 1.243182] omap_voltage_late_init: Voltage driver support not added
[ 1.278984] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 1.284675] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.316614] mmc1: MAN_BKOPS_EN bit is not set
[ 1.328320] mmc1: new high speed MMC card at address 0001
[ 1.334351] mmcblk1: mmc1:0001 S10004 3.56 GiB
[ 1.339135] mmcblk1boot0: mmc1:0001 S10004 partition 1 4.00 MiB
[ 1.345390] mmcblk1boot1: mmc1:0001 S10004 partition 2 4.00 MiB
[ 1.352466] mmcblk1: p1 p2
[ 1.414188] tda998x 0-0070: found TDA19988
[ 1.419567] tilcdc 4830e000.lcdc: bound 0-0070 (ops tda998x_ops)
[ 1.425663] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.432318] [drm] No driver support for vblank timestamp query.
[ 1.438562] tilcdc 4830e000.lcdc: No connectors reported connected with modes
[ 1.445765] [drm] Cannot find any crtc or sizes - going 1024x768
[ 1.460039] Console: switching to colour frame buffer device 128x48
[ 1.471308] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.502040] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0
[ 1.508066] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.515077] at24 2-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.522233] at24 2-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.529293] at24 2-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.536376] at24 2-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 1.543319] omap_i2c 4819c000.i2c: bus 2 rev0.11 at 100 kHz
[ 1.550927] hctosys: unable to open rtc device (rtc0)
[ 1.559347] ALSA device list:
[ 1.562496] No soundcards found.
[ 8.373774] EXT4-fs (mmcblk0p2): recovery complete
[ 9.609389] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 9.617710] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 9.632735] devtmpfs: mounted
[ 9.636857] Freeing unused kernel memory: 268K (c08d5000 - c0918000)
[ 9.643319] This architecture does not have kernel memory protection.
[ 10.001150] systemd[1]: System time before build time, advancing clock.
[ 10.078472] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 10.094058] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 10.117372] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 10.136467] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.10!
[ 10.163786] systemd[1]: Set hostname to <am335x-evm>.
[ 10.280509] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 32 bits of entropy available)
[ 10.295026] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 32 bits of entropy available)
[ 10.305808] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 32 bits of entropy available)
[ 10.329814] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[ 10.347900] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 33 bits of entropy available)
[ 10.462281] random: systemd: uninitialized urandom read (16 bytes read, 38 bits of entropy available)
[ 10.472270] random: systemd: uninitialized urandom read (16 bytes read, 38 bits of entropy available)
[ 10.482865] random: systemd: uninitialized urandom read (16 bytes read, 38 bits of entropy available)
[ 10.883116] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 11.198798] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 11.206805] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 11.214655] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 11.222147] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 11.231603] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 11.270420] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 11.302562] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 11.332591] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 11.362383] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 11.392305] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 11.439811] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 11.463725] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 11.493904] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 11.523867] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 11.553858] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 11.582673] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 11.612449] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 11.633087] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 11.662803] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 11.697580] systemd[1]: Starting Setup Virtual Console...
[ 11.746303] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 11.821282] systemd[1]: Starting Load Kernel Modules...
[ 11.859389] systemd[1]: Mounting Temporary Directory...
[ 11.901353] cryptodev: driver 1.8 loaded.
[ 11.909840] systemd[1]: Starting Journal Service...
[ 11.961349] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.027586] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.103085] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 12.126597] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 12.162896] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 12.202568] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 12.226173] systemd[1]: Mounting Debug File System...
[ 12.286924] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 12.312564] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 12.332456] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 12.353019] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Remount Root and Kernel File Systems.
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 13.707519] systemd-journald[90]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Found device /dev/ttyS0.
[ 16.643306] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ OK ] Started Load/Save Random Seed.
[ 16.678599] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 16.794424] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ OK ] Started Create Volatile Files and Directories.
[ 16.927886] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 16.969640] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
Starting Update UTMP about System Boot/Shutdown...
[ 17.226190] remoteproc0: wkup_m3 is available
Starting Network Time Synchronization...
[ 17.306180] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 17.335251] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 17.412669] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started Network Time Synchronization.
[ 17.978157] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 18.032510] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 18.041764] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 18.195232] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 18.234214] remoteproc0: powering up wkup_m3
[ 18.239609] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217280
[ 18.321292] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 18.366196] remoteproc1: 4a334000.pru0 is available
[ 18.371210] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 18.448214] remoteproc0: remote processor wkup_m3 is now up
[ 18.448243] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 18.473396] PM: bootloader does not support rtc-only!
[ 18.580646] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ 18.726998] remoteproc1: registered virtio0 (type 7)
[ 18.748995] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 18.832650] remoteproc2: 4a338000.pru1 is available
[ 18.864602] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 18.956783] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 19.009220] random: nonblocking pool is initialized
[ OK ] Found device /dev/ttyS3.
[ 19.052141] remoteproc2: registered virtio1 (type 7)
[ 19.057305] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ 19.128496] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 19.163093] asoc-simple-card sound: i2s-hifi <-> 48038000.mcasp mapping ok
[ 19.180955] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[ 19.522835] EXT4-fs (mmcblk1p2): recovery complete
[ 19.527688] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Found device /dev/mmcblk0p1.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ OK ] Started D-Bus System Message Bus.
Starting Network Service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started Kernel Logging Service.
[ 21.351142] NET: Registered protocol family 15
Starting Save/Restore Sound Card State...
Starting Print notice about GPLv3 packages...
Starting uim-sysfs.service...
Starting Login Service...
[ OK ] Started System Logging Service.
Starting Permit User Sessions...
Starting Start USB gadget...
Starting Telephony service...
[ 21.927207] net eth0: initializing cpsw version 1.12 (0)
[ 22.035930] net eth0: initialized cpsw ale version 1.4
[ 22.041119] net eth0: ALE Table size 1024
[ OK ] Started Network Service.
[ OK ] Started Save/Restore Sound Card State.
[ 22.139093] net eth0: phy found : id is : 0x7c0f1
[ OK ] Started Permit User Sessions.
[ 22.246552] libphy: PHY 4a101000.mdio:01 not found
[ 22.296302] net eth0: phy "4a101000.mdio:01" not found on slave 1, err -19
[ 22.465058] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 22.553305] Initializing XFRM netlink socket
[ 22.584759] Bluetooth: Core ver 2.21
[ 22.588456] NET: Registered protocol family 31
[ 22.702147] Bluetooth: HCI device and connection manager initialized
[ 22.789668] Bluetooth: HCI socket layer initialized
[ 22.840960] Bluetooth: L2CAP socket layer initialized
[ 22.906381] Bluetooth: SCO socket layer initialized
[FAILED] Failed to start Start USB gadget.
See 'systemctl status gadget-init.service' for details.
[ 24.791707] usbcore: registered new interface driver usbfs
[ 24.898935] usbcore: registered new interface driver hub
[ 24.976983] usbcore: registered new device driver usb
[ 25.159852] musb-hdrc musb-hdrc.2.auto: MUSB HDRC host driver
[ 25.308538] musb-hdrc musb-hdrc.2.auto: new USB bus registered, assigned bus number 1
[ 25.347305] remoteproc1: powering up 4a334000.pru0
[ 25.426090] hub 1-0:1.0: USB hub found
[ 25.434278] remoteproc1: Booting fw image am335x-pru0-fw, size 75576
[ 25.492710] hub 1-0:1.0: 1 port detected
[ 25.519688] ti-pruss 4a300000.pruss: configured system_events = 0x0000000000030000 intr_channels = 0x00000005 host_intr = 0x00000005
[ 25.698190] remoteproc1: remote processor 4a334000.pru0 is now up
[ 25.753791] virtio_rpmsg_bus virtio0: creating channel rpmsg-pru addr 0x1e
[ 25.761421] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 25.803057] remoteproc2: powering up 4a338000.pru1
[ 25.845150] remoteproc2: Booting fw image am335x-pru1-fw, size 75576
[ 25.851810] ti-pruss 4a300000.pruss: configured system_events = 0x00000000000c0000 intr_channels = 0x0000000a host_intr = 0x0000000a
[ 25.992201] remoteproc2: remote processor 4a338000.pru1 is now up
[ 26.042401] virtio_rpmsg_bus virtio1: creating channel rpmsg-pru addr 0x1f
[ 26.050229] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 26.172139] rpmsg_pru rpmsg0: new rpmsg_pru device: /dev/rpmsg_pru30
[ 26.222937] rpmsg_pru rpmsg1: new rpmsg_pru device: /dev/rpmsg_pru31
[ OK ] Started uim-sysfs.service.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
Mounting Configuration File System...
[ OK ] Reached target Sound Card.
Starting rc.pvr.service...
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Started Serial Getty on ttyS0.
[ 30.248180] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[ OK ] Started Getty on tty1.
[ OK ] Reached target Network.
Starting Network Name Resolution...
Starting Lightning Fast Webserver With Light System Requirements...
[ OK ] Mounted Configuration File System.
[ OK ] Started Network Name Resolution.
[ OK ] Started rc.pvr.service.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Login Service.
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting busybox-udhcpd.service...
Starting thttpd.service...
[ OK ] Started busybox-udhcpd.service.
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting parse-ip.service...
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Started parse-ip.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS0
Arago 2016.10 am335x-evm ttyS0
am335x-evm login: root
5-Linux-x86-Install.binrocessor-sdk-linux-am335x-evm-03.02.00.0
