dm8168 算法集成问题
我用的是8168 dvr_rdk 4.03,我在ccs下面优化一段代码后,从profile里面的cycles计算出来是12ms左右,但是我把这段代码集成到rdk里面计算出来的是300ms,相差是相当大的,而且代码也相对简单,代码如下:
#define NUM_SAMPLES 16
static short c_xoff[16] = {-1,0,1,-1,1,-1,0,1,0,-1,0,1,-1,1,-1,0};
static short c_c_xoff[16] = {-2,0,2,-2,2,-2,0,2,0,-2,0,2,-2,2,-2,0};
static short c_yoff[16] = {-1,0,1,-1,1,-1,0,1,0,-1,0,1,-1,1,-1,0};
extern unsigned char m_samples_c[288][352][20];
extern unsigned char m_samples_c_c[144][352][20];
extern unsigned char m_mask_c[288][352];
extern unsigned char yuv_c[288][352];
extern unsigned char yuv_c_c[144][352];
for( i = y_s+1; i < y_e-1; i++)
        for( j = x_s+1; j < x_e-1; j++)
               for( k = 0 ; k < NUM_SAMPLES; k+=2)
                           row = i + c_yoff[k];
                          col = j + c_xoff[k];
                          m_samples_c[i][j][k] = yuv_c_y[row][col];
                          k++;
               if(up)
                        y_c = i >>1;
                              row = y_c + c_yoff[k];
                              col = j + c_c_xoff[k];
                              m_samples_c_c[y_c][j][k] = yuv_c_uv[row][col];
                              k++;
请问是怎么回事呢???????????????????????????????????????????????????????????????
