U-Boot SPL 2013.01.01 (Mar 09 2017 - 08:42:08)
Could not probe the EEPROM; something fundamentally wrong on the I2C bus.
I2C read: I/O error
Could not read the EEPROM; something fundamentally wrong on the I2C bus.
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
U-Boot 2013.01.01 (Mar 09 2017 - 08:42:08)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
Net: cpsw, usb_ether
Hit any key to stop autoboot: 1 0
U-Boot#
一直停在这里,板子是自己做的,仿照一家开发板公司,
才开始调试时,自己做的板子是可以的,突然就遇到这个问题里,而且,这一批做了三块板,全都这样。
