试验例程所在位置\mcsdk_2_00_05_17\tools\boot_loader\examples\ethernet,按照readme说明操作,想问第一步是怎么实现的,第一步的过程如下:
Steps to build the example:
1. Run "simple.bat" under "tools\boot_loader\examples\ethernet\simple\". This will build the simple.out and use
hex6x.exe (delivered in CG tools package) to convert the .out to a boot table file, and then use the
bconvert64x.exe/bootpacket.exe to convert the hex6x boot table file to the Ethernet boot format data file,
simple.eth.
问:simple.out文件在哪?怎样执行生成simple.eth?虽然在\mcsdk_2_00_05_17\tools\boot_loader\examples\ethernet\Ethernet_boot里能找到生成后的simple.eth。现在想自己编 .out文件,通过以太网boot。
