在opensuse leap下编译oe-layersetup,出现一下的错误提示,请问,如何处理:
| g++ x86/AllocasToEntry.o x86/BarrierBlock.o x86/BarrierTailReplication.o x86/BreakConstantGEPs.o x86/CanonicalizeBarriers.o x86/DebugHelpers.o x86/Flatten.o x86/GenerateHeader.o x86/ImplicitLoopBarriers.o x86/ImplicitConditionalBarriers.o x86/IsolateRegions.o x86/Kern
el.o x86/LLVMUtils.o x86/LoopBarriers.o x86/ParallelRegion.o x86/PHIsToAllocas.o x86/TargetAddressSpaces.o x86/VariableUniformityAnalysis.o x86/WIVectorize.o x86/Workgroup.o x86/WorkItemAliasAnalysis.o x86/WorkitemHandler.o x86/WorkitemHandlerChooser.o x86/WorkitemLoops.
o x86/WorkitemReplication.o x86/SimplifyShuffleBIFCall.o x86/PrivatizationAliasAnalysis.o x86/main.o x86/compiler.o x86/wga.o x86/program.o x86/file_manip.o x86/options.o x86/util.o -static -lclangFrontendTool -lclangFrontend -lclangDriver -lclangSerialization -lclangCod
eGen -lclangParse -lclangSema -lclangEdit -lclangAnalysis -lclangAST -lclangLex -lclangBasic `llvm-config --libs` -L/opt/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib/ti-llvm3.6 -lpthread -lrt -ldl -lm -L/opt/tisdk/oe-layer
setup/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib -L/opt/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib -Wl,-rpath-link,/opt/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64
-linux/usr/lib -Wl,-rpath-link,/opt/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib -Wl,-rpath,/opt/tisdk/oe-layersetup/build/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/usr/lib -Wl,-rpath,/opt/tisdk/oe-layersetup/bui
ld/arago-tmp-external-linaro-toolchain/sysroots/x86_64-linux/lib -Wl,-O1 -o x86/clocl
| /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lpthread
| /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lrt
| /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -ldl
| /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lm
| /usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld: cannot find -lc
