Am335x报错Waiting for root device /dev/mmcblk0p2...
Other Parts Discussed in Thread: AM1808
U-Boot SPL 2011.09-00000-gc0d1c2f (Jul 25 2012 - 10:47:29)
Texas Instruments Revision detection unimplemented
Could not probe the EEPROM; something fundamentally wrong on the I2C bus.
read_eeprom() failure
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2011.09-00000-gc0d1c2f (Jul 25 2012 - 10:47:29)
I2C:   ready
DRAM:  256 MiB
WARNING: Caches not enabled
NAND:  HW ECC Hamming Code selected
256 MiB
MMC:   OMAP SD/MMC: 0
*** Warning - bad CRC, using default environment
Net:   cpsw
Hit any key to stop autoboot:  0
SD/MMC found on device 0
reading uEnv.txt
214 bytes read
Loaded environment from uEnv.txt
Importing environment from mmc ...
Running uenvcmd ...
reading uImage
2631200 bytes read
## Booting kernel from Legacy Image at 82000000 ...
  Image Name:   Linux-3.1.0-g62911f8-dirty
  Image Type:   ARM Linux Kernel Image (uncompressed)
  Data Size:    2631136 Bytes = 2.5 MiB
  Load Address: 80008000
  Entry Point:  80008000
  Verifying Checksum ... OK
  Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[    0.000000] Linux version 3.1.0-g62911f8-dirty (liujiangman@ubuntu) (gcc version 4.4.3 (GCC) ) #1 Mon Sep 3 15:13:26 CST 2012
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
[    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: am335xevm
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES1.0 (neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait init=/init ip=off
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 256MB = 256MB total
[    0.000000] Memory: 253292k/253292k available, 8852k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
[    0.000000]     vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc04b5000   (4788 kB)
[    0.000000]       .init : 0xc04b5000 - 0xc04e9000   ( 208 kB)
[    0.000000]       .data : 0xc04ea000 - 0xc0532fa0   ( 292 kB)
[    0.000000]        .bss : 0xc0532fdc - 0xc0669f48   (1244 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000264] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
[    0.058633] pid_max: default: 32768 minimum: 301
[    0.058802] Security Framework initialized
[    0.058888] Mount-cache hash table entries: 512
[    0.059363] CPU: Testing write buffer coherency: ok
[    0.064463] print_constraints: dummy:
[    0.064716] NET: Registered protocol family 16
[    0.064948] GPMC revision 6.0
[    0.066020] OMAP GPIO hardware version 0.1
[    0.066871] omap_l3_smx omap_l3_smx.0: couldn't find resource
[    0.066991] omap_mux_init: Add partition: #1: core, flags: 0
[    0.069730]  omap_i2c.1: alias fck already exists
[    0.070633]  omap2_mcspi.1: alias fck already exists
[    0.070767]  omap2_mcspi.2: alias fck already exists
[    0.080462] bio: create slab <bio-0> at 0
[    0.081534] SCSI subsystem initialized
[    0.082502] usbcore: registered new interface driver usbfs
[    0.082628] usbcore: registered new interface driver hub
[    0.082798] usbcore: registered new device driver usb
[    0.083717] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
[    0.084622] Advanced Linux Sound Architecture Driver Version 1.0.24.
[    0.085281] Bluetooth: Core ver 2.16
[    0.085376] NET: Registered protocol family 31
[    0.085394] Bluetooth: HCI device and connection manager initialized
[    0.085419] Bluetooth: HCI socket layer initialized
[    0.085437] Bluetooth: L2CAP socket layer initialized
[    0.085472] Bluetooth: SCO socket layer initialized
[    0.085682] Switching to clocksource gp timer
[    0.088714] Switched to NOHz mode on CPU #0
[    0.095049] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    0.095239] musb-hdrc musb-hdrc.0: dma type: pio
[    0.096018] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
[    0.096318] musb-hdrc musb-hdrc.1: dma type: pio
[    0.096988] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
[    0.097365] NET: Registered protocol family 2
[    0.097614] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.098039] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.098267] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    0.098405] TCP: Hash tables configured (established 8192 bind 8192)
[    0.098424] TCP reno registered
[    0.098444] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.098481] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.098768] NET: Registered protocol family 1
[    0.099131] RPC: Registered named UNIX socket transport module.
[    0.099150] RPC: Registered udp transport module.
[    0.099165] RPC: Registered tcp transport module.
[    0.099180] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.099464] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.099547] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
[    0.255676] Gpio value is :117
[    0.256344] ashmem: initialized
[    0.257402] msgmni has been set to 494
[    0.258502] io scheduler noop registered
[    0.258523] io scheduler deadline registered
[    0.258609] io scheduler cfq registered (default)
[    0.259137] Could not set LED4 to fully on
[    0.260265] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.261505] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    0.770709] console [ttyO0] enabled
[    0.774694] WL1271: BT Enable
[    0.778066] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    0.785896] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    0.793574] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    0.801315] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    0.809014] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    0.823840] brd: module loaded
[    0.831026] loop: module loaded
[    0.834549] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    0.895731] No daughter card found
[    0.899365] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
[    0.965734] AM335X: EVM Config read fail: -110
[    0.971504] omap2-nand driver initializing
[    0.975980] OneNAND driver initializing
[    0.980508] Initializing USB Mass Storage driver...
[    0.985803] usbcore: registered new interface driver usb-storage
[    0.992121] USB Mass Storage support registered.
[    0.999221]  gadget: Mass Storage Function, version: 2009/09/11
[    1.005458]  gadget: Number of LUNs=1
[    1.009371]  lun0: LUN: removable file: (no medium)
[    1.014799]  gadget: android_usb ready
[    1.018812] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    1.024414] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[    1.032979] hub 1-0:1.0: USB hub found
[    1.036986] hub 1-0:1.0: 1 port detected
[    1.041700] mousedev: PS/2 mouse device common for all mice
[    1.049087] using rtc device, omap_rtc, for alarms
[    1.054003] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[    1.061030] i2c /dev entries driver
[    1.065603] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    1.072252] device-mapper: uevent: version 1.0.3
[    1.077393] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
[    1.086308] Bluetooth: HCI UART driver ver 2.2
[    1.090986] Bluetooth: HCI H4 protocol initialized
[    1.096040] Bluetooth: HCILL protocol initialized
[    1.101554] usbcore: registered new interface driver usbhid
[    1.107454] usbhid: USB HID core driver
[    1.112068] logger: created 256K log 'log_main'
[    1.117007] logger: created 256K log 'log_events'
[    1.122089] logger: created 256K log 'log_radio'
[    1.127102] logger: created 256K log 'log_system'
[    1.133322] ALSA device list:
[    1.136508]   No soundcards found.
[    1.140228] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
[    1.147087] ip_tables: (C) 2000-2006 Netfilter Core Team
[    1.152824] TCP cubic registered
[    1.156269] NET: Registered protocol family 17
[    1.161261] Bluetooth: RFCOMM TTY layer initialized
[    1.166449] Bluetooth: RFCOMM socket layer initialized
[    1.171855] Bluetooth: RFCOMM ver 1.11
[    1.175819] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[    1.181406] Bluetooth: BNEP filters: protocol multicast
[    1.186921] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    1.193337] Registering the dns_resolver key type
[    1.198406] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    1.206502] ThumbEE CPU extension supported.
[    1.211970] omap2_set_init_voltage: unable to get clk dpll1_ck
[    1.218147] omap2_set_init_voltage: unable to set vdd_mpu_iva
[    1.224204] omap2_set_init_voltage: unable to get clk l3_ick
[    1.230173] omap2_set_init_voltage: unable to set vdd_core
[    1.241143] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[    1.250644] Waiting for root device /dev/mmcblk0p2...
  • 根据AM335x的EVM进行裁剪做了块板子,移植android系统时出现以上错误,请问大家是怎么回事呢。
  • 你确定你的文件系统烧写正确了么?
  • 我给你个建议。当你内核下载完毕,就是到这里
    reading uImage
    2631200 bytes read
    拔出你的SD卡,你等下看看报错,是不是还是在这里停下
  • alvin lu您好,按照您的指点,我试了试,
    2631224 bytes read
      Data Size:    2631160 Bytes = 2.5 MiB
    这一块几乎是同时出来的,所以我卡不到您说的那个点上,拔出SD卡时已经运行到到Verifying Checksum ... ,到最后还是停在这里
    [    1.250925] Waiting for root device /dev/mmcblk0p2...
    请问这是哪里的问题,需要怎么解决啊?
  • 似的,在am335x EVM上使用能够正确启动。
  • 呵呵,我的意思只要内核下载完毕就行,无需卡在那个点上。
    我要看到的结果是这个[    1.250925] Waiting for root device /dev/mmcblk0p2...
    你在uboot下mmc可以检测到并且可以下载内核,理论上来说,硬件特性问题不大。
    这样吧,你设置rootfs=/dev/nfs ,尝试从nfs启动linux,系统启动完之后,ls /dev 看看,有没有mmcblk0的设备驱动节点。我觉得结果应该是没有的。
  • 要是拔SD卡拔的早了,就是再reading uImage之后拔,就找不到SD卡了,
    2631224 bytes read
      Verifying Checksum ... Bad Data CRC
    ERROR: can't get kernel image!
    mmc_send_cmd: timedout waiting for cmddis!
    ** Can't read from device 0 **
    ** Unable to use mmc 0:1 for fatload **
    Booting from nand ...
    HW ECC BCH8 Selected
    NAND read: device 0 offset 0x280000, size 0x500000
    5242880 bytes read: OK
    ## Booting kernel from Legacy Image at 80007fc0 ...
      XIP Kernel Image ... OK
    OK
    Starting kernel ...
    [    0.000000] Linux version 3.1.0-g62911f8-dirty (a0131746@sditapps03) (gcc version 4.4.3 (GCC) ) #1 Mon Nov 28 21:00:21 IST 2011
    [    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mtdblock7 rw noinitrd rootfstype=jffs2 ip=none
    [    0.058630] pid_max: default: 32768 minimum: 301
    [    0.058801] Security Framework initialized
    [    0.058890] Mount-cache hash table entries: 512
    [    0.059365] CPU: Testing write buffer coherency: ok
    [    0.064489] print_constraints: dummy:
    [    0.064743] NET: Registered protocol family 16
    [    0.064981] GPMC revision 6.0
    [    0.066065] OMAP GPIO hardware version 0.1
    [    0.066911] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067029] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069812]  omap_i2c.1: alias fck already exists
    [    0.070712]  omap2_mcspi.1: alias fck already exists
    [    0.070849]  omap2_mcspi.2: alias fck already exists
    [    0.080583] bio: create slab <bio-0> at 0
    [    0.081669] SCSI subsystem initialized
    [    0.082647] usbcore: registered new interface driver usbfs
    [    0.082773] usbcore: registered new interface driver hub
    [    0.082942] usbcore: registered new device driver usb
    [    0.083864] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084765] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085427] Bluetooth: Core ver 2.16
    [    0.085530] NET: Registered protocol family 31
    [    0.085548] Bluetooth: HCI device and connection manager initialized
    [    0.085572] Bluetooth: HCI socket layer initialized
    [    0.085589] Bluetooth: L2CAP socket layer initialized
    [    0.085627] Bluetooth: SCO socket layer initialized
    [    0.085837] Switching to clocksource gp timer
    [    0.088710] Switched to NOHz mode on CPU #0
    [    0.095198] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095395] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.096177] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096476] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.097130] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097510] NET: Registered protocol family 2
    [    0.097757] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098191] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098420] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098557] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098577] TCP reno registered
    [    0.098597] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098633] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098926] NET: Registered protocol family 1
    [    0.099298] RPC: Registered named UNIX socket transport module.
    [    0.099319] RPC: Registered udp transport module.
    [    0.099333] RPC: Registered tcp transport module.
    [    0.099348] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099641] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099727] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.256061] Gpio value is :117
    [    0.256641] ashmem: initialized
    [    0.257705] msgmni has been set to 494
    [    0.258815] io scheduler noop registered
    [    0.258835] io scheduler deadline registered
    [    0.258922] io scheduler cfq registered (default)
    [    0.259453] Could not set LED4 to fully on
    [    0.260587] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.261827] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.767202] console [ttyO0] enabled
    [    0.771184] WL1271: BT Enable
    [    0.774502] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.782349] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.790093] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.797826] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.805491] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.820386] brd: module loaded
    [    0.827640] loop: module loaded
    [    0.831162] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.895891] No daughter card found
    [    0.899528] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.965891] AM335X: EVM Config read fail: -110
    [    0.971658] omap2-nand driver initializing
    [    0.976134] OneNAND driver initializing
    [    0.980668] Initializing USB Mass Storage driver...
    [    0.985967] usbcore: registered new interface driver usb-storage
    [    0.992287] USB Mass Storage support registered.
    [    0.999424]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.005660]  gadget: Number of LUNs=1
    [    1.009568]  lun0: LUN: removable file: (no medium)
    [    1.015000]  gadget: android_usb ready
    [    1.019017] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.024618] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.033195] hub 1-0:1.0: USB hub found
    [    1.037202] hub 1-0:1.0: 1 port detected
    [    1.041917] mousedev: PS/2 mouse device common for all mice
    [    1.049322] using rtc device, omap_rtc, for alarms
    [    1.054239] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.061267] i2c /dev entries driver
    [    1.065844] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.072503] device-mapper: uevent: version 1.0.3
    [    1.077644] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.086558] Bluetooth: HCI UART driver ver 2.2
    [    1.091236] Bluetooth: HCI H4 protocol initialized
    [    1.096291] Bluetooth: HCILL protocol initialized
    [    1.101808] usbcore: registered new interface driver usbhid
    [    1.107706] usbhid: USB HID core driver
    [    1.112317] logger: created 256K log 'log_main'
    [    1.117252] logger: created 256K log 'log_events'
    [    1.122334] logger: created 256K log 'log_radio'
    [    1.127344] logger: created 256K log 'log_system'
    [    1.133561] ALSA device list:
    [    1.136743]   No soundcards found.
    [    1.140472] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
    [    1.147344] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.153081] TCP cubic registered
    [    1.156525] NET: Registered protocol family 17
    [    1.161530] Bluetooth: RFCOMM TTY layer initialized
    [    1.166719] Bluetooth: RFCOMM socket layer initialized
    [    1.172125] Bluetooth: RFCOMM ver 1.11
    [    1.176088] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.181676] Bluetooth: BNEP filters: protocol multicast
    [    1.187189] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.193610] Registering the dns_resolver key type
    [    1.198698] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.206795] ThumbEE CPU extension supported.
    [    1.212274] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.218449] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.224508] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.230478] omap2_set_init_voltage: unable to set vdd_core
    [    1.241497] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    1.250841] Root-NFS: no NFS server address
    [    1.255245] VFS: Unable to mount root fs via NFS, trying floppy.
    [    1.262377] VFS: Cannot open root device "mtdblock7" or unknown-block(2,0)
    [    1.269664] Please append a correct "root=" boot option; here are the available partitions:
    [    1.278496] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
    [    1.287204] Backtrace:
    [    1.289822] [<c0016f24>] (dump_backtrace+0x0/0x110) from [<c038326c>] (dump_stack+0x18/0x1c)
    [    1.298715]  r7:c0442332 r6:00008000 r5:c0533ed0 r4:c0533ed0
    [    1.304703] [<c0383254>] (dump_stack+0x0/0x1c) from [<c03832d4>] (panic+0x64/0x18c)
    [    1.312798] [<c0383270>] (panic+0x0/0x18c) from [<c04b5dd8>] (mount_block_root+0x1dc/0x21c)
    [    1.321597]  r3:00000000 r2:00000000 r1:cf81df50 r0:c04423d9
    [    1.327602] [<c04b5bfc>] (mount_block_root+0x0/0x21c) from [<c04b5ec4>] (mount_root+0xac/0xcc)
    [    1.336691] [<c04b5e18>] (mount_root+0x0/0xcc) from [<c04b6050>] (prepare_namespace+0x16c/0x1c4)
    [    1.345945]  r4:c0533060
    [    1.348628] [<c04b5ee4>] (prepare_namespace+0x0/0x1c4) from [<c04b52f8>] (kernel_init+0xf0/0x124)
    [    1.357973]  r5:c04e8c14 r4:c0533000
    [    1.361768] [<c04b5208>] (kernel_init+0x0/0x124) from [<c003bc10>] (do_exit+0x0/0x604)
    [    1.370110]  r5:c04b5208 r4:00000000
  • 你的uboot给kernel的command line是啥啊
  • 呵呵,是这样的,你可能对uboot不是很熟悉,
    OK
    Starting kernel ...
    到这里,串口终端就没有再输出任何信息了.
    以上的串口输出信息是uboot的引导过程,至于这个starting kernel其实是uboot阶段输出最后的一句信息,这时候正准备进入内核引导。
    在这个阶段过后,uboot的工作才算做完,这个时候拔SD才与uboot无关。
    然后我看了下你的报错,当检测不到sd的时候将会从nand下载内核,我在你的内核打印里面并没有看到关于nand初始化的信息,你的nand似乎跟我一样都没起来。
    你从nfs起来试试吧,然后cat /proc/mtd ,看有没有分区信息输出
    再看看/dev下面关于nand和mmc的设备驱动节点,应该都没有吧。
  • 按照上面的信息,很明显,他用的是默认的env,并且启动方式设置为mmc0为第一优先级,其次是nand。
    默认的env大家的板子似乎都一样。
  • 从他给出的信息来看,在mmc下的command line是[    0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait init=/init ip=off
    在nand下,command line是Kernel command line: console=ttyO0,115200n8 root=/dev/mtdblock7 rw noinitrd rootfstype=jffs2 ip=none
    不过他设备都没检测到,这些怎么改都没用的。
  • 要是不确定的话,我建议在设备Init阶段加一些打印信息,如果什么都没有打印出来,那么就证明设备根本没有init。
  • 请问nfs是网络文件系统么,可是板子上没有网口啊
  • /dev/mtdblock7 这个是怎么来的
  • 呵呵,没网口?这调试起来就纠结了。从硬件上跟EVM对比下吧,我没有板子,不能确定的事情太多,意见也只能给到这里了。
  • kernel boot argument:
    bootargs=console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait init=/init ip=off
    bootcmd=mmc rescan ; fatload mmc 0 82000000 uImage ; bootm 82000000
    uenvcmd=boot,请问您说的是在这里改么,改成bootargs=console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M rootfs=/dev/nfs rw rootfstype=ext3 rootwait init=/init ip=off
    uenvcmd=bootrootfs=/dev/nfs
  • 文件系统的分区吧,我刚才看了下board.3359.c,nand一共分区8个,0-7,这个mtd7就是filesystem,不过他检测到不到nand设备,哪个区文件系统都没用。
  • SD卡里有个uEnv.txt,里面内容:
    uenvcmd=boot
    请问您说的是在这个文件里改么,改成
    uenvcmd=boot
    还是在编译kernel时改呢,要是编译kernel时在哪里改呢。
    要是只改这个文档,结果是
    U-Boot SPL 2011.09-00001-g95a7849 (Feb 14 2012 - 10:53:14)
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    U-Boot 2011.09-00001-g95a7849 (Feb 14 2012 - 10:53:14)
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    211 bytes read
    Running uenvcmd ...
    reading uImage
    2631224 bytes read
    OK
    Starting kernel ...
    [    0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M rootfts=/dev/nfs rw rootfstype=ext3 rootwait init=/init ip=off
    [    0.000266] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
    [    0.058804] Security Framework initialized
    [    0.058891] Mount-cache hash table entries: 512
    [    0.059376] CPU: Testing write buffer coherency: ok
    [    0.064525] print_constraints: dummy:
    [    0.064778] NET: Registered protocol family 16
    [    0.065012] GPMC revision 6.0
    [    0.066090] OMAP GPIO hardware version 0.1
    [    0.066939] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067060] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069821]  omap_i2c.1: alias fck already exists
    [    0.070718]  omap2_mcspi.1: alias fck already exists
    [    0.070850]  omap2_mcspi.2: alias fck already exists
    [    0.080557] bio: create slab <bio-0> at 0
    [    0.081645] SCSI subsystem initialized
    [    0.082617] usbcore: registered new interface driver usbfs
    [    0.082745] usbcore: registered new interface driver hub
    [    0.082922] usbcore: registered new device driver usb
    [    0.083843] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084751] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085416] Bluetooth: Core ver 2.16
    [    0.085514] NET: Registered protocol family 31
    [    0.085533] Bluetooth: HCI device and connection manager initialized
    [    0.085556] Bluetooth: HCI socket layer initialized
    [    0.085575] Bluetooth: L2CAP socket layer initialized
    [    0.085612] Bluetooth: SCO socket layer initialized
    [    0.085820] Switching to clocksource gp timer
    [    0.088712] Switched to NOHz mode on CPU #0
    [    0.095204] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095401] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.096181] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096485] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.097145] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097517] NET: Registered protocol family 2
    [    0.097772] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098209] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098437] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098575] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098595] TCP reno registered
    [    0.098614] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098650] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098942] NET: Registered protocol family 1
    [    0.099307] RPC: Registered named UNIX socket transport module.
    [    0.099327] RPC: Registered udp transport module.
    [    0.099342] RPC: Registered tcp transport module.
    [    0.099357] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099648] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099732] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.256223] Gpio value is :117
    [    0.256803] ashmem: initialized
    [    0.257882] msgmni has been set to 494
    [    0.258953] io scheduler noop registered
    [    0.258971] io scheduler deadline registered
    [    0.259061] io scheduler cfq registered (default)
    [    0.259594] Could not set LED4 to fully on
    [    0.260729] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.261967] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.771076] console [ttyO0] enabled
    [    0.775066] WL1271: BT Enable
    [    0.778445] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.786276] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.793947] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.801688] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.809388] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.824234] brd: module loaded
    [    0.831469] loop: module loaded
    [    0.834998] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.895872] No daughter card found
    [    0.899507] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.965874] AM335X: EVM Config read fail: -110
    [    0.971665] omap2-nand driver initializing
    [    0.976147] OneNAND driver initializing
    [    0.980679] Initializing USB Mass Storage driver...
    [    0.985978] usbcore: registered new interface driver usb-storage
    [    0.992296] USB Mass Storage support registered.
    [    0.999408]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.005644]  gadget: Number of LUNs=1
    [    1.009556]  lun0: LUN: removable file: (no medium)
    [    1.014986]  gadget: android_usb ready
    [    1.018998] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.024601] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.033178] hub 1-0:1.0: USB hub found
    [    1.037183] hub 1-0:1.0: 1 port detected
    [    1.041901] mousedev: PS/2 mouse device common for all mice
    [    1.049308] using rtc device, omap_rtc, for alarms
    [    1.054222] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.061253] i2c /dev entries driver
    [    1.065814] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.072474] device-mapper: uevent: version 1.0.3
    [    1.077624] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.086534] Bluetooth: HCI UART driver ver 2.2
    [    1.091212] Bluetooth: HCI H4 protocol initialized
    [    1.096266] Bluetooth: HCILL protocol initialized
    [    1.101786] usbcore: registered new interface driver usbhid
    [    1.107683] usbhid: USB HID core driver
    [    1.112292] logger: created 256K log 'log_main'
    [    1.117231] logger: created 256K log 'log_events'
    [    1.122316] logger: created 256K log 'log_radio'
    [    1.127324] logger: created 256K log 'log_system'
    [    1.133529] ALSA device list:
    [    1.136712]   No soundcards found.
    [    1.140432] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
    [    1.147298] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.153040] TCP cubic registered
    [    1.156482] NET: Registered protocol family 17
    [    1.161489] Bluetooth: RFCOMM TTY layer initialized
    [    1.166677] Bluetooth: RFCOMM socket layer initialized
    [    1.172082] Bluetooth: RFCOMM ver 1.11
    [    1.176045] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.181633] Bluetooth: BNEP filters: protocol multicast
    [    1.187147] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.193575] Registering the dns_resolver key type
    [    1.198635] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.206731] ThumbEE CPU extension supported.
    [    1.212208] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.218384] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.224443] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.230412] omap2_set_init_voltage: unable to set vdd_core
    [    1.241446] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    1.250895] Waiting for root device ...
  • 1. 我看他的这个是从sd卡启动的
    2. 我就是想问问他在他的board 文件里面是怎么排列几个分区的
  • sd卡里有个uEnv.txt文档,内容是bootargs=console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait init=/init ip=off
    uenvcmd=boot
    请问是在这里改么,改成bootargs=console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M rootfs=/dev/nfs rw rootfstype=ext3 rootwait init=/init ip=off
    uenvcmd=boot
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    211 bytes read
    Running uenvcmd ...
    reading uImage
    2631224 bytes read
    OK
    Starting kernel ...
    uenvcmd=boot
    uenvcmd=boot
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    211 bytes read
    Running uenvcmd ...
    reading uImage
    2631224 bytes read
    OK
    Starting kernel ...
    [    1.250895] Waiting for root device...
  • 哎,你ip=off。
    我这里有个以前AM1808的env,你看着改吧。
    nfs
    U-Boot > pri
    baudrate=115200
    ethaddr=00:00:68:23:0b:c1
    bootdelay=3
    bootcmd=nand read.e 0xc0700000 0x200000 0x230000;bootm 0xc0700000
    bootfile=uImage
    dnsip=192.168.10.230
    dnsip2=218.2.135.1
    bootargs=root=/dev/nfs nfsroot=192.168.10.2:/usr/local/ti-sdk-am180x-evm/targetNFS ip=192.168.10.167:192.168.10.2:192.168.10.230:255.255.255.0::eth0:off console=ttyS2,115200
    stdin=serial
    stdout=serial
    stderr=serial
    ver=U-Boot 2009.11 (Nov 09 2011 - 07:48:52)
    filesize=DAE090
    fileaddr=C0008000
    gatewayip=192.168.10.230
    netmask=255.255.255.0
    ipaddr=192.168.10.167
    serverip=192.168.10.2
    Environment size: 560/131068 bytes
  • 我现在改成:
    bootargs=console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/nfs rw rootfstype=ext3 rootwait init=/init ip=dhcp
    uenvcmd=boot
    还是卡住了
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    209 bytes read
    Running uenvcmd ...
    reading uImage
    2631224 bytes read
    OK
    Starting kernel ...
    [    0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/nfs rw rootfstype=ext3 rootwait init=/init ip=dhcp
    [    0.000265] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
    [    0.058632] pid_max: default: 32768 minimum: 301
    [    0.059364] CPU: Testing write buffer coherency: ok
    [    0.064472] print_constraints: dummy:
    [    0.064727] NET: Registered protocol family 16
    [    0.064960] GPMC revision 6.0
    [    0.066037] OMAP GPIO hardware version 0.1
    [    0.066880] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067001] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069761]  omap_i2c.1: alias fck already exists
    [    0.070667]  omap2_mcspi.1: alias fck already exists
    [    0.070800]  omap2_mcspi.2: alias fck already exists
    [    0.080501] bio: create slab <bio-0> at 0
    [    0.081578] SCSI subsystem initialized
    [    0.082567] usbcore: registered new interface driver usbfs
    [    0.082695] usbcore: registered new interface driver hub
    [    0.082866] usbcore: registered new device driver usb
    [    0.083789] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084695] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085357] Bluetooth: Core ver 2.16
    [    0.085458] NET: Registered protocol family 31
    [    0.085475] Bluetooth: HCI device and connection manager initialized
    [    0.085499] Bluetooth: HCI socket layer initialized
    [    0.085518] Bluetooth: L2CAP socket layer initialized
    [    0.085558] Bluetooth: SCO socket layer initialized
    [    0.085771] Switching to clocksource gp timer
    [    0.095133] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095329] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.096109] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096413] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.097071] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097447] NET: Registered protocol family 2
    [    0.097702] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098134] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098360] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098498] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098518] TCP reno registered
    [    0.098537] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098573] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098862] NET: Registered protocol family 1
    [    0.099231] RPC: Registered named UNIX socket transport module.
    [    0.099251] RPC: Registered udp transport module.
    [    0.099266] RPC: Registered tcp transport module.
    [    0.099281] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099573] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099658] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.256204] Gpio value is :117
    [    0.256783] ashmem: initialized
    [    0.257839] msgmni has been set to 494
    [    0.258918] io scheduler noop registered
    [    0.258938] io scheduler deadline registered
    [    0.259026] io scheduler cfq registered (default)
    [    0.259559] Could not set LED4 to fully on
    [    0.260693] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.261932] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.770859] console [ttyO0] enabled
    [    0.774853] WL1271: BT Enable
    [    0.778233] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.786073] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.793753] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.801496] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.809197] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.824039] brd: module loaded
    [    0.831275] loop: module loaded
    [    0.834803] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.895822] No daughter card found
    [    0.899458] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.965824] AM335X: EVM Config read fail: -110
    [    0.971602] omap2-nand driver initializing
    [    0.976080] OneNAND driver initializing
    [    0.980618] Initializing USB Mass Storage driver...
    [    0.985916] usbcore: registered new interface driver usb-storage
    [    0.992234] USB Mass Storage support registered.
    [    0.999349]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.005585]  gadget: Number of LUNs=1
    [    1.009496]  lun0: LUN: removable file: (no medium)
    [    1.014924]  gadget: android_usb ready
    [    1.018938] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.024540] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.033115] hub 1-0:1.0: USB hub found
    [    1.037121] hub 1-0:1.0: 1 port detected
    [    1.041831] mousedev: PS/2 mouse device common for all mice
    [    1.049235] using rtc device, omap_rtc, for alarms
    [    1.054146] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.061179] i2c /dev entries driver
    [    1.065748] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.072402] device-mapper: uevent: version 1.0.3
    [    1.077544] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.086458] Bluetooth: HCI UART driver ver 2.2
    [    1.091134] Bluetooth: HCI H4 protocol initialized
    [    1.096189] Bluetooth: HCILL protocol initialized
    [    1.101704] usbcore: registered new interface driver usbhid
    [    1.107606] usbhid: USB HID core driver
    [    1.112227] logger: created 256K log 'log_main'
    [    1.117171] logger: created 256K log 'log_events'
    [    1.122255] logger: created 256K log 'log_radio'
    [    1.127264] logger: created 256K log 'log_system'
    [    1.133487] ALSA device list:
    [    1.136674]   No soundcards found.
    [    1.140394] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
    [    1.147269] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.153011] TCP cubic registered
    [    1.156453] NET: Registered protocol family 17
    [    1.161460] Bluetooth: RFCOMM TTY layer initialized
    [    1.166650] Bluetooth: RFCOMM socket layer initialized
    [    1.172055] Bluetooth: RFCOMM ver 1.11
    [    1.176019] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.181606] Bluetooth: BNEP filters: protocol multicast
    [    1.187120] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.193547] Registering the dns_resolver key type
    [    1.198609] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.206702] ThumbEE CPU extension supported.
    [    1.212174] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.218354] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.224414] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.230383] omap2_set_init_voltage: unable to set vdd_core
    [    1.241394] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [   13.366543] Root-NFS: no NFS server address
    [   13.370953] VFS: Unable to mount root fs via NFS, trying floppy.
    [   13.378001] VFS: Cannot open root device "nfs" or unknown-block(2,0)
    [   13.384691] Please append a correct "root=" boot option; here are the available partitions:
    [   13.393561] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
    [   13.402272] Backtrace:
    [   13.404890] [<c0016f24>] (dump_backtrace+0x0/0x110) from [<c038326c>] (dump_stack+0x18/0x1c)
    [   13.413784]  r7:c0442332 r6:00008000 r5:c0533ed0 r4:c0533ed0
    [   13.419787] [<c0383254>] (dump_stack+0x0/0x1c) from [<c03832d4>] (panic+0x64/0x18c)
    [   13.427882] [<c0383270>] (panic+0x0/0x18c) from [<c04b5dd8>] (mount_block_root+0x1dc/0x21c)
    [   13.436681]  r3:00000000 r2:00000000 r1:cf81df50 r0:c04423d9
    [   13.442671] [<c04b5bfc>] (mount_block_root+0x0/0x21c) from [<c04b5ec4>] (mount_root+0xac/0xcc)
    [   13.451760] [<c04b5e18>] (mount_root+0x0/0xcc) from [<c04b6050>] (prepare_namespace+0x16c/0x1c4)
    [   13.461015]  r4:c0533060
    [   13.463697] [<c04b5ee4>] (prepare_namespace+0x0/0x1c4) from [<c04b52f8>] (kernel_init+0xf0/0x124)
    [   13.473042]  r5:c04e8c14 r4:c0533000
    [   13.476850] [<c04b5208>] (kernel_init+0x0/0x124) from [<c003bc10>] (do_exit+0x0/0x604)
    [   13.485177]  r5:c04b5208 r4:00000000
    请问是怎么回事啊,还是没改好的问题么
  • 你的server上大好了nfs server么?你用你的pc去mount这个nfs server看看
  • 您好,我是新手,有很多东西都不知道,有的您的提议我也不知道去哪里改,请原谅。我又看了些资料,是不是没有网口的话不能用nfs那种,还有有的资料中提及分区,我的卡是三块
     /dev/sdb2         909168   664556    198428  78% /media/rootfs
    /dev/sdb3        2751348  2357568    254016  91% /media/START_HERE
    /dev/sdb1          71681     5230     66451   8% /media/BOOT ,我编译的文件都是放在boot下,想放到别的分区也放不进去,请问这个有关系么
  • 您说的这个挂载nfs server是不是得联网才可以,没有网口的话应该是不行吧
  • 是的,你先google下吧
  • 查了许多资料照着改了还解决不了才来提问希望得到大家帮助的呢,uEnv.tet是开发板里的卡里带着的资料,看了许多说是改这个,可是照的哪个改还是出那个错,肿么办
  • 这几天我又查了点资料,在code.google.com/.../LinuxBootDiskFormat 上看到一句话:Bootloader settings
    If you use bootloader U-Boot, use following settings to mount root file system at second partition from kernel:
    console=ttyS2,115200n8 root=/dev/mmcblk0p2 rw rootdelay=1
    我觉得我一直停留在这里,是不是从内核的第二部分没有挂载上根文件系统,然后我processors.wiki.ti.com/.../How_to_Make_3_Partition_SD_Card 在这个网站了给SD卡分了俩区,一个fat32,一个ext3,把filesystem解压到ext3,把MLO、u-boot.img、uImage、uEnv.txt放到fat32,结果插上SD卡就只输出cccc了,请问这是怎么回事啊,这几天都不知道去哪里找问题了。
  • 我又仔细看了processors.wiki.ti.com/.../TI-Android-GingerBread-2.3.4-DevKit-2.1.1_DeveloperGuide,原来有一块To generate SD/MMC card to boot Android,按着做就可以给SD卡分区并且把需要的复制进去,我也做了,分了3个区,并且每个里面都有文件,可是执行还是卡在那里,请问/mmcblk0p2...是什么意思啊,。。。
  • 你这个情况我后来也遇到了,我能告诉你的是,你编译内核的时候有文件没改对。硬件是没有问题的。
  • 因为你的子板去掉了,读不到ID
    ret = mem_acc->read(mem_acc, (char *)&config, 0, sizeof(config));
    if (ret != sizeof(config)) {
    pr_err("AM335X EVM config read fail, read %d bytes\n", ret);
    pr_err("This likely means that there either is no/or a failed EEPROM\n");
    goto out;
    if (config.header != AM335X_EEPROM_HEADER) {
    pr_err("AM335X: wrong header 0x%x, expected 0x%x\n",
    config.header, AM335X_EEPROM_HEADER);
    goto out;
    if (strncmp("A335", config.name, 4)) {
    pr_err("Board %s\ndoesn't look like an AM335x board\n",
    config.name);
    goto out;
  • 经过高人的指点和这几天的摸索,对内核进行了修改,卡着的那步终于过去了,不过还是有错,请大家指导一下
    CCCCCCCC
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    203 bytes read
    Running uenvcmd ...
    reading uImage
    2571312 bytes read
       Data Size:    2571248 Bytes = 2.5 MiB
    OK
    Starting kernel ...
    [    0.000000] Linux version 3.1.0-g62911f8-dirty (liujiangman@ubuntu) (gcc version 4.4.3 (GCC) ) #2 Sun Sep 16 15:08:21 CST 2012
    [    0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait ip=off
    [    0.000000] Memory: 253396k/253396k available, 8748k reserved, 0K highmem
    [    0.000000]       .text : 0xc0008000 - 0xc049b000   (4684 kB)
    [    0.000000]       .init : 0xc049b000 - 0xc04cf000   ( 208 kB)
    [    0.000000]       .data : 0xc04d0000 - 0xc0518fa0   ( 292 kB)
    [    0.000000]        .bss : 0xc0518fdc - 0xc064ff48   (1244 kB)
    [    0.058635] pid_max: default: 32768 minimum: 301
    [    0.058806] Security Framework initialized
    [    0.058895] Mount-cache hash table entries: 512
    [    0.059380] CPU: Testing write buffer coherency: ok
    [    0.064516] print_constraints: dummy:
    [    0.064768] NET: Registered protocol family 16
    [    0.065008] GPMC revision 6.0
    [    0.066094] OMAP GPIO hardware version 0.1
    [    0.066946] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067061] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069826]  omap_i2c.1: alias fck already exists
    [    0.070728]  omap2_mcspi.1: alias fck already exists
    [    0.070859]  omap2_mcspi.2: alias fck already exists
    [    0.080506] bio: create slab <bio-0> at 0
    [    0.081610] SCSI subsystem initialized
    [    0.082582] usbcore: registered new interface driver usbfs
    [    0.082706] usbcore: registered new interface driver hub
    [    0.082875] usbcore: registered new device driver usb
    [    0.083802] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084712] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085370] Bluetooth: Core ver 2.16
    [    0.085464] NET: Registered protocol family 31
    [    0.085482] Bluetooth: HCI device and connection manager initialized
    [    0.085507] Bluetooth: HCI socket layer initialized
    [    0.085524] Bluetooth: L2CAP socket layer initialized
    [    0.085562] Bluetooth: SCO socket layer initialized
    [    0.085773] Switching to clocksource gp timer
    [    0.088715] Switched to NOHz mode on CPU #0
    [    0.095311] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095512] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.096295] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096592] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.097252] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097630] NET: Registered protocol family 2
    [    0.097888] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098319] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098546] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098684] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098703] TCP reno registered
    [    0.098722] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098758] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.099046] NET: Registered protocol family 1
    [    0.099420] RPC: Registered named UNIX socket transport module.
    [    0.099442] RPC: Registered udp transport module.
    [    0.099456] RPC: Registered tcp transport module.
    [    0.099471] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099759] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099842] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.233430] Gpio value is :117
    [    0.234011] ashmem: initialized
    [    0.235082] msgmni has been set to 494
    [    0.236290] io scheduler noop registered
    [    0.236312] io scheduler deadline registered
    [    0.236405] io scheduler cfq registered (default)
    [    0.236932] Could not set LED4 to fully on
    [    0.238062] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.239319] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.747576] console [ttyO0] enabled
    [    0.751552] WL1271: BT Enable
    [    0.754871] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.762705] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.770443] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.778175] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.785876] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.800808] brd: module loaded
    [    0.808101] loop: module loaded
    [    0.811618] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.875825] No daughter card found
    [    0.879460] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.886805] AM335x:EVM Config Without Read E2PROM
    [    1.005835] Board name: A335ABCD
    [    1.009416] Board version: 00AA
    [    1.012718] SKU: SKU#01
    [    1.015455] The board is general purpose EVM in profile 0
    [    1.021152] Found invalid GP EVM revision, falling back to Rev1.1A
    [    1.027988]  omap_hsmmc.0: alias fck already exists
    [    1.033619]  omap_hsmmc.2: alias fck already exists
    [    1.039026] Configure Bluetooth Enable pin...
    [    1.044742] omap2-nand driver initializing
    [    1.049269] OneNAND driver initializing
    [    1.053833] Initializing USB Mass Storage driver...
    [    1.059132] usbcore: registered new interface driver usb-storage
    [    1.065451] USB Mass Storage support registered.
    [    1.072718]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.079007]  gadget: Number of LUNs=1
    [    1.082863]  lun0: LUN: removable file: (no medium)
    [    1.088325]  gadget: android_usb ready
    [    1.092313] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.097943] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.106496] hub 1-0:1.0: USB hub found
    [    1.110463] hub 1-0:1.0: 1 port detected
    [    1.115192] mousedev: PS/2 mouse device common for all mice
    [    1.122416] using rtc device, omap_rtc, for alarms
    [    1.127381] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.134350] i2c /dev entries driver
    [    1.138991] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.145585] device-mapper: uevent: version 1.0.3
    [    1.150729] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.159641] Bluetooth: HCI UART driver ver 2.2
    [    1.164318] Bluetooth: HCI H4 protocol initialized
    [    1.169376] Bluetooth: HCILL protocol initialized
    [    1.175778] usbcore: registered new interface driver usbhid
    [    1.181702] usbhid: USB HID core driver
    [    1.186538] logger: created 256K log 'log_main'
    [    1.191440] logger: created 256K log 'log_events'
    [    1.196574] logger: created 256K log 'log_radio'
    [    1.201558] logger: created 256K log 'log_system'
    [    1.207890] ALSA device list:
    [    1.211017]   No soundcards found.
    [    1.214747] nf_conntrack version 0.5.0 (3959 buckets, 15836 max)
    [    1.221646] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.227418] TCP cubic registered
    [    1.230819] NET: Registered protocol family 17
    [    1.236055] Bluetooth: RFCOMM TTY layer initialized
    [    1.241202] Bluetooth: RFCOMM socket layer initialized
    [    1.246640] Bluetooth: RFCOMM ver 1.11
    [    1.250587] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.256196] Bluetooth: BNEP filters: protocol multicast
    [    1.261695] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.268132] Registering the dns_resolver key type
    [    1.273175] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.281278] ThumbEE CPU extension supported.
    [    1.286786] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.292927] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.299022] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.304974] omap2_set_init_voltage: unable to set vdd_core
    [    1.316079] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    1.325525] Waiting for root device /dev/mmcblk0p2...
    [    1.369090] mmc0: new high speed SD card at address 1234
    [    1.375310] mmcblk0: mmc0:1234 SA02G 1.85 GiB
    [    1.382454]  mmcblk0: p1 p2
    [    4.278698] kjournald starting.  Commit interval 5 seconds
    [    4.284561] EXT3-fs (mmcblk0p2): warning: mounting unchecked fs, running e2fsck is recommended
    [    4.523686] EXT3-fs (mmcblk0p2): using internal journal
    [    4.529214] EXT3-fs (mmcblk0p2): recovery complete
    [    4.539017] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    [    4.546533] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [    4.553286] Freeing init memory: 208K
    INIT: version 2.86 booting
    Usage: mount [-r] [-w] [-o options] [-t type] device directory
    INIT: Entering runlevel: 5
    INIT: Id "S" respawning too fast: disabled for 5 minutes
    最后这一句隔几分钟出现一次,请问是哪里的问题
  • 对卡重新进行了分区,文件系统重新烧写,输出信息如下
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    203 bytes read
    Running uenvcmd ...
    reading uImage
    2631080 bytes read
      Data Size:    2631016 Bytes = 2.5 MiB
    OK
    Starting kernel ...
    [    0.000000] Linux version 3.1.0-g62911f8-dirty (liujiangman@ubuntu) (gcc version 4.4.3 (GCC) ) #1 Sun Sep 16 16:26:08 CST 2012
    [    0.000263] Calibrating delay loop... 498.89 BogoMIPS (lpj=2494464)
    [    0.058800] Security Framework initialized
    [    0.064491] print_constraints: dummy:
    [    0.064748] NET: Registered protocol family 16
    [    0.064978] GPMC revision 6.0
    [    0.066038] OMAP GPIO hardware version 0.1
    [    0.066887] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067004] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069749]  omap_i2c.1: alias fck already exists
    [    0.070648]  omap2_mcspi.1: alias fck already exists
    [    0.070782]  omap2_mcspi.2: alias fck already exists
    [    0.080377] bio: create slab <bio-0> at 0
    [    0.081471] SCSI subsystem initialized
    [    0.082452] usbcore: registered new interface driver usbfs
    [    0.082582] usbcore: registered new interface driver hub
    [    0.082757] usbcore: registered new device driver usb
    [    0.083666] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084570] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085238] Bluetooth: Core ver 2.16
    [    0.085334] NET: Registered protocol family 31
    [    0.085352] Bluetooth: HCI device and connection manager initialized
    [    0.085376] Bluetooth: HCI socket layer initialized
    [    0.085394] Bluetooth: L2CAP socket layer initialized
    [    0.085431] Bluetooth: SCO socket layer initialized
    [    0.085644] Switching to clocksource gp timer
    [    0.088709] Switched to NOHz mode on CPU #0
    [    0.094995] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095190] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.095973] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096280] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.096932] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097315] NET: Registered protocol family 2
    [    0.097564] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098002] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098230] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098368] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098388] TCP reno registered
    [    0.098407] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098444] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098735] NET: Registered protocol family 1
    [    0.099103] RPC: Registered named UNIX socket transport module.
    [    0.099124] RPC: Registered udp transport module.
    [    0.099139] RPC: Registered tcp transport module.
    [    0.099154] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099448] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099534] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.256042] Gpio value is :117
    [    0.256627] ashmem: initialized
    [    0.257694] msgmni has been set to 494
    [    0.258765] io scheduler noop registered
    [    0.258785] io scheduler deadline registered
    [    0.258874] io scheduler cfq registered (default)
    [    0.259409] Could not set LED4 to fully on
    [    0.260540] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.261780] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.770067] console [ttyO0] enabled
    [    0.774054] WL1271: BT Enable
    [    0.777433] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.785129] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.792952] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.800705] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.808414] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.823264] brd: module loaded
    [    0.830461] loop: module loaded
    [    0.833980] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.895697] No daughter card found
    [    0.899333] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.906680] AM335x:EVM Config Without Read E2PROM
    [    1.025696] Board name: A335ABCD
    [    1.029277] Board version: 00AA
    [    1.032580] SKU: SKU#01
    [    1.035313] The board is general purpose EVM in profile 0
    [    1.041010] Found invalid GP EVM revision, falling back to Rev1.1A
    [    1.047858]  omap_hsmmc.0: alias fck already exists
    [    1.053495]  omap_hsmmc.2: alias fck already exists
    [    1.058903] Configure Bluetooth Enable pin...
    [    1.064632] omap2-nand driver initializing
    [    1.069134] OneNAND driver initializing
    [    1.073693] Initializing USB Mass Storage driver...
    [    1.078991] usbcore: registered new interface driver usb-storage
    [    1.085310] USB Mass Storage support registered.
    [    1.092567]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.098857]  gadget: Number of LUNs=1
    [    1.102713]  lun0: LUN: removable file: (no medium)
    [    1.108166]  gadget: android_usb ready
    [    1.112152] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.117784] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.126330] hub 1-0:1.0: USB hub found
    [    1.130297] hub 1-0:1.0: 1 port detected
    [    1.135014] mousedev: PS/2 mouse device common for all mice
    [    1.142260] using rtc device, omap_rtc, for alarms
    [    1.147225] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.154193] i2c /dev entries driver
    [    1.158832] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.165429] device-mapper: uevent: version 1.0.3
    [    1.170568] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.179482] Bluetooth: HCI UART driver ver 2.2
    [    1.184158] Bluetooth: HCI H4 protocol initialized
    [    1.189214] Bluetooth: HCILL protocol initialized
    [    1.195636] usbcore: registered new interface driver usbhid
    [    1.201556] usbhid: USB HID core driver
    [    1.206396] logger: created 256K log 'log_main'
    [    1.211301] logger: created 256K log 'log_events'
    [    1.216429] logger: created 256K log 'log_radio'
    [    1.221414] logger: created 256K log 'log_system'
    [    1.227743] ALSA device list:
    [    1.230870]   No soundcards found.
    [    1.234606] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
    [    1.241505] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.247287] TCP cubic registered
    [    1.250691] NET: Registered protocol family 17
    [    1.255930] Bluetooth: RFCOMM TTY layer initialized
    [    1.261080] Bluetooth: RFCOMM socket layer initialized
    [    1.266514] Bluetooth: RFCOMM ver 1.11
    [    1.270461] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.276070] Bluetooth: BNEP filters: protocol multicast
    [    1.281568] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.288015] Registering the dns_resolver key type
    [    1.293046] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.301150] ThumbEE CPU extension supported.
    [    1.306655] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.312795] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.318887] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.324840] omap2_set_init_voltage: unable to set vdd_core
    [    1.336006] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    1.345459] Waiting for root device /dev/mmcblk0p2...
    [    1.388961] mmc0: new high speed SD card at address 1234
    [    1.395193] mmcblk0: mmc0:1234 SA02G 1.85 GiB
    [    1.402354]  mmcblk0: p1 p2
    [   22.204917] kjournald starting.  Commit interval 5 seconds
    [   22.451991] EXT3-fs (mmcblk0p2): using internal journal
    [   22.457523] EXT3-fs (mmcblk0p2): recovery complete
    [   22.466985] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    [   22.474478] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [   22.481258] Freeing init memory: 208K
    [   22.485288] Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
    [   22.498406] Backtrace:
    [   22.501025] [<c0016f24>] (dump_backtrace+0x0/0x110) from [<c038322c>] (dump_stack+0x18/0x1c)
    [   22.509920]  r7:00000013 r6:c003bbe8 r5:c0533ed0 r4:c0533ed0
    [   22.515924] [<c0383214>] (dump_stack+0x0/0x1c) from [<c0383294>] (panic+0x64/0x18c)
    [   22.523991] [<c0383230>] (panic+0x0/0x18c) from [<c0008680>] (init_post+0xa8/0xcc)
    [   22.531967]  r3:fffffffe r2:0000000c r1:0000f96f r0:c04420dd
    [   22.537983] [<c00085d8>] (init_post+0x0/0xcc) from [<c04b52fc>] (kernel_init+0xf4/0x124)
    [   22.546513]  r5:c04e8c14 r4:c0533000
    [   22.550309] [<c04b5208>] (kernel_init+0x0/0x124) from [<c003bbe8>] (do_exit+0x0/0x604)
    OMAP SD/MMC: 0
    reading u-boot.img
    reading u-boot.img
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    reading uEnv.txt
    214 bytes read
    Running uenvcmd ...
    reading uImage
    2571312 bytes read
    OK
    Starting kernel ...
    [    0.058631] pid_max: default: 32768 minimum: 301
    [    0.058796] Security Framework initialized
    [    0.058886] Mount-cache hash table entries: 512
    [    0.059368] CPU: Testing write buffer coherency: ok
    [    0.064522] print_constraints: dummy:
    [    0.064773] NET: Registered protocol family 16
    [    0.065005] GPMC revision 6.0
    [    0.066938] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067053] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069810]  omap_i2c.1: alias fck already exists
    [    0.070845]  omap2_mcspi.2: alias fck already exists
    [    0.080481] bio: create slab <bio-0> at 0
    [    0.081573] SCSI subsystem initialized
    [    0.082545] usbcore: registered new interface driver usbfs
    [    0.082671] usbcore: registered new interface driver hub
    [    0.082842] usbcore: registered new device driver usb
    [    0.083770] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084679] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085337] Bluetooth: Core ver 2.16
    [    0.085431] NET: Registered protocol family 31
    [    0.085449] Bluetooth: HCI device and connection manager initialized
    [    0.085474] Bluetooth: HCI socket layer initialized
    [    0.085491] Bluetooth: L2CAP socket layer initialized
    [    0.085529] Bluetooth: SCO socket layer initialized
    [    0.085740] Switching to clocksource gp timer
    [    0.095275] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095475] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.096257] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096562] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.097223] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097601] NET: Registered protocol family 2
    [    0.097853] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098287] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098516] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098653] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098673] TCP reno registered
    [    0.098693] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098728] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.099019] NET: Registered protocol family 1
    [    0.099394] RPC: Registered named UNIX socket transport module.
    [    0.099415] RPC: Registered udp transport module.
    [    0.099430] RPC: Registered tcp transport module.
    [    0.099445] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099733] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099818] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.233285] Gpio value is :117
    [    0.233870] ashmem: initialized
    [    0.234942] msgmni has been set to 494
    [    0.236161] io scheduler noop registered
    [    0.236183] io scheduler deadline registered
    [    0.236273] io scheduler cfq registered (default)
    [    0.236799] Could not set LED4 to fully on
    [    0.237931] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.239185] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.748460] console [ttyO0] enabled
    [    0.752430] WL1271: BT Enable
    [    0.755751] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.763588] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.771327] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.779059] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.786754] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.801666] brd: module loaded
    [    0.808910] loop: module loaded
    [    0.812430] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.875793] No daughter card found
    [    0.879429] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.886774] AM335x:EVM Config Without Read E2PROM
    [    1.005799] Board name: A335ABCD
    [    1.009379] Board version: 00AA
    [    1.012681] SKU: SKU#01
    [    1.015417] The board is general purpose EVM in profile 0
    [    1.021116] Found invalid GP EVM revision, falling back to Rev1.1A
    [    1.027954]  omap_hsmmc.0: alias fck already exists
    [    1.033586]  omap_hsmmc.2: alias fck already exists
    [    1.038983] Configure Bluetooth Enable pin...
    [    1.044709] omap2-nand driver initializing
    [    1.049240] OneNAND driver initializing
    [    1.053789] Initializing USB Mass Storage driver...
    [    1.059089] usbcore: registered new interface driver usb-storage
    [    1.065408] USB Mass Storage support registered.
    [    1.072656]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.078944]  gadget: Number of LUNs=1
    [    1.082800]  lun0: LUN: removable file: (no medium)
    [    1.088262]  gadget: android_usb ready
    [    1.092250] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.097883] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.106444] hub 1-0:1.0: USB hub found
    [    1.110411] hub 1-0:1.0: 1 port detected
    [    1.115135] mousedev: PS/2 mouse device common for all mice
    [    1.122361] using rtc device, omap_rtc, for alarms
    [    1.127326] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.134299] i2c /dev entries driver
    [    1.138957] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.145554] device-mapper: uevent: version 1.0.3
    [    1.150694] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.159606] Bluetooth: HCI UART driver ver 2.2
    [    1.164283] Bluetooth: HCI H4 protocol initialized
    [    1.169340] Bluetooth: HCILL protocol initialized
    [    1.175744] usbcore: registered new interface driver usbhid
    [    1.181664] usbhid: USB HID core driver
    [    1.186496] logger: created 256K log 'log_main'
    [    1.191400] logger: created 256K log 'log_events'
    [    1.196525] logger: created 256K log 'log_radio'
    [    1.201511] logger: created 256K log 'log_system'
    [    1.207835] ALSA device list:
    [    1.210960]   No soundcards found.
    [    1.214688] nf_conntrack version 0.5.0 (3959 buckets, 15836 max)
    [    1.221594] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.227371] TCP cubic registered
    [    1.230773] NET: Registered protocol family 17
    [    1.236012] Bluetooth: RFCOMM TTY layer initialized
    [    1.241163] Bluetooth: RFCOMM socket layer initialized
    [    1.246599] Bluetooth: RFCOMM ver 1.11
    [    1.250546] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.256157] Bluetooth: BNEP filters: protocol multicast
    [    1.261657] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.268095] Registering the dns_resolver key type
    [    1.273133] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.281234] ThumbEE CPU extension supported.
    [    1.286742] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.292887] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.298978] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.304931] omap2_set_init_voltage: unable to set vdd_core
    [    1.316039] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
    [    1.325484] Waiting for root device /dev/mmcblk0p2...
    [    1.369050] mmc0: new high speed SD card at address 1234
    [    1.375264] mmcblk0: mmc0:1234 SA02G 1.85 GiB
    [    1.382412]  mmcblk0: p1 p2 p3
    [    1.682443] kjournald starting.  Commit interval 5 seconds
    [    1.693039] EXT3-fs (mmcblk0p2): using internal journal
    [    1.698570] EXT3-fs (mmcblk0p2): recovery complete
    [    1.707394] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    [    1.714879] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [    1.721657] Freeing init memory: 208K
    [    1.880146] WL1271: BT Disable
    [    2.783919] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
    # [    5.798357] warning: `dhcpcd' uses 32-bit capabilities (legacy support in use)
    [    6.102732] adb_open
    [    8.115439] g_zero: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [    8.129336] android_usb: already disabled
    [    8.134858] adb_bind_config
    [    8.700183] compat: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [    9.196862] cfg80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [    9.236848] pvrsrvkm: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [    9.829184] omaplfb: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [    9.908563] mac80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   10.725994] wl12xx: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   11.008736] compat: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   11.268586] cfg80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   11.772127] mac80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   18.204605] wl12xx: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   19.741510] compat: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   20.287487] cfg80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   20.534195] mac80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   20.802407] pvrsrvkm: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   20.821961] wl12xx: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   21.072111] omaplfb: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   29.378541] compat: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    [   30.497420] cfg80211: version magic '3.1.0-g62911f8-dirty mod_unload modversions ARMv7 ' should be '3.1.0-g62911f8-dirty ARMv7 '
    后面这几句重复出现,一直在出,请问这是怎么回事
  • 请问下 你做了什么修改?我现在也遇到和你一样的问题
  • 我开始使用的tisdk-rootfs-am335x-evm.tar.gz做的文件系统,遇到跟楼主一样的问题,后来用base-rootfs-am335x-evm.tar.gz做了一个就可以正常的启动了。
  • TI  E2E  上有个回答 可能有帮助
    It looks like your SD Card is not created properly. How did you create the card? The TI Wiki has some instructions here:
    processors.wiki.ti.com/.../AM335x_U-Boot_User%27s_Guide
    You might want to try a 1GB or 4GB card. The 2GB size can cause problems if your card reader is one of the older models. That size needs a MBR.
  • 我的是修改了内核里面的配置才可以的,现在又卡到了另一处,估计还得改配置
    I2C:   ready
    DRAM:  256 MiB
    WARNING: Caches not enabled
    Could not probe the EEPROM; something fundamentally wrong on the I2C bus.
    NAND:  HW ECC Hamming Code selected
    256 MiB
    MMC:   OMAP SD/MMC: 0
    Net:   cpsw
    Hit any key to stop autoboot:  0
    SD/MMC found on device 0
    reading uEnv.txt
    227 bytes read
    Loaded environment from uEnv.txt
    Importing environment from mmc ...
    Running uenvcmd ...
    reading uImage
    2631088 bytes read
    ## Booting kernel from Legacy Image at 82000000 ...
      Image Name:   Linux-3.1.0-g62911f8-dirty
      Image Type:   ARM Linux Kernel Image (uncompressed)
      Data Size:    2631024 Bytes = 2.5 MiB
      Load Address: 80008000
      Entry Point:  80008000
      Verifying Checksum ... OK
      Loading Kernel Image ... OK
    OK
    Starting kernel ...
    Uncompressing Linux... done, booting the kernel.
    [    0.000000] Linux version 3.1.0-g62911f8-dirty (liujiangman@ubuntu) (gcc version 4.4.3 (GCC) ) #1 Tue Sep 18 09:40:45 CST 2012
    [    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
    [    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine: am335xevm
    [    0.000000] Memory policy: ECC disabled, Data cache writeback
    [    0.000000] AM335X ES1.0 (neon )
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
    [    0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait rootdelay=1 init=/init ip=off
    [    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    [    0.000000] Memory: 256MB = 256MB total
    [    0.000000] Memory: 253292k/253292k available, 8852k reserved, 0K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     DMA     : 0xffa00000 - 0xffe00000   (   4 MB)
    [    0.000000]     vmalloc : 0xd0800000 - 0xf8000000   ( 632 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
    [    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc04b5000   (4788 kB)
    [    0.000000]       .init : 0xc04b5000 - 0xc04e9000   ( 208 kB)
    [    0.000000]       .data : 0xc04ea000 - 0xc0532fa0   ( 292 kB)
    [    0.000000]        .bss : 0xc0532fdc - 0xc0669f48   (1244 kB)
    [    0.000000] NR_IRQS:396
    [    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
    [    0.000000] Total of 128 interrupts on 1 active controller
    [    0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
    [    0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
    [    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
    [    0.000000] Console: colour dummy device 80x30
    [    0.058633] pid_max: default: 32768 minimum: 301
    [    0.064476] print_constraints: dummy:
    [    0.064733] NET: Registered protocol family 16
    [    0.064966] GPMC revision 6.0
    [    0.066051] OMAP GPIO hardware version 0.1
    [    0.066899] omap_l3_smx omap_l3_smx.0: couldn't find resource
    [    0.067019] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.069764]  omap_i2c.1: alias fck already exists
    [    0.070664]  omap2_mcspi.1: alias fck already exists
    [    0.070795]  omap2_mcspi.2: alias fck already exists
    [    0.080417] bio: create slab <bio-0> at 0
    [    0.081513] SCSI subsystem initialized
    [    0.082479] usbcore: registered new interface driver usbfs
    [    0.082608] usbcore: registered new interface driver hub
    [    0.082783] usbcore: registered new device driver usb
    [    0.083694] omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
    [    0.084607] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.085274] Bluetooth: Core ver 2.16
    [    0.085377] NET: Registered protocol family 31
    [    0.085395] Bluetooth: HCI device and connection manager initialized
    [    0.085419] Bluetooth: HCI socket layer initialized
    [    0.085437] Bluetooth: L2CAP socket layer initialized
    [    0.085476] Bluetooth: SCO socket layer initialized
    [    0.085685] Switching to clocksource gp timer
    [    0.088707] Switched to NOHz mode on CPU #0
    [    0.095071] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    0.095265] musb-hdrc musb-hdrc.0: dma type: pio
    [    0.096040] musb-hdrc musb-hdrc.0: USB OTG mode controller at d080a000 using PIO, IRQ 18
    [    0.096341] musb-hdrc musb-hdrc.1: dma type: pio
    [    0.096993] musb-hdrc musb-hdrc.1: USB OTG mode controller at d080c800 using PIO, IRQ 19
    [    0.097374] NET: Registered protocol family 2
    [    0.097625] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.098056] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    0.098282] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    0.098421] TCP: Hash tables configured (established 8192 bind 8192)
    [    0.098441] TCP reno registered
    [    0.098460] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098496] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    0.098786] NET: Registered protocol family 1
    [    0.099154] RPC: Registered named UNIX socket transport module.
    [    0.099175] RPC: Registered udp transport module.
    [    0.099190] RPC: Registered tcp transport module.
    [    0.099206] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.099493] NetWinder Floating Point Emulator V0.97 (double precision)
    [    0.099579] omap_init_opp_table: no hwmod or odev for iva, [8] cannot add OPPs.
    [    0.256033] Gpio value is :117
    [    0.257688] msgmni has been set to 494
    [    0.258797] io scheduler noop registered
    [    0.258817] io scheduler deadline registered
    [    0.258907] io scheduler cfq registered (default)
    [    0.259435] Could not set LED4 to fully on
    [    0.260559] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
    [    0.261797] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    0.772176] console [ttyO0] enabled
    [    0.776191] WL1271: BT Enable
    [    0.779515] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    0.787364] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    0.795039] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    0.802793] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    0.810513] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    0.825349] brd: module loaded
    [    0.832558] loop: module loaded
    [    0.836161] at24 1-0051: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.895736] No daughter card found
    [    0.899369] at24 1-0050: 32768 byte 24c256 EEPROM, writable, 64 bytes/write
    [    0.906714] AM335x:EVM Config Without Read E2PROM
    [    1.025738] Board name: A335ABCD
    [    1.029317] Board version: 00AA
    [    1.032619] SKU: SKU#01
    [    1.035356] The board is general purpose EVM in profile 0
    [    1.041053] Found invalid GP EVM revision, falling back to Rev1.1A
    [    1.047897]  omap_hsmmc.0: alias fck already exists
    [    1.053539]  omap_hsmmc.2: alias fck already exists
    [    1.058948] Configure Bluetooth Enable pin...
    [    1.064667] omap2-nand driver initializing
    [    1.069171] OneNAND driver initializing
    [    1.073724] Initializing USB Mass Storage driver...
    [    1.079021] usbcore: registered new interface driver usb-storage
    [    1.085339] USB Mass Storage support registered.
    [    1.092594]  gadget: Mass Storage Function, version: 2009/09/11
    [    1.098881]  gadget: Number of LUNs=1
    [    1.102737]  lun0: LUN: removable file: (no medium)
    [    1.108202]  gadget: android_usb ready
    [    1.112191] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    1.117822] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    1.126373] hub 1-0:1.0: USB hub found
    [    1.130339] hub 1-0:1.0: 1 port detected
    [    1.135053] mousedev: PS/2 mouse device common for all mice
    [    1.142274] using rtc device, omap_rtc, for alarms
    [    1.147244] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
    [    1.154147] omap_rtc: already running
    [    1.158094] i2c /dev entries driver
    [    1.162729] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    1.169366] device-mapper: uevent: version 1.0.3
    [    1.174450] device-mapper: ioctl: 4.21.0-ioctl (2011-07-06) initialised: dm-devel@redhat.com
    [    1.183374] Bluetooth: HCI UART driver ver 2.2
    [    1.188069] Bluetooth: HCI H4 protocol initialized
    [    1.193108] Bluetooth: HCILL protocol initialized
    [    1.199547] usbcore: registered new interface driver usbhid
    [    1.205415] usbhid: USB HID core driver
    [    1.210273] logger: created 256K log 'log_main'
    [    1.215176] logger: created 256K log 'log_events'
    [    1.220306] logger: created 256K log 'log_radio'
    [    1.225290] logger: created 256K log 'log_system'
    [    1.231612] ALSA device list:
    [    1.234736]   No soundcards found.
    [    1.238519] nf_conntrack version 0.5.0 (3957 buckets, 15828 max)
    [    1.245358] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    1.251143] TCP cubic registered
    [    1.254547] NET: Registered protocol family 17
    [    1.259807] Bluetooth: RFCOMM TTY layer initialized
    [    1.264958] Bluetooth: RFCOMM socket layer initialized
    [    1.270400] Bluetooth: RFCOMM ver 1.11
    [    1.274347] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    1.279956] Bluetooth: BNEP filters: protocol multicast
    [    1.285454] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    1.291896] Registering the dns_resolver key type
    [    1.296966] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    1.305041] ThumbEE CPU extension supported.
    [    1.310556] omap2_set_init_voltage: unable to get clk dpll1_ck
    [    1.316731] omap2_set_init_voltage: unable to set vdd_mpu_iva
    [    1.322789] omap2_set_init_voltage: unable to get clk l3_ick
    [    1.328756] omap2_set_init_voltage: unable to set vdd_core
    [    1.339873] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:06:18 UTC (946685178)
    [    1.349147] Waiting 1sec before mounting root device...
    [    1.389000] mmc0: new high speed SD card at address 1234
    [    1.395216] mmcblk0: mmc0:1234 SA02G 1.85 GiB
    [    1.402390]  mmcblk0: p1 p2 p3
    [    5.479382] kjournald starting.  Commit interval 5 seconds
    [    5.727193] EXT3-fs (mmcblk0p2): using internal journal
    [    5.732696] EXT3-fs (mmcblk0p2): recovery complete
    [    5.741537] EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
    [    5.749054] VFS: Mounted root (ext3 filesystem) on device 179:2.
    [    5.755830] Freeing init memory: 208K
    [    6.151153] WL1271: BT Disable
    [    6.547639] init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
    # [   10.534472] warning: `dhcpcd' uses 32-bit capabilities (legacy support in use)
    [   10.546141] adb_open
    [   11.482998]  gadget: Gadget Zero, version: Cinco de Mayo 2008
    [   11.489157]  gadget: zero ready
    [   11.492496] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    [   11.498117] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
    [   11.506816] hub 2-0:1.0: USB hub found
    [   11.510757] hub 2-0:1.0: 1 port detected
    [   11.517654] android_usb: already disabled
    [   11.522995] adb_bind_config
    [   12.039825] Compat-wireless backport release: compat-wireless-2011-07-27
    [   12.047006] Backport based on wl12xx.git v2.6.39-1152-g0c08ddf
    [   13.340948] cfg80211: Calling CRDA to update world regulatory domain
    [   14.216383] cfg80211: World regulatory domain updated:
    [   14.221864] cfg80211:     (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
    [   14.230693] cfg80211:     (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   14.239040] cfg80211:     (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [   14.247386] cfg80211:     (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
    [   14.255735] cfg80211:     (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   14.264066] cfg80211:     (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
    [   14.274403]
    [   21.850254] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   26.028853] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   33.312458] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   39.201803] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   43.669687] request_suspend_state: wakeup (3->0) at 43663947842 (2000-01-01 00:07:00.819479715 UTC)
    [   44.949766] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   50.313479] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   53.857606] request_suspend_state: wakeup (0->0) at 53851864926 (2000-01-01 00:07:11.007397341 UTC)
    [   54.331072] init: untracked pid 215 exited
    [   55.920544] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   60.295655] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   62.928680] request_suspend_state: wakeup (0->0) at 62922939968 (2000-01-01 00:07:20.078473050 UTC)
    [   66.648763] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   70.201490] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   72.809300] request_suspend_state: wakeup (0->0) at 72803559887 (2000-01-01 00:07:29.959091719 UTC)
    [   74.953584] init: untracked pid 296 exited
    [   78.610656] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   83.573503] request_suspend_state: wakeup (0->0) at 83567761346 (2000-01-01 00:07:40.723292636 UTC)
    [   85.206749] init: untracked pid 332 exited
    [   86.027051] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   90.589514] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [   95.621215] request_suspend_state: wakeup (0->0) at 95615473681 (2000-01-01 00:07:52.771005429 UTC)
    [   95.718844] init: untracked pid 360 exited
    [   96.947099] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  101.304100] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  106.849297] request_suspend_state: wakeup (0->0) at 106843557182 (2000-01-01 00:08:03.999088722 UTC)
    [  106.922636] init: untracked pid 402 exited
    [  109.699917] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  116.308268] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  118.075549] request_suspend_state: wakeup (0->0) at 118069806725 (2000-01-01 00:08:15.225338557 UTC)
    [  122.141980] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  128.142550] request_suspend_state: wakeup (0->0) at 128136807518 (2000-01-01 00:08:25.292339225 UTC)
    [  129.529415] init: untracked pid 493 exited
    [  129.729520] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  135.612791] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  138.073478] request_suspend_state: wakeup (0->0) at 138067736228 (2000-01-01 00:08:35.223269601 UTC)
    [  139.564742] init: untracked pid 532 exited
    [  142.652653] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  147.236316] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  149.197063] request_suspend_state: wakeup (0->0) at 149191321854 (2000-01-01 00:08:46.346855186 UTC)
    [  149.209699] init: untracked pid 570 exited
    [  152.851621] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
    [  158.442229] request_suspend_state: wakeup (0->0) at 158436486480 (2000-01-01 00:08:55.592018062 UTC)
    [  159.538519] omaplfb: OMAPLFB_Init: OMAPLFBInit failed
  • 你好 我也遇到这个问题了 请问下你是怎么修改配置解决这个问题的  内核里面哪些选项做了修改 谢谢
  • 我只是修改了board_am335xevm.c,只是这里过去了,别的还有错,你可以参考下我的改的,这个路径是kernel/arch/arm/mach-omap2
  • 问题解决没 求赐教
x 出现错误。请重试或与管理员联系。
x 出现错误。请重试或与管理员联系。
