C6678 system_printf
您好:代码如下
void cbFxn(UInt16 procId, UInt16 lineId, UInt32 eventId, UArg arg, UInt32 payload)//Notify回调函数
Semaphore_post(semHandle);
void *tsk_func(void *arg)
int status;
if (MultiProc_self() == 0) {
/*这里可以添加主核需要执行的任务代码*/
System_printf("core%d \n",MultiProc_self());
/* Send an event to the next processor */
status = Notify_sendEvent(1, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore1 failed\n");
/* Wait to be released by the cbFxn posting the semaphore */
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核1完成其工作返回
status = Notify_sendEvent(2, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore2 failed\n");
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核2完成其工作返回
status = Notify_sendEvent(3, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore3 failed\n");
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核3完成其工作返回
status = Notify_sendEvent(4, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore4 failed\n");
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核4完成其工作返回
status = Notify_sendEvent(5, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore5 failed\n");
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核5完成其工作返回
status = Notify_sendEvent(6, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore6 failed\n");
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核6完成其工作返回
status = Notify_sendEvent(7, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("Notify_sendEvent for slaveCore7 failed\n");
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核7完成其工作返回
System_printf("MasterCore0 Received Event from All SloverCores \n");
else {
/* wait forever on a semaphore, semaphore is posted in callback */
Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 等待主核通知开始执行任务
System_printf("SlaverCore%d Received Event from MasterCore0 \n", MultiProc_self());
/*这里可以添加从核执行的任务*/
status = Notify_sendEvent(0, 0, 10, NULL, TRUE);
if (status < 0) {
System_abort("sendEvent to MasterCore0 failed\n");
System_printf("SlaverCore%d sent Event to MasterCore0 \n", MultiProc_self());
System_printf("Test over \n");
BIOS_exit(0);
return (void*)0;
int main()
int status;
status = Ipc_start();
if (status < 0) {
System_abort("Ipc_start failed\n");
System_printf("Ipc_start successfully\n");
pthread_t tsk;
pthread_attr_t attr;
size_t stacksize = 0x1000000;//16MB
pthread_attr_init(&attr);
pthread_attr_setstacksize(&attr,stacksize);
if(pthread_create(&tsk,&attr,tsk_func,NULL))
tsk = 0;
System_abort("create tsk failed\n");
if(MultiProc_self() == 0)//0是主核,1-7是从核
do{
status = Ipc_attach(1);
}while(status < 0);// 完成从核1的连接
do{
status = Ipc_attach(2);
}while(status < 0);// 完成从核2的连接
do{
status = Ipc_attach(3);
}while(status < 0);// 完成从核3的连接
do{
status = Ipc_attach(4);
}while(status < 0);// 完成从核4的连接
do{
status = Ipc_attach(5);
}while(status < 0);// 完成从核5的连接
do{
status = Ipc_attach(6);
}while(status < 0);// 完成从核6的连接
do{
status = Ipc_attach(7);
}while(status < 0);// 完成从核7的连接
status = Notify_registerEvent(1, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore1 failed\n");
}// 完成从核1的事件注册
status = Notify_registerEvent(2, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore2 failed\n");
}// 完成从核2的事件注册
status = Notify_registerEvent(3, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore3 failed\n");
}// 完成从核3的事件注册
status = Notify_registerEvent(4, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore4 failed\n");
}// 完成从核4的事件注册
status = Notify_registerEvent(5, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore5 failed\n");
}// 完成从核5的事件注册
status = Notify_registerEvent(6, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore6 failed\n");
}// 完成从核6的事件注册
status = Notify_registerEvent(7, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for slaveCore7 failed\n");
}// 完成从核7的事件注册
System_printf("Notify_registerEvent for slaveCores successfully\n");
else{
do{
status = Ipc_attach(0);
}while(status < 0);// 完成主核0的连接
status = Notify_registerEvent(0, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
if (status < 0) {
System_abort("Notify_registerEvent for masterCore0 failed\n");
}// 完成主核0的事件注册
System_printf("Notify_registerEvent for masterCore0 successfully\n");
BIOS_start();
return 0;
结果:
[C66xx_6] Ipc_start successfully
core6
SlaverCore6 Received Event from MasterCore0
SlaverCore6 sent Event to MasterCore0
Test over
[C66xx_7] Ipc_start successfully
core7
SlaverCore7 Received Event from MasterCore0
SlaverCore7 sent Event to MasterCore0
Test over
[C66xx_5] Ipc_start successfully
core5
SlaverCore5 Received Event from MasterCore0
SlaverCore5 sent Event to MasterCore0
Test over
[C66xx_0] Ipc_start successfully
core0
Test over
[C66xx_1] Ipc_start successfully
core1
SlaverCore1 Received Event from MasterCore0
SlaverCore1 sent Event to MasterCore0
Test over
[C66xx_2] Ipc_start successfully
core2
SlaverCore2 Received Event from MasterCore0
SlaverCore2 sent Event to MasterCore0
Test over
[C66xx_3] Ipc_start successfully
core3
SlaverCore3 Received Event from MasterCore0
SlaverCore3 sent Event to MasterCore0
Test over
[C66xx_4] Ipc_start successfully
core4
SlaverCore4 Received Event from MasterCore0
SlaverCore4 sent Event to MasterCore0
Test over
当使用system _printf()的时候,运行是正常的,打印信息也是对的,但是当使用printf()的时候,运行就会出错,显示如下:
[C66xx_1] Notify_registerEvent for masterCore0 successfully
[C66xx_2] Notify_registerEvent for masterCore0 successfully
[C66xx_3] Notify_registerEvent for masterCore0 successfully
[C66xx_4] Notify_registerEvent for masterCore0 successfully
[C66xx_5] Notify_registerEvent for masterCore0 successfully
[C66xx_6] Notify_registerEvent for masterCore0 successfully
[C66xx_7] Notify_registerEvent for masterCore0 successfully
[C66xx_1] core1
[C66xx_2] core2
[C66xx_3] core3
[C66xx_4] core4
[C66xx_5] core5
[C66xx_6] core6
[C66xx_7] core7
[C66xx_0] Notify_registerEvent for slaveCores successfully
20bc338 B15=0x81000640
B16=0x4 B17=0x800003e0
B18=0xff B19=0x920b9cc8
B20=0x20 B21=0x10028066
B22=0x0 B23=0x7ff00000
B24=0x4410 B25=0x10
B26=0xd4206 B27=0x62180
B28=0x42800040 B29=0x6383
B30=0xc00f100 B31=0x2
NTSR=0x1000f
ITSR=0x0
IRP=0x0
SSR=0x0
AMR=0x0
RILC=0x0
ILC=0x0
Exception at 0xbebebebe
EFR=0x2 NRP=0xbebebebe
Internal exception: IERR=0x2
Fetch packet exception
ti.sysbios.family.c64p.Exception: line 256: E_exceptionMax: pc = 0xbebebebe, sp = 0x81000640.
xdc.runtime.Error.raise: terminating execution
使用system_printf会一次性打印一个内核的信息,不便于观察,我想使用printf(),请问是什么原因,谢谢!
