C6678 IPC Notify
您好:代码如下
void *threadFxn(void *arg);
void cbFxn(UInt16 procId, UInt16 lineId, UInt32 eventId, UArg arg, UInt32 payload) {
              Semaphore_post(semHandle);
void *tsk_func(void *arg)
    int status;
    if (MultiProc_self() == 0) {
               /*这里可以添加主核需要执行的任务代码*/
                  pthread_t thread;
                  pthread_attr_t attr;
                  size_t stacksize = 0x400000;//4MB
                  pthread_attr_init(&attr);
                  pthread_attr_setstacksize(&attr,stacksize);
                  if( pthread_create(&thread,&attr,threadFxn,NULL) )
                         thread = 0;
                         System_abort("create thread failed\n");
            /* Send an event to the next processor */
            status = Notify_sendEvent(1, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore1 failed\n");
            status = Notify_sendEvent(2, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore2 failed\n");
            status = Notify_sendEvent(3, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore3 failed\n");
            status = Notify_sendEvent(4, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore4 failed\n");
            status = Notify_sendEvent(5, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore5 failed\n");
            status = Notify_sendEvent(6, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore6 failed\n");
            status = Notify_sendEvent(7, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("Notify_sendEvent for slaveCore7 failed\n");
            /* Wait to be released by the cbFxn posting the semaphore */
            Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 主核等待从核完成其工作返回
            System_printf("MasterCore0 Received Event from All SloverCores\n");
 疑问:主核在等待从核完成任务的时候被挂起,再从核执行完之后,不是应该返回这里,但是核0并没有打印这条信息,而是直接进入创建的线程。
    else {
            /* wait forever on a semaphore, semaphore is posted in callback */
            Semaphore_pend(semHandle, BIOS_WAIT_FOREVER); // 等待主核通知开始执行任务
            System_printf("SlaverCore%d Received Event from MasterCore0\n", MultiProc_self());
疑问:为什么这里MultiProc_self()得到的是同一个核的ID,而不是执行这段代码的核的ID
            /*这里可以添加从核执行的任务*/
                  pthread_t thread;
                         thread = 0;
                         System_abort("create threadMain failed\n");
            status = Notify_sendEvent(0, 0, 10, NULL, TRUE);
            if (status < 0) {
                System_abort("sendEvent to MasterCore0 failed\n");
            System_printf("SlaverCore%d sent Event to MasterCore0 \n", MultiProc_self());
    return (void*)0;
    System_printf("Core%d enter thread\n", MultiProc_self());
    System_printf("Test over\n");
    BIOS_exit(0);
    return (void*)0;
int main()
    int status;
    status = Ipc_start();
    if (status < 0) {
        System_abort("Ipc_start failed\n");
    System_printf("Ipc_start successfully\n");
    pthread_t tsk;
    if(pthread_create(&tsk,&attr,tsk_func,NULL))
       tsk = 0;
       System_abort("create tsk failed\n");
    if(MultiProc_self() == 0)//0是主核,1-7是从核
           do{
                  status = Ipc_attach(1);
           }while(status < 0);// 完成从核1的连接
       do{
              status = Ipc_attach(2);
       }while(status < 0);// 完成从核2的连接
       do{
              status = Ipc_attach(3);
       }while(status < 0);// 完成从核3的连接
       do{
              status = Ipc_attach(4);
       }while(status < 0);// 完成从核4的连接
       do{
              status = Ipc_attach(5);
       }while(status < 0);// 完成从核5的连接
       do{
              status = Ipc_attach(6);
       }while(status < 0);// 完成从核6的连接
       do{
              status = Ipc_attach(7);
       }while(status < 0);// 完成从核7的连接
        status = Notify_registerEvent(1, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore1 failed\n");
        }// 完成从核1的事件注册
        status = Notify_registerEvent(2, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore2 failed\n");
        }// 完成从核2的事件注册
        status = Notify_registerEvent(3, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore3 failed\n");
        }// 完成从核3的事件注册
        status = Notify_registerEvent(4, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore4 failed\n");
        }// 完成从核4的事件注册
        status = Notify_registerEvent(5, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore5 failed\n");
        }// 完成从核5的事件注册
        status = Notify_registerEvent(6, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore6 failed\n");
        }// 完成从核6的事件注册
        status = Notify_registerEvent(7, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for slaveCore7 failed\n");
        }// 完成从核7的事件注册
        System_printf("Notify_registerEvent for slaveCores successfully\n");
    else{
           do{
                  status = Ipc_attach(0);
           }while(status < 0);// 完成主核0的连接
        status = Notify_registerEvent(0, 0, 10, (Notify_FnNotifyCbck)cbFxn, NULL);
        if (status < 0) {
            System_abort("Notify_registerEvent for masterCore0 failed\n");
        }// 完成主核0的事件注册
        System_printf("Notify_registerEvent for masterCore0 successfully\n");
    BIOS_start();
    return 0;
测试结果:
 [C66xx_7] Ipc_start successfully
SlaverCore4 Received Event from MasterCore0
SlaverCore7 sent Event to MasterCore0
Core7 enter thread
Test over
[C66xx_0] Ipc_start successfully
//这里不是应该再从核完成之后返回主核之后,打印一条信息,在进入创建的线程的吗
Core0 enter thread
Test over
[C66xx_1] Ipc_start successfully
SlaverCore1 sent Event to MasterCore0
Core1 enter thread
Test over
[C66xx_2] Ipc_start successfully
SlaverCore2 sent Event to MasterCore0
Core2 enter thread
Test over
[C66xx_3] Ipc_start successfully
SlaverCore3 sent Event to MasterCore0
Core3 enter thread
Test over
[C66xx_4] Ipc_start successfully
SlaverCore4 sent Event to MasterCore0
Core4 enter thread
Test over
[C66xx_5] Ipc_start successfully
SlaverCore5 sent Event to MasterCore0
Core5 enter thread
Test over
多次测试,也没有找出原因,希望得到您的帮助,另外请问这个测试代码写的有没有其他问题,谢谢!
  • 先只用两个核呢?如只有core0, core1 核间通信,看是否也有一样的问题。
  • 您好,core0和core1的测试情况是这样的:
     [C66xx_2] ti.sdo.ipc.family.c647x.MultiProcSetup: line 62: assertion failure: A_invalidProcessor: This core is not present in the MultiProc name list
    xdc.runtime.Error.raise: terminating execution
    [C66xx_3] ti.sdo.ipc.family.c647x.MultiProcSetup: line 62: assertion failure: A_invalidProcessor: This core is not present in the MultiProc name list
    [C66xx_4] ti.sdo.ipc.family.c647x.MultiProcSetup: line 62: assertion failure: A_invalidProcessor: This core is not present in the MultiProc name list
    [C66xx_5] ti.sdo.ipc.family.c647x.MultiProcSetup: line 62: assertion failure: A_invalidProcessor: This core is not present in the MultiProc name list
    [C66xx_6] ti.sdo.ipc.family.c647x.MultiProcSetup: line 62: assertion failure: A_invalidProcessor: This core is not present in the MultiProc name list
    [C66xx_7] ti.sdo.ipc.family.c647x.MultiProcSetup: line 62: assertion failure: A_invalidProcessor: This core is not present in the MultiProc name list
    Core0 enter thread
    Test over
    [C66xx_1] B13=0x0
    B14=0x920bbb4c B15=0x80400478
    B16=0x4 B17=0x0
    B18=0x3a B19=0x64
    B20=0x8 B21=0x0
    B22=0xffffffff B23=0x10000
    B24=0x20001210 B25=0x80002053
    B26=0x1001 B27=0x24204
    B28=0x220000 B29=0x42000048
    B30=0xc000600 B31=0x2
    NTSR=0x1000f
    ITSR=0x0
    IRP=0x0
    SSR=0x0
    AMR=0x0
    RILC=0x0
    ILC=0x0
    Exception at 0x0
    EFR=0x2 NRP=0x0
    Internal exception: IERR=0x1
    Instruction fetch exception
    ti.sysbios.family.c64p.Exception: line 256: E_exceptionMax: pc = 0x00000000, sp = 0x80400478.
