C6747的调试
TI工程师:
                你好,我使用的TMS320C6747的开发板,程序的自己写的,当在debug模式下进行调试时,点击暂停时,过=并不会马上停止,但过几秒后:会出现如下的错误:C674X_0: Trouble Halting Target CPU: (Error -1202 @ 0x0) Device core is hung. The debugger will attempt to force the device to a ready state to recover debug control. Your application's state will be corrupt. You should have limited access to memory and registers, but you may need to reset the device to debug further. (Emulation package 6.0.407.3) ;
并在单步运行时也会出现,请问这是有什么原因造成的呢
