请教一下,IPIPE 的resizer的缩放范围是多少?
缩放范围是1/16~16倍。见下面手册上的描述。
Programmable down or up-sampling filter for both horizontal and vertical directions with range from 1/16x to 16x, in which the filter outputs two images with different magnification simultaneously (Resizer module)
http://www.ti.com/lit/ug/sprugu5c/sprugu5c.pdf
