wpa_supplicant -i wlan0 -c /etc/wpa_supplicant.conf -B
RTL871X: [rtw_wx_set_pmkid] IW_PMKSA_FLUSH!
RTL871X: set_mode = IW_MODE_INFRA
RTL871X: wlan0Port-0 set opmode = 2
RTL871X: set bssid:00:00:00:00:00:00
ioctl[SIOCSIWAP]: Operation not permitted
/mnt/config/test # RTL871X: SetHwReg8188E:(HW_VAR_CHECK_TXBUF)TXBUF Empty(1) in 0 ms
RTL871X: survey done event(3c) band:0 for wlan0
RTL871X: rtw_indicate_scan_done(wlan0)
RTL871X: =>rtw_wx_set_essid
RTL871X: <=rtw_wx_set_essid, ret 0
RTL871X: wpa_set_auth_algs, AUTH_ALG_OPEN_SYSTEM
RTL871X:
wpa_ie(length:22):
RTL871X: 0x30 0x14 0x01 0x00 0x00 0x0f 0xac 0x02
RTL871X: 0x01 0x00 0x00 0x0f 0xac 0x04 0x01 0x00
RTL871X: 0x00 0x0f 0xac 0x02 0x00 0x00 0x00 0x00
RTL871X: SetHwReg8188E, 4804, RCR= 700060ca
RTL871X: rtw_wx_set_freq: set to channel 1
RTL871X: set bssid:b0:95:8e:e1:f8:8d
RTL871X: Set BSSID under fw_state=0x00000008
RTL871X: [by_bssid:1][assoc_ssid:][to_roam:0] new candidate: ucloudtech(b0:95:8e:e1:f8:8d, ch1) rssi:-58
RTL871X: rtw_select_and_join_from_scanned_queue: candidate: ucloudtech(b0:95:8e:e1:f8:8d, ch:1)
RTL871X: link to Ralink AP
RTL871X: [HT] HAL Support STBC = 0x01
RTL871X: [HT] Declare supporting RX STBC_1R
RTL871X: rtw_chk_start_clnt_join(wlan0) req: 1,1,1
RTL871X: rtw_chk_start_clnt_join(wlan0) union: 1,1,1
RTL871X: ssid=ucloudtech, len=10
RTL871X: set ssid [ucloudtech] fw_state=0x00000088
RTL871X: Set SSID under fw_state=0x00000088
RTL871X: OnBeacon: beacon keys ready
RTL871X: start auth
RTL871X: issue_auth
RTL871X: OnAuthClient
RTL871X: auth success, start assoc
RTL871X: network.SupportedRates[0]=82
RTL871X: network.SupportedRates[1]=84
RTL871X: network.SupportedRates[2]=8B
RTL871X: network.SupportedRates[3]=96
RTL871X: network.SupportedRates[4]=12
RTL871X: network.SupportedRates[5]=24
RTL871X: network.SupportedRates[6]=48
RTL871X: network.SupportedRates[7]=6C
RTL871X: network.SupportedRates[8]=0C
RTL871X: network.SupportedRates[9]=18
RTL871X: network.SupportedRates[10]=30
RTL871X: network.SupportedRates[11]=60
RTL871X: bssrate_len = 12
RTL871X: OnAssocRsp
RTL871X: report_join_res(2)
RTL871X: rtw_joinbss_update_network
RTL871X: +rtw_update_ht_cap()
RTL871X: rtw_alloc_macid(wlan0) if1, hwaddr:b0:95:8e:e1:f8:8d macid:0
RTL871X: rtw_joinbss_update_stainfo
RTL871X: supp_mcs_set = ff, 00, 00, rf_type=3, tx_ra_bitmap=00000000000fffff
RTL871X: ### Set STA_(0) info ###
RTL871X: rtw_cfg80211_indicate_connect(wlan0)
RTL871X: pwdev->sme_state(b)=0
RTL871X: pwdev->sme_state(a)=0
RTL871X: assoc success
RTL871X: HW_VAR_BASIC_RATE: 0x15f -> 0x15f -> 0x15f
RTL871X: WMM(0): 0, a42b
RTL871X: WMM(1): 0, a44f
RTL871X: WMM(2): 0, 5e4322
RTL871X: WMM(3): 0, 2f3222
RTL871X: wmm_para_seq(0): 0
RTL871X: wmm_para_seq(1): 1
RTL871X: wmm_para_seq(2): 2
RTL871X: wmm_para_seq(3): 3
RTL871X: HTOnAssocRsp
RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x00, WirelessMode:0x0b, rate_bitmap:0x000ff015
RTL871X: UpdateHalRAMask8188E => mac_id:0, rate_id:0, networkType:0x0b, mask:0x000fffff
==> rssi_level:0, rate_bitmap:0x000ff015
RTL871X: ### MacID(31),Set Max Tx RPT MID(32)
RTL871X: ### rtl8188e_set_FwMediaStatus_cmd: MStatus=1 MACID=0
RTL871X: SetHwReg8188E(wlan0): [HW_VAR_MACID_WAKEUP] macid=0, org reg_0x48c=0x00000000
RTL871X: rtl8188e_set_FwJoinBssReport_cmd mstatus(1)
RTL871X: rtw_hal_set_fw_rsvd_page wowlan_in_resume: 0
RTL871X: rtw_hal_set_fw_rsvd_page PageSize: 128, RsvdPageNUm: 8
RTL871X: LocPsPoll: 2
RTL871X: LocNullData: 3
RTL871X: LocQosNull: 4
RTL871X: rtw_hal_set_fw_rsvd_page: Set RSVD page location to Fw ,TotalPacketLen(570), TotalPageNum(5)
RTL871X: RsvdPageLoc: ProbeRsp=0 PsPoll=2 Null=3 QoSNull=4 BTNull=0
RTL871X: wlan0: 1 DL RSVD page success! DLBcnCount:1, poll:1
RTL871X: Set RSVD page location to Fw.
RTL871X: =>mlmeext_joinbss_event_callback - End to Connection without 4-way
RTL871X: recv eapol packet
RTL871X: ODM_Get_Rate_Bitmap ==> rssi_level:0x02, WirelessMode:0x0b, rate_bitmap:0x000ff000
==> rssi_level:2, rate_bitmap:0x000ff000
RTL871X: Group handshake still in progress !!!
RTL871X: rtw_tkip_decrypt(wlan0) no_gkey_bc_cnt:3, no_gkey_mc_cnt:0
RTL871X: OnDeAuth(wlan0) - Start to Disconnect
RTL871X: OnDeAuth(wlan0) reason=15, ta=b0:95:8e:e1:f8:8d, ignore=0
RTL871X: receive_disconnect
RTL871X: report_del_sta_event(wlan0) b0:95:8e:e1:f8:8d mac_id=0, enqueue:1, res:1
RTL871X: rtw_stadel_event_callback(mac_id=0)=b0:95:8e:e1:f8:8d
RTL871X: ### rtl8188e_set_FwMediaStatus_cmd: MStatus=0 MACID=0
RTL871X: ### Clean STA_(0) info ###
RTL871X: free disconnecting network
RTL871X: rtw_cfg80211_indicate_disconnect(wlan0)
RTL871X: rtw_reset_securitypriv(wlan0) - End to Disconnect
RTL871X: rtl8188e_set_FwJoinBssReport_cmd mstatus(0)
RTL871X: survey done event(4f) band:0 for wlan0
RTL871X:
wpa_ie(length:22):
RTL871X: start auth
RTL871X: issue_auth
RTL871X: OnAssocRsp
无法连接
