am3354 sd卡启动,不能识别nand ,调试打印 nand_get_flash_type,*maf_id is 0x0,dev_idis 0x0.
No NAND device found!
请问大神需要怎么修改的,谢谢。
mux.c 管脚配置, 管脚没有复用,
static struct module_pin_mux nand_pin_mux[] = {
{OFFSET(gpmc_ad0), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD0 */
{OFFSET(gpmc_ad1), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD1 */
{OFFSET(gpmc_ad2), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD2 */
{OFFSET(gpmc_ad3), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD3 */
{OFFSET(gpmc_ad4), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD4 */
{OFFSET(gpmc_ad5), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD5 */
{OFFSET(gpmc_ad6), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD6 */
{OFFSET(gpmc_ad7), (MODE(0) | PULLUP_EN | RXACTIVE)}, /* NAND AD7 */
{OFFSET(gpmc_wait0), (MODE(0) | RXACTIVE | PULLUP_EN)}, /* NAND WAIT */
{OFFSET(gpmc_wpn), (MODE(7) | PULLUP_EN | RXACTIVE)}, /* NAND_WPN */
{OFFSET(gpmc_csn0), (MODE(0) | PULLUDEN)}, /* NAND_CS0 */
{OFFSET(gpmc_advn_ale), (MODE(0) | PULLUDEN)}, /* NAND_ADV_ALE */
{OFFSET(gpmc_oen_ren), (MODE(0) | PULLUDEN)}, /* NAND_OE */
{OFFSET(gpmc_wen), (MODE(0) | PULLUDEN)}, /* NAND_WEN */
{OFFSET(gpmc_be0n_cle), (MODE(0) | PULLUDEN)}, /* NAND_BE_CLE */
{-1},
nandflash 型号 MT29F4G08ABADA
