关于EVMK2G(66AK2G02) rootfs移植到emmc出现的kernel halt的问题
你好,现在我手里面有一块EVMK2G的评估模块,由于这个评估模块官方提供的SDK不支持从emmc或者nand flash之类的存储器启动,现在我在做移植到emmc的工作。现在我已经完成了uboot,kernel的移植,但是在根文件系统启动的过程中,出现的下面的问题。希望能寻求帮助:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.41-gf9f6f0db2d (gtbldadm@ubuntu-16) (gcc version 5.3.1 27
[ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: Texas Instruments K2G General Purpose EVM
[ 0.000000] Switching physical address space to 0x800000000
[ 0.000000] Reserved memory: created DMA memory pool at 0x000000081d000000, size 40 MiB
[ 0.000000] Reserved memory: initialized node dsp_reserved_mpm_area, compatible id shal
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp_common_cma_pool, compatible id sharel
[ 0.000000] cma: Reserved 48 MiB at 0x000000087cc00000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] PERCPU: Embedded 11 pages/cpu @eedc8000 s14848 r8192 d22016 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 491840
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=PARTUUID=c9e378c3-02 rw rt
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 1888796K/1974272K available (6555K kernel code, 250K rwdata, 2320K)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08b3044 (8877 kB)
[ 0.000000] .init : 0xc08b4000 - 0xc08fc000 ( 288 kB)
[ 0.000000] .data : 0xc08fc000 - 0xc093aae0 ( 251 kB)
[ 0.000000] .bss : 0xc093c000 - 0xc0985f04 ( 296 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9s
[ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000024] Switching to timer-based delay loop, resolution 41ns
[ 0.000223] keystone_timer_init: failed to get clock
[ 0.000581] Console: colour dummy device 80x30
[ 0.000614] Calibrating delay loop (skipped), value calculated using timer frequency..)
[ 0.000636] pid_max: default: 32768 minimum: 301
[ 0.000787] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000805] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001692] Initializing cgroup subsys io
[ 0.001722] Initializing cgroup subsys memory
[ 0.001760] Initializing cgroup subsys devices
[ 0.001782] Initializing cgroup subsys freezer
[ 0.001801] Initializing cgroup subsys perf_event
[ 0.001819] Initializing cgroup subsys pids
[ 0.001858] CPU: Testing write buffer coherency: ok
[ 0.002194] /cpus/cpu@0 missing clock-frequency property
[ 0.002216] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002279] Setting up static identity map for 0x800082c0 - 0x800083f8
[ 0.050293] Brought up 1 CPUs
[ 0.050312] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.050326] CPU: All CPU(s) started in HYP mode.
[ 0.050336] CPU: Virtualization extensions available.
[ 0.050855] devtmpfs: initialized
[ 0.070267] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.070775] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_nss
[ 0.082024] pinctrl core: initialized pinctrl subsystem
[ 0.083430] NET: Registered protocol family 16
[ 0.084985] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.110214] cpuidle: using governor ladder
[ 0.140251] cpuidle: using governor menu
[ 0.147066] omap-gpmc 21818000.gpmc: could not find pctldev for node /soc/pinmux@02621e
[ 0.148895] genirq: Setting trigger mode 8 for irq 36 failed (gic_set_type+0x0/0x5c)
[ 0.152147] irq: no irq domain found for /soc/keystone_irq@026202a0 !
[ 0.169340] No ATAGs?
[ 0.169380] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.169396] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.247222] soc:usb-phy@0 supply vcc not found, using dummy regulator
[ 0.247564] soc:usb-phy@1 supply vcc not found, using dummy regulator
[ 0.248122] i2c_davinci 2530000.i2c: could not find pctldev for node /soc/pinmux@02621e
[ 0.248178] i2c_davinci 2530400.i2c: could not find pctldev for node /soc/pinmux@02621e
[ 0.248487] media: Linux media interface: v0.10
[ 0.248578] Linux video capture interface: v2.00
[ 0.248640] pps_core: LinuxPPS API ver. 1 registered
[ 0.248652] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giom>
[ 0.248690] PTP clock support registered
[ 0.248733] EDAC MC: Ver: 3.0.0
[ 0.251631] Advanced Linux Sound Architecture Driver Initialized.
[ 0.253075] clocksource: Switched to clocksource arch_sys_counter
[ 0.268338] NET: Registered protocol family 2
[ 0.269282] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.269390] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.269598] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.269685] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.269736] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.269983] NET: Registered protocol family 1
[ 0.283350] RPC: Registered named UNIX socket transport module.
[ 0.283367] RPC: Registered udp transport module.
[ 0.283379] RPC: Registered tcp transport module.
[ 0.283390] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.283752] Unpacking initramfs...
[ 0.283787] Freeing initrd memory: 4K (cffff000 - d0000000)
[ 0.284113] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters availae
[ 0.285571] platform alarmtimer: set dma_pfn_offset00780000
[ 0.286064] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.315365] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.333683] NFS: Registering the id_resolver key type
[ 0.333730] Key type id_resolver registered
[ 0.333743] Key type id_legacy registered
[ 0.333862] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.336512] bounce: pool size: 64 pages
[ 0.336778] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.336805] io scheduler noop registered
[ 0.336823] io scheduler deadline registered
[ 0.336880] io scheduler cfq registered (default)
[ 0.337320] keystone_irq soc:keystone_irq@026202a0: irqchip registered, nr_irqs 28
[ 0.339144] pinctrl-single 2621000.pinmux: 260 pins at pa f0854000 size 1040
[ 0.455662] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.455833] platform serial8250: set dma_pfn_offset00780000
[ 0.460934] [drm] Initialized drm 1.1.0 20060810
[ 0.462928] connector-hdmi connector: failed to find video source
[ 0.623953] loop: module loaded
[ 0.628119] platform Fixed MDIO bus.0: set dma_pfn_offset00780000
[ 0.628413] libphy: Fixed MDIO Bus: probed
[ 0.632076] mousedev: PS/2 mouse device common for all mice
[ 0.643445] i2c /dev entries driver
[ 0.645986] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.649759] platform snd-soc-dummy: set dma_pfn_offset00780000
[ 0.650869] clk: couldn't get parent clock 0 for /soc/mcasp@02344000
[ 0.652644] NET: Registered protocol family 10
[ 0.673521] sit: IPv6 over IPv4 tunneling driver
[ 0.674497] NET: Registered protocol family 17
[ 0.674901] Key type dns_resolver registered
[ 0.675139] Registering SWP/SWPB emulation handler
[ 0.699995] connector-hdmi connector: failed to find video source
[ 0.702572] ti-sci 2921c00.pmmc: ABI: 2.4 (firmware rev 0x0011 '0.1.1-37-g1e950 (Eagle)
[ 0.703882] ti-sci-clk soc:k2g_clks: initialized.
[ 0.711806] console [ttyS0] disabled
[ 0.711903] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 23, base_baud = 12000000) iA
[ 1.544595] console [ttyS0] enabled
[ 1.550253] 2531400.serial: ttyS2 at MMIO 0x2531400 (irq = 24, base_baud = 12000000) iA
[ 1.560648] omap_dss6 2540000.dss: bound 2550000.dispc (ops dispc6_component_ops)
[ 1.568481] platform omapdrm.0: set dma_pfn_offset00780000
[ 1.574626] connector-hdmi connector: failed to find video source
[ 1.582414] spi_davinci 21805800.spi: DMA is not supported (-19)
[ 1.589747] m25p80 spi32766.0: n25q128a13 (16384 Kbytes)
[ 1.595161] 2 ofpart partitions found on MTD device spi32766.0
[ 1.600987] Creating 2 MTD partitions on "spi32766.0":
[ 1.606154] 0x000000000000-0x000000100000 : "u-boot-spl"
[ 1.623999] 0x000000100000-0x000001000000 : "misc"
[ 1.643973] spi_davinci 21805800.spi: Controller at 0xf099e800
[ 1.693092] davinci_mdio 4200f00.mdio: davinci mdio revision 1.7
[ 1.699096] libphy: 4200f00.mdio: probed
[ 1.723621] davinci_mdio 4200f00.mdio: phy[0]: device 4200f00.mdio:00, driver Micrel KY
[ 1.775064] keystone timer clock @100000000 Hz
[ 1.783949] omap-gpmc 21818000.gpmc: GPMC revision 6.0
[ 1.790701] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.797175] nand: Micron MT29F2G16ABAFAWP
[ 1.801263] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 224
[ 1.809076] using OMAP_ECC_BCH16_CODE_HW ECC scheme
[ 1.814168] 3 ofpart partitions found on MTD device 30000000.nand
[ 1.820336] Creating 3 MTD partitions on "30000000.nand":
[ 1.826851] 0x000000000000-0x000000100000 : "u-boot"
[ 1.846506] 0x000000100000-0x000000180000 : "params"
[ 1.863537] 0x000000180000-0x000010000000 : "ubifs"
[ 1.868460] mmc0: MAN_BKOPS_EN bit is not set
[ 1.884027] mmc0: new high speed MMC card at address 0001
[ 1.923122] mmcblk0: mmc0:0001 S10016 14.6 GiB
[ 1.943124] mmcblk0boot0: mmc0:0001 S10016 partition 1 4.00 MiB
[ 1.963120] mmcblk0boot1: mmc0:0001 S10016 partition 2 4.00 MiB
[ 1.970173] mmcblk0: p1 p2
[ 2.146512] edma 2700000.edma: TI EDMA DMA engine driver
[ 2.152495] edma 2728000.edma: memcpy is disabled
[ 2.165294] edma 2728000.edma: TI EDMA DMA engine driver
[ 2.172486] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
[ 2.182139] sii9022 1-003b: SiI902xA HDMI device b0, rev 2, tpi 3
[ 2.189099] ti,keystone-serdes 2320000.phy: use default lane control-rate: 0
[ 2.196181] ti,keystone-serdes 2320000.phy: use default lane rx-start 0 0
[ 2.202963] ti,keystone-serdes 2320000.phy: use default lane rx-force 0 0
[ 2.209768] ti,keystone-serdes 2320000.phy: use default tx-coeff 0
[ 2.216283] ti,keystone-serdes 2320000.phy: Direct firmware load for ks2_pcie_serdes.b2
[ 2.226281] ti,keystone-serdes 2320000.phy: can't get any serdes init fw
[ 2.232978] ti,keystone-serdes 2320000.phy: serdes procider init failed -19
[ 2.242114] PCI host bridge /soc/pcie@21800000 ranges:
[ 2.247355] No bus range found for /soc/pcie@21800000, using [bus 00-ff]
[ 2.254285] IO 0x23250000..0x23253fff -> 0x00000000
[ 2.259435] MEM 0x70000000..0x7fffffff -> 0x70000000
[ 2.470701] keystone-pcie 21801000.pcie: phy link never came up
[ 2.476713] keystone-pcie 21801000.pcie: fatal error (status 0x00000010)
[ 2.483711] keystone-pcie 21801000.pcie: PCI host bridge to bus 0000:00
[ 2.490325] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.495838] pci_bus 0000:00: root bus resource [io 0x0000-0x3fff]
[ 2.502014] pci_bus 0000:00: root bus resource [mem 0x70000000-0x7fffffff]
[ 2.509433] PCI: bus0: Fast back to back transfers disabled
[ 2.515224] PCI: bus1: Fast back to back transfers enabled
[ 2.520827] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 2.526233] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.533914] keystone-navigator-qmss soc:qmss@4020000: qmgr start queue 0, number of qu8
[ 2.542694] keystone-navigator-qmss soc:qmss@4020000: added qmgr start queue 0, num of0
[ 2.563117] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 53 logical 2
[ 2.576037] netcp-1.0 2620110.netcp: ALE enabled
[ 2.581159] netcp-1.0 2620110.netcp: cpts: overflow check period 850
[ 2.587551] netcp-1.0 2620110.netcp: CPTS: ref_clk_freq:250000000 calc_mult:2147483648c
[ 2.598173] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.4
[ 2.604631] netcp-1.0 2620110.netcp: ALE Table size 64
[ 2.611166] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
[ 2.618182] netcp-1.0 2620110.netcp: module(netcp-pa) not used for device
[ 2.624995] netcp-1.0 2620110.netcp: module(netcp-pa2) not used for device
[ 2.631869] netcp-1.0 2620110.netcp: module(netcp-qos) not used for device
[ 2.638764] netcp-1.0 2620110.netcp: module(netcp-sa) not used for device
[ 2.646373] omap_hsmmc 23000000.mmc: Got CD GPIO
[ 2.690334] omapdrm omapdrm.0: DMM not available, disable DMM support
[ 2.700799] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 2.707518] [drm] No driver support for vblank timestamp query.
[ 2.713775] omapdrm omapdrm.0: No connectors reported connected with modes
[ 2.720686] [drm] Cannot find any crtc or sizes - going 1024x768
[ 2.738409] Console: switching to colour frame buffer device 128x48
[ 2.753298] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
[ 2.783167] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
[ 2.790444] hctosys: unable to open rtc device (rtc0)
[ 2.799074] ALSA device list:
[ 2.802044] No soundcards found.
[ 3.302002] mmc1: host does not support reading read-only switch, assuming write-enable
[ 3.312516] mmc1: new high speed SD card at address b368
[ 3.328717] mmcblk1: mmc1:b368 SD 1.91 GiB
[ 3.334871] mmcblk1: p1 p2
[ 3.749463] EXT4-fs (mmcblk0p2): recovery complete
[ 3.755228] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (nul)
[ 3.763397] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 3.769524] devtmpfs: mounted
[ 3.772794] Freeing unused kernel memory: 288K (c08b4000 - c08fc000)
[ 3.779176] This architecture does not have kernel memory protection.
[ 3.897743] systemd[1]: System time before build time, advancing clock.
[ 3.923598] random: systemd: uninitialized urandom read (16 bytes read, 25 bits of ent)
[ 3.937007] random: systemd: uninitialized urandom read (16 bytes read, 25 bits of ent)
[ 3.949771] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA)
[ 3.968560] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[ 3.994131] systemd[1]: Set hostname to <k2g-evm>.
[ 3.999274] random: systemd: uninitialized urandom read (16 bytes read, 25 bits of ent)
[ 4.008637] systemd[1]: Initializing machine ID from random generator.
[ 4.085716] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 26 bit)
[ 4.108696] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 26 bit)
[ 4.122483] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 26 bit)
[ 4.134736] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 27 bit)
[ 4.194206] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of ent)
[ 4.204662] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of ent)
[ 4.214688] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of ent)
[ 4.268249] random: nonblocking pool is initialized
[ 7.560815] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 7.583588] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 7.603403] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 7.633488] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 7.663557] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 7.704419] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 7.733515] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 7.763663] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 7.793439] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 7.814629] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 7.844746] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 7.874664] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 7.903607] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 7.933803] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 7.963328] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 7.983578] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 8.017766] systemd[1]: Starting Create list of required static device nodes for the c.
Starting Create list of required st... nodes for the current kernel...
[ 8.068282] systemd[1]: Mounting Debug File System...
[ 8.098923] systemd[1]: Starting Load Kernel Modules...
[ 8.147759] systemd[1]: Starting Setup Virtual Console...
[ 8.164283] NET: Registered protocol family 41
[ 8.192752] systemd[1]: Starting Journal Service...
[ 8.238268] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.282201] systemd[1]: Mounting Temporary Directory...
[ 8.342605] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 8.350040] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 8.417022] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.501193] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 8.523701] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 8.543553] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 8.565819] systemd[1]: Started Create list of required static device nodes for the cu.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ 8.606215] systemd[1]: Started Load Kernel Modules.
[ OK ] Started Load Kernel Modules.
[ 8.625708] systemd[1]: Started Setup Virtual Console.
[ OK ] Started Setup Virtual Console.
[ 8.655550] systemd[1]: Started Remount Root and Kernel File Systems.
[ OK ] Started Remount Root and Kernel File Systems.
[ 8.685651] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
Starting Flush Journal to Persistent Storage...
Starting Rebuild Hardware Database...
Starting Rebuild Dynamic Linker Cache...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
[FAILED] Failed to start Rebuild Dynamic Linker Cache.
See 'systemctl status ldconfig.service' for details.
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 9.644034] systemd-journald[99]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
Starting Rebuild Journal Catalog...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ OK ] Started Rebuild Journal Catalog.
Starting Network Time Synchronization...
Starting Opkg first boot configure...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Opkg first boot configure.
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Started Rebuild Hardware Database.
Starting udev Coldplug all Devices...
Starting Update is Completed...
[ OK ] Started Update is Completed.
[ 15.033518] ti-pruss 20a80000.pruss: creating PRU cores and other child platform devics
[ 15.088361] irq: no irq domain found for /soc/pruss@20a80000/intc@20aa0000 !
[ 15.187369] irq: no irq domain found for /soc/pruss@20a80000/intc@20aa0000 !
[ 15.257207] keystone-rproc 10800000.dsp0: assigned reserved memory node dsp_common_cmal
[ OK 15.330730] remoteproc0: 10800000.dsp0 is available
m] Started udev Coldplug all Devices.
[ 15.404850] remoteproc0: Note: remoteproc is still under development and considered e.
[ 15.490780] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compati.
[ OK ] Reached target System Initialization.
[ 15.584593] davinci-wdt 2250000.wdt: heartbeat 60 sec
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ 15.631982] ti-pruss 20ac0000.pruss: creating PRU cores and other child platform devics
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ 15.709533] irq: no irq domain found for /soc/pruss@20ac0000/intc@20ae0000 !
Starting tiipclad-daemon.service...
Starting telnetd.service...
[ 15.871067] irq: no irq domain found for /soc/pruss@20ac0000/intc@20ae0000 !
[ OK ] Started Kernel Logging Service.
[ 16.036848] remoteproc1: 20ab4000.pru0 is available
[ 16.041823] remoteproc1: Note: remoteproc is still under development and considered e.
[ OK ] Started System Logging Service.
Starting Permit User Sessions...
[ 16.262103] CAN device driver interface
[ 16.291790] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compati.
Starting Print notice about GPLv3 packages...
[ 16.424651] c_can_platform 260b200.can: c_can_platform device registered (regs=f144a20)
Starting Login Service...
[ 16.467279] remoteproc1: Direct firmware load for k2g-pru0_0-fw failed with error -2
[ 16.578872] remoteproc1: failed to load k2g-pru0_0-fw
[ 16.594412] c_can_platform 260b400.can: c_can_platform device registered (regs=f14c640)
[ OK ] Started D-Bus System Message Bus.
[ 16.646057] pru-rproc 20ab4000.pru0: booting the PRU core manually
[ 16.652245] remoteproc1: powering up 20ab4000.pru0
[ 16.792843] remoteproc1: Direct firmware load for k2g-pru0_0-fw failed with error -2
[ 16.893013] remoteproc1: request_firmware failed: -2
[ 16.950909] pru-rproc 20ab4000.pru0: rproc_boot failed
[ 17.009649] remoteproc1: releasing 20ab4000.pru0
[ 17.058115] pru-rproc: probe of 20ab4000.pru0 failed with error -2
[ 17.109671] remoteproc1: 20ab8000.pru1 is available
[ 17.231272] remoteproc1: Note: remoteproc is still under development and considered e.
[ 17.338288] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compati.
Starting Network Service...
[ OK ] Started tiipclad-daemon.service.
[ OK ] Started telnetd.service.
[ 17.475116] remoteproc1: Direct firmware load for k2g-pru0_1-fw failed with error -2
[ 17.482955] remoteproc1: failed to load k2g-pru0_1-fw
[ OK ] Started Permit User Sessions.
[ 17.607987] pru-rproc 20ab8000.pru1: booting the PRU core manually
[ 17.683174] remoteproc1: powering up 20ab8000.pru1
[ 17.688116] remoteproc1: Direct firmware load for k2g-pru0_1-fw failed with error -2
[ 17.870629] remoteproc1: request_firmware failed: -2
[ 17.933906] pru-rproc 20ab8000.pru1: rproc_boot failed
[ 17.939157] remoteproc1: releasing 20ab8000.pru1
[ OK ] Started Network Service.
[ 18.044217] netcp-1.0 2620110.netcp eth0: Link is Down
[ 18.093389] pru-rproc: probe of 20ab8000.pru1 failed with error -2
[ 18.100038] remoteproc1: 20af4000.pru0 is available
[ 18.115475] pps pps0: new PPS source ptp0
[ 18.120315] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 18.244399] remoteproc1: Note: remoteproc is still under development and considered e.
[ OK ] Started Print notice about GPLv3 packages.
[ 18.343035] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compati.
[ 18.484939] remoteproc1: Direct firmware load for k2g-pru1_0-fw failed with error -2
[ 18.492780] remoteproc1: failed to load k2g-pru1_0-fw
[ 18.612810] pru-rproc 20af4000.pru0: booting the PRU core manually
[ 18.654313] remoteproc1: powering up 20af4000.pru0
[ 18.688683] cadence-qspi 2940000.qspi: s25fl512s (65536 Kbytes)
[ 18.706528] remoteproc1: Direct firmware load for k2g-pru1_0-fw failed with error -2
[ 18.763376] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be co.
[ 18.779870] 7 ofpart partitions found on MTD device 2940000.qspi
[ 18.808426] EXT4-fs (mmcblk1p2): mounting ext3 file system using the ext4 subsystem
[ 18.822938] remoteproc1: request_firmware failed: -2
[ 18.865266] Creating 7 MTD partitions on "2940000.qspi":
[ 18.870588] 0x000000000000-0x000000100000 : "QSPI.u-boot"
[ 18.887907] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be co.
[ 18.912350] pru-rproc 20af4000.pru0: rproc_boot failed
[ 18.963374] remoteproc1: releasing 20af4000.pru0
[ 19.012025] 0x000000100000-0x000000140000 : "QSPI.u-boot-env"
[ 19.024774] pru-rproc: probe of 20af4000.pru0 failed with error -2
[ 19.111671] remoteproc1: 20af8000.pru1 is available
[ 19.122317] 0x000000140000-0x000000180000 : "QSPI.skern"
[ 19.164683] remoteproc1: Note: remoteproc is still under development and considered e.
[ 19.193017] 0x000000180000-0x0000001c0000 : "QSPI.pmmc-firmware"
[ 19.287898] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compati.
[ 19.301168] 0x0000001c0000-0x0000009c0000 : "QSPI.kernel"
[ 19.352918] 0x0000009c0000-0x000000a00000 : "QSPI.u-boot-spl-os"
[ 19.403435] remoteproc1: Direct firmware load for k2g-pru1_1-fw failed with error -2
[ 19.451804] 0x000000a00000-0x000004000000 : "QSPI.file-system"
[ 19.460216] remoteproc1: failed to load k2g-pru1_1-fw
[ 19.534487] pru-rproc 20af8000.pru1: booting the PRU core manually
[ 19.540676] remoteproc1: powering up 20af8000.pru1
[ OK ] Found device /dev/ttyS0.
[ 19.565180] keystone-dsp-mem 9d000000.dspmem: registered misc device dspmem
[ 19.623653] remoteproc1: Direct firmware load for k2g-pru1_1-fw failed with error -2
[ 19.631489] remoteproc1: request_firmware failed: -2
[ 19.711154] pru-rproc 20af8000.pru1: rproc_boot failed
[ 19.819047] remoteproc1: releasing 20af8000.pru1
[ 19.879619] pru-rproc: probe of 20af8000.pru1 failed with error -2
[ 20.334703] asoc-simple-card sound@0: tlv320aic3x-hifi <-> 2344000.mcasp mapping ok
[ 20.385340] asoc-simple-card sound@0: hdmi-hifi <-> 2344000.mcasp mapping ok
[ 21.043924] netcp-1.0 2620110.netcp eth0: Link is Up - 100Mbps/Full - flow control rx/x
[ 21.052164] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 22.662939] EXT4-fs (mmcblk1p2): recovery complete
[ 22.686670] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (nul)
[ 24.532039] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
[** ] (1 of 2) A start job is running for dev-ttyO0.device (17s / 1min 30s)[ 25.0069s
[ 25.023250] usbcore: registered new interface driver hub
[ 25.036960] usbcore: registered new device driver usb
[ 25.066611] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 25.072147] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 25.104128] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f66d hci version 0x100 quirks 00
[ 25.112861] xhci-hcd xhci-hcd.0.auto: irq 28, io mem 0x02690000
[ 25.147445] hub 1-0:1.0: USB hub found
[ 25.151357] hub 1-0:1.0: 1 port detected
[ 25.173949] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 25.179460] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 25.203336] usb usb2: We don't know the algorithms for LPM for this host, disabling LP.
[ 25.226485] hub 2-0:1.0: USB hub found
[ 25.230313] hub 2-0:1.0: 1 port detected
[ OK ] Started Login Service.
[ OK ] Reached target Sound Card.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS0.
Starting thttpd.service...
[ OK ] Started Network Name Resolution.
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Serial Getty on ttyS0.
[ TIME ] Timed out waiting for device dev-ttyO0.device.
[DEPEND] Dependency failed for Serial Getty on ttyO0.
[ OK ] Reached target Login Prompts.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
内核在Started Update UTMP about System Runlevel Changes.这句话打印后挂掉,我之前怀疑前面的ttyX设备的进程调用超时导致的,但是如果串口设备调用失败的话,后面的话是打印不出来的,现在不能确定具体原因,根文件系统我用的是sdk中的arago-base-tisdk-image。请问现在我的问题是出现在哪里。
  • 你好,请问你怎样实现的EMMC启动?uboot做了哪些修改,怎样烧录到emmc的?
    我使用开发套件中的Uboot,将MLO和u-boot.img拷贝到emmc中,拨码开关调到EMMC启动,结果板子启动不了。希望得到回复,谢谢!
