我想对一个浮点数矩阵做傅里叶变换,
fft_plan_t fft_sp_plan_2d_r2c ( int N1, /* FFT size */ int N2, /* FFT size */ int mode, /* FFT_DIRECT or FFT_ECPY */ fft_callout_t fxns );
int fft_sp_2d_r2c_ecpy ( /* int N1; FFT size */ /* int N2; FFT size */ /* fft_para_mix_bs_t para1; */ /* fft_para_mix_bs_t para2; */ /* float *data; input/output pointer */ /* float *workbuf; working pointer */ /* float *workbuf_w; working buffer pointer */ /* float *workbuf_t; working buffer pointer */ /* float *tw; twiddle pointer */ /* float *tw_w; twiddle buffer pointer */ /* float *Bn; Bluestein pointer */ /* float *Bn_w; Bluestein buffer pointer */ /* float *workbuf_bn; Bluestein scratch pointer */ fft_param_u u, void *edmaState );
这两个函数怎样调用
