各位技术支持:
我这里遇到一个问题:打印信息如下:
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.28-geed43d1050 (linux@ubuntu) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #10 PREEMPT Mon Sep 4 08:00:15 PDT 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: TI AM335x EVM-SK
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x8a800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64960
[ 0.000000] Kernel command line: console=ttyO0,115200 ip=192.168.1.199:192.168.175:192.168.1.1:255.255.255.0::eth0:off root=/dev/nfs rw nfsroot=192.168.1.175:/source/rootfs
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 198324K/262144K available (7168K kernel code, 279K rwdata, 2348K rodata, 1024K init, 272K bss, 14668K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0800000 (8160 kB)
[ 0.000000] .init : 0xc0b00000 - 0xc0c00000 (1024 kB)
[ 0.000000] .data : 0xc0c00000 - 0xc0c45f10 ( 280 kB)
[ 0.000000] .bss : 0xc0c45f10 - 0xc0c8a1b4 ( 273 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000033] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000043] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000203] clocksource_probe: no matching clocksources found
[ 0.000370] Console: colour dummy device 80x30
[ 0.000396] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.000402] This ensures that you still see kernel messages. Please
[ 0.000407] update your kernel commandline.
[ 0.000429] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736)
[ 0.089222] pid_max: default: 32768 minimum: 301
[ 0.089343] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089353] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090098] CPU: Testing write buffer coherency: ok
[ 0.090476] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.091265] EFI services will not be available.
[ 0.092417] devtmpfs: initialized
[ 0.103141] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.103463] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.103488] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.106981] pinctrl core: initialized pinctrl subsystem
[ 0.108182] NET: Registered protocol family 16
[ 0.110100] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.123264] omap_hwmod: debugss: _wait_target_disable failed
[ 0.199213] cpuidle: using governor ladder
[ 0.229201] cpuidle: using governor menu
[ 0.234658] OMAP GPIO hardware version 0.1
[ 0.248924] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.286523] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.287364] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe
[ 0.290415] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.290563] media: Linux media interface: v0.10
[ 0.290615] Linux video capture interface: v2.00
[ 0.290655] pps_core: LinuxPPS API ver. 1 registered
[ 0.290661] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.290684] PTP clock support registered
[ 0.290719] EDAC MC: Ver: 3.0.0
[ 0.291744] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.292065] Advanced Linux Sound Architecture Driver Initialized.
[ 0.293197] clocksource: Switched to clocksource timer1
[ 0.302499] NET: Registered protocol family 2
[ 0.303297] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.303329] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.303355] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.303427] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.303444] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.303574] NET: Registered protocol family 1
[ 0.303998] RPC: Registered named UNIX socket transport module.
[ 0.304011] RPC: Registered udp transport module.
[ 0.304017] RPC: Registered tcp transport module.
[ 0.304022] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.304924] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.307092] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[ 0.314037] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.314912] NFS: Registering the id_resolver key type
[ 0.314957] Key type id_resolver registered
[ 0.314964] Key type id_legacy registered
[ 0.315006] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.316779] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.316799] io scheduler noop registered
[ 0.316806] io scheduler deadline registered
[ 0.316948] io scheduler cfq registered (default)
[ 0.317834] pinctrl-single 44e10800.pinmux: please update dts to use #pinctrl-cells = <1>
[ 0.318283] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.321174] backlight supply power not found, using dummy regulator
[ 0.375183] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.378869] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.990946] console [ttyS0] enabled
[ 0.996212] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.002990] [drm] Initialized
[ 1.007041] panel panel: found backlight
[ 1.011867] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.018592] [drm] No driver support for vblank timestamp query.
[ 1.047957] Console: switching to colour frame buffer device 60x34
[ 1.055874] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.096217] brd: module loaded
[ 1.105508] loop: module loaded
[ 1.110832] libphy: Fixed MDIO Bus: probed
[ 1.183235] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.189400] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[ 1.196935] libphy: 4a101000.mdio: probed
[ 1.200977] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet
[ 1.210358] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet
[ 1.220371] cpsw 4a100000.ethernet: Detected MACID = c4:ed:ba:8b:76:95
[ 1.227302] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[ 1.235610] cpsw 4a100000.ethernet: cpsw: Detected MACID = c4:ed:ba:8b:76:97
[ 1.244181] mousedev: PS/2 mouse device common for all mice
[ 1.250126] i2c /dev entries driver
[ 1.255410] cpuidle: enable-method property 'ti,am3352' found operations
[ 1.263119] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.324625] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.333650] NET: Registered protocol family 10
[ 1.339505] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.346339] NET: Registered protocol family 17
[ 1.351194] Key type dns_resolver registered
[ 1.355814] omap_voltage_late_init: Voltage driver support not added
[ 1.393407] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.401154] vrtc: supplied by vbat
[ 1.408333] vio: supplied by vbat
[ 1.413117] vdd1: supplied by vbat
[ 1.418347] vdd2: supplied by vbat
[ 1.423208] random: fast init done
[ 1.428268] vdig1: supplied by vbat
[ 1.433088] vdig2: supplied by vbat
[ 1.437963] vpll: supplied by vbat
[ 1.442695] vdac: supplied by vbat
[ 1.447504] vaux1: supplied by vbat
[ 1.452332] vaux2: supplied by vbat
[ 1.457232] vaux33: supplied by vbat
[ 1.462159] vmmc: supplied by vbat
[ 1.466927] vbb: supplied by vbat
[ 1.471744] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.479163] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 1.652695] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.664079] mmc0: new high speed SDHC card at address aaaa
[ 1.670535] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
[ 1.676997] mmcblk0: p1 p2 p3
[ 1.695078] input: gpio_buttons0 as /devices/platform/gpio_buttons0/input/input0
[ 1.706413] hctosys: unable to open rtc device (rtc0)
[ 1.726390] net eth0: initializing cpsw version 1.12 (0)
[ 1.731814] net eth0: initialized cpsw ale version 1.4
[ 1.737139] net eth0: ALE Table size 1024
[ 1.844174] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=-1)
[ 1.864648] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.924399] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[ 3.933330] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 3.963291] IP-Config: Complete:
[ 3.966576] device=eth0, hwaddr=c4:ed:ba:8b:76:95, ipaddr=192.168.1.199, mask=255.255.255.0, gw=192.168.1.1
[ 3.977225] host=192.168.1.199, domain=, nis-domain=(none)
[ 3.983258] bootserver=192.168.175.0, rootserver=192.168.1.175, rootpath=
[ 3.991320] lis3_reg: disabling
[ 3.994680] vwl1271: disabling
[ 3.998146] ALSA device list:
[ 4.001150] No soundcards found.
[ 4.151278] VFS: Mounted root (nfs filesystem) on device 0:15.
[ 4.158288] devtmpfs: mounted
[ 4.165400] Freeing unused kernel memory: 1024K (c0b00000 - c0c00000)
[ 4.924685] systemd[1]: System time before build time, advancing clock.
[ 5.073952] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.087718] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.135585] systemd[1]: systemd 230 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 5.154709] systemd[1]: Detected architecture arm.
Welcome to Arago 2017.05!
[ 5.196152] systemd[1]: Set hostname to <am335x-evm>.
[ 5.773458] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.789063] systemd[1]: Configuration file /lib/systemd/system/remote-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.818162] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.832912] systemd[1]: Configuration file /lib/systemd/system/shutdown.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.851449] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 5.866615] systemd[1]: Configuration file /lib/systemd/system/remote-fs-pre.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ 5.887289] systemd[1]: Configuration file /lib/systemd/system/-.slice is marked executable. Please remove executable permission bits. Proceeding anyway.
[ SKIP ] Ordering cycle found, skipping alignment.service
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Created slice User and Session Slice.
[ OK ] Reached target Swap.
[ OK ] Listening on Journal Socket.
[ OK ] Listening on udev Kernel Socket.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Created slice System Slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Remount Root and Kernel File Systems...
Starting Load Kernel Modules...
[ OK ] Created slice system-getty.slice.
Mounting Debug File System...
Mounting Temporary Directory...
[ OK ] Reached target Slices.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ OK ] Reached target Paths.
[ 7.066330] cryptodev: loading out-of-tree module taints kernel.
[ 7.081488] cryptodev: driver 1.8 loaded.
Mounting POSIX Message Queue File System...
[ OK ] Listening on Syslog Socket.
[ OK ] Listening on Network Service Netlink Socket.
Starting Create Static Device Nodes in /dev...
[ OK ] Reached target Remote File Systems.
[ OK ] Listening on Journal Socket (/dev/log).
Starting Setup Virtual Console...
Starting Journal Service...
[ OK ] Listening on udev Control Socket.
[ OK ] Mounted Debug File System.
[ OK ] Mounted POSIX Message Queue File System.
[ OK ] Mounted Temporary Directory.
[ 7.579193] systemd-journald[101]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[ OK ] Started Remount Root and Kernel File Systems.[ 7.600908] systemd-journald[101]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create Static Device Nodes in /dev.
Starting udev Kernel Device Manager...
Mounting Configuration File System...
Starting Apply Kernel Variables...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Coldplug all Devices...
[ 8.070517] random: crng init done
[ OK ] Mounted Configuration File System.
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started Journal Service.
[ OK ] Started Apply Kernel Variables.
Starting Flush Journal to Persistent Storage...
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Load/Save Random Seed.
[ 8.675549] systemd-journald[101]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
Starting Create Volatile Files and Directories...
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
Starting Synchronize System and HW clocks...
[ OK ] Reached target System Time Synchronized.
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Created slice system-systemd\x2dbacklight.slice.
[ 10.580193] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
Starting Load/Save Screen Backlight...htness of backlight:backlight...
[ OK ] Found device /dev/ttyS0.
[ OK ] Started udev Coldplug all Devices.
[ 10.770731] omap_rtc 44e3e000.rtc: already running
[ 10.830973] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started System Logging Service.
Starting Telephony service...
Starting uim-sysfs.service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started D-Bus System Message Bus.
[ 12.126716] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 12.263682] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 12.379929] omap-aes 53500000.aes: will run requests pump with realtime priority
[ 12.560413] [drm] Initialized pvr 1.14.3699939 20110701 on minor 1
[ 12.734696] remoteproc remoteproc0: wkup_m3 is available
[ 12.741438] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[ 12.764585] PM: Cannot get wkup_m3_ipc handle
[ 13.017427] PM: Cannot get wkup_m3_ipc handle
[ 13.022266] remoteproc remoteproc0: powering up wkup_m3
[ 13.246392] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224344
[ 13.281784] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok
[ 13.309966] PM: Cannot get wkup_m3_ipc handle
[ 13.458124] remoteproc remoteproc0: remote processor wkup_m3 is now up
[ 13.458148] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ OK ] Started Telephony service.
Starting Network Service...
[ 14.551246] Bluetooth: Core ver 2.22
[ 14.660555] NET: Registered protocol family 31
Starting Login Service...
Starting Print notice about GPLv3 packages...
[ 14.775019] Bluetooth: HCI device and connection manager initialized
[ OK ] Started Kernel Logging Service.
[ 14.916245] Bluetooth: HCI socket layer initialized
[ 15.029733] Bluetooth: L2CAP socket layer initialized
[ 15.170756] Bluetooth: SCO socket layer initialized
[ OK ] Found device /dev/ttyS3.
[ OK ] Started Network Service.
[ 17.100740] EXT4-fs (mmcblk0p3): mounting ext3 file system using the ext4 subsystem
[ 17.123759] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 17.185425] EXT4-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
[ 17.188347] EXT4-fs (mmcblk0p2): recovery complete
[ 17.188370] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 17.537682] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 17.898512] EXT4-fs (mmcblk0p3): warning: maximal mount count reached, running e2fsck is recommended
[ 18.035534] EXT4-fs (mmcblk0p3): recovery complete
[ 18.104397] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Found device /dev/mmcblk0p1.
[ OK ] Started Login Service.
[ 21.859266] TI-am335x-tsc TI-am335x-tsc: ti,charge-delay not specified
[ 21.944514] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/TI-am335x-tsc/input/input1
[ 22.045188] PM: bootloader does not support rtc-only!
[ 23.385424] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 23.512971] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 23.535392] usbcore: registered new interface driver usbfs
[ 23.535458] usbcore: registered new interface driver hub
[ 23.535755] usbcore: registered new device driver usb
[ 23.884305] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 23.889699] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[ 24.055325] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 24.056864] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 !
[ 24.087943] irq: no irq domain found for /ocp/pruss_soc_bus@4a326000/pruss@4a300000/intc@4a320000 !
[ 24.402004] hub 1-0:1.0: USB hub found
[ 24.459767] hub 1-0:1.0: 1 port detected
[ 24.625879] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 24.631269] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
[ 24.675372] remoteproc remoteproc1: 4a334000.pru0 is available
[ 24.675468] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a334000 probed successfully
[ 24.693553] remoteproc remoteproc2: 4a338000.pru1 is available
[ 24.693635] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss_soc_bus@4a326000/pruss@4a300000/pru@4a338000 probed successfully
[ 25.041666] hub 2-0:1.0: USB hub found
[ 25.067945] hub 2-0:1.0: 1 port detected
[ OK ] Started uim-sysfs.service.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
libreadline-dev
libreadline6
m4-dev
m4
make
nettle
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Reached target Sound Card.
Starting rc.pvr.service...
Starting Start USB gadget...
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting Enable and configure wl18xx bluetooth stack...
[ 31.327331] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
Starting Lightning Fast Webserver With Light System Requirements...
Starting Simple Network Management Protocol (SNMP) Daemon....
Starting Permit User Sessions...
[ 31.744256] using random self ethernet address
[ 31.791452] using random host ethernet address
[ OK ] [ 31.855990] using host ethernet address: C4:ED:BA:8B:76:97Started Permit User Sessions.
[ 31.924254] using random self ethernet address
[ 31.924260] using random host ethernet address
[ 31.924275] using host ethernet address: C4:ED:BA:8B:76:97
[ 31.936687] usb0: HOST MAC c4:ed:ba:8b:76:97
[ 31.937384] usb0: MAC f6:64:bb:d8:26:d8
[ OK ] Started Getty on tty1.
[ 32.302171] Mass Storage Function, version: 2009/09/11
[ 32.331421] LUN: removable file: (no medium)
[ 32.344318] LUN: removable read only file: /dev/mmcblk0p1
[ 32.344327] Number of LUNs=1
[ 32.346219] g_multi gadget: Multifunction Composite Gadget
[ 32.346229] g_multi gadget: g_multi ready
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Started Network Name Resolution.
[ OK ] Started rc.pvr.service.
[ OK ] Started Enable and configure wl18xx bluetooth stack.
[ 32.785935] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Found device /dev/ttyGS0.
[ 33.035969] NET: Registered protocol family 15
Starting weston.service...
[ OK ] Started weston.service.
Starting telnetd.service...
[ OK ] Started Start USB gadget.
[ OK ] Started Serial Getty on ttyGS0.
[ OK ] Reached target Login Prompts.
[ OK ] Started telnetd.service.
[ 33.998580] Initializing XFRM netlink socket
Starting busybox-udhcpd.service...
Starting thttpd.service...
[ OK ] Started busybox-udhcpd.service.
[ OK ] Started thttpd.service.
Starting rng-tools.service...
[ OK ] Started Simple Network Management Protocol (SNMP) Daemon..
[ OK ] Started rng-tools.service.
Starting SYSV: The kdump script provides the support:...
[FAILED] Failed to start SYSV: The kdump script provides the support:.
See 'systemctl status kdump.service' for details.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting parse-ip.service...
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ OK ] Started parse-ip.service.
[ OK ] Reached target Multi-User System.
Starting Update UTMP about System Runlevel Changes...
[ OK ] Started Update UTMP about System Runlevel Changes.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS0
Arago 2017.05 am335x-evm ttyS0
am335x-evm login: root
Login incorrect
am335x-evm login: ^C
_____ _____ _ _
|___| |___|
am335x-evm login:
我这里使用的是AM335X starter kit板子,用的最新的SDK,现在uboot和kernel编译后,下载到板子运行,能够正常登陆,如果我重新编译一下kernel后,再次启动的时候就提示我做标记的地方,导致登陆的时候一直提示Login incorrect,文件系统我是通过nfs挂载的方式。不知道这个问题怎么解决。。。各位高手支招,谢谢!
