6657 spi加载
请问在SPI往NOR flash烧写,进行到把生成的.dat文件往0x80000000"load memory",然后首地址填0x80000000,请问字符长度填多少?
  • 打开.dat文件, 第一行信息里的最后一个参数是dat文件的数据长度。下面是dat文件第一行信息的解释。
    The header information for data files uses this syntax:
    MagicNumber  Format StartingAddress PageNum Length
    • MagicNumber—fixed at 1651.
    • Format—a number from 1 to 4, indicating the format of the samples in the file.
      This number represents a data format: (1) hexadecimal, (2) integer, (3) long, or (4) float.
    • StartingAddress—starting address of the block that was saved.
    • PageNum—page number the block was taken from.
