OMAPL138 Device Tree无法启动 “Uncompressing Linux... done, booting the kernel.”
Other Parts Discussed in Thread: OMAP-L138, TLV320AIC3106, TCA6416
大家好,我使用的是da850-evm.dts,sdk版本为ti-processor-sdk-linux-omapl138-lcdk-04.00.00.04,编译下载后发现内核启动不了,如下:
## Flattened Device Tree blob at c0700000
Booting using the fdt blob at 0xc0700000
Loading Device Tree to c3e10000, end c3e15f2f ... OK
Starting kernel ...
然后就没有了,但是我直接启动内核(直接bootz内核,不使用dtb)缺可以启动,请问是什么情况?
我的dts文件如下:
/dts-v1/;
#include "da850.dtsi"
#include <dt-bindings/gpio/gpio.h>
/*compatible = "ti,da850-evm", "ti,da850";
compatible = "ti,omapl138-evm", "ti,omapl138";*/
model = "DaVinci DA850/OMAP-L138/AM18x EVM";
soc@1c00000 {
pmx_core: pinmux@14120 {
status = "okay";
mcasp0_pins: pinmux_mcasp0_pins {
pinctrl-single,bits = <
* AHCLKX, ACLKX, AFSX, AHCLKR, ACLKR,
* AFSR, AMUTE
0x00 0x11111111 0xffffffff
/* AXR11, AXR12 */
0x04 0x00011000 0x000ff000
nand_pins: nand_pins {
/* EMA_WAIT[0], EMA_OE, EMA_WE, EMA_CS[4], EMA_CS[3] */
0x1c 0x10110110 0xf0ff0ff0
* EMA_D[0], EMA_D[1], EMA_D[2],
* EMA_D[3], EMA_D[4], EMA_D[5],
* EMA_D[6], EMA_D[7]
0x24 0x11111111 0xffffffff
/* EMA_A[1], EMA_A[2] */
0x30 0x01100000 0x0ff00000
serial0: serial@42000 {
status = "okay";
serial1: serial@10c000 {
status = "okay";
serial2: serial@10d000 {
status = "okay";
rtc0: rtc@23000 {
status = "okay";
i2c0: i2c@22000 {
status = "okay";
clock-frequency = <100000>;
pinctrl-names = "default";
pinctrl-0 = <&i2c0_pins>;
tps: tps@48 {
reg = <0x48>;
tlv320aic3106: tlv320aic3106@18 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x18>;
status = "okay";
/* Regulators */
IOVDD-supply = <&vdcdc2_reg>;
/* Derived from VBAT: Baseboard 3.3V / 1.8V */
AVDD-supply = <&vbat>;
DRVDD-supply = <&vbat>;
DVDD-supply = <&vbat>;
tca6416: gpio@20 {
compatible = "ti,tca6416";
reg = <0x20>;
wdt: wdt@21000 {
status = "okay";
mmc0: mmc@40000 {
max-frequency = <50000000>;
bus-width = <4>;
status = "okay";
pinctrl-0 = <&mmc0_pins>;
spi1: spi@30e000 {
status = "okay";
pinctrl-0 = <&spi1_pins &spi1_cs0_pin>;
/*flash: m25p80@0 {
#address-cells = <1>;
#size-cells = <1>;
compatible = "m25p64";
spi-max-frequency = <30000000>;
m25p,fast-read;
reg = <0>;
partition@0 {
label = "U-Boot-SPL";
reg = <0x00000000 0x00010000>;
read-only;
partition@1 {
label = "U-Boot";
reg = <0x00010000 0x00080000>;
read-only;
partition@2 {
label = "U-Boot-Env";
reg = <0x00090000 0x00010000>;
read-only;
partition@3 {
label = "Kernel";
reg = <0x000a0000 0x00280000>;
partition@4 {
label = "Filesystem";
reg = <0x00320000 0x00400000>;
partition@5 {
label = "MAC-Address";
reg = <0x007f0000 0x00010000>;
read-only;
mdio: mdio@224000 {
status = "okay";
pinctrl-0 = <&mdio_pins>;
bus_freq = <2200000>;
eth0: ethernet@220000 {
status = "okay";
pinctrl-0 = <&mii_pins>;
gpio: gpio@226000 {
status = "okay";
vbat: fixedregulator0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
/*sound {
compatible = "simple-audio-card";
simple-audio-card,name = "DA850/OMAP-L138 EVM";
simple-audio-card,widgets =
"Line", "Line In",
"Line", "Line Out";
simple-audio-card,routing =
"LINE1L", "Line In",
"LINE1R", "Line In",
"Line Out", "LLOUT",
"Line Out", "RLOUT";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&link0_codec>;
simple-audio-card,frame-master = <&link0_codec>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp0>;
system-clock-frequency = <24576000>;
link0_codec: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
};*//*Zoick*/
/include/ "tps6507x.dtsi"
&tps {
vdcdc1_2-supply = <&vbat>;
vdcdc3-supply = <&vbat>;
vldo1_2-supply = <&vbat>;
regulators {
vdcdc1_reg: regulator@0 {
regulator-name = "VDCDC1_3.3V";
regulator-min-microvolt = <3150000>;
regulator-max-microvolt = <3450000>;
regulator-always-on;
regulator-boot-on;
vdcdc2_reg: regulator@1 {
regulator-name = "VDCDC2_3.3V";
regulator-min-microvolt = <1710000>;
regulator-boot-on;
ti,defdcdc_default = <1>;
vdcdc3_reg: regulator@2 {
regulator-name = "VDCDC3_1.2V";
regulator-min-microvolt = <950000>;
regulator-max-microvolt = <1350000>;
regulator-boot-on;
ldo1_reg: regulator@3 {
regulator-name = "LDO1_1.8V";
regulator-max-microvolt = <1890000>;
regulator-boot-on;
ldo2_reg: regulator@4 {
regulator-name = "LDO2_1.2V";
regulator-min-microvolt = <1140000>;
regulator-max-microvolt = <1320000>;
regulator-boot-on;
};*//*Zoick*/
&mcasp0 {
status = "okay";
pinctrl-0 = <&mcasp0_pins>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializer */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 0 0 0
0 0 0 0
0 0 0 1
2 0 0 0
tx-num-evt = <32>;
rx-num-evt = <32>;
&edma0 {
ti,edma-reserved-slot-ranges = <32 50>;
&edma1 {
ti,edma-reserved-slot-ranges = <32 90>;
&aemif {
pinctrl-0 = <&nand_pins>;
status = "ok";
cs3 {
#address-cells = <2>;
#size-cells = <1>;
clock-ranges;
ranges;
ti,cs-chipselect = <3>;
nand@2000000,0 {
compatible = "ti,davinci-nand";
#size-cells = <1>;
reg = <0 0x02000000 0x02000000
1 0x00000000 0x00008000>;
ti,davinci-chipselect = <1>;
ti,davinci-mask-ale = <0>;
ti,davinci-mask-cle = <0>;
ti,davinci-mask-chipsel = <0>;
ti,davinci-ecc-mode = "hw";
ti,davinci-ecc-bits = <4>;
ti,davinci-nand-use-bbt;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {/*Zoick*/
label = "NAND.u-boot-env";
reg = <0 0x020000>;
partition@0x020000 {
label = "NAND.UBL";
reg = <0x020000 0x040000>;
partition@0x040000 {
label = "NAND.u-boot";
reg = <0x040000 0x140000>;
partition@0x140000 {
label = "NAND.dtb";
reg = <0x140000 0x300000>;
partition@0x300000 {
label = "NAND.kernel";
reg = <0x300000 0xB00000>;
partition@0xB00000 {
label = "NAND.file-system";
reg = <0xB00000 0x0>;
&vpif {
pinctrl-0 = <&vpif_capture_pins>, <&vpif_display_pins>;
status = "okay";
/* VPIF capture port */
port@0 {
vpif_input_ch0: endpoint@0 {
reg = <0>;
bus-width = <8>;
vpif_input_ch1: endpoint@1 {
reg = <1>;
bus-width = <8>;
data-shift = <8>;
/* VPIF display port */
port@1 {
vpif_output_ch0: endpoint {
bus-width = <8>;
直接启动内核信息如下:
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 4.9.28-geed43d1050 (root@hxdw-virtual-machine) (gcc version 6.2.1
20161016 (Linaro GCC 6.2-2016.11) ) #7 PREEMPT Tue Sep 26 10:30:46 CST 2017
CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
CPU: VIVT data cache, VIVT instruction cache
Machine: DaVinci DA850/OMAP-L138/AM18x EVM
da8xx_rproc_reserve_cma: 'rproc_mem=nn@address' badly specified
'nn' and 'address' must both be non-zero
cma: Reserved 16 MiB at 0xc2800000
Memory policy: Data cache writethrough
DaVinci da850/omap-l138/am18x variant 0x1
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 14971
Kernel command line: console=ttyS1,115200n8 root=nfs nfsroot=172.16.16.49:/home/
epri/workspace/138/rootfs/root138 mem=59M ip=172.16.16.123:255.255.255.0:172.16.
16.1 rootdelay=10
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 36652K/60416K available (4529K kernel code, 308K rwdata, 1448K rodata, 2
24K init, 162K bss, 7380K reserved, 16384K cma-reserved)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xc4000000 - 0xff800000 ( 952 MB)
lowmem : 0xc0000000 - 0xc3b00000 ( 59 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.text : 0xc0008000 - 0xc0474b38 (4531 kB)
.init : 0xc05e0000 - 0xc0618000 ( 224 kB)
.data : 0xc0618000 - 0xc0665110 ( 309 kB)
.bss : 0xc0665110 - 0xc068dc08 ( 163 kB)
SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Preemptible hierarchical RCU implementation.
Build-time adjustment of leaf fanout to 32.
NR_IRQS:245
clocksource: timer0_1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 796
35851949 ns
sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
Console: colour dummy device 80x30
Calibrating delay loop... 148.88 BogoMIPS (lpj=744448)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
CPU: Testing write buffer coherency: ok
Setting up static identity map for 0xc0008400 - 0xc0008458
devtmpfs: initialized
VFP support v0.3: not present
clocksourcclocksource: jiffies: mfffff max_cycles: 0xffffffff, max_idle_ns: 1911
2604462750000 ns
futex hash table entries: 256 (order: -1, 3072 bytes)
pinctrl core: initialized pinctrl subsystem
NET: Registered protocol family 16
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
mux: initialized GPIO4_0
mux: Setting register GPIO4_0
mux: PINMUX10 (0x00000028) = 0x00222222 -> 0x80222222
mux: initialized GPIO4_1
mux: Setting register GPIO4_1
mux: PINMUX10 (0x00000028) = 0x80222222 -> 0x88222222
mux: initialized AHCLKX
mux: Setting register AHCLKX
mux: PINMUX0 (0x00000000) = 0x44080000 -> 0x44180000
mux: initialized ACLKX
mux: Setting register ACLKX
mux: PINMUX0 (0x00000000) = 0x44180000 -> 0x44180010
mux: initialized AFSX
mux: Setting register AFSX
mux: PINMUX0 (0x00000000) = 0x44180010 -> 0x44181010
mux: initialized AHCLKR
mux: Setting register AHCLKR
mux: PINMUX0 (0x00000000) = 0x44181010 -> 0x44111010
mux: initialized ACLKR
mux: Setting register ACLKR
mux: PINMUX0 (0x00000000) = 0x44111010 -> 0x44111011
mux: initialized AFSR
mux: Setting register AFSR
mux: PINMUX0 (0x00000000) = 0x44111011 -> 0x44111111
mux: initialized AMUTE
mux: Setting register AMUTE
mux: PINMUX0 (0x00000000) = 0x44111111 -> 0x41111111
mux: initialized AXR_11
mux: Setting register AXR_11
mux: PINMUX1 (0x00000004) = 0x00000000 -> 0x00010000
mux: initialized AXR_12
mux: Setting register AXR_12
mux: PINMUX1 (0x00000004) = 0x00010000 -> 0x00011000
mux: initialized LCD_D_0
mux: Setting register LCD_D_0
mux: PINMUX17 (0x00000044) = 0x00000000 -> 0x00000020
mux: initialized LCD_D_1
mux: Setting register LCD_D_1
mux: PINMUX17 (0x00000044) = 0x00000020 -> 0x00000022
mux: initialized LCD_D_2
mux: Setting register LCD_D_2
mux: PINMUX16 (0x00000040) = 0x00000000 -> 0x20000000
mux: initialized LCD_D_3
mux: Setting register LCD_D_3
mux: PINMUX16 (0x00000040) = 0x20000000 -> 0x22000000
mux: initialized LCD_D_4
mux: Setting register LCD_D_4
mux: PINMUX16 (0x00000040) = 0x22000000 -> 0x22200000
mux: initialized LCD_D_5
mux: Setting register LCD_D_5
mux: PINMUX16 (0x00000040) = 0x22200000 -> 0x22220000
mux: initialized LCD_D_6
mux: Setting register LCD_D_6
mux: PINMUX16 (0x00000040) = 0x22220000 -> 0x22222000
mux: initialized LCD_D_7
mux: Setting register LCD_D_7
mux: PINMUX16 (0x00000040) = 0x22222000 -> 0x22222200
mux: initialized LCD_D_8
mux: Setting register LCD_D_8
mux: PINMUX18 (0x00000048) = 0x80000000 -> 0x80000020
mux: initialized LCD_D_9
mux: Setting register LCD_D_9
mux: PINMUX18 (0x00000048) = 0x80000020 -> 0x80000022
mux: initialized LCD_D_10
mux: Setting register LCD_D_10
mux: PINMUX17 (0x00000044) = 0x00000022 -> 0x20000022
mux: initialized LCD_D_11
mux: Setting register LCD_D_11
mux: PINMUX17 (0x00000044) = 0x20000022 -> 0x22000022
mux: initialized LCD_D_12
mux: Setting register LCD_D_12
mux: PINMUX17 (0x00000044) = 0x22000022 -> 0x22200022
mux: initialized LCD_D_13
mux: Setting register LCD_D_13
mux: PINMUX17 (0x00000044) = 0x22200022 -> 0x22220022
mux: initialized LCD_D_14
mux: Setting register LCD_D_14
mux: PINMUX17 (0x00000044) = 0x22220022 -> 0x22222022
mux: initialized LCD_D_15
mux: Setting register LCD_D_15
mux: PINMUX17 (0x00000044) = 0x22222022 -> 0x22222222
mux: initialized LCD_PCLK
mux: Setting register LCD_PCLK
mux: PINMUX18 (0x00000048) = 0x80000022 -> 0x82000022
mux: initialized LCD_HSYNC
mux: Setting register LCD_HSYNC
mux: PINMUX19 (0x0000004c) = 0x00000000 -> 0x00000002
mux: initialized LCD_VSYNC
mux: Setting register LCD_VSYNC
mux: PINMUX19 (0x0000004c) = 0x00000002 -> 0x00000022
mux: initialized NLCD_AC_ENB_CS
mux: Setting register NLCD_AC_ENB_CS
mux: PINMUX19 (0x0000004c) = 0x00000022 -> 0x02000022
mux: initialized GPIO2_8
mux: Setting register GPIO2_8
mux: PINMUX5 (0x00000014) = 0x00110110 -> 0x80110110
mux: initialized GPIO2_15
mux: Setting register GPIO2_15
mux: PINMUX5 (0x00000014) = 0x80110110 -> 0x80110118
mux: initialized RTC_ALARM
mux: Setting register RTC_ALARM
mux: PINMUX0 (0x00000000) = 0x41111111 -> 0x21111111
da8xx_register_rproc: memory not reserved for DSP, not registering DSP device
da850_evm_init: dsp/rproc registration failed: -12
edma edma.0: Legacy memcpy is enabled, things might not work
edma edma.0: TI EDMA DMA engine driver
edma edma.1: Legacy memcpy is enabled, things might not work
edma edma.1: TI EDMA DMA engine driver
pca953x 1-0020: failed reading register
pca953x: probe of 1-0020 failed with error -121
clocksource: Switched to clocksource timer0_1
NET: Registered protocol family 2
TCP established hash table entries: 1024 (order: 0, 4096 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
mux: initialized MII_TXEN
mux: Setting register MII_TXEN
mux: PINMUX2 (0x00000008) = 0x00000000 -> 0x00000080
mux: initialized MII_TXCLK
mux: Setting register MII_TXCLK
mux: PINMUX2 (0x00000008) = 0x00000080 -> 0x00000880
mux: initialized MII_COL
mux: Setting register MII_COL
mux: PINMUX2 (0x00000008) = 0x00000880 -> 0x00008880
mux: initialized MII_TXD_3
mux: Setting register MII_TXD_3
mux: PINMUX2 (0x00000008) = 0x00008880 -> 0x00088880
mux: initialized MII_TXD_2
mux: Setting register MII_TXD_2
mux: PINMUX2 (0x00000008) = 0x00088880 -> 0x00888880
mux: initialized MII_TXD_1
mux: Setting register MII_TXD_1
mux: PINMUX2 (0x00000008) = 0x00888880 -> 0x08888880
mux: initialized MII_TXD_0
mux: Setting register MII_TXD_0
mux: PINMUX2 (0x00000008) = 0x08888880 -> 0x88888880
mux: initialized MII_RXER
mux: Setting register MII_RXER
mux: PINMUX3 (0x0000000c) = 0x00000000 -> 0x00000800
mux: initialized MII_CRS
mux: Setting register MII_CRS
mux: PINMUX3 (0x0000000c) = 0x00000800 -> 0x00008800
mux: initialized MII_RXCLK
mux: Setting register MII_RXCLK
mux: PINMUX3 (0x0000000c) = 0x00008800 -> 0x00008808
mux: initialized MII_RXDV
mux: Setting register MII_RXDV
mux: PINMUX3 (0x0000000c) = 0x00008808 -> 0x00008888
mux: initialized MII_RXD_3
mux: Setting register MII_RXD_3
mux: PINMUX3 (0x0000000c) = 0x00008888 -> 0x00088888
mux: initialized MII_RXD_2
mux: Setting register MII_RXD_2
mux: PINMUX3 (0x0000000c) = 0x00088888 -> 0x00888888
mux: initialized MII_RXD_1
mux: Setting register MII_RXD_1
mux: PINMUX3 (0x0000000c) = 0x00888888 -> 0x08888888
mux: initialized MII_RXD_0
mux: Setting register MII_RXD_0
mux: PINMUX3 (0x0000000c) = 0x08888888 -> 0x88888888
EMAC: MII PHY configured, RMII PHY will not be functional
workingset: timestamp_bits=14 max_order=14 bucket_order=0
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
io scheduler noop registered (default)
da8xx_lcdc da8xx_lcdc.0: found Sharp_LK043T1DG01 panel
Console: switching to colour frame buffer device 60x34
Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
serial8250.0: ttyS0 at MMIO 0x1c42000 (irq = 25, base_baud = 9375000) is a 16550
A
serial8250.1: ttyS1 at MMIO 0x1d0c000 (irq = 53, base_baud = 9375000) is a 16550
A
console [ttyS1] enabled
serial8250.2: ttyS2 at MMIO 0x1d0d000 (irq = 61, base_baud = 9375000) is a 16550
A
random: fast init done
brd: module loaded
libphy: Fixed MDIO Bus: probed
davinci_mdio davinci_mdio.0: davinci mdio revision 1.5
davinci_mdio davinci_mdio.0: detected phy mask fffffffe
libphy: davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device davinci_mdio-0:00, driver unknown
i2c /dev entries driver
davinci_mmc da830-mmc.0: cannot find GPIO chip davinci_gpio.2
davinci_mmc da830-mmc.0: Using DMA, 4-bit mode
NET: Registered protocol family 10
sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
NET: Registered protocol family 17
------------[ cut here ]------------
WARNING: CPU: 0 PID: 1 at arch/arm/mach-davinci/da850.c:1131 da850_regulator_ini
t+0x40/0x5c
Unable to obtain voltage regulator for CVDD; voltage scaling unsupported
Modules linked in:
CPU: 0 PID: 1 Comm: swapper Not tainted 4.9.28-geed43d1050 #7
Hardware name: DaVinci DA850/OMAP-L138/AM18x EVM
Backtrace:
[<c0012ff0>] (dump_backtrace) from [<c0013294>] (show_stack+0x18/0x1c)
r7:00000009 r6:00000000 r5:c05747ec r4:c2437c70
[<c001327c>] (show_stack) from [<c02358dc>] (dump_stack+0x20/0x28)
[<c02358bc>] (dump_stack) from [<c0021a00>] (__warn+0xdc/0x104)
[<c0021924>] (__warn) from [<c0021a68>] (warn_slowpath_fmt+0x40/0x48)
r9:c065c100 r8:c0685768 r7:00000000 r6:c06304e0 r5:c06857f8 r4:c05747a0
[<c0021a2c>] (warn_slowpath_fmt) from [<c001c990>] (da850_regulator_init+0x40/0x
5c)
r3:00000000 r2:c05747a0
r4:c066540c
[<c001c950>] (da850_regulator_init) from [<c032ad14>] (davinci_cpu_init+0x3c/0x7
8)
r5:c06857f8 r4:c2592600
[<c032acd8>] (davinci_cpu_init) from [<c032737c>] (cpufreq_online+0xa4/0x66c)
r7:00000000 r6:00000004 r5:00000001 r4:c2592600
[<c03272d8>] (cpufreq_online) from [<c03279e8>] (cpufreq_add_dev+0x8c/0xa4)
r10:00000000 r9:c05ddf04 r8:00000000 r7:fffffdfb r6:c061e338 r5:c06583f0
r4:00000000
[<c032795c>] (cpufreq_add_dev) from [<c02c9040>] (subsys_interface_register+0x9c
/0xd4)
r7:fffffdfb r6:c065bf68 r5:c06583f0 r4:c065bfb0
[<c02c8fa4>] (subsys_interface_register) from [<c0325b08>] (cpufreq_register_dri
ver+0x1d8/0x280)
r5:c0685768 r4:c06857f8
[<c0325930>] (cpufreq_register_driver) from [<c0600450>] (davinci_cpufreq_probe+
0x84/0xa4)
r6:c065c5bc r5:c0630520 r4:c06857f8
[<c06003cc>] (davinci_cpufreq_probe) from [<c02cc6b8>] (platform_drv_probe+0x40/
0xa4)
r5:c0630520 r4:ffffffed
[<c02cc678>] (platform_drv_probe) from [<c02cabc8>] (driver_probe_device+0x20c/0
x2c0)
r7:00000000 r6:c065c5bc r5:c0684e98 r4:c0630520
[<c02ca9bc>] (driver_probe_device) from [<c02cad3c>] (__driver_attach+0xc0/0xc4)
r9:c05ddf04 r8:00000000 r7:00000000 r6:c0630554 r5:c065c5bc r4:c0630520
[<c02cac7c>] (__driver_attach) from [<c02c8c00>] (bus_for_each_dev+0x74/0xa4)
r7:00000000 r6:c02cac7c r5:c065c5bc r4:00000000
[<c02c8b8c>] (bus_for_each_dev) from [<c02ca434>] (driver_attach+0x20/0x28)
r6:c0658370 r5:c26b3b40 r4:c065c5bc
[<c02ca414>] (driver_attach) from [<c02c9f70>] (bus_add_driver+0x104/0x214)
[<c02c9e6c>] (bus_add_driver) from [<c02cb568>] (driver_register+0x80/0xfc)
r7:c065c5bc r6:c0665120 r5:00000002 r4:c065c5bc
[<c02cb4e8>] (driver_register) from [<c02cc8b8>] (__platform_driver_probe+0x64/0
x130)
r5:00000002 r4:c065c5a8
[<c02cc854>] (__platform_driver_probe) from [<c060048c>] (davinci_cpufreq_init+0
x1c/0x28)
r7:c060a834 r6:c0665120 r5:ffffe000 r4:c05e3764
[<c0600470>] (davinci_cpufreq_init) from [<c05e7e10>] (davinci_init_late+0x10/0x
18)
[<c05e7e00>] (davinci_init_late) from [<c05e3788>] (init_machine_late+0x24/0x98)
[<c05e3764>] (init_machine_late) from [<c0009760>] (do_one_initcall+0x44/0x180)
[<c000971c>] (do_one_initcall) from [<c05e0ebc>] (kernel_init_freeable+0x190/0x2
54)
r8:c05e05fc r7:c060a834 r6:c0665120 r5:0000006c r4:c06174f4
[<c05e0d2c>] (kernel_init_freeable) from [<c046fd80>] (kernel_init+0x10/0xfc)
r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c046fd70
r4:00000000
[<c046fd70>] (kernel_init) from [<c000fb10>] (ret_from_fork+0x14/0x24)
r5:c046fd70 r4:00000000
---[ end trace 88e757ab161d5796 ]---
console [netcon0] enabled
netconsole: network logging started
davinci_emac davinci_emac.1: using random MAC addr: ba:b5:bc:43:c9:49
hctosys: unable to open rtc device (rtc0)
davinci_mdio davinci_mdio.0: resetting idled controller
Generic PHY davinci_mdio-0:00: attached PHY driver [Generic PHY] (mii_bus:phy_ad
dr=davinci_mdio-0:00, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
davinci_emac davinci_emac.1 eth0: Link is Up - 100Mbps/Full - flow control rx/tx
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
IP-Config: Guessing netmask 255.255.0.0
IP-Config: Complete:
device=eth0, hwaddr=ba:b5:bc:43:c9:49, ipaddr=172.16.16.123, mask=255.255.0
.0, gw=172.16.16.1
host=172.16.16.123, domain=, nis-domain=(none)
bootserver=255.255.255.0, rootserver=172.16.16.49, rootpath=
Waiting 10 sec before mounting root device...
VFS: Cannot open root device "nfs" or unknown-block(0,0): error -6
Please append a correct "root=" boot option; here are the available partitions:
0100 32768 ram0 (driver?)
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
---[ end Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-blo
ck(0,0)
