DVRRDK MCFW链路问题
请问下大家:mcfw下链路为:
cap -> dei -> merge -.> vpssout -> hostin -> hostout (process link)  -> frame in dsp ->dsp alg -> swms ->dis
这样有没有问题:
          mergePrm.inQueParams[0].prevLinkId    = gVcapModuleContext.deiId[0];
        mergePrm.inQueParams[0].prevLinkQueId = DEI_LINK_OUT_QUE_DEI_SC;
        mergePrm.notifyNextLink               = TRUE;
        mergePrm.numInQue                     = 1;
        mergePrm.outQueParams.nextLink        = gVcapModuleContext.ipcFramesOutVpssId[0];
        ipcOutVpssPrm.baseCreateParams.noNotifyMode = FALSE;
        ipcOutVpssPrm.baseCreateParams.notifyNextLink = TRUE;
        ipcOutVpssPrm.baseCreateParams.notifyPrevLink = TRUE;
        ipcOutVpssPrm.baseCreateParams.inQueParams.prevLinkId = VPSS_LINK_ID_MERGE;
        ipcOutVpssPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
        ipcOutVpssPrm.baseCreateParams.outQueParams[0].nextLink = gVcapModuleContext.ipcFramesInHostId;
        hostInPrm.baseCreateParams.noNotifyMode              = FALSE;
        hostInPrm.baseCreateParams.notifyNextLink         = TRUE;
        hostInPrm.baseCreateParams.notifyPrevLink         = TRUE;
        //hostInPrm.baseCreateParams.notifyProcessLink         = TRUE;
        hostInPrm.baseCreateParams.inQueParams.prevLinkId     = gVcapModuleContext.ipcFramesOutVpssId[0];
        hostInPrm.baseCreateParams.inQueParams.prevLinkQueId = 0;
        hostInPrm.baseCreateParams.outQueParams[0].nextLink    =  gVdisModuleContext.ipcFramesOutHostId;
        hostInPrm.cbCtx                                      = NULL;
         hostInPrm.cbFxn                                      = save_frames1;
 hostOutPrm.baseCreateParams.inQueParams.prevLinkId      = gVcapModuleContext.ipcFramesInHostId;
 hostOutPrm.baseCreateParams.inQueParams.prevLinkQueId = DEI_LINK_OUT_QUE_DEI_SC;
 hostOutPrm.baseCreateParams.noNotifyMode              = FALSE;
 hostOutPrm.baseCreateParams.notifyPrevLink              = TRUE;
 hostOutPrm.baseCreateParams.notifyNextLink              = TRUE;
 hostOutPrm.baseCreateParams.numOutQue                  = 1;
 hostOutPrm.baseCreateParams.outQueParams[0].nextLink  = gVdisModuleContext.swMsId[0];
 hostOutPrm.baseCreateParams.processLink               = DSP_LINK_ID_IPC_FRAME_IN;
 hostOutPrm.baseCreateParams.notifyProcessLink          = TRUE;
 ipcFramesInDspPrms.baseCreateParams.noNotifyMode               = FALSE;
 ipcFramesInDspPrms.baseCreateParams.notifyPrevLink            = FALSE;
 ipcFramesInDspPrms.baseCreateParams.notifyNextLink            = TRUE;
 ipcFramesInDspPrms.baseCreateParams.inQueParams.prevLinkId    = gVdisModuleContext.ipcFramesOutHostId;
 ipcFramesInDspPrms.baseCreateParams.inQueParams.prevLinkQueId = 0;
 ipcFramesInDspPrms.baseCreateParams.numOutQue                   = 1;
 ipcFramesInDspPrms.baseCreateParams.outQueParams[0].nextLink  = DSP_LINK_ID_APP;
 /* DSP App link */
 appPrms.numInQue                   = 1;
 appPrms.inQueParams.prevLinkId    = DSP_LINK_ID_IPC_FRAME_IN;
 appPrms.inQueParams.prevLinkQueId = 0;
 /* Mosaic link init */
 swmsPrms.numSwMsInst                = 1;
 swmsPrms.swMsInstId[0]             = SYSTEM_SW_MS_SC_INST_DEI_SC_NO_DEI;
 swmsPrms.includeVipScInDrvPath     = TRUE;
 swmsPrms.inQueParams.prevLinkId    = gVdisModuleContext.ipcFramesOutHostId;
 swmsPrms.inQueParams.prevLinkQueId = 0;
 swmsPrms.outQueParams.nextLink     = gVdisModuleContext.displayId[0];
 swmsPrms.maxInputQueLen            = 4;
 swmsPrms.maxOutRes                 = VSYS_STD_1080P_60;
 swmsPrms.initOutRes                = gVdisModuleContext.vdisConfig.deviceParams[0].resolution;
 swmsPrms.numOutBuf                 = 8;
 swmsPrms.lineSkipMode                = FALSE;
 swmsPrms.enableLayoutGridDraw        = gVdisModuleContext.vdisConfig.enableLayoutGridDraw;
 MultiCh_swMsGetDefaultLayoutPrm(VDIS_DEV_HDMI, &swmsPrms, TRUE);
 /* Display link init */
 disPrms.inQueParams[0].prevLinkId      = gVdisModuleContext.swMsId[0];
 disPrms.inQueParams[0].prevLinkQueId = 0;
 disPrms.displayRes                   = swmsPrms.initOutRes;
发现链路不通:
 [host]  454: IPC_FRAMES_IN   : Create Done !!!
[HOST]
ThreadName:IpcFramesOutLink_tskMain_30000013,ThreadID:1567
 [host]  455: IPC_FRAMES_OUT   : Create in progress !!!
 [host]  456: IPC_FRAMES_OUT   : Create Done !!!
[HOST]
ThreadName:IpcFramesOutLink_periodicTaskFxn_30000013,ThreadID:1572
 [c6xdsp ]  6627: IPC_FRAMES_IN   : Create in progress !!!
 [c6xdsp ]  6627: SYSTEM: Opening ListMP [HOST_IPC_OUT_19] ...
 [m3vpss ] DEI:HEAPID:0 USED:64
 [c6xdsp ]  6628: SYSTEM: Opening ListMP [HOST_IPC_IN_19] ...
 [m3vpss ] DEI:HEAPID:1 USED:4272
 [c6xdsp ]  6628: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
 [m3vpss ] DEI:HEAPID:4 USED:29030400
 [m3vpss ]  7123: DEI    : Create Done !!!
 [m3vpss ]  7123: MERGE:  0: Format: PROGRESSIVE, 1920 x 1080
 [c6xdsp ] IPC_FRAMES_IN:HEAPID:0       USED:304
 [m3vpss ]  7124: MERGE   : Create Done !!!
 [c6xdsp ]  6629: IPC_FRAMES_IN   : Create Done !!!
 [m3vpss ]  7124: IPC_FRAMES_OUT   : Create in progress !!!
 [c6xdsp ]  6629: App   : Create Done !!!
 [m3vpss ]  7126: IPC_FRAMES_OUT   : Create Done !!!
 [m3vpss ]  7136: SWMS: Create in progress !!!
 [m3vpss ]  7137: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
 [m3vpss ]  UTILS: DMA: Allocated CH (TCC) = 59 (59)
 [m3vpss ]  UTILS: DMA: 0 of 1: Allocated PaRAM = 59 (0x49004760)
 [m3vpss ] SWMS: instance 0, sc id 7, start win 0 end win 17
 [m3vpss ]  7314: SWMS    : VipScReq is TRUE!!!
 [m3vpss ]  7315: Assertion @ Line: 2505 in links_m3vpss/swMs/swMsLink_drv.c: p!
这是打印结果,死在这拉
