关于i2c 触摸屏的问题
Other Parts Discussed in Thread: AM5726, TLV320AIC3104
我们用am5726开发板在不接触摸屏的时候dmesg有如下信息root@am57xx-evm:~# dmesg |grep i2c
[    0.553624] gpiochip_add: registered GPIOs 504 to 511 on device: 48070000.i2c
:tps659038@58:tps659038_gpio
[    0.554034] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.554538] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    0.555111] omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
[    1.800765] i2c /dev entries driver
[    6.082145] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of no
de '/ocp/i2c@48070000/tlv320aic3104@18[0]'
[    6.263581] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of no
de '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.263618] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/o
cp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[    6.263657] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of n
ode '/ocp/i2c@4807c000/pixcir_ts@5c[0]'
[    6.263691] of_get_named_gpiod_flags: parsed 'reset-gpio' property of node '/
ocp/i2c@4807c000/pixcir_ts@5c[0]' - status (0)
[    6.292526] rtc rtc1: 48070000.i2c:tps659: dev (254:1)
[    6.292545] palmas-rtc 48070000.i2c:tps659038@58:tps659038_rtc: rtc core: reg
istered 48070000.i2c:tps659 as rtc1
[    6.329956] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup f
or consumer id
[    6.329971] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device
tree for GPIO lookup
[    6.329984] of_get_named_gpiod_flags: can't parse 'id-gpios' property of node
 '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[    6.329994] of_get_named_gpiod_flags: can't parse 'id-gpio' property of node
[    6.330003] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using lookup
tables for GPIO lookup
[    6.330014] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: lookup for GP
IO id failed
[    6.330023] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: GPIO lookup f
or consumer vbus
[    6.330032] palmas-usb 48070000.i2c:tps659038@58:tps659038_usb: using device
[    6.330041] of_get_named_gpiod_flags: can't parse 'vbus-gpios' property of no
de '/ocp/i2c@48070000/tps659038@58/tps659038_usb[0]'
[    6.330097] of_get_named_gpiod_flags: parsed 'vbus-gpio' property of node '/o
cp/i2c@48070000/tps659038@58/tps659038_usb[0]' - status (0)
[    6.546022] of_get_named_gpiod_flags: parsed 'reset-gpios' property of node '
/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.546081] of_get_named_gpiod_flags: parsed 'powerdown-gpios' property of no
de '/ocp/i2c@4807c000/mt9t11x@3C[0]' - status (0)
[    6.546131] of_get_named_gpiod_flags: parsed 'oscen-gpios' property of node '
[    6.546181] of_get_named_gpiod_flags: parsed 'bufen-gpios' property of node '
[    6.546231] of_get_named_gpiod_flags: parsed 'camen-gpios' property of node '
我们自己设计的版卡root@am57xx-evm:~# dmesg |grep i2c
or consumer id
IO id failed
or consumer vbus
同样的内核为什么开发板可以检测到omap_i2c 4807c000.i2c: bus 4 rev0.12 at 400 kHz
而我们的版卡却没有这句打印,硬件设计也一样和开发板一样触摸屏接在i2c5上,谢谢ti工程师们的解答!
