各位专家: 我在EVM6678L上运行论坛里下载的KeyStone_SRIO例程,目前使用的digital_loopback模式。前面的各个速率的1x,2x,4x传输都没有问题,只有最后一项测试multi-port传输有两处数据传输错误,请问这可能是什么原因造成的?
[C66xx_0] SRIO_DIGITAL_LOOPBACK test start............................................
[C66xx_0] Initialize main PLL = x10/1
[C66xx_0] Initialize DDR PLL = x20/1
[C66xx_0] configure DDR at 666 MHz
[C66xx_0] SRIO link speed is 5.000Gbps
[C66xx_0] SRIO path configuration 1xLaneA
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8 bytes, 895 cycles, 71 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 909 cycles, 140 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 913 cycles, 280 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 916 cycles, 558 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1298 cycles, 788 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 1773 cycles, 1155 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 2323 cycles, 1763 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 3321 cycles, 2466 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 5637 cycles, 2906 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 10046 cycles, 3261 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 18847 cycles, 3477 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 36922 cycles, 3549 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 951 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 921 cycles, 138 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 923 cycles, 277 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 929 cycles, 551 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1309 cycles, 782 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 1777 cycles, 1152 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 2327 cycles, 1760 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 3327 cycles, 2462 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 5703 cycles, 2872 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 10037 cycles, 3264 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 18835 cycles, 3479 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 36875 cycles, 3554 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 996 cycles, 64 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 980 cycles, 130 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 984 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1062 cycles, 482 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1452 cycles, 705 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 1647 cycles, 1243 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 2188 cycles, 1872 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 3532 cycles, 2319 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 5692 cycles, 2878 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 10041 cycles, 3263 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 19053 cycles, 3439 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 36763 cycles, 3565 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8 bytes, 1024 cycles, 62 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 997 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 997 cycles, 256 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1000 cycles, 512 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1300 cycles, 787 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 1772 cycles, 1155 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 2344 cycles, 1747 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 3344 cycles, 2449 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 5710 cycles, 2869 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 10065 cycles, 3255 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 18851 cycles, 3476 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 36916 cycles, 3550 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1033 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 963 cycles, 132 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 979 cycles, 261 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 981 cycles, 521 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1293 cycles, 791 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 1556 cycles, 1316 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 2334 cycles, 1754 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 3332 cycles, 2458 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 5690 cycles, 2879 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 10042 cycles, 3263 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 19088 cycles, 3433 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 36860 cycles, 3555 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1051 cycles, 60 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1065 cycles, 120 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1067 cycles, 479 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1437 cycles, 712 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 1643 cycles, 1246 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 2202 cycles, 1860 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 3555 cycles, 2304 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 5690 cycles, 2879 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 10070 cycles, 3254 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 18998 cycles, 3449 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 36920 cycles, 3550 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8 bytes, 1014 cycles, 63 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 997 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 997 cycles, 256 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1000 cycles, 512 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1378 cycles, 743 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 1783 cycles, 1148 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 2289 cycles, 1789 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 3330 cycles, 2460 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 5666 cycles, 2891 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 10076 cycles, 3252 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 19082 cycles, 3434 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 36798 cycles, 3561 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8 bytes, 1033 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1007 cycles, 127 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1007 cycles, 254 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1011 cycles, 506 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1303 cycles, 785 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 1793 cycles, 1142 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 2299 cycles, 1781 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 3339 cycles, 2453 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 5671 cycles, 2889 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 10069 cycles, 3254 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 19061 cycles, 3438 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 36765 cycles, 3565 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1169 cycles, 54 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1068 cycles, 119 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1154 cycles, 221 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1100 cycles, 465 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1550 cycles, 660 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 1721 cycles, 1190 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 2505 cycles, 1635 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 3549 cycles, 2308 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 5641 cycles, 2904 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 10089 cycles, 3247 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 18997 cycles, 3449 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 36956 cycles, 3546 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 922 cycles, 69 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 914 cycles, 140 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 972 cycles, 263 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1157 cycles, 442 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1362 cycles, 751 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 1995 cycles, 1026 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 2301 cycles, 1780 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 3413 cycles, 2400 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 5647 cycles, 2901 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 10103 cycles, 3243 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 19032 cycles, 3443 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 36999 cycles, 3542 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 992 cycles, 64 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 992 cycles, 129 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1156 cycles, 442 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1437 cycles, 712 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 2000 cycles, 1024 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 2368 cycles, 1729 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 3487 cycles, 2349 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 5720 cycles, 2864 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 10187 cycles, 3216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 19051 cycles, 3440 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 36904 cycles, 3551 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1085 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1084 cycles, 118 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1156 cycles, 221 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1249 cycles, 409 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1534 cycles, 667 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 2181 cycles, 939 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 2462 cycles, 1663 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 3585 cycles, 2285 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 5731 cycles, 2858 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 10205 cycles, 3210 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 19125 cycles, 3426 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 36999 cycles, 3542 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 970 cycles, 65 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 982 cycles, 130 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1156 cycles, 442 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1374 cycles, 745 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 2003 cycles, 1022 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 2375 cycles, 1724 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 3491 cycles, 2346 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 5729 cycles, 2859 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 10189 cycles, 3216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 19115 cycles, 3428 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 37022 cycles, 3540 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 970 cycles, 65 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 970 cycles, 131 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1166 cycles, 439 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1461 cycles, 700 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 2010 cycles, 1018 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 2365 cycles, 1731 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 3482 cycles, 2352 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 5736 cycles, 2856 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 10196 cycles, 3213 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 19133 cycles, 3425 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 36930 cycles, 3549 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1064 cycles, 60 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1069 cycles, 119 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1158 cycles, 221 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1263 cycles, 405 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1562 cycles, 655 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 2186 cycles, 936 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 2467 cycles, 1660 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 3577 cycles, 2290 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 5827 cycles, 2811 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 10288 cycles, 3185 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 19219 cycles, 3409 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 37001 cycles, 3542 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1072 cycles, 59 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1086 cycles, 117 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1181 cycles, 216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1344 cycles, 380 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1532 cycles, 668 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 2093 cycles, 978 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 2485 cycles, 1648 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 3603 cycles, 2273 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 5813 cycles, 2818 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 10292 cycles, 3183 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 19245 cycles, 3405 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 37189 cycles, 3524 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1098 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1164 cycles, 109 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1180 cycles, 216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1346 cycles, 380 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1624 cycles, 630 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 2184 cycles, 937 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 2479 cycles, 1652 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 3604 cycles, 2273 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 5821 cycles, 2814 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 10281 cycles, 3187 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 19243 cycles, 3405 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 37091 cycles, 3533 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1280 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1260 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1361 cycles, 188 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1437 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1718 cycles, 596 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2317 cycles, 883 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 2553 cycles, 1604 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 3678 cycles, 2227 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 5904 cycles, 2775 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 10493 cycles, 3122 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 19356 cycles, 3385 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 37193 cycles, 3524 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 2xLaneAB
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8 bytes, 897 cycles, 71 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 915 cycles, 559 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1018 cycles, 1005 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 1300 cycles, 1575 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 1802 cycles, 2273 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 2328 cycles, 3518 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 3318 cycles, 4937 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 5685 cycles, 5763 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 10061 cycles, 6513 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 18852 cycles, 6952 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 945 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 919 cycles, 139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 925 cycles, 553 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1035 cycles, 989 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 1309 cycles, 1564 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 1801 cycles, 2274 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 2325 cycles, 3523 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 3321 cycles, 4933 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 5695 cycles, 5753 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 10051 cycles, 6520 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 18833 cycles, 6959 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 994 cycles, 64 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 982 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 986 cycles, 519 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1088 cycles, 941 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 1449 cycles, 1413 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 1696 cycles, 2415 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 2194 cycles, 3733 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 3526 cycles, 4646 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 5643 cycles, 5806 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 10101 cycles, 6488 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 18997 cycles, 6899 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 995 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 995 cycles, 257 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 997 cycles, 513 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1020 cycles, 1003 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 1299 cycles, 1576 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 1542 cycles, 2656 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 2350 cycles, 3485 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 3337 cycles, 4909 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 5425 cycles, 6040 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 10082 cycles, 6500 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 18803 cycles, 6970 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 979 cycles, 522 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1021 cycles, 1002 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 1294 cycles, 1582 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 1808 cycles, 2265 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 2336 cycles, 3506 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 3328 cycles, 4923 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 5688 cycles, 5760 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 10056 cycles, 6517 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 18836 cycles, 6958 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1053 cycles, 60 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1065 cycles, 480 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1089 cycles, 940 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 1439 cycles, 1423 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 1712 cycles, 2392 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 2259 cycles, 3626 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 3548 cycles, 4617 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 5680 cycles, 5769 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 10110 cycles, 6482 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 19006 cycles, 6896 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 997 cycles, 513 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1096 cycles, 934 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 1377 cycles, 1487 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 1830 cycles, 2238 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 2336 cycles, 3506 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 3323 cycles, 4930 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 5669 cycles, 5780 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 10019 cycles, 6541 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 19102 cycles, 6861 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8 bytes, 1035 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1007 cycles, 508 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1031 cycles, 993 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 1389 cycles, 1474 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 1839 cycles, 2227 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 2345 cycles, 3493 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 3329 cycles, 4921 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 5667 cycles, 5782 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 10079 cycles, 6502 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 19071 cycles, 6872 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1066 cycles, 240 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1170 cycles, 437 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1176 cycles, 870 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 1553 cycles, 1318 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 1779 cycles, 2302 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 2551 cycles, 3211 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 3581 cycles, 4575 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 5711 cycles, 5737 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 10191 cycles, 6430 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 19160 cycles, 6840 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 901 cycles, 71 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 910 cycles, 140 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1064 cycles, 481 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1197 cycles, 855 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 1724 cycles, 1187 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 1818 cycles, 2253 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 2294 cycles, 3571 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 3406 cycles, 4810 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 5641 cycles, 5808 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 10095 cycles, 6491 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 19030 cycles, 6887 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 905 cycles, 70 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 905 cycles, 141 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 972 cycles, 263 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1064 cycles, 481 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1249 cycles, 819 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 1718 cycles, 1192 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 1820 cycles, 2250 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 2365 cycles, 3463 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 3424 cycles, 4785 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 5639 cycles, 5810 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 10093 cycles, 6493 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 19030 cycles, 6887 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1011 cycles, 63 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1064 cycles, 120 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1063 cycles, 240 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1156 cycles, 442 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1375 cycles, 744 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 1908 cycles, 1073 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 1908 cycles, 2146 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 2460 cycles, 3330 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 3511 cycles, 4666 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 5735 cycles, 5713 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 10186 cycles, 6433 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 19032 cycles, 6886 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 889 cycles, 71 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 970 cycles, 131 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 978 cycles, 261 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1066 cycles, 480 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1254 cycles, 816 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 1723 cycles, 1188 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 1808 cycles, 2265 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 2372 cycles, 3453 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 3482 cycles, 4705 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 5642 cycles, 5807 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 10106 cycles, 6484 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 19133 cycles, 6850 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 975 cycles, 131 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 976 cycles, 262 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1082 cycles, 473 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1270 cycles, 806 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 1734 cycles, 1181 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 1810 cycles, 2262 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 2378 cycles, 3444 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 3487 cycles, 4698 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 5724 cycles, 5724 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 10116 cycles, 6478 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 19038 cycles, 6884 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1065 cycles, 120 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1073 cycles, 238 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1251 cycles, 409 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1361 cycles, 752 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 1913 cycles, 1070 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 1904 cycles, 2151 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 2458 cycles, 3332 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 3589 cycles, 4565 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 5809 cycles, 5640 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 10193 cycles, 6429 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 19054 cycles, 6878 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1077 cycles, 59 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1078 cycles, 118 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1091 cycles, 234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1251 cycles, 409 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1373 cycles, 745 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 1819 cycles, 1125 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 1903 cycles, 2152 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 2463 cycles, 3326 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 3590 cycles, 4563 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 6005 cycles, 5456 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 10281 cycles, 6374 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 19245 cycles, 6810 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1071 cycles, 59 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1083 cycles, 118 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1171 cycles, 218 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1251 cycles, 409 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1447 cycles, 707 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 1906 cycles, 1074 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 2005 cycles, 2042 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 2469 cycles, 3317 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 3589 cycles, 4565 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 5832 cycles, 5618 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 10282 cycles, 6373 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 19127 cycles, 6852 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1260 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1263 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1265 cycles, 202 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1389 cycles, 368 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1541 cycles, 664 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2036 cycles, 1005 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 2088 cycles, 1961 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 2554 cycles, 3207 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 3948 cycles, 4149 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 6190 cycles, 5293 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 10560 cycles, 6206 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 19496 cycles, 6723 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 4xLaneABCD
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 911 cycles, 140 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1017 cycles, 1006 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 1294 cycles, 1582 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 1393 cycles, 2940 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 1649 cycles, 4967 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 2183 cycles, 7505 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 3401 cycles, 9634 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 5842 cycles, 11218 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 10710 cycles, 12238 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 947 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1031 cycles, 993 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 1305 cycles, 1569 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 1395 cycles, 2936 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 1659 cycles, 4937 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 2459 cycles, 6662 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 3679 cycles, 8906 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 5845 cycles, 11212 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 10721 cycles, 12225 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1086 cycles, 942 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 1447 cycles, 1415 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 1558 cycles, 2629 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 1804 cycles, 4541 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 2344 cycles, 6989 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 3621 cycles, 9049 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 6083 cycles, 10773 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 11107 cycles, 11800 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8 bytes, 701 cycles, 91 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 999 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1019 cycles, 1004 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 1295 cycles, 1581 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 1474 cycles, 2778 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 1742 cycles, 4702 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 2264 cycles, 7236 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 3484 cycles, 9405 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 5925 cycles, 11060 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 10799 cycles, 12137 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 701 cycles, 91 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 981 cycles, 130 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 981 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1019 cycles, 1004 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 1292 cycles, 1585 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 1468 cycles, 2790 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 1734 cycles, 4724 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 2258 cycles, 7255 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 3480 cycles, 9416 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 5916 cycles, 11077 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 10792 cycles, 12145 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1087 cycles, 942 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 1437 cycles, 1425 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 1614 cycles, 2537 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 1887 cycles, 4341 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 2400 cycles, 6826 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 3624 cycles, 9041 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 6150 cycles, 10656 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 11110 cycles, 11797 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1183 cycles, 865 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 1371 cycles, 1493 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 1550 cycles, 2642 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 1994 cycles, 4108 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 2774 cycles, 5906 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 4431 cycles, 7395 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 7740 cycles, 8467 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 14445 cycles, 9073 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1027 cycles, 997 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 1387 cycles, 1476 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 1563 cycles, 2620 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 2003 cycles, 4089 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 2787 cycles, 5878 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 4445 cycles, 7371 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 7753 cycles, 8452 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 14459 cycles, 9065 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1066 cycles, 480 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1172 cycles, 873 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 1549 cycles, 1322 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 1701 cycles, 2407 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 2133 cycles, 3840 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 3093 cycles, 5297 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 4927 cycles, 6650 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 8494 cycles, 7715 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 15726 cycles, 8334 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 886 cycles, 72 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 901 cycles, 142 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 895 cycles, 286 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 987 cycles, 518 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1158 cycles, 884 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 1559 cycles, 1313 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 1551 cycles, 2640 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 1835 cycles, 4464 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 2467 cycles, 6641 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 3862 cycles, 8484 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 6489 cycles, 10099 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 11868 cycles, 11044 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 899 cycles, 71 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 907 cycles, 141 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1085 cycles, 471 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1167 cycles, 877 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 1565 cycles, 1308 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 1645 cycles, 2489 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 1835 cycles, 4464 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 2551 cycles, 6422 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 3863 cycles, 8482 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 6469 cycles, 10130 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 11790 cycles, 11117 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 996 cycles, 64 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 992 cycles, 129 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1172 cycles, 436 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1258 cycles, 813 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 1746 cycles, 1172 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 1737 cycles, 2358 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 2022 cycles, 4051 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 2566 cycles, 6385 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 3947 cycles, 8302 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 6552 cycles, 10002 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 11790 cycles, 11117 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 880 cycles, 72 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 883 cycles, 144 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 972 cycles, 263 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1063 cycles, 481 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1161 cycles, 881 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 1544 cycles, 1326 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 1625 cycles, 2520 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 1901 cycles, 4309 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 2648 cycles, 6187 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 4133 cycles, 7928 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 7040 cycles, 9309 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 12998 cycles, 10084 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 970 cycles, 263 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1064 cycles, 481 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1263 cycles, 810 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 1627 cycles, 1258 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 1621 cycles, 2526 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 1904 cycles, 4302 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 2737 cycles, 5986 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 4236 cycles, 7735 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 7125 cycles, 9198 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 12995 cycles, 10086 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1063 cycles, 120 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1158 cycles, 442 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1346 cycles, 760 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 1808 cycles, 1132 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 1807 cycles, 2266 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 1999 cycles, 4098 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 2836 cycles, 5777 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 4249 cycles, 7711 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 7225 cycles, 9070 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 13070 cycles, 10028 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1071 cycles, 59 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1071 cycles, 119 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1097 cycles, 233 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1162 cycles, 440 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1346 cycles, 760 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 1721 cycles, 1190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 1726 cycles, 2373 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 2283 cycles, 3588 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 3206 cycles, 5110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 5159 cycles, 6351 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 9072 cycles, 7223 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 16908 cycles, 7752 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1073 cycles, 119 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1099 cycles, 232 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1259 cycles, 406 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1372 cycles, 746 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 1722 cycles, 1189 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 1726 cycles, 2373 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 2276 cycles, 3599 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 3205 cycles, 5112 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 5181 cycles, 6324 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 9076 cycles, 7220 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 16893 cycles, 7758 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1181 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1179 cycles, 108 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1286 cycles, 199 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1345 cycles, 380 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1469 cycles, 697 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 1906 cycles, 1074 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 1902 cycles, 2153 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82024000, 1024 bytes, 2368 cycles, 3459 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82034000, 2048 bytes, 3762 cycles, 4355 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82044000, 4096 bytes, 6180 cycles, 5302 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82054000, 8192 bytes, 11494 cycles, 5701 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82064000, 16384 bytes, 20519 cycles, 6387 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO link speed is 3.125Gbps
[C66xx_0] SRIO path configuration 1xLaneA
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 909 cycles, 140 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1192 cycles, 214 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1196 cycles, 428 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1711 cycles, 598 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 2386 cycles, 858 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 3209 cycles, 1276 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 4835 cycles, 1694 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 8674 cycles, 1888 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 15573 cycles, 2104 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 29774 cycles, 2201 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 58568 cycles, 2237 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 1197 cycles, 213 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1203 cycles, 425 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1711 cycles, 598 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 2383 cycles, 859 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 3209 cycles, 1276 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 4835 cycles, 1694 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 8431 cycles, 1943 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 15785 cycles, 2075 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 30007 cycles, 2184 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 58517 cycles, 2239 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 986 cycles, 129 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 1350 cycles, 189 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1350 cycles, 379 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1584 cycles, 646 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 2325 cycles, 880 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 3138 cycles, 1305 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 5110 cycles, 1603 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 8620 cycles, 1900 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 15657 cycles, 2092 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 29871 cycles, 2193 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 58597 cycles, 2236 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8 bytes, 1024 cycles, 62 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 1000 cycles, 256 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1276 cycles, 401 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1708 cycles, 599 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 2383 cycles, 859 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 3230 cycles, 1268 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 4854 cycles, 1687 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 8388 cycles, 1953 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 15522 cycles, 2111 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 30064 cycles, 2179 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 58563 cycles, 2238 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1033 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 967 cycles, 132 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 983 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1267 cycles, 404 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1697 cycles, 603 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 2368 cycles, 864 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 3212 cycles, 1275 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 4840 cycles, 1692 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 8436 cycles, 1942 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 15558 cycles, 2106 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 30064 cycles, 2179 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 58516 cycles, 2239 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1071 cycles, 119 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1069 cycles, 239 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1413 cycles, 362 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1575 cycles, 650 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 2309 cycles, 886 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 3162 cycles, 1295 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 5133 cycles, 1595 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 8750 cycles, 1872 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 15658 cycles, 2092 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 29886 cycles, 2192 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 58686 cycles, 2233 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8 bytes, 1276 cycles, 50 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 997 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1276 cycles, 200 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1278 cycles, 400 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1656 cycles, 618 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 2393 cycles, 855 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 3174 cycles, 1290 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 5122 cycles, 1599 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 8686 cycles, 1886 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 15815 cycles, 2071 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 30068 cycles, 2179 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 58441 cycles, 2242 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1007 cycles, 127 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1281 cycles, 199 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1283 cycles, 399 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1707 cycles, 599 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 2399 cycles, 853 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 3177 cycles, 1289 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 5117 cycles, 1600 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 8689 cycles, 1885 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 15809 cycles, 2072 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 30071 cycles, 2179 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 58665 cycles, 2234 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1171 cycles, 54 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1088 cycles, 117 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1446 cycles, 177 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1446 cycles, 354 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 2082 cycles, 491 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 2363 cycles, 866 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 3465 cycles, 1182 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 5145 cycles, 1592 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 8785 cycles, 1864 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 15699 cycles, 2087 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 30219 cycles, 2168 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 58778 cycles, 2229 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1086 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1109 cycles, 115 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1186 cycles, 215 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1361 cycles, 376 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1716 cycles, 596 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 2561 cycles, 799 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 3300 cycles, 1241 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 5072 cycles, 1615 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 8605 cycles, 1904 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 15772 cycles, 2077 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 30015 cycles, 2183 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 58620 cycles, 2235 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 1085 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1103 cycles, 116 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1255 cycles, 203 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1454 cycles, 352 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1809 cycles, 566 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 2581 cycles, 793 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 3304 cycles, 1239 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 5072 cycles, 1615 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 8608 cycles, 1903 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 15806 cycles, 2073 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 30013 cycles, 2183 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 58600 cycles, 2236 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1185 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1199 cycles, 106 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1342 cycles, 190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1547 cycles, 330 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1900 cycles, 538 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 2759 cycles, 742 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 3399 cycles, 1205 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 5166 cycles, 1585 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 8689 cycles, 1885 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 15797 cycles, 2074 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 30114 cycles, 2176 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 58611 cycles, 2236 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1090 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1156 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1251 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1435 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1733 cycles, 590 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 2551 cycles, 802 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 3296 cycles, 1242 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 5090 cycles, 1609 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 8624 cycles, 1899 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 15779 cycles, 2076 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 30035 cycles, 2181 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 58699 cycles, 2232 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1090 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1158 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1249 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1436 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1828 cycles, 560 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 2646 cycles, 773 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 3295 cycles, 1243 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 5080 cycles, 1612 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 8613 cycles, 1902 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 15783 cycles, 2076 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 30113 cycles, 2176 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 58592 cycles, 2237 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1251 cycles, 51 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1251 cycles, 102 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1344 cycles, 190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1528 cycles, 335 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1917 cycles, 534 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 2840 cycles, 721 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 3388 cycles, 1208 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 5174 cycles, 1583 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 8725 cycles, 1877 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 15886 cycles, 2062 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 30134 cycles, 2174 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 58684 cycles, 2233 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1258 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1282 cycles, 99 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1364 cycles, 187 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1530 cycles, 334 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1904 cycles, 537 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 2743 cycles, 746 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 3391 cycles, 1207 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 5157 cycles, 1588 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 8789 cycles, 1864 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 15873 cycles, 2064 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 30203 cycles, 2169 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 58827 cycles, 2228 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1258 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1274 cycles, 100 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1369 cycles, 186 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1550 cycles, 330 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1918 cycles, 533 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 2745 cycles, 746 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 3406 cycles, 1202 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 5173 cycles, 1583 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 8794 cycles, 1863 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 15964 cycles, 2052 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 30203 cycles, 2169 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 58796 cycles, 2229 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1364 cycles, 46 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1470 cycles, 87 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1472 cycles, 173 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1716 cycles, 298 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 2093 cycles, 489 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2929 cycles, 699 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 3487 cycles, 1174 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 5446 cycles, 1504 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 8890 cycles, 1842 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 15966 cycles, 2052 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 30240 cycles, 2167 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 58799 cycles, 2229 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 2xLaneAB
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8 bytes, 897 cycles, 71 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 911 cycles, 281 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1194 cycles, 428 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1300 cycles, 787 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 1708 cycles, 1199 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 2128 cycles, 1924 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 3206 cycles, 2555 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 4822 cycles, 3397 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 8445 cycles, 3880 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 15513 cycles, 4224 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 29771 cycles, 4402 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 951 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 919 cycles, 139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 921 cycles, 277 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1199 cycles, 427 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1309 cycles, 782 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 1715 cycles, 1194 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 2133 cycles, 1920 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 3205 cycles, 2556 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 4819 cycles, 3399 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 8419 cycles, 3892 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 15491 cycles, 4230 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 29721 cycles, 4410 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 996 cycles, 64 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 980 cycles, 130 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 984 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1348 cycles, 379 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1452 cycles, 705 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 1929 cycles, 1061 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 2346 cycles, 1745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 3238 cycles, 2529 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 5134 cycles, 3191 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 8427 cycles, 3888 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 15711 cycles, 4171 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 29833 cycles, 4393 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 997 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 997 cycles, 256 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1279 cycles, 400 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1300 cycles, 787 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 1707 cycles, 1199 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 2369 cycles, 1728 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 3227 cycles, 2538 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 4841 cycles, 3384 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 8396 cycles, 3902 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 15579 cycles, 4206 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 29773 cycles, 4402 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1035 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 963 cycles, 132 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 979 cycles, 261 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1253 cycles, 408 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1293 cycles, 791 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 1698 cycles, 1206 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 2140 cycles, 1914 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 3210 cycles, 2552 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 4892 cycles, 3349 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 8442 cycles, 3881 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 15562 cycles, 4211 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 29794 cycles, 4399 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1051 cycles, 60 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1065 cycles, 120 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1093 cycles, 468 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1437 cycles, 712 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 1917 cycles, 1068 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 2292 cycles, 1787 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 3159 cycles, 2593 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 5138 cycles, 3188 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 8752 cycles, 3744 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 15656 cycles, 4185 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 29852 cycles, 4390 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8 bytes, 1014 cycles, 63 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 1171 cycles, 109 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 997 cycles, 256 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1378 cycles, 743 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 1935 cycles, 1058 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 2374 cycles, 1725 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 3215 cycles, 2548 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 5099 cycles, 3213 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 8433 cycles, 3885 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 15536 cycles, 4218 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 29809 cycles, 4397 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8 bytes, 1035 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1015 cycles, 126 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1007 cycles, 254 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1297 cycles, 394 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1303 cycles, 785 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 1937 cycles, 1057 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 2377 cycles, 1723 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 3217 cycles, 2546 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 5095 cycles, 3215 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 8425 cycles, 3889 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 15797 cycles, 4148 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 30029 cycles, 4364 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1081 cycles, 59 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1068 cycles, 119 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1154 cycles, 221 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1554 cycles, 658 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 1907 cycles, 1073 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 2337 cycles, 1752 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 3201 cycles, 2559 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 5135 cycles, 3190 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 8793 cycles, 3726 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 15711 cycles, 4171 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 29926 cycles, 4379 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 994 cycles, 64 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1009 cycles, 126 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1074 cycles, 238 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1253 cycles, 408 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1464 cycles, 699 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 2118 cycles, 966 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 2385 cycles, 1717 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 3218 cycles, 2545 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 4999 cycles, 3277 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 8530 cycles, 3841 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 15699 cycles, 4174 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 30036 cycles, 4363 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1094 cycles, 117 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1162 cycles, 220 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1250 cycles, 409 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1543 cycles, 663 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 2132 cycles, 960 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 2393 cycles, 1711 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 3311 cycles, 2474 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 5081 cycles, 3224 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 8612 cycles, 3804 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 15709 cycles, 4171 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 29946 cycles, 4376 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1188 cycles, 53 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1184 cycles, 108 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1249 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1343 cycles, 381 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1651 cycles, 620 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 2295 cycles, 892 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 2478 cycles, 1652 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 3315 cycles, 2471 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 5089 cycles, 3219 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 8723 cycles, 3756 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 15798 cycles, 4148 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 29946 cycles, 4376 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1063 cycles, 60 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1078 cycles, 118 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1158 cycles, 221 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1255 cycles, 407 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1532 cycles, 668 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 2095 cycles, 977 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 2375 cycles, 1724 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 3296 cycles, 2485 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 5072 cycles, 3230 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 8615 cycles, 3803 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 15674 cycles, 4181 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 30032 cycles, 4364 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1063 cycles, 60 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1072 cycles, 119 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1158 cycles, 221 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1342 cycles, 381 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1533 cycles, 667 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 2181 cycles, 939 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 2374 cycles, 1725 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 3299 cycles, 2483 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 5065 cycles, 3234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 8607 cycles, 3807 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 15699 cycles, 4174 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 29928 cycles, 4379 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1169 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1162 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1259 cycles, 203 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1435 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1626 cycles, 629 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 2375 cycles, 862 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 2467 cycles, 1660 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 3388 cycles, 2417 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 5155 cycles, 3178 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 8698 cycles, 3767 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 15779 cycles, 4153 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 30014 cycles, 4367 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1168 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1170 cycles, 109 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1274 cycles, 200 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1438 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1631 cycles, 627 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 2279 cycles, 898 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 2470 cycles, 1658 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 3390 cycles, 2416 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 5165 cycles, 3172 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 8720 cycles, 3757 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 15886 cycles, 4125 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 30145 cycles, 4348 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1257 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1259 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1276 cycles, 200 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1439 cycles, 355 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1724 cycles, 593 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 2281 cycles, 897 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 2554 cycles, 1603 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 3397 cycles, 2411 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 5173 cycles, 3167 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 8716 cycles, 3759 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 15869 cycles, 4129 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 30033 cycles, 4364 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1352 cycles, 47 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1351 cycles, 94 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1460 cycles, 175 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1540 cycles, 332 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1814 cycles, 564 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2473 cycles, 828 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 2571 cycles, 1593 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 3484 cycles, 2351 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 5259 cycles, 3115 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 8885 cycles, 3688 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 15900 cycles, 4121 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 30113 cycles, 4352 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 4xLaneABCD
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 913 cycles, 280 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 917 cycles, 558 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1294 cycles, 791 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 1577 cycles, 1298 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 1951 cycles, 2099 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 2407 cycles, 3403 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 3206 cycles, 5110 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 5131 cycles, 6386 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 8993 cycles, 7287 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 16956 cycles, 7730 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 947 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 923 cycles, 277 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1195 cycles, 428 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1307 cycles, 783 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 1581 cycles, 1295 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 1945 cycles, 2105 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 2407 cycles, 3403 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 3201 cycles, 5118 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 5119 cycles, 6401 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 9227 cycles, 7102 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 16905 cycles, 7753 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 994 cycles, 64 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 982 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1026 cycles, 499 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1460 cycles, 701 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 1801 cycles, 1137 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 1900 cycles, 2155 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 2392 cycles, 3424 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 3480 cycles, 4708 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 5199 cycles, 6302 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 9201 cycles, 7122 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 16873 cycles, 7768 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 995 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 995 cycles, 257 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 997 cycles, 513 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1296 cycles, 790 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 1576 cycles, 1299 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 1752 cycles, 2337 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 2364 cycles, 3465 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 3224 cycles, 5081 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 5124 cycles, 6395 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 9003 cycles, 7279 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 16963 cycles, 7726 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 965 cycles, 132 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 981 cycles, 521 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1291 cycles, 793 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 1568 cycles, 1306 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 1744 cycles, 2348 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 2412 cycles, 3396 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 3204 cycles, 5113 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 5164 cycles, 6345 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 9256 cycles, 7080 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 16958 cycles, 7729 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1065 cycles, 480 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1435 cycles, 713 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 1785 cycles, 1147 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 1964 cycles, 2085 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 2289 cycles, 3578 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 3502 cycles, 4678 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 5460 cycles, 6001 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 9216 cycles, 7111 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 17102 cycles, 7664 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 999 cycles, 512 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1374 cycles, 745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 1652 cycles, 1239 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 1830 cycles, 2238 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 2279 cycles, 3594 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 3346 cycles, 4896 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 5347 cycles, 6128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 9182 cycles, 7137 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 17015 cycles, 7703 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1007 cycles, 508 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1301 cycles, 787 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 1661 cycles, 1232 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 1839 cycles, 2227 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 2553 cycles, 3208 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 3339 cycles, 4906 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 5261 cycles, 6228 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 9179 cycles, 7139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 17013 cycles, 7704 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1169 cycles, 54 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1154 cycles, 110 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1068 cycles, 239 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1122 cycles, 456 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1550 cycles, 660 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 1901 cycles, 1077 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 2079 cycles, 1970 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 2481 cycles, 3301 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 3363 cycles, 4871 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 5293 cycles, 6190 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 9199 cycles, 7124 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 16958 cycles, 7729 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1003 cycles, 63 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 992 cycles, 129 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1072 cycles, 238 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1160 cycles, 441 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1354 cycles, 756 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 1902 cycles, 1076 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 1911 cycles, 2143 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 2459 cycles, 3331 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 3388 cycles, 4835 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 5341 cycles, 6135 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 9204 cycles, 7120 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 17079 cycles, 7674 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 998 cycles, 64 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1018 cycles, 125 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1072 cycles, 238 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1252 cycles, 408 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1435 cycles, 713 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 1900 cycles, 1077 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 1997 cycles, 2051 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 2458 cycles, 3332 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 3392 cycles, 4830 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 5351 cycles, 6123 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 9294 cycles, 7051 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 17022 cycles, 7700 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1119 cycles, 57 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1157 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1165 cycles, 219 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1349 cycles, 379 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1528 cycles, 670 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 2088 cycles, 980 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 2097 cycles, 1953 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 2487 cycles, 3293 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 3490 cycles, 4694 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 5444 cycles, 6019 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 9351 cycles, 7008 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 17079 cycles, 7674 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 988 cycles, 64 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1063 cycles, 120 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1091 cycles, 234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1183 cycles, 432 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1383 cycles, 740 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 1918 cycles, 1067 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 1928 cycles, 2124 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 2474 cycles, 3311 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 3410 cycles, 4804 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 5365 cycles, 6107 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 9281 cycles, 7061 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 17102 cycles, 7664 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1090 cycles, 234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1277 cycles, 400 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1459 cycles, 701 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 1929 cycles, 1061 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 2008 cycles, 2039 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 2480 cycles, 3303 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 3420 cycles, 4790 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 5367 cycles, 6105 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 9279 cycles, 7062 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 17037 cycles, 7693 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1157 cycles, 55 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1158 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1250 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1344 cycles, 380 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1557 cycles, 657 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 2096 cycles, 977 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 2104 cycles, 1946 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 2572 cycles, 3185 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 3508 cycles, 4670 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 5447 cycles, 6015 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 9364 cycles, 6998 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 17089 cycles, 7669 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1179 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1185 cycles, 108 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1265 cycles, 202 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1344 cycles, 380 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1538 cycles, 665 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 2005 cycles, 1021 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 2089 cycles, 1960 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 2554 cycles, 3207 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 3575 cycles, 4582 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 5465 cycles, 5995 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 9357 cycles, 7003 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 17269 cycles, 7590 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1175 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1190 cycles, 107 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1264 cycles, 202 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1349 cycles, 379 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1624 cycles, 630 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 2092 cycles, 978 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 2089 cycles, 1960 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 2566 cycles, 3192 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 3583 cycles, 4572 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 5546 cycles, 5908 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 9445 cycles, 6938 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 17172 cycles, 7632 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1366 cycles, 46 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1371 cycles, 93 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1358 cycles, 188 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1530 cycles, 334 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1718 cycles, 596 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2278 cycles, 899 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 2276 cycles, 1799 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 2655 cycles, 3085 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 3684 cycles, 4447 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 6190 cycles, 5293 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 13910 cycles, 4711 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 18566 cycles, 7059 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO link speed is 2.500Gbps
[C66xx_0] SRIO path configuration 1xLaneA
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8 bytes, 1172 cycles, 54 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 1184 cycles, 108 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1192 cycles, 214 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1537 cycles, 333 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1772 cycles, 577 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 2578 cycles, 794 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 3891 cycles, 1052 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 5920 cycles, 1383 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 10321 cycles, 1587 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 19367 cycles, 1691 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 37224 cycles, 1760 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 73011 cycles, 1795 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 945 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 1189 cycles, 107 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 1197 cycles, 213 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1537 cycles, 333 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1777 cycles, 576 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 2579 cycles, 794 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 3879 cycles, 1055 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 5915 cycles, 1384 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 10325 cycles, 1586 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 19341 cycles, 1694 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 37143 cycles, 1764 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 72927 cycles, 1797 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 1342 cycles, 47 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 1326 cycles, 96 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 1350 cycles, 189 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1416 cycles, 361 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1994 cycles, 513 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 2865 cycles, 714 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 3886 cycles, 1054 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 5946 cycles, 1377 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 10390 cycles, 1576 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 19329 cycles, 1695 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 37191 cycles, 1762 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 73059 cycles, 1794 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8 bytes, 1024 cycles, 62 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 1274 cycles, 200 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1555 cycles, 329 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1772 cycles, 577 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 2577 cycles, 794 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 3909 cycles, 1047 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 5939 cycles, 1379 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 10338 cycles, 1584 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 19366 cycles, 1692 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 37225 cycles, 1760 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 73012 cycles, 1795 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1033 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 1233 cycles, 103 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 1253 cycles, 204 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1527 cycles, 335 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1823 cycles, 561 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 2628 cycles, 779 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 3884 cycles, 1054 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 5986 cycles, 1368 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 10588 cycles, 1547 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 19344 cycles, 1693 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 37130 cycles, 1765 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 72912 cycles, 1797 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1081 cycles, 118 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1415 cycles, 180 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1417 cycles, 361 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1979 cycles, 517 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 2855 cycles, 717 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 3908 cycles, 1048 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 5979 cycles, 1370 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 10454 cycles, 1567 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 19354 cycles, 1693 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 37194 cycles, 1762 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 73012 cycles, 1795 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8 bytes, 1291 cycles, 49 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 1272 cycles, 100 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1276 cycles, 200 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1641 cycles, 312 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1785 cycles, 573 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 2874 cycles, 712 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 3916 cycles, 1045 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 6208 cycles, 1319 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 10580 cycles, 1548 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 19397 cycles, 1689 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 37168 cycles, 1763 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 73186 cycles, 1790 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1277 cycles, 100 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1281 cycles, 199 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1555 cycles, 329 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 2043 cycles, 501 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 2867 cycles, 714 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 3915 cycles, 1046 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 6197 cycles, 1321 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 10565 cycles, 1550 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 19375 cycles, 1691 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 37379 cycles, 1753 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 73011 cycles, 1795 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1442 cycles, 88 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1358 cycles, 188 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1794 cycles, 285 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 2046 cycles, 500 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 2903 cycles, 705 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 3927 cycles, 1043 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 6277 cycles, 1305 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 10605 cycles, 1544 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 19453 cycles, 1684 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 37269 cycles, 1758 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 72994 cycles, 1795 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1179 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1177 cycles, 108 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1344 cycles, 190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1528 cycles, 335 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1995 cycles, 513 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 2925 cycles, 700 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 3873 cycles, 1057 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 6104 cycles, 1342 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 10507 cycles, 1559 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 19516 cycles, 1679 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 37377 cycles, 1753 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 73122 cycles, 1792 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 1178 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1250 cycles, 102 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1351 cycles, 189 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1633 cycles, 313 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1999 cycles, 512 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 3016 cycles, 679 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 3860 cycles, 1061 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 6092 cycles, 1344 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 10558 cycles, 1551 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 19505 cycles, 1679 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 37380 cycles, 1753 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 73038 cycles, 1794 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1275 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1364 cycles, 93 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1435 cycles, 178 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1636 cycles, 312 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 2086 cycles, 490 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 3212 cycles, 637 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 3957 cycles, 1035 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 6204 cycles, 1320 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 10675 cycles, 1534 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 19598 cycles, 1672 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 37584 cycles, 1743 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 73119 cycles, 1792 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1183 cycles, 54 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1258 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1344 cycles, 190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1544 cycles, 331 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 2000 cycles, 512 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 3017 cycles, 678 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 3866 cycles, 1059 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 6178 cycles, 1325 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 10643 cycles, 1539 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 19523 cycles, 1678 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 37367 cycles, 1753 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 73124 cycles, 1792 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1249 cycles, 51 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1249 cycles, 102 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1351 cycles, 189 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1645 cycles, 311 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 2016 cycles, 507 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 3017 cycles, 678 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 3955 cycles, 1035 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 6189 cycles, 1323 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 10567 cycles, 1550 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 19497 cycles, 1680 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 37376 cycles, 1753 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 73118 cycles, 1792 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1342 cycles, 47 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1344 cycles, 95 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1436 cycles, 178 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1716 cycles, 298 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 2184 cycles, 468 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 3203 cycles, 639 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 4039 cycles, 1014 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 6187 cycles, 1324 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 10753 cycles, 1523 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 19588 cycles, 1672 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 37463 cycles, 1749 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 73117 cycles, 1792 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1351 cycles, 47 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1350 cycles, 94 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1454 cycles, 176 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1726 cycles, 296 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 2120 cycles, 483 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 3128 cycles, 654 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 4042 cycles, 1013 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 6282 cycles, 1304 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 10745 cycles, 1524 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 19685 cycles, 1664 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 37470 cycles, 1749 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 73224 cycles, 1790 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1359 cycles, 47 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1454 cycles, 88 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1543 cycles, 165 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1742 cycles, 293 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 2197 cycles, 466 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 3120 cycles, 656 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 4051 cycles, 1011 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 6283 cycles, 1303 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 10747 cycles, 1524 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 19687 cycles, 1664 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 37468 cycles, 1749 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 73212 cycles, 1790 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1456 cycles, 43 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1536 cycles, 83 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1637 cycles, 156 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1851 cycles, 276 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 2303 cycles, 444 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 3307 cycles, 619 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 4143 cycles, 988 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 6367 cycles, 1286 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 10764 cycles, 1522 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 19778 cycles, 1656 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 37659 cycles, 1740 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 73213 cycles, 1790 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 2xLaneAB
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8 bytes, 897 cycles, 71 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 909 cycles, 140 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1186 cycles, 215 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1194 cycles, 428 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1577 cycles, 649 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 2048 cycles, 1000 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 2603 cycles, 1573 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 3611 cycles, 2268 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 5975 cycles, 2742 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 10381 cycles, 3156 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 19372 cycles, 3383 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 36930 cycles, 3549 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 921 cycles, 138 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 1193 cycles, 214 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1199 cycles, 427 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1581 cycles, 647 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 2047 cycles, 1000 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 2607 cycles, 1571 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 3873 cycles, 2115 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 5967 cycles, 2745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 10589 cycles, 3094 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 19343 cycles, 3388 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 37155 cycles, 3527 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 996 cycles, 64 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 1000 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 1344 cycles, 190 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1406 cycles, 364 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1800 cycles, 568 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 2067 cycles, 990 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 2596 cycles, 1577 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 3882 cycles, 2110 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 5968 cycles, 2745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 10437 cycles, 3139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 19413 cycles, 3375 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 37171 cycles, 3526 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 997 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 997 cycles, 256 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1276 cycles, 401 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1577 cycles, 649 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 2047 cycles, 1000 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 2620 cycles, 1563 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 3623 cycles, 2261 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 5926 cycles, 2764 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 10321 cycles, 3174 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 19373 cycles, 3382 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 37236 cycles, 3520 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 963 cycles, 132 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 1251 cycles, 204 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1251 cycles, 409 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1567 cycles, 653 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 2096 cycles, 977 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 2612 cycles, 1568 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 3880 cycles, 2111 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 5972 cycles, 2743 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 10358 cycles, 3163 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 19400 cycles, 3378 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 37138 cycles, 3529 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1053 cycles, 60 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1065 cycles, 120 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1069 cycles, 239 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1413 cycles, 362 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1789 cycles, 572 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 2327 cycles, 880 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 2610 cycles, 1569 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 3905 cycles, 2097 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 5952 cycles, 2752 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 10414 cycles, 3146 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 19298 cycles, 3395 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 37432 cycles, 3501 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8 bytes, 1014 cycles, 63 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 997 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1272 cycles, 201 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1276 cycles, 401 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1653 cycles, 619 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 2063 cycles, 992 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 2853 cycles, 1435 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 3891 cycles, 2105 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 5968 cycles, 2745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 10589 cycles, 3094 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 19381 cycles, 3381 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 37176 cycles, 3525 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8 bytes, 1035 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1007 cycles, 127 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1277 cycles, 200 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1281 cycles, 399 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1575 cycles, 650 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 2065 cycles, 991 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 2589 cycles, 1582 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 3887 cycles, 2107 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 5967 cycles, 2745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 10571 cycles, 3099 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 19357 cycles, 3385 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 37111 cycles, 3531 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1167 cycles, 54 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1110 cycles, 115 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1442 cycles, 177 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1324 cycles, 386 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1566 cycles, 653 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 2379 cycles, 860 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 2881 cycles, 1421 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 3957 cycles, 2070 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 6323 cycles, 2591 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 10497 cycles, 3121 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 19347 cycles, 3387 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 37136 cycles, 3529 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1086 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1088 cycles, 117 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1171 cycles, 218 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1345 cycles, 380 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1656 cycles, 618 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 2391 cycles, 856 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 2760 cycles, 1484 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 3881 cycles, 2110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 6121 cycles, 2676 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 10558 cycles, 3103 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 19419 cycles, 3374 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 37281 cycles, 3515 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1178 cycles, 108 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1258 cycles, 203 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1441 cycles, 355 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1723 cycles, 594 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 2464 cycles, 831 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 2753 cycles, 1487 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 3881 cycles, 2110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 6106 cycles, 2683 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 10559 cycles, 3103 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 19402 cycles, 3377 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 37186 cycles, 3524 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1251 cycles, 51 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1271 cycles, 100 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1342 cycles, 190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1531 cycles, 334 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1834 cycles, 558 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 2570 cycles, 796 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 2859 cycles, 1432 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 3972 cycles, 2062 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 6208 cycles, 2639 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 10652 cycles, 3076 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 19509 cycles, 3359 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 37203 cycles, 3523 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1156 cycles, 55 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1156 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1251 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1363 cycles, 375 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1728 cycles, 592 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 2380 cycles, 860 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 2737 cycles, 1496 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 3860 cycles, 2122 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 6104 cycles, 2684 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 10559 cycles, 3103 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 19409 cycles, 3376 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 37277 cycles, 3516 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1156 cycles, 55 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1161 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1249 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1436 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1741 cycles, 588 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 2459 cycles, 832 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 2832 cycles, 1446 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 3875 cycles, 2114 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c01a000, 2048 bytes, 6094 cycles, 2688 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c02a000, 4096 bytes, 10555 cycles, 3104 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c032000, 8192 bytes, 19497 cycles, 3361 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c00a000, 16384 bytes, 37185 cycles, 3524 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000600, 8 bytes, 1253 cycles, 51 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000700, 16 bytes, 1258 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000800, 32 bytes, 1344 cycles, 190 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000900, 64 bytes, 1539 cycles, 332 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000a00, 128 bytes, 1812 cycles, 565 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000b00, 256 bytes, 2645 cycles, 774 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82084000, 512 bytes, 2845 cycles, 1439 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82094000, 1024 bytes, 3946 cycles, 2076 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820a4000, 2048 bytes, 6187 cycles, 2648 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820b4000, 4096 bytes, 10651 cycles, 3076 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820c4000, 8192 bytes, 19505 cycles, 3359 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820d4000, 16384 bytes, 37276 cycles, 3516 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1279 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1260 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1376 cycles, 186 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1530 cycles, 334 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1826 cycles, 560 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 2557 cycles, 800 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 2926 cycles, 1399 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 4041 cycles, 2027 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 6203 cycles, 2641 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 10658 cycles, 3074 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 19532 cycles, 3355 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 37392 cycles, 3505 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1278 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1351 cycles, 94 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1369 cycles, 186 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1625 cycles, 315 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1903 cycles, 538 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 2562 cycles, 799 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 2926 cycles, 1399 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c01a000, 1024 bytes, 4051 cycles, 2022 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 6283 cycles, 2607 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 10657 cycles, 3074 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 19591 cycles, 3345 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 37377 cycles, 3506 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1442 cycles, 44 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1443 cycles, 88 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1565 cycles, 163 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1716 cycles, 298 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1997 cycles, 512 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2744 cycles, 746 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 3018 cycles, 1357 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 4063 cycles, 2016 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 6366 cycles, 2573 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 10748 cycles, 3048 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 19682 cycles, 3329 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 37379 cycles, 3506 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 4xLaneABCD
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 911 cycles, 140 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1190 cycles, 215 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1190 cycles, 430 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 1296 cycles, 790 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 1854 cycles, 1104 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 2089 cycles, 1960 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 2605 cycles, 3144 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 3880 cycles, 4222 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 6515 cycles, 5029 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 11197 cycles, 5852 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 20831 cycles, 6292 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 947 cycles, 67 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1197 cycles, 427 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 1305 cycles, 784 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 1853 cycles, 1105 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 2083 cycles, 1966 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 2599 cycles, 3151 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 3869 cycles, 4234 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 6491 cycles, 5048 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 11159 cycles, 5872 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 21043 cycles, 6228 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 998 cycles, 128 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 1022 cycles, 250 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1346 cycles, 380 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 1448 cycles, 707 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 1797 cycles, 1139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 2080 cycles, 1969 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 2874 cycles, 2850 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 3898 cycles, 4203 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 6333 cycles, 5174 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 11241 cycles, 5830 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 20929 cycles, 6262 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 995 cycles, 257 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1270 cycles, 403 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 1296 cycles, 790 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 1851 cycles, 1106 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 2096 cycles, 1954 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 2626 cycles, 3119 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 3901 cycles, 4199 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 6270 cycles, 5226 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 11198 cycles, 5852 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 21111 cycles, 6208 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1035 cycles, 61 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 981 cycles, 260 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1249 cycles, 409 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 1291 cycles, 793 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 1840 cycles, 1113 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 2078 cycles, 1971 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 2882 cycles, 2842 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 3874 cycles, 4229 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 6522 cycles, 5024 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 11142 cycles, 5881 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 21028 cycles, 6233 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1051 cycles, 60 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1065 cycles, 240 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1411 cycles, 362 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 1435 cycles, 713 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 1791 cycles, 1143 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 2376 cycles, 1723 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 2897 cycles, 2827 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 3960 cycles, 4137 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 6506 cycles, 5036 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 11214 cycles, 5844 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 21192 cycles, 6184 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1171 cycles, 218 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1272 cycles, 402 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 1374 cycles, 745 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 1929 cycles, 1061 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 2108 cycles, 1943 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 2900 cycles, 2824 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 4167 cycles, 3931 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 6499 cycles, 5042 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 11489 cycles, 5704 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 21121 cycles, 6205 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1007 cycles, 254 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1277 cycles, 400 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 1571 cycles, 651 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 1933 cycles, 1059 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 2111 cycles, 1940 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 2895 cycles, 2829 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 4155 cycles, 3943 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 6477 cycles, 5059 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 11441 cycles, 5728 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 21001 cycles, 6241 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1068 cycles, 119 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1234 cycles, 207 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1442 cycles, 355 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 1550 cycles, 660 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 1901 cycles, 1077 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 2427 cycles, 1687 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 2913 cycles, 2812 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 4263 cycles, 3843 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 6433 cycles, 5093 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 11325 cycles, 5786 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 21270 cycles, 6162 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1087 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1094 cycles, 117 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1158 cycles, 221 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1259 cycles, 406 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 1528 cycles, 670 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 2118 cycles, 966 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 2207 cycles, 1855 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 2858 cycles, 2866 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 4048 cycles, 4047 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 6502 cycles, 5039 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 11328 cycles, 5785 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 21192 cycles, 6184 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 1085 cycles, 58 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1156 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1156 cycles, 221 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1361 cycles, 376 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 1537 cycles, 666 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 2179 cycles, 939 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 2213 cycles, 1850 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 2830 cycles, 2894 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 4039 cycles, 4056 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 6503 cycles, 5038 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 11407 cycles, 5745 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 21106 cycles, 6210 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1193 cycles, 53 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1202 cycles, 106 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1249 cycles, 204 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 1442 cycles, 355 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 1633 cycles, 627 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 2300 cycles, 890 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 2310 cycles, 1773 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 2949 cycles, 2777 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 4141 cycles, 3956 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 6551 cycles, 5001 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 11418 cycles, 5739 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 21108 cycles, 6209 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1069 cycles, 59 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1181 cycles, 216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1348 cycles, 379 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 1541 cycles, 664 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 2180 cycles, 939 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 2273 cycles, 1802 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 2831 cycles, 2893 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 4049 cycles, 4046 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 6473 cycles, 5062 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 11396 cycles, 5750 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 21188 cycles, 6186 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1157 cycles, 55 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1162 cycles, 110 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1173 cycles, 218 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1342 cycles, 381 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 1629 cycles, 628 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 2184 cycles, 937 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 2272 cycles, 1802 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 2849 cycles, 2875 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 4060 cycles, 4035 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 6561 cycles, 4994 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 11396 cycles, 5750 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 21090 cycles, 6214 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1250 cycles, 51 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1251 cycles, 102 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 1280 cycles, 200 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 1435 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 1719 cycles, 595 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 2366 cycles, 865 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 2371 cycles, 1727 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 2923 cycles, 2802 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 4141 cycles, 3956 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 6559 cycles, 4995 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 11491 cycles, 5703 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 21185 cycles, 6187 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1257 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1266 cycles, 101 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1358 cycles, 188 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 1437 cycles, 356 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 1718 cycles, 596 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 2279 cycles, 898 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 2368 cycles, 1729 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 3018 cycles, 2714 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 4232 cycles, 3871 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 6654 cycles, 4924 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 11514 cycles, 5691 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 21282 cycles, 6158 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1258 cycles, 50 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1268 cycles, 100 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1357 cycles, 188 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 1532 cycles, 334 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 1717 cycles, 596 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 2289 cycles, 894 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 2377 cycles, 1723 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 3018 cycles, 2714 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 4235 cycles, 3868 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 6664 cycles, 4917 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 11497 cycles, 5700 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 21278 cycles, 6159 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1445 cycles, 44 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1461 cycles, 87 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1460 cycles, 175 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 1626 cycles, 314 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 1823 cycles, 561 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 2474 cycles, 827 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 2460 cycles, 1665 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 3115 cycles, 2629 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 4332 cycles, 3782 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 6741 cycles, 4860 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 11595 cycles, 5652 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 21281 cycles, 6159 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO link speed is 1.250Gbps
[C66xx_0] SRIO path configuration 1xLaneA
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8 bytes, 1447 cycles, 44 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 1740 cycles, 73 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1810 cycles, 141 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 2354 cycles, 217 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 3134 cycles, 326 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 4488 cycles, 456 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 6768 cycles, 605 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 11185 cycles, 732 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 20225 cycles, 810 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 38072 cycles, 860 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 73651 cycles, 889 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 145136 cycles, 903 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 1485 cycles, 43 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 1735 cycles, 73 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 1811 cycles, 141 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 2341 cycles, 218 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 3127 cycles, 327 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 4743 cycles, 431 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 6749 cycles, 606 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 11429 cycles, 716 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 20201 cycles, 811 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 38213 cycles, 857 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 73831 cycles, 887 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 145193 cycles, 902 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 1686 cycles, 37 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 1694 cycles, 75 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 2106 cycles, 121 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 2372 cycles, 215 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 3216 cycles, 318 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 4647 cycles, 440 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 6976 cycles, 587 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 11488 cycles, 713 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 20374 cycles, 804 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 38175 cycles, 858 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 73739 cycles, 888 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 145147 cycles, 903 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8 bytes, 1574 cycles, 40 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 1552 cycles, 82 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 1832 cycles, 139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 2306 cycles, 222 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 3136 cycles, 326 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 4490 cycles, 456 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 6788 cycles, 603 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 11202 cycles, 731 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 20222 cycles, 810 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 38087 cycles, 860 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 73725 cycles, 888 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 145221 cycles, 902 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1575 cycles, 40 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 1777 cycles, 72 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 1799 cycles, 142 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 2331 cycles, 219 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 3175 cycles, 322 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 4728 cycles, 433 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 6834 cycles, 599 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 11434 cycles, 716 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 20238 cycles, 809 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 37978 cycles, 862 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 73870 cycles, 887 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 145266 cycles, 902 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1741 cycles, 36 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1765 cycles, 72 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1789 cycles, 143 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 2311 cycles, 221 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 3201 cycles, 319 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 4631 cycles, 442 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 6998 cycles, 585 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 11499 cycles, 712 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 20396 cycles, 803 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 38212 cycles, 857 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 73850 cycles, 887 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 145118 cycles, 903 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8 bytes, 1564 cycles, 40 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 1828 cycles, 70 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1832 cycles, 139 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 2308 cycles, 221 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 3150 cycles, 325 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 4713 cycles, 434 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 7083 cycles, 578 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 11464 cycles, 714 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 20251 cycles, 809 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 38027 cycles, 861 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 73974 cycles, 885 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 145216 cycles, 902 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8 bytes, 1575 cycles, 40 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1821 cycles, 70 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1827 cycles, 140 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 2295 cycles, 223 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 3121 cycles, 328 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 4693 cycles, 436 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 7059 cycles, 580 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 11431 cycles, 716 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 20491 cycles, 799 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 38225 cycles, 857 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 73831 cycles, 887 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 145361 cycles, 901 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1889 cycles, 33 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1794 cycles, 71 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 2144 cycles, 119 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 2340 cycles, 218 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 3252 cycles, 314 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 4969 cycles, 412 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 7011 cycles, 584 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 11539 cycles, 709 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 20401 cycles, 803 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 38175 cycles, 858 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 73797 cycles, 888 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 145294 cycles, 902 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1642 cycles, 38 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1735 cycles, 73 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1908 cycles, 134 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 2369 cycles, 216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 3131 cycles, 327 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 4971 cycles, 411 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 6933 cycles, 590 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 11420 cycles, 717 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 20425 cycles, 802 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 38146 cycles, 859 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 73971 cycles, 885 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 145404 cycles, 901 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 1643 cycles, 38 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1717 cycles, 74 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1932 cycles, 132 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 2365 cycles, 216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 3225 cycles, 317 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 4918 cycles, 416 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 6943 cycles, 589 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 11492 cycles, 712 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 20362 cycles, 804 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 38222 cycles, 857 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 73954 cycles, 886 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 145357 cycles, 901 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1743 cycles, 36 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1838 cycles, 69 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 2086 cycles, 122 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 2465 cycles, 207 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 3310 cycles, 309 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 5166 cycles, 396 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 7062 cycles, 580 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 11490 cycles, 712 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 20425 cycles, 802 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 38345 cycles, 854 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 73974 cycles, 885 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 145287 cycles, 902 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1621 cycles, 39 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1729 cycles, 74 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1998 cycles, 128 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 2374 cycles, 215 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 3207 cycles, 319 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 4982 cycles, 411 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 7025 cycles, 583 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 11414 cycles, 717 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 20333 cycles, 805 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 38150 cycles, 858 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 73946 cycles, 886 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 145361 cycles, 901 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1714 cycles, 37 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1812 cycles, 70 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1993 cycles, 128 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 2381 cycles, 215 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 3210 cycles, 319 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 4982 cycles, 411 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 7026 cycles, 582 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 11420 cycles, 717 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c022000, 2048 bytes, 20433 cycles, 801 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c02a000, 4096 bytes, 38208 cycles, 857 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c032000, 8192 bytes, 73955 cycles, 886 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c00a000, 16384 bytes, 145266 cycles, 902 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000600, 8 bytes, 1807 cycles, 35 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000700, 16 bytes, 1900 cycles, 67 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000800, 32 bytes, 2088 cycles, 122 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000900, 64 bytes, 2580 cycles, 198 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000a00, 128 bytes, 3308 cycles, 309 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82000b00, 256 bytes, 5165 cycles, 396 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82084000, 512 bytes, 7033 cycles, 582 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x82094000, 1024 bytes, 11491 cycles, 712 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820a4000, 2048 bytes, 20518 cycles, 798 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820b4000, 4096 bytes, 38245 cycles, 856 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820c4000, 8192 bytes, 73954 cycles, 886 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x820d4000, 16384 bytes, 145361 cycles, 901 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1819 cycles, 35 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1913 cycles, 66 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 2102 cycles, 121 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 2554 cycles, 200 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 3314 cycles, 308 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 5075 cycles, 403 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 7111 cycles, 576 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 11583 cycles, 707 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 20528 cycles, 798 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 38327 cycles, 854 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 74049 cycles, 885 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 145493 cycles, 900 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1818 cycles, 35 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 2006 cycles, 63 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 2110 cycles, 121 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 2588 cycles, 197 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 3394 cycles, 301 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 5091 cycles, 402 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 7121 cycles, 575 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c022000, 1024 bytes, 11676 cycles, 701 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 20529 cycles, 798 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 38338 cycles, 854 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 74050 cycles, 885 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 145452 cycles, 901 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 2000 cycles, 32 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 2097 cycles, 61 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 2210 cycles, 115 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 2648 cycles, 193 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 3491 cycles, 293 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 5273 cycles, 388 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 7210 cycles, 568 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 11682 cycles, 701 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82034000, 2048 bytes, 20622 cycles, 794 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82044000, 4096 bytes, 38403 cycles, 853 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82054000, 8192 bytes, 74142 cycles, 883 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82064000, 16384 bytes, 145460 cycles, 901 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 2xLaneAB
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16 bytes, 1459 cycles, 87 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1469 cycles, 174 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1814 cycles, 282 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 2328 cycles, 439 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 3413 cycles, 600 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 4730 cycles, 865 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 6767 cycles, 1210 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 11164 cycles, 1467 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 20216 cycles, 1620 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 38021 cycles, 1723 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 73425 cycles, 1785 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8 bytes, 1487 cycles, 43 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16 bytes, 1459 cycles, 87 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 1737 cycles, 147 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1809 cycles, 283 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 2321 cycles, 441 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 3399 cycles, 602 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 4699 cycles, 871 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 6743 cycles, 1214 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 11407 cycles, 1436 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 20171 cycles, 1624 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 37939 cycles, 1727 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 73331 cycles, 1787 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 1684 cycles, 38 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 1670 cycles, 76 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 1680 cycles, 152 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 2112 cycles, 242 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 2360 cycles, 433 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 3563 cycles, 574 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 4606 cycles, 889 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 6966 cycles, 1175 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 11302 cycles, 1449 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 20085 cycles, 1631 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 37923 cycles, 1728 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 73609 cycles, 1780 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 1545 cycles, 82 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 1552 cycles, 164 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1832 cycles, 279 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 2328 cycles, 439 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 3424 cycles, 598 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 4748 cycles, 862 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 6784 cycles, 1207 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 11464 cycles, 1429 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 20215 cycles, 1620 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 38025 cycles, 1723 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 73444 cycles, 1784 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16 bytes, 1503 cycles, 85 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 1523 cycles, 168 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1799 cycles, 284 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 2367 cycles, 432 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 3450 cycles, 593 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 4706 cycles, 870 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 6814 cycles, 1202 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 11412 cycles, 1435 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 20176 cycles, 1624 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 38012 cycles, 1724 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 73556 cycles, 1781 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1743 cycles, 36 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1755 cycles, 72 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1765 cycles, 145 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 2113 cycles, 242 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 2675 cycles, 382 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 3551 cycles, 576 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 4790 cycles, 855 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 6989 cycles, 1172 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 11240 cycles, 1457 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 20152 cycles, 1626 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 37884 cycles, 1729 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 73418 cycles, 1785 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16 bytes, 1547 cycles, 82 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1552 cycles, 164 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1832 cycles, 279 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 2621 cycles, 390 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 3426 cycles, 597 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 4756 cycles, 861 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 6770 cycles, 1210 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 11431 cycles, 1433 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 20243 cycles, 1618 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 38045 cycles, 1722 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 73661 cycles, 1779 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16 bytes, 1547 cycles, 82 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1551 cycles, 165 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1827 cycles, 280 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 2587 cycles, 395 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 3427 cycles, 597 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 4735 cycles, 865 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 6789 cycles, 1206 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 11399 cycles, 1437 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 20203 cycles, 1621 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 37969 cycles, 1726 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 73543 cycles, 1782 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8 bytes, 1543 cycles, 41 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1530 cycles, 83 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1704 cycles, 150 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 2052 cycles, 249 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 2728 cycles, 375 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 3599 cycles, 569 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 4659 cycles, 879 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 6979 cycles, 1173 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 11463 cycles, 1429 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 20385 cycles, 1607 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 38049 cycles, 1722 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 73538 cycles, 1782 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1551 cycles, 41 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1574 cycles, 81 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1725 cycles, 148 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1996 cycles, 256 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 2551 cycles, 401 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 3800 cycles, 538 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 4695 cycles, 872 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 6941 cycles, 1180 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 11341 cycles, 1444 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 20251 cycles, 1618 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 38022 cycles, 1723 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 73676 cycles, 1779 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 1550 cycles, 41 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1624 cycles, 78 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1723 cycles, 148 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 2002 cycles, 255 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 2553 cycles, 401 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 3799 cycles, 539 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 4730 cycles, 865 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 6940 cycles, 1180 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 11401 cycles, 1437 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 20343 cycles, 1610 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 38025 cycles, 1723 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 73522 cycles, 1782 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1650 cycles, 38 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1736 cycles, 73 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1807 cycles, 141 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 2102 cycles, 243 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 2737 cycles, 374 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 3972 cycles, 515 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 4797 cycles, 853 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 7203 cycles, 1137 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 11488 cycles, 1426 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 20366 cycles, 1608 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 38208 cycles, 1715 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 73584 cycles, 1781 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1558 cycles, 41 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1552 cycles, 82 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1719 cycles, 148 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 2002 cycles, 255 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 2592 cycles, 395 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 3860 cycles, 530 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 4706 cycles, 870 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 6932 cycles, 1181 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 11405 cycles, 1436 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 20240 cycles, 1618 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 38021 cycles, 1723 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 73619 cycles, 1780 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1630 cycles, 39 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1623 cycles, 78 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1735 cycles, 147 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 2105 cycles, 243 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 2647 cycles, 386 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 3860 cycles, 530 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 4788 cycles, 855 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 6935 cycles, 1181 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c01a000, 2048 bytes, 11502 cycles, 1424 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c02a000, 4096 bytes, 20354 cycles, 1609 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c032000, 8192 bytes, 38049 cycles, 1722 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c00a000, 16384 bytes, 73583 cycles, 1781 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000600, 8 bytes, 1667 cycles, 38 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000700, 16 bytes, 1716 cycles, 74 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000800, 32 bytes, 1832 cycles, 139 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000900, 64 bytes, 2181 cycles, 234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000a00, 128 bytes, 2745 cycles, 373 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000b00, 256 bytes, 4040 cycles, 506 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82084000, 512 bytes, 4876 cycles, 840 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82094000, 1024 bytes, 7117 cycles, 1151 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820a4000, 2048 bytes, 11581 cycles, 1414 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820b4000, 4096 bytes, 20333 cycles, 1611 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820c4000, 8192 bytes, 38129 cycles, 1718 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820d4000, 16384 bytes, 73675 cycles, 1779 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1731 cycles, 36 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1728 cycles, 74 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1916 cycles, 133 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 2181 cycles, 234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 2741 cycles, 373 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 3971 cycles, 515 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 4879 cycles, 839 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 7044 cycles, 1162 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 11489 cycles, 1426 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 20343 cycles, 1610 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 38217 cycles, 1714 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 73806 cycles, 1775 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1725 cycles, 37 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1748 cycles, 73 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1914 cycles, 133 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 2184 cycles, 234 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 2746 cycles, 372 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 3960 cycles, 517 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 4888 cycles, 837 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c01a000, 1024 bytes, 7119 cycles, 1150 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 11596 cycles, 1412 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 20431 cycles, 1603 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 38208 cycles, 1715 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 73770 cycles, 1776 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1831 cycles, 34 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1911 cycles, 66 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 2007 cycles, 127 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 2367 cycles, 216 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 2858 cycles, 358 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 4175 cycles, 490 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 4981 cycles, 822 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 7213 cycles, 1135 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82024000, 2048 bytes, 11584 cycles, 1414 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82034000 to 0x82044000, 4096 bytes, 20521 cycles, 1596 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82034000 to 0x82054000, 8192 bytes, 38305 cycles, 1710 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82034000 to 0x82064000, 16384 bytes, 73772 cycles, 1776 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 4xLaneABCD
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 32 bytes, 1461 cycles, 175 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 64 bytes, 1746 cycles, 293 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 128 bytes, 2131 cycles, 480 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 256 bytes, 2884 cycles, 710 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 512 bytes, 3440 cycles, 1190 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 1024 bytes, 4725 cycles, 1733 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 2048 bytes, 7099 cycles, 2307 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 4096 bytes, 12024 cycles, 2725 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 8192 bytes, 21926 cycles, 2988 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x10806200, 16384 bytes, 41214 cycles, 3180 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 32 bytes, 1463 cycles, 174 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 64 bytes, 1739 cycles, 294 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 128 bytes, 2123 cycles, 482 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 256 bytes, 2863 cycles, 715 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 512 bytes, 3425 cycles, 1195 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 1024 bytes, 4697 cycles, 1744 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 2048 bytes, 7345 cycles, 2230 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 4096 bytes, 11963 cycles, 2739 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 8192 bytes, 21835 cycles, 3001 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x c00a000, 16384 bytes, 41323 cycles, 3171 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8 bytes, 1360 cycles, 47 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16 bytes, 1686 cycles, 75 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 32 bytes, 1688 cycles, 151 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 64 bytes, 1698 cycles, 301 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 128 bytes, 2336 cycles, 438 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 256 bytes, 3037 cycles, 674 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 512 bytes, 3598 cycles, 1138 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 1024 bytes, 4936 cycles, 1659 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 2048 bytes, 7372 cycles, 2222 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 4096 bytes, 12231 cycles, 2679 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 8192 bytes, 21867 cycles, 2997 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x10802200 to 0x82014000, 16384 bytes, 41209 cycles, 3180 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8 bytes, 1301 cycles, 49 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16 bytes, 1547 cycles, 82 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 32 bytes, 1545 cycles, 165 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 64 bytes, 1828 cycles, 280 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 128 bytes, 2131 cycles, 480 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 256 bytes, 2881 cycles, 710 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 512 bytes, 3459 cycles, 1184 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 1024 bytes, 4745 cycles, 1726 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 2048 bytes, 7338 cycles, 2232 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 4096 bytes, 12008 cycles, 2728 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 8192 bytes, 21936 cycles, 2987 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x10806200, 16384 bytes, 41213 cycles, 3180 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8 bytes, 1303 cycles, 49 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 32 bytes, 1519 cycles, 168 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 64 bytes, 1793 cycles, 285 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 128 bytes, 2109 cycles, 485 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 256 bytes, 2914 cycles, 702 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 512 bytes, 3704 cycles, 1105 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 1024 bytes, 4702 cycles, 1742 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 2048 bytes, 7078 cycles, 2314 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 4096 bytes, 12006 cycles, 2729 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 8192 bytes, 21906 cycles, 2991 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x c00a000, 16384 bytes, 41308 cycles, 3173 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8 bytes, 1395 cycles, 45 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16 bytes, 1411 cycles, 90 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 32 bytes, 1755 cycles, 145 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 64 bytes, 1765 cycles, 290 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 128 bytes, 2137 cycles, 479 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 256 bytes, 3023 cycles, 677 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 512 bytes, 3618 cycles, 1132 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 1024 bytes, 5031 cycles, 1628 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 2048 bytes, 7358 cycles, 2226 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 4096 bytes, 12250 cycles, 2674 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 8192 bytes, 21852 cycles, 2999 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x c002000 to 0x82014000, 16384 bytes, 41308 cycles, 3173 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 32 bytes, 1545 cycles, 165 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 64 bytes, 1828 cycles, 280 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 128 bytes, 2207 cycles, 463 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 256 bytes, 2895 cycles, 707 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 512 bytes, 3689 cycles, 1110 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 1024 bytes, 4732 cycles, 1731 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 2048 bytes, 7376 cycles, 2221 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 4096 bytes, 12054 cycles, 2718 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 8192 bytes, 21941 cycles, 2986 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x10806200, 16384 bytes, 41449 cycles, 3162 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 32 bytes, 1547 cycles, 165 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 64 bytes, 1821 cycles, 281 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 128 bytes, 2119 cycles, 483 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 256 bytes, 3153 cycles, 649 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 512 bytes, 3669 cycles, 1116 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 1024 bytes, 4983 cycles, 1643 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 2048 bytes, 7347 cycles, 2230 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 4096 bytes, 12235 cycles, 2678 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 8192 bytes, 21865 cycles, 2997 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x c00a000, 16384 bytes, 41279 cycles, 3175 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16 bytes, 1788 cycles, 71 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 32 bytes, 1786 cycles, 143 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 64 bytes, 1794 cycles, 285 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 128 bytes, 2250 cycles, 455 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 256 bytes, 3075 cycles, 666 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 512 bytes, 3579 cycles, 1144 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 1024 bytes, 5023 cycles, 1630 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 2048 bytes, 7431 cycles, 2204 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 4096 bytes, 12321 cycles, 2659 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 8192 bytes, 21949 cycles, 2985 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x82004000 to 0x82014000, 16384 bytes, 41405 cycles, 3165 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800200, 8 bytes, 1467 cycles, 43 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800300, 16 bytes, 1463 cycles, 87 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800400, 32 bytes, 1630 cycles, 157 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800500, 64 bytes, 1823 cycles, 280 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800600, 128 bytes, 2274 cycles, 450 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11800700, 256 bytes, 3224 cycles, 635 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200, 512 bytes, 3678 cycles, 1113 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180a200, 1024 bytes, 4886 cycles, 1676 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1180e200, 2048 bytes, 7303 cycles, 2243 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11812200, 4096 bytes, 12142 cycles, 2698 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11816200, 8192 bytes, 21858 cycles, 2998 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x1181a200, 16384 bytes, 41397 cycles, 3166 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000000, 8 bytes, 1484 cycles, 43 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000100, 16 bytes, 1558 cycles, 82 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000200, 32 bytes, 1629 cycles, 157 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000300, 64 bytes, 1901 cycles, 269 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000400, 128 bytes, 2365 cycles, 432 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c000500, 256 bytes, 3295 cycles, 621 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c00a000, 512 bytes, 3701 cycles, 1106 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c012000, 1024 bytes, 4876 cycles, 1680 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c01a000, 2048 bytes, 7295 cycles, 2245 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c022000, 4096 bytes, 12149 cycles, 2697 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c02a000, 8192 bytes, 21925 cycles, 2989 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x c032000, 16384 bytes, 41377 cycles, 3167 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000000, 8 bytes, 1575 cycles, 40 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000100, 16 bytes, 1642 cycles, 77 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000200, 32 bytes, 1720 cycles, 148 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000300, 64 bytes, 2017 cycles, 253 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000400, 128 bytes, 2377 cycles, 430 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82000500, 256 bytes, 3482 cycles, 588 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82014000, 512 bytes, 3765 cycles, 1087 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82024000, 1024 bytes, 5103 cycles, 1605 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82034000, 2048 bytes, 7398 cycles, 2214 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82044000, 4096 bytes, 12233 cycles, 2678 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82054000, 8192 bytes, 22017 cycles, 2976 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x82064000, 16384 bytes, 41472 cycles, 3160 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800800, 8 bytes, 1528 cycles, 41 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800900, 16 bytes, 1543 cycles, 82 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800a00, 32 bytes, 1626 cycles, 157 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800b00, 64 bytes, 1900 cycles, 269 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800c00, 128 bytes, 2276 cycles, 449 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11800d00, 256 bytes, 3295 cycles, 621 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 512 bytes, 3668 cycles, 1116 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180e200, 1024 bytes, 4886 cycles, 1676 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11812200, 2048 bytes, 7304 cycles, 2243 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x11816200, 4096 bytes, 12155 cycles, 2695 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1181a200, 8192 bytes, 21926 cycles, 2988 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x1180a200, 16384 bytes, 41477 cycles, 3160 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000600, 8 bytes, 1528 cycles, 41 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000700, 16 bytes, 1531 cycles, 83 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000800, 32 bytes, 1639 cycles, 156 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000900, 64 bytes, 1901 cycles, 269 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000a00, 128 bytes, 2301 cycles, 445 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c03a000 to 0x c000b00, 256 bytes, 3297 cycles, 621 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c00a000 to 0x c00a000, 512 bytes, 3676 cycles, 1114 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c012000 to 0x c012000, 1024 bytes, 4901 cycles, 1671 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c01a000 to 0x c01a000, 2048 bytes, 7324 cycles, 2237 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c02a000, 4096 bytes, 12169 cycles, 2692 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c032000, 8192 bytes, 21926 cycles, 2988 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x c00a000, 16384 bytes, 41390 cycles, 3166 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000600, 8 bytes, 1631 cycles, 39 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000700, 16 bytes, 1621 cycles, 78 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000800, 32 bytes, 1747 cycles, 146 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000900, 64 bytes, 2021 cycles, 253 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000a00, 128 bytes, 2466 cycles, 415 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82000b00, 256 bytes, 3485 cycles, 587 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82084000, 512 bytes, 3760 cycles, 1089 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x82094000, 1024 bytes, 4979 cycles, 1645 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820a4000, 2048 bytes, 7397 cycles, 2214 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820b4000, 4096 bytes, 12255 cycles, 2673 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820c4000, 8192 bytes, 22018 cycles, 2976 Mbps, completion code = 0
[C66xx_0] STREAM from 0x c022000 to 0x820d4000, 16384 bytes, 41483 cycles, 3159 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800e00, 8 bytes, 1644 cycles, 38 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11800f00, 16 bytes, 1629 cycles, 78 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801000, 32 bytes, 1826 cycles, 140 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801100, 64 bytes, 2001 cycles, 255 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801200, 128 bytes, 2462 cycles, 415 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11801300, 256 bytes, 3401 cycles, 602 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 512 bytes, 3784 cycles, 1082 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 1024 bytes, 5103 cycles, 1605 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 2048 bytes, 7436 cycles, 2203 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x11816200, 4096 bytes, 12335 cycles, 2656 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1181a200, 8192 bytes, 22017 cycles, 2976 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x1180a200, 16384 bytes, 41575 cycles, 3152 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000c00, 8 bytes, 1656 cycles, 38 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000d00, 16 bytes, 1724 cycles, 74 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000e00, 32 bytes, 1822 cycles, 140 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c000f00, 64 bytes, 2003 cycles, 255 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001000, 128 bytes, 2461 cycles, 416 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c001100, 256 bytes, 3420 cycles, 598 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 512 bytes, 3856 cycles, 1062 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c01a000, 1024 bytes, 5074 cycles, 1614 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c02a000, 2048 bytes, 7493 cycles, 2186 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c032000, 4096 bytes, 12343 cycles, 2654 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c00a000, 8192 bytes, 22102 cycles, 2965 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x c012000, 16384 bytes, 41477 cycles, 3160 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000c00, 8 bytes, 1835 cycles, 34 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000d00, 16 bytes, 1816 cycles, 70 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000e00, 32 bytes, 1916 cycles, 133 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82000f00, 64 bytes, 2190 cycles, 233 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001000, 128 bytes, 2567 cycles, 398 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820e4000 to 0x82001100, 256 bytes, 3589 cycles, 570 Mbps, completion code = 0
[C66xx_0] STREAM from 0x820f4000 to 0x820f4000, 512 bytes, 3960 cycles, 1034 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82014000 to 0x82014000, 1024 bytes, 5095 cycles, 1607 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82024000 to 0x82024000, 2048 bytes, 7518 cycles, 2179 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82034000 to 0x82044000, 4096 bytes, 12434 cycles, 2635 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82034000 to 0x82054000, 8192 bytes, 22110 cycles, 2964 Mbps, completion code = 0
[C66xx_0] STREAM from 0x82034000 to 0x82064000, 16384 bytes, 41574 cycles, 3152 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO mulitple ports test with link speed 5.000Gbps
[C66xx_0] SRIO path configuration 1xLaneA_1xLaneB_1xLaneC_1xLaneD
[C66xx_0] NREAD from 0x12802200 to 0x13802200 through port 0, 16384 bytes, 49670 cycles, 2638 Mbps, completion code = 0
[C66xx_0] NWRITE from 0x12806200 to 0x13806200 through port 1, 16384 bytes, 40230 cycles, 3258 Mbps, completion code = 0
[C66xx_0] NWRITE_R from 0x1280a200 to 0x1380a200 through port 2, 16384 bytes, 49686 cycles, 2638 Mbps, completion code = 0
[C66xx_0] SWRITE from 0x1280e200 to 0x1380e200 through port 3, 16384 bytes, 37962 cycles, 3452 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 2xLaneAB_2xLaneCD
[C66xx_0] STREAM from 0x10802200 to 0x82004000 through port 0, 4096 bytes, 5801 cycles, 5648 Mbps, completion code = 0
[C66xx_0] MESSAGE from 0x c002000 to 0x11802200 through port 2, 4096 bytes, 7026 cycles, 4663 Mbps, completion code = 0
[C66xx_0]
[C66xx_0] SRIO path configuration 2xLaneAB_1xLaneC_1xLaneD
[C66xx_0] SWRITE from 0x12802200 to 0x13802200 through port 0, 16384 bytes, 20865 cycles, 6281 Mbps, completion code = 0
[C66xx_0] STREAM from 0x10802200 to 0x11806200 through port 2, 4096 bytes, 10654 cycles, 3075 Mbps, completion code = 3
[C66xx_0] data mismatch at unit 0, 0xa28 (at 0x10802200) != 0xa29 (at 0x11806200)
[C66xx_0] MESSAGE from 0x c002000 to 0x11802200 through port 3, 4096 bytes, 559213587 cycles, 0 Mbps, completion code = 2
[C66xx_0] data mismatch at unit 0, 0xa29 (at 0xc002000) != 0xa28 (at 0x11802200)
[C66xx_0]
[C66xx_0] received doorbell for latency test.
[C66xx_0] doorbell latency is 779 cycles
[C66xx_0]
[C66xx_0] SRIO test complete.
[C66xx_0]
