DM8127 CSK 启动运行autorun-usecase.sh, 无法看到摄像头图像 ?
Other Parts Discussed in Thread: TMS320DM8127
问题:  需要知道买的TI DM8127 CSK开发板, 测试时, 无法看到摄像头图像?
1.硬件:  TMS320dm8127  Camera Sensor  Kit (Leopard Imaging LI-CAM-AR0331-1.8)
2,软件:  IPNC-RDK-CSK-3.9.0, 使用开发板子带TF卡启动
3,启动信息如下所示,
4, 接hdmi显示器看, 有时能看到图像(时间不到30秒),大部分情况下,看不到图像!!
启动信息如下:
U-Boot SPL 2016.05-dirty (Apr 25 2017 - 10:16:19)
Trying to boot from MMC2
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-dirty (Apr 25 2017 - 10:16:19 -0400)
I2C: ready
DRAM: 1 GiB
MMC: OMAP SD/MMC: 0
Using default environment
Net: <ethaddr> not set. Reading from E-fuse
cpsw
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
Booting from mmc ...
reading uImage
2666240 bytes read in 305 ms (8.3 MiB/s)
reading dm8127-csk.dtb
57759 bytes read in 15 ms (3.7 MiB/s)
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-4.4.12-dirty
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2666176 Bytes = 2.5 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
## Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
Loading Kernel Image ... OK
Loading Device Tree to 8146e000, end 8147f19e ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.12-dirty (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 Tue Apr 25 10:30:11 EDT 2017
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: DM8127 CSK
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] omap_barrier_reserve_memblock():Reserving DRAM area @ addr = 0x84e00000 size = 1048576 Bytes
[ 0.000000] cma: Reserved 24 MiB at 0x83400000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] TI81XX: Map 0x84e00000 to 0xfe500000 for dram barrier
[ 0.000000] TI81XX: Map 0x40300000 to 0xfe600000 for sram barrier
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] TI814X ES2.1 (iva neon )
[ 0.000000] powerdomain: gem_pwrdm: voltagedomain dsp does not exist
[ 0.000000] powerdomain: ivahd_pwrdm: voltagedomain iva does not exist
[ 0.000000] powerdomain: hdvpss_pwrdm: voltagedomain dsp does not exist
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 19788
[ 0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rw mem=80M vram=4M cmemk.phys_start=0x85000000 cmemk.phys_end=0x89000000 cmemk.allowOverlap=1 notifyk.vpssm3_sva=0xBFD00000 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 46652K/79872K available (4915K kernel code, 261K rwdata, 1708K rodata, 272K init, 241K bss, 8644K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc5800000 - 0xff800000 ( 928 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc5000000 ( 80 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc067ffa4 (6624 kB)
[ 0.000000] .init : 0xc0680000 - 0xc06c4000 ( 272 kB)
[ 0.000000] .data : 0xc06c4000 - 0xc07054c8 ( 262 kB)
[ 0.000000] .bss : 0xc07054c8 - 0xc0741950 ( 242 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 20000000 Hz
[ 0.000014] sched_clock: 32 bits at 20MHz, resolution 50ns, wraps every 107374182375ns
[ 0.008259] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 95563022313 ns
[ 0.017835] OMAP clocksource: timer1 at 20000000 Hz
[ 0.023126] Console: colour dummy device 80x30
[ 0.027822] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.086964] pid_max: default: 32768 minimum: 301
[ 0.091914] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.098826] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.106861] Initializing cgroup subsys io
[ 0.111090] Initializing cgroup subsys memory
[ 0.115705] Initializing cgroup subsys devices
[ 0.120376] Initializing cgroup subsys freezer
[ 0.125054] Initializing cgroup subsys pids
[ 0.129464] CPU: Testing write buffer coherency: ok
[ 0.134898] Setting up static identity map for 0x800082c0 - 0x80008318
[ 0.142651] devtmpfs: initialized
[ 0.167998] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.215875] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.227985] pinctrl core: initialized pinctrl subsystem
[ 0.234713] NET: Registered protocol family 16
[ 0.240884] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.253479] OMAP GPIO hardware version 0.1
[ 0.265612] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/nandflash_pins_s0, deferring probe
[ 0.298367] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.305885] omap_i2c 48028000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 0.319458] omap_i2c 4802a000.i2c: could not find pctldev for node /ocp/l4ls@48000000/control@140000/pinmux@800/pinmux_i2c1_pins, deferring probe
[ 0.333108] media: Linux media interface: v0.10
[ 0.337938] Linux video capture interface: v2.00
[ 0.342822] pps_core: LinuxPPS API ver. 1 registered
[ 0.348030] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.357553] PTP clock support registered
[ 0.361678] EDAC MC: Ver: 3.0.0
[ 0.365668] Advanced Linux Sound Architecture Driver Initialized.
[ 0.373196] clocksource: Switched to clocksource timer1
[ 0.390401] NET: Registered protocol family 2
[ 0.395714] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.402984] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.409651] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.416363] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.422466] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.429168] NET: Registered protocol family 1
[ 0.434067] RPC: Registered named UNIX socket transport module.
[ 0.440247] RPC: Registered udp transport module.
[ 0.445197] RPC: Registered tcp transport module.
[ 0.450123] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.458028] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.464993] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.481717] NFS: Registering the id_resolver key type
[ 0.487085] Key type id_resolver registered
[ 0.491478] Key type id_legacy registered
[ 0.497210] io scheduler noop registered
[ 0.501341] io scheduler deadline registered
[ 0.506065] io scheduler cfq registered (default)
[ 0.512287] pinctrl-single 48140800.pinmux: 270 pins at pa fa140800 size 1080
[ 0.592330] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.603147] console [ttyS0] disabled
[ 0.606996] 48020000.uart: ttyS0 at MMIO 0x48020000 (irq = 21, base_baud = 3000000) is a 8250
[ 0.615918] console [ttyS0] enabled
[ 0.623090] bootconsole [earlycon0] disabled
[ 0.632807] Reference Linux version 4.4.12
[ 0.637126] File /home/gtbldadm/nightlybuilds/ipnc_rdk/utils/package-script/TI_GIT/NEWDIR/Source/ti_tools/linuxutils_3_23_00_01/packages/ti/sdo/linuxutils/cmem/src/module/cmemk.c
[ 0.655631] allocated heap buffer 0xc8000000 of size 0x4000000
[ 0.661502] cmemk initialized
[ 0.671497] loop: module loaded
[ 0.733246] davinci_mdio 4a100800.mdio: davinci mdio revision 1.6
[ 0.739376] libphy: 4a100800.mdio: probed
[ 0.744203] davinci_mdio 4a100800.mdio: phy[25]: device 4a100800.mdio:19, driver TI DP83867
[ 0.753065] cpsw 4a100000.ethernet: Detected MACID = d4:f5:13:99:03:d0
[ 0.762767] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 0.792205] mousedev: PS/2 mouse device common for all mice
[ 0.798615] omap_rtc 480c0000.rtc: rtc core: registered 480c0000.rtc as rtc0
[ 0.805928] i2c /dev entries driver
[ 0.810317] omap_wdt: OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
[ 0.817410] sdhci: Secure Digital Host Controller Interface driver
[ 0.823637] sdhci: Copyright(c) Pierre Ossman
[ 0.948529] omap_hsmmc 48060000.mmc: card claims to support voltages below defined range
[ 0.967374] mmc0: queuing unknown CIS tuple 0x91 (3 bytes)
[ 0.973708] mmc0: new high speed SDIO card at address 0001
[ 0.983406] Synopsys Designware Multimedia Card Interface Driver
[ 0.989855] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.996802] notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbfd00000
[ 1.008073] davinci_evm sound: ASoC: CODEC DAI tlv320aic3x-hifi not registered
[ 1.015378] davinci_evm sound: snd_soc_register_card failed (-517)
[ 1.022856] NET: Registered protocol family 10
[ 1.029588] sit: IPv6 over IPv4 tunneling driver
[ 1.035056] NET: Registered protocol family 17
[ 1.039759] Key type dns_resolver registered
[ 1.044304] omap_voltage_late_init: Could not get sys clk.
[ 1.050115] Power Management for TI81XX.
[ 1.059290] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 1.064522] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 1.072215] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xca
[ 1.078634] nand: Micron MT29F2G16ABAEAWP
[ 1.082666] nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 1.090301] nand: using OMAP_ECC_BCH8_CODE_HW ECC scheme
[ 1.095724] 8 ofpart partitions found on MTD device 8000000.nand
[ 1.101758] Creating 8 MTD partitions on "8000000.nand":
[ 1.107116] 0x000000000000-0x000000020000 : "NAND.SPL"
[ 1.114675] 0x000000020000-0x000000420000 : "NAND.u-boot"
[ 1.124736] 0x000000420000-0x000000440000 : "NAND.u-boot-env"
[ 1.131711] 0x000000440000-0x000000a40000 : "NAND.kernel"
[ 1.140468] 0x000000a40000-0x00000ca40000 : "NAND.file-system"
[ 1.153499] mmc1: host does not support reading read-only switch, assuming write-enable
[ 1.173268] mmc1: new high speed SDHC card at address 0007
[ 1.193243] mmcblk0: mmc1:0007 SD16G 14.5 GiB
[ 1.199126] mmcblk0: p1 p2
[ 1.239134] 0x00000ca40000-0x00000ca80000 : "NAND.u-boot-spl-os"
[ 1.246396] 0x00000ca80000-0x00000d680000 : "NAND.data"
[ 1.257041] 0x00000d680000-0x000010000000 : "NAND.reserved"
[ 1.279439] omap_i2c 48028000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.286505] omap_i2c 4802a000.i2c: bus 1 rev0.11 at 100 kHz
[ 1.293252] davinci_evm sound: ASoC: DAPM unknown pin MONO_LOUT
[ 1.300196] davinci_evm sound: tlv320aic3x-hifi <-> 48050000.mcasp mapping ok
[ 1.309442] omap_rtc 480c0000.rtc: setting system clock to 2000-01-01 00:00:00 UTC (946684800)
[ 1.331170] wlan-en-regulator: disabling
[ 1.335480] ALSA device list:
[ 1.338464] #0: TI81XX-CSK
[ 1.343411] EXT4-fs (mmcblk0p2): mounting ext3 file system using the ext4 subsystem
[ 13.457484] EXT4-fs (mmcblk0p2): recovery complete
[ 13.470761] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 13.478971] VFS: Mounted root (ext3 filesystem) on device 179:2.
[ 13.493822] devtmpfs: mounted
[ 13.497394] Freeing unused kernel memory: 272K (c0680000 - c06c4000)
[ 13.503798] This architecture does not have kernel memory protection.
[ 13.744455] systemd[1]: System time before build time, advancing clock.
[ 13.778866] random: systemd urandom read with 35 bits of entropy available
[ 13.798969] systemd[1]: systemd 229 running in system mode. (-PAM -AUDIT -SELINUX -IMA -APPARMOR -SMACK +SYSVINIT -UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL -XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 13.817648] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.05!
[ 13.844847] systemd[1]: Set hostname to <ti81xx>.
[ 14.105458] systemd[1]: Configuration file /etc/systemd/system/ipnc-rdk-usecase.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[ 14.236732] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 14.273996] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 14.293492] systemd[1]: Reached target Timers.
[ OK ] Reached target Timers.
[ 14.313862] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 14.343415] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 14.363551] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 14.383563] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 14.404488] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 14.424360] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 14.443601] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 14.463411] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 14.483666] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 14.513554] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 14.543587] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 14.575428] systemd[1]: tmp.mount: Directory /tmp to mount over is not empty, mounting anyway.
[ 14.587245] systemd[1]: Mounting Temporary Directory...
[ 14.617040] systemd[1]: Starting Synchronize System and HW clocks...
[ 14.691404] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 14.727554] systemd[1]: Starting Journal Service...
[ 14.739436] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 14.777146] systemd[1]: Starting udev Coldplug all Devices...
[ 14.837544] systemd[1]: Starting udev Kernel Device Manager...
[ 14.876052] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 14.932359] systemd[1]: Mounting /media/ram...
[ 14.967257] systemd[1]: Mounting POSIX Message Queue File System...
[ 15.017045] systemd[1]: Mounting /var/volatile...
[ 15.089675] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 15.123621] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 15.143513] systemd[1]: Mounted /var/volatile.
[ OK ] Mounted /var/volatile.
[ 15.163482] systemd[1]: Mounted /media/ram.
[ OK ] Mounted /media/ram.
[ 15.183927] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Found device /dev/ttyS0.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started IPNC RDK use case service.
[ OK ] Reached target Local File Systems.
[ OK ] Reached target System Initialization.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
[ OK ] Started Getty on tty1.
[ 16.258205] autorun-usecase.sh[113]: numid=1,iface=MIXER,name='PCM Playback Volume'
[ 16.266636] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=127,step=0
[ 16.267911] autorun-usecase.sh[113]: : values=115,115
[ 16.269013] autorun-usecase.sh[113]: | dBscale-min=-63.50dB,step=0.50dB,mute=0
[ OK ] Started Serial Getty on ttyS0.
[ 16.292088] autorun-usecase.sh[113]: numid=31,iface=MIXER,name='PGA Capture Volume'
[ 16.312742] autorun-usecase.sh[113]: ; type=INTEGER,access=rw---R--,values=2,min=0,max=119,step=0
[ 16.314015] autorun-usecase.sh[113]: : values=72,72
[ 16.315116] autorun-usecase.sh[113]: | dBscale-min=0.00dB,step=0.50dB,mute=0
[ OK ] Reached target Login Prompts.
[ 16.321784] autorun-usecase.sh[113]: numid=51,iface=MIXER,name='Right PGA Mixer Mic2R Switch'
[ 16.366753] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ 16.367943] autorun-usecase.sh[113]: : values=on
[ 16.369126] autorun-usecase.sh[113]: numid=46,iface=MIXER,name='Left PGA Mixer Mic2L Switch'
Starting uim-sysfs.service...
[ 16.378631] autorun-usecase.sh[113]: ; type=BOOLEAN,access=rw------,values=1
[ OK ] Started System Logging Service.
[ OK ] Started Kernel Logging Service.
[ 16.441620] autorun-usecase.sh[113]: : values=on
[ 16.473377] autorun-usecase.sh[113]: Mount mtd6 and mtd7 partitions
[ 16.494604] ubi0: attaching mtd6
[ OK ] Started D-Bus System Message Bus.
[ 16.712365] ubi0: scanning is finished
[ 16.763328] ubi0: attached mtd6 (name "NAND.data", size 12 MiB)
[ 16.769297] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 16.776239] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 16.782972] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 16.789991] ubi0: good PEBs: 96, bad PEBs: 0, corrupted PEBs: 0
[ 16.795955] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 16.803225] ubi0: max/mean erase counter: 18/8, WL threshold: 4096, image sequence number: 2296442730
[ 16.812486] ubi0: available PEBs: 0, total reserved PEBs: 96, PEBs reserved for bad PEB handling: 40
[ 16.822155] ubi0: background thread "ubi_bgt0d" started, PID 143
Starting Network Service...
[ 17.033977] net eth0: initializing cpsw version 1.10 (0)
[ 17.039337] net eth0: initialized cpsw ale version 1.3
[ 17.047858] net eth0: phy found : id is : 0x2000a231
[ 17.052896] libphy: PHY not found
[ 17.056342] net eth0: phy "" not found on slave 1, err -19
[ OK ] Started Network Service.
[ 17.093446] autorun-usecase.sh[113]: UBI device number 0, total 96 LEBs (12189696 bytes, 11.6 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ 17.138195] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 17.723382] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 151
[ 17.800432] UBIFS (ubi0:0): recovery needed
[ 18.055118] UBIFS (ubi0:0): recovery completed
[ 18.059696] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "ubifs_volume"
[ 18.067693] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 18.077674] UBIFS (ubi0:0): FS size: 5332992 bytes (5 MiB, 42 LEBs), journal size 1015809 bytes (0 MiB, 6 LEBs)
[ 18.087824] UBIFS (ubi0:0): reserved for root: 251889 bytes (245 KiB)
[ 18.094315] UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID DA2FDED9-0E1A-4C04-A11E-5521FFBEB415, small LPT model
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Network Name Resolution.
[ 18.902197] ubi1: attaching mtd7
[ OK ] Started uim-sysfs.service.
Starting telnetd.service...
[ OK ] Started telnetd.service.
[ 19.179283] ubi1: scanning is finished
[ 19.210642] ubi1: attached mtd7 (name "NAND.reserved", size 41 MiB)
[ 19.217028] ubi1: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 19.223959] ubi1: min./max. I/O unit sizes: 2048/2048, sub-page size 512
[ 19.230692] ubi1: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 19.237701] ubi1: good PEBs: 332, bad PEBs: 0, corrupted PEBs: 0
[ 19.243749] ubi1: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 19.251007] ubi1: max/mean erase counter: 2/1, WL threshold: 4096, image sequence number: 958200812
[ 19.260108] ubi1: available PEBs: 0, total reserved PEBs: 332, PEBs reserved for bad PEB handling: 40
[ 19.273186] ubi1: background thread "ubi_bgt1d" started, PID 169
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
[ 19.341225] autorun-usecase.sh[113]: UBI device number 1, total 332 LEBs (42156032 bytes, 40.2 MiB), available 0 LEBs (0 bytes), LEB size 126976 bytes (124.0 KiB)
[ OK ] Reached target Multi-User System.
[ 19.893240] UBIFS (ubi1:0): background thread "ubifs_bgt1_0" started, PID 181
[ 19.914383] UBIFS (ubi1:0): recovery needed
[ 19.933269] UBIFS (ubi1:0): recovery completed
[ 19.937839] UBIFS (ubi1:0): UBIFS: mounted UBI device 1, volume 0, name "ubifs_volume"
[ 19.945828] UBIFS (ubi1:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 19.955810] UBIFS (ubi1:0): FS size: 35299328 bytes (33 MiB, 278 LEBs), journal size 1777664 bytes (1 MiB, 14 LEBs)
[ 19.966309] UBIFS (ubi1:0): reserved for root: 1667274 bytes (1628 KiB)
[ 19.972960] UBIFS (ubi1:0): media format: w4/r0 (latest is w4/r0), UUID 6190F1C0-596D-4932-BF89-AB21CD472537, small LPT model
[ 20.490135] autorun-usecase.sh[113]: wifi: in STA mode
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org ti81xx ttyS0
Arago 2016.05 ti81xx ttyS0
ti81xx login: [ 23.086975] cfg80211: World regulatory domain updated:
[ 23.092199] cfg80211: DFS Master region: unset
[ 23.096618] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 23.106431] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.114490] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.122532] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.130592] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 23.140136] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 23.149677] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 23.157821] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 23.165878] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 23.463879] wl18xx_driver wl18xx.1.auto: Direct firmware load for ti-connectivity/wl1271-nvs.bin failed with error -2
[ 23.853844] wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
[ 23.911337] wlcore: loaded
[ 24.510494] wlcore: PHY firmware version: Rev 8.2.0.0.232
[ 24.599880] random: nonblocking pool is initialized
[ 24.609885] wlcore: firmware booted (Rev 8.9.0.0.48)
[ 24.626271] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 28.810826] autorun-usecase.sh[113]: SSID: 602
[ 28.812435] autorun-usecase.sh[113]: SSID: NETGEAR69
[ 28.813638] autorun-usecase.sh[113]: SSID: ChinaNGB-LJ2Z6Z
[ 28.814774] autorun-usecase.sh[113]: SSID: ChinaNGB-LJXXNs
[ 28.815928] autorun-usecase.sh[113]: SSID: CMCC-vHfC
[ 28.817048] autorun-usecase.sh[113]: SSID: Tenda_0F1830
[ 28.818189] autorun-usecase.sh[113]: SSID: TP-LINK_DBF9
[ 28.819314] autorun-usecase.sh[113]: SSID: Tenda_309D70
[ 28.830926] autorun-usecase.sh[113]: SSID: Xiaomi_C9C0
[ 28.832436] autorun-usecase.sh[113]: SSID: TP-LINK_AEB3
[ 28.833699] autorun-usecase.sh[113]: SSID: TP-LINK_602
[ 28.836642] autorun-usecase.sh[113]: SSID: TP-LINK_5G_AEB3
[ 28.838115] autorun-usecase.sh[113]: SSID: TP-LINK_5G_605A
[ 29.278578] <1>SysLink version : 2.21.02.10
[ 29.278578] SysLink module created on Date:Apr 25 2017 Time:10:34:31
[ 29.289224] <1>Trace enabled
[ 29.292120] <1>Trace SetFailureReason enabled
[ 29.384187] autorun-usecase.sh[113]: /dev/mem opened.
[ 29.385839] autorun-usecase.sh[113]: Phy Addr : 0x48181560 Data : 0x00000002
[ 29.387072] autorun-usecase.sh[113]: secss put in low power state
[ 29.391253] autorun-usecase.sh[113]: Phy Addr : 0x48180f10 Data : 0x00000000
[ 29.392734] autorun-usecase.sh[113]: Phy Addr : 0x48180508 Data : 0x00000302
[ 29.393926] autorun-usecase.sh[113]: Phy Addr : 0x48180520 Data : 0x00000002
[ 29.395121] autorun-usecase.sh[113]: Phy Addr : 0x48180524 Data : 0x00000002
[ 29.396288] autorun-usecase.sh[113]: Phy Addr : 0x48180528 Data : 0x00000002
[ 29.397629] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 29.398790] autorun-usecase.sh[113]: Phy Addr : 0x4d0000e4 Data : 0x00170209
[ 29.399945] autorun-usecase.sh[113]: Phy Addr : 0x4c0000e4 Data : 0x00170209
[ 29.401228] autorun-usecase.sh[113]: Phy Addr : 0x4d0000e4 Data : 0x00170209
[ 29.402388] autorun-usecase.sh[113]: DDR IOs RX is shutdown
[ 30.369408] autorun-usecase.sh[113]: /opt/ipnc/autorun-usecase.sh: line 52: kill: (225) - No such process
[host] Setting L3 bandwidth regulator for [HDVICP0 ] to [press=[0,0] BW=900, WM Cycles=2500]
[host] Setting DMM priority for [HDVICP0 ] to [1] ( 0x4e000634 = 0x00000009 )
[host] Setting L3 bandwidth regulator for [ISS ] to [press=[3,3] BW=400, WM Cycles=2500]
[host] Setting DMM priority for [ISS ] to [0] ( 0x4e000634 = 0x00080000 )
[ 30.464167] autorun-usecase.sh[113]: insmod: ERROR: could not insert module sbull.ko: File exists
[ 31.500608] autorun-usecase.sh[113]: mkfs.fat 3.0.28 (2015-05-16)
[ 31.502137] autorun-usecase.sh[113]: unable to get drive geometry, using default 255/63
[ 31.503282] autorun-usecase.sh[113]: /dev/sbulla has 255 heads and 63 sectors per track,
[ 31.504370] autorun-usecase.sh[113]: hidden sectors 0x0000;
[ 31.505472] autorun-usecase.sh[113]: logical sector size is 512,
[ 31.515175] autorun-usecase.sh[113]: using 0xf8 media descriptor, with 1024 sectors;
[ 31.519706] autorun-usecase.sh[113]: drive number 0x80;
[ 31.521337] autorun-usecase.sh[113]: filesystem has 2 16-bit FATs and 4 sectors per cluster.
[ 31.523035] autorun-usecase.sh[113]: FAT size is 1 sector, and provides 247 clusters.
[ 31.524343] autorun-usecase.sh[113]: There is 1 reserved sector.
[ 31.526508] autorun-usecase.sh[113]: Root directory contains 512 slots and uses 32 sectors.
[ 31.527773] autorun-usecase.sh[113]: Volume ID is 9c1bb3c2, no volume label.
[ 31.761007] Mass Storage Function, version: 2009/09/11
[ 31.766247] LUN: removable file: (no medium)
[ 31.786228] LUN: removable file: /dev/sbulla
[ 31.790537] Number of LUNs=1
[ 31.803348] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 31.810376] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 31.817483] g_mass_storage gadget: g_mass_storage ready
[ 31.877556] autorun-usecase.sh[113]: Creat queue id:0
[ 31.879408] autorun-usecase.sh[113]: queue id:0
[ 31.882395] autorun-usecase.sh[113]: Creat queue id:32769
[ 31.883823] autorun-usecase.sh[113]: queue id:32769
[ 31.890898] autorun-usecase.sh[113]: Creat queue id:65538
[ 31.895336] autorun-usecase.sh[113]: queue id:65538
[ 31.896729] autorun-usecase.sh[113]: Creat queue id:98307
[ 31.898835] autorun-usecase.sh[113]: queue id:98307
[ 31.920422] autorun-usecase.sh[113]: queue id:32769
[host] Attached to slave procId 2.13]:
[ 41.406535] autorun-usecase.sh[113]: queue id:0
[host] Attached to slave procId 1.13]:
[host] Loaded file ./firmware/ipnc_rdk_fw_m3vpss.xem3 on slave procId 2.
[host] Attached to slave procId 0.13]:
[host] Started slave procId 2.sh[113]:
[host] After Ipc_loadcallback status [0x00000000]
[host] Loaded file ./firmware/ipnc_rdk_fw_m3video.xem3 on slave procId 1.
[host] Started slave procId 1.sh[113]:
[host] Loaded file ./firmware/ipnc_rdk_fw_c6xdsp.xe674 on slave procId 0.
[host] Started slave procId 0.sh[113]:
[host] After Ipc_startcallback status [0x00000000]
[ 42.148621] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 42.152110] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 42.153879] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 42.156667] autorun-usecase.sh[113]: [m3vpss ] Received character 's'
[ 42.159684] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 42.162994] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 42.165801] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 42.169664] autorun-usecase.sh[113]: [m3vpss ] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 42.172300] autorun-usecase.sh[113]: [m3vpss ] notify_attach rtnVal 0
[ 42.175114] autorun-usecase.sh[113]: [m3vpss ] initProxyServer rtnVal 0
[ 42.177664] autorun-usecase.sh[113]: [m3vpss ]
[ 42.180093] autorun-usecase.sh[113]: [m3vpss ] *** UTILS: CPU KHz = 400000 Khz ***
[ 42.182842] autorun-usecase.sh[113]: [m3vpss ]
[ 42.185412] autorun-usecase.sh[113]: [m3vpss ] 68: SYSTEM : System Common Init in progress !!!
[ 42.188389] autorun-usecase.sh[113]: [m3vpss ] 69: SYSTEM: IPC init in progress !!!
[ 42.193092] autorun-usecase.sh[113]: [m3vpss ] 69: SYSTEM: Attaching to [HOST] ...
[ 42.196052] autorun-usecase.sh[113]: [m3video] ***** SYSTEM : Frequency <ORG> - 200000000, <NEW> - 200000000
[ 42.198657] autorun-usecase.sh[113]: [m3video]
[ 42.201349] autorun-usecase.sh[113]: [m3video] *** UTILS: CPU KHz = 400000 Khz ***
[ 42.204582] autorun-usecase.sh[113]: [m3video]
[ 42.207152] autorun-usecase.sh[113]: [m3video] 129: SYSTEM : System Common Init in progress !!!
[ 42.210442] autorun-usecase.sh[113]: [m3video] 129: SYSTEM: IPC init in progress !!!
[ 42.213016] autorun-usecase.sh[113]: [m3video] 129: SYSTEM: Attaching to [HOST] ...
[ 42.216012] autorun-usecase.sh[113]: [c6xdsp ] ***** SYSTEM : Frequency <ORG> - 500000000, <NEW> - 500000000
[ 42.218561] autorun-usecase.sh[113]: [m3video] 179: SYSTEM: Attaching to [HOST] ...
[ 42.220721] autorun-usecase.sh[113]: [c6xdsp ]
[ 42.223257] autorun-usecase.sh[113]: [c6xdsp ] *** UTILS: CPU KHz = 500000 Khz ***
[ 42.226996] autorun-usecase.sh[113]: [c6xdsp ]
[ 42.229583] autorun-usecase.sh[113]: [c6xdsp ] 1: SYSTEM : System Common Init in progress !!!
[ 42.236356] autorun-usecase.sh[113]: [c6xdsp ] 1: SYSTEM: IPC init in progress !!!
[ 42.245331] autorun-usecase.sh[113]: [c6xdsp ] 1: SYSTEM: Attaching to [HOST] ...
[ 42.247345] autorun-usecase.sh[113]: [m3vpss ] 210: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 42.255443] autorun-usecase.sh[113]: [m3vpss ] 210: SYSTEM: Attaching to [DSP] ...
[ 42.257107] autorun-usecase.sh[113]: [c6xdsp ] 51: SYSTEM: Attaching to [HOST] ...
[ 42.264425] autorun-usecase.sh[113]: [m3video] 218: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 42.270130] autorun-usecase.sh[113]: [m3video] 218: SYSTEM: Attaching to [DSP] ...
[ 42.275823] autorun-usecase.sh[113]: [c6xdsp ] 77: SYSTEM: Attaching to [HOST] ... SUCCESS !!!
[ 42.281421] autorun-usecase.sh[113]: [m3vpss ] 260: SYSTEM: Attaching to [DSP] ...
[ 42.286928] autorun-usecase.sh[113]: [c6xdsp ] 77: SYSTEM: Attaching to [VIDEO-M3] ...
[ 42.289279] autorun-usecase.sh[113]: [m3video] 268: SYSTEM: Attaching to [DSP] ...
[ 42.290945] autorun-usecase.sh[113]: [c6xdsp ] 126: SYSTEM: Attaching to [VIDEO-M3] ...
[ 42.292257] autorun-usecase.sh[113]: [m3video] 318: SYSTEM: Attaching to [DSP] ...
[ 42.293912] autorun-usecase.sh[113]: [m3vpss ] 310: SYSTEM: Attaching to [DSP] ...
[ 42.295145] autorun-usecase.sh[113]: [c6xdsp ] 136: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 42.296478] autorun-usecase.sh[113]: [m3video] 318: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[ 42.297679] autorun-usecase.sh[113]: [c6xdsp ] 136: SYSTEM: Attaching to [VPSS-M3] ...
[ 42.300525] autorun-usecase.sh[113]: [m3video] 318: SYSTEM: Attaching to [VPSS-M3] ...
[ 42.301855] autorun-usecase.sh[113]: [c6xdsp ] 185: SYSTEM: Attaching to [VPSS-M3] ...
[ 42.303055] autorun-usecase.sh[113]: [m3video] 368: SYSTEM: Attaching to [VPSS-M3] ...
[ 42.304253] autorun-usecase.sh[113]: [m3vpss ] 360: SYSTEM: Attaching to [DSP] ...
[ 42.305454] autorun-usecase.sh[113]: [c6xdsp ] 228: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 42.306751] autorun-usecase.sh[113]: [m3video] 418: SYSTEM: Attaching to [VPSS-M3] ...
[ 42.307959] autorun-usecase.sh[113]: [m3vpss ] 410: SYSTEM: Attaching to [DSP] ...
[ 42.309276] autorun-usecase.sh[113]: [c6xdsp ] 228: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 42.310555] autorun-usecase.sh[113]: [m3vpss ] 411: SYSTEM: Attaching to [DSP] ... SUCCESS !!!
[ 42.311809] autorun-usecase.sh[113]: [m3vpss ] 411: SYSTEM: Attaching to [VIDEO-M3] ...
[ 42.313059] autorun-usecase.sh[113]: [m3video] 462: SYSTEM: Attaching to [VPSS-M3] ... SUCCESS !!!
[ 42.318761] autorun-usecase.sh[113]: [m3vpss ] 461: SYSTEM: Attaching to [VIDEO-M3] ...
[ 42.320291] autorun-usecase.sh[113]: [m3video] 462: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 42.321602] autorun-usecase.sh[113]: [m3vpss ] 462: SYSTEM: Attaching to [VIDEO-M3] ... SUCCESS !!!
[ 42.322827] autorun-usecase.sh[113]: [m3video] 463: SYSTEM: Creating MsgQ [VIDEO-M3_MSGQ] ...
[ 42.325539] autorun-usecase.sh[113]: [m3vpss ] 462: SYSTEM: Creating MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 42.326902] autorun-usecase.sh[113]: [m3video] 463: SYSTEM: Creating MsgQ [VIDEO-M3_ACK_MSGQ] ...
[ 42.328185] autorun-usecase.sh[113]: [m3vpss ] 463: SYSTEM: Creating MsgQ [VPSS-M3_MSGQ] ...
[ 42.337851] autorun-usecase.sh[113]: [m3video] 465: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 42.340215] autorun-usecase.sh[113]: [m3vpss ] 463: SYSTEM: Creating MsgQ [VPSS-M3_ACK_MSGQ] ...
[ 42.345964] autorun-usecase.sh[113]: [m3video] 465: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[ 42.347583] autorun-usecase.sh[113]: [m3vpss ] 465: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 42.349138] autorun-usecase.sh[113]: [m3video] 466: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 42.350435] autorun-usecase.sh[113]: [m3vpss ] 465: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[ 42.683269] autorun-usecase.sh[113]: [m3video] 466: SYSTEM: IPC init DONE !!!
[ 42.684663] autorun-usecase.sh[113]: [m3vpss ] 465: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 42.685918] autorun-usecase.sh[113]: [m3vpss ] 466: SYSTEM: IPC init DONE !!!
[ 42.687173] autorun-usecase.sh[113]: [m3video] 476: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 42.688424] autorun-usecase.sh[113]: [m3vpss ] 476: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 42.689643] autorun-usecase.sh[113]: [m3video] 477: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 42.690921] autorun-usecase.sh[113]: [m3vpss ] 477: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 42.692379] autorun-usecase.sh[113]: [m3video] 479: SYSTEM : System Common Init Done !!!
[ 42.693727] autorun-usecase.sh[113]: [m3vpss ] 479: SYSTEM : System Commo [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 42.694963] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 42.696162] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 42.697354] autorun-usecase.sh[113]: [m3video] Received character 's'
[ 42.698627] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 42.699849] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 42.701135] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 42.702339] autorun-usecase.sh[113]: [c6xdsp ] Received character 's'
[ 42.703601] autorun-usecase.sh[113]: queue id:65538
[ 42.704835] autorun-usecase.sh[113]: Creat queue id:131076
[ 42.706035] autorun-usecase.sh[113]: queue id:131076
[ 42.707232] autorun-usecase.sh[113]: CPU is TI812x
[ 42.708428] autorun-usecase.sh[113]: vsenable : 0
[ 42.709710] autorun-usecase.sh[113]: Creat queue id:163845
[ 42.710949] autorun-usecase.sh[113]: queue id:163845
[ 42.712210] autorun-usecase.sh[113]: queue id:65538
[ 42.713436] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 42.714626] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 42.715834] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 42.717062] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 42.718246] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 42.719447] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 42.720850] autorun-usecase.sh[113]: n Init Done !!!
[ 42.722160] autorun-usecase.sh[113]: [c6xdsp ] 328: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 42.723405] autorun-usecase.sh[113]: [c6xdsp ] 328: SYSTEM: Creating MsgQ [DSP_MSGQ] ...
[ 42.724616] autorun-usecase.sh[113]: [c6xdsp ] 328: SYSTEM: Creating MsgQ [DSP_ACK_MSGQ] ...
[ 42.725822] autorun-usecase.sh[113]: [c6xdsp ] 329: SYSTEM: Notify register to [HOST] line 0, event 12 ...
[ 42.727054] autorun-usecase.sh[113]: [c6xdsp ] 329: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[ 42.728259] autorun-usecase.sh[113]: [c6xdsp ] 329: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[ 42.729460] autorun-usecase.sh[113]: [c6xdsp ] 329: SYSTEM: IPC init DONE !!!
[ 42.730699] autorun-usecase.sh[113]: [c6xdsp ] 333: MEM: Shared Region 2: Base = 0xb8000000, Length = 0x06900000 (105 MB)
[ 42.731996] autorun-usecase.sh[113]: [c6xdsp ] 333: MEM: Shared Region 1: Base = 0x89000000, Length = 0x03b00000 (59 MB)
[ 42.733221] autorun-usecase.sh[113]: [c6xdsp ] 333: SYSTEM : System Common Init Done !!!
[ 42.734426] autorun-usecase.sh[113]: [m3video] 879: SYSTEM : System Video Init in progress !!!
[ 42.735635] autorun-usecase.sh[113]: [m3vpss ] 878: SYSTEM : System VPSS Init in progress !!!
[ 42.736839] autorun-usecase.sh[113]: [m3video] 879: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_0] in region 0 ...
[ 42.738071] autorun-usecase.sh[113]: [m3video] 880: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_0] in region 0 ...
[ 42.739282] autorun-usecase.sh[113]: [m3video] 880: SYSTEM: ListElem Shared Addr = 0xbe98b680
[ 42.740523] autorun-usecase.sh[113]: [m3video] 882: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_1] in region 0 ...
[ 43.074022] autorun-usecase.sh[113]: [m3video] 883: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_1] in region 0 ...
[ 43.075290] autorun-usecase.sh[113]: [m3video] 883: SYSTEM: ListElem Shared Addr = 0xbe98eb80
[ 43.076514] autorun-usecase.sh[113]: [m3video] 892: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_29] in region 0 ...
[ 43.077726] autorun-usecase.sh[113]: [m3vpss ] === I2C0/2 Clk is active ===
[ 43.078959] autorun-usecase.sh[113]: [m3video] 893: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_29] in region 0 ...
[ 43.080190] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_1
[ 43.081399] autorun-usecase.sh[113]: [m3video] 893: SYSTEM: ListElem Shared Addr = 0xbe992080
[ 43.082607] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to ISS_PLATFORM_CPU_REV_2_1
[ 43.083808] autorun-usecase.sh[113]: [m3video] 895: SYSTEM: Creating ListMP [VIDEO-M3_IPC_OUT_30] in region 0 ...
[ 43.085109] autorun-usecase.sh[113]: [m3vpss ] 898: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_0] in region 0 ...
[ 43.086323] autorun-usecase.sh[113]: [m3video] 896: SYSTEM: Creating ListMP [VIDEO-M3_IPC_IN_30] in region 0 ...
[ 43.087536] autorun-usecase.sh[113]: [m3vpss ] 898: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_0] in region 0 ...
[ 43.088741] autorun-usecase.sh[113]: [m3video] 896: SYSTEM: ListElem Shared Addr = 0xbe9abd00
[ 43.090116] autorun-usecase.sh[113]: [m3vpss ] 898: SYSTEM: ListElem Shared Addr = 0xbe9c5980
[ 43.091368] autorun-usecase.sh[113]: [m3video] 898: HDVICP: Doing PRCM for IVAHD[0] ...
[ 43.092590] autorun-usecase.sh[113]: [m3vpss ] 901: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_1] in region 0 ...
[ 43.093890] autorun-usecase.sh[113]: [m3video] 898: HDVICP: PRCM for IVAHD[0] ... DONE.
[ 43.095203] autorun-usecase.sh[113]: [m3video] 899: SYSTEM : Initializing Links !!!
[ 43.096449] autorun-usecase.sh[113]: [m3video] 899: SYSTEM : FREE SPACE : System Heap = 6282072 B, Mbx = 10240 msgs)
[ 43.097662] autorun-usecase.sh[113]: [m3vpss ] 901: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_1] in region 0 ...
[ 43.098872] autorun-usecase.sh[113]: [m3vpss ] 902: SYSTEM: ListElem Shared Addr = 0xbe9c8e80
[ 43.100106] autorun-usecase.sh[113]: [m3video] 900: SYSTEM : FREE SPACE : SR0 Heap = 15955840 B (15 MB)
[ 43.101348] autorun-usecase.sh[113]: [m3video] 900: SYSTEM : FREE SPACE : Frame Buffer = 110100352 B (104 MB)
[ 43.102552] autorun-usecase.sh[113]: [m3vpss ] 915: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_24] in region 0 ...
[ 43.103756] autorun-usecase.sh[113]: [m3vpss ] 916: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_24] in region 0 ...
[ 43.105021] autorun-usecase.sh[113]: [m3video] 900: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 43.106248] autorun-usecase.sh[113]: [m3vpss ] 916: SYSTEM: ListElem Shared Addr = 0xbe9cc380
[ 43.107481] autorun-usecase.sh[113]: [m3vpss ] 919: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_25] in region 0 ...
[ 43.108685] autorun-usecase.sh[113]: [m3video] 901: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[ 43.109894] autorun-usecase.sh[113]: [m3vpss ] 919: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_25] in region 0 ...
[ 43.111137] autorun-usecase.sh[113]: [m3video] 902: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 43.112370] autorun-usecase.sh[113]: [m3vpss ] 919: SYSTEM: ListElem Shared Addr = 0xbe9ebd80
[ 43.113572] autorun-usecase.sh[113]: [m3video] Entered the MctnfLink_init()
[ 43.114837] autorun-usecase.sh[113]: [m3vpss ] 922: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_26] in region 0 ...
[ 43.116065] autorun-usecase.sh[113]: [m3vpss ] 922: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_26] in region 0 ...
[ 43.117270] autorun-usecase.sh[113]: [m3vpss ] 923: SYSTEM: ListElem Shared Addr = 0xbea0b780
[ 43.118500] autorun-usecase.sh[113]: [m3vpss ] 929: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_29] in region 0 ...
[ 43.119706] autorun-usecase.sh[113]: [m3vpss ] 929: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_29] in region 0 ...
[ 43.120945] autorun-usecase.sh[113]: [m3vpss ] 930: SYSTEM: ListElem Shared Addr = 0xbea2b180
[ 43.455103] autorun-usecase.sh[113]: [m3vpss ] 932: SYSTEM: Creating ListMP [VPSS-M3_IPC_OUT_30] in region 0 ...
[ 43.456531] autorun-usecase.sh[113]: [m3vpss ] 933: SYSTEM: Creating ListMP [VPSS-M3_IPC_IN_30] in region 0 ...
[ 43.457868] autorun-usecase.sh[113]: [m3vpss ] 933: SYSTEM: ListElem Shared Addr = 0xbea44e00
[ 44.034311] autorun-usecase.sh[113]: [m3vpss ] 935: SYSTEM : HDVPSS Drivers Version: HD [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 44.044849] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 44.049326] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 44.055177] autorun-usecase.sh[113]: ApproDrvInit: 7
[ 44.059678] autorun-usecase.sh[113]: queue id:163845
[ 46.030359] autorun-usecase.sh[113]: queue id:0
[ 47.180106] autorun-usecase.sh[113]: ApproDrvInit: 3
[ 47.190475] autorun-usecase.sh[113]: queue id:163845
[ 50.660688] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 50.661260] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 50.661697] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 50.662141] autorun-usecase.sh[113]: [m3vpss ] Received character 't'
[ 50.681241] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 50.681905] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 50.682360] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 50.682787] autorun-usecase.sh[113]: [m3video] Received character 't'
[ 50.702154] autorun-usecase.sh[113]: [c6xdsp ] Remote Debug Shared Memory @ 0xbff00000
[ 50.702820] autorun-usecase.sh[113]: [m3video] Remote Debug Shared Memory @ 0xbff05020
[ 50.703269] autorun-usecase.sh[113]: [m3vpss ] Remote Debug Shared Memory @ 0xbff0a040
[ 50.703701] autorun-usecase.sh[113]: [c6xdsp ] Received character 't'
[ 50.729501] autorun-usecase.sh[113]: rmmod: ERROR: Module osa_kermod is not currently loaded
[ 50.790435] DMA: Module install successful, device major num = 244
[ 50.796818] DRV: Module install successful
[ 50.800936] DRV: Module built on Apr 25 2017 10:45:50
[ 50.866277]
[ 50.866277] soc_is_ti814x
[ 50.929100] HDMI W1 rev 4.0
[ 50.931949] HDMI CEC Spec version 1.2
[ 51.303215] I2C No Ack
[ 51.305708] HDMI failed to read E-EDID
[host]793024] autorun-usecase.sh[113]:
[host] ORG 0x46c00524: 0case.sh[113]:
[host] NEW 0x46c00524: 2case.sh[113]:
[host]794828] autorun-usecase.sh[113]:
[host] Application Start Completed13]:
[host] 0: SYSTEM: System Common Init in progress !!!
[host] 0: SYSTEM: IPC init in progress !!!
[host] 9: SYSTEM: CPU [DSP] syslink proc ID is [0] !!!
[host] 10: SYSTEM: CPU [VIDEO-M3] syslink proc ID is [1] !!!
[host] 11: SYSTEM: CPU [VPSS-M3][ 51.947833] DMA: ChannelID allocated:4
syslink proc ID is [2] !!!
[host] 12: SYSTEM: CPU [HOST] syslink proc ID is [3] !!!
[host] 12: SYSTEM: Opening MsgQ Heap [IPC_MSGQ_MSG_HEAP] ...
[ 51.905184] autoru[ 51.975211] DMA: ChannelID allocated:5
[host] 13: SYSTEM: Creating MsgQ [HOST_MSGQ] ...
[host] 14: SYSTEM: Creating MsgQ [HOST_ACK_MSGQ] ...
[host] 14: SYSTEM: Opening MsgQ [DSP_MSGQ] ...
[host] 14: SYSTEM: Opening MsgQ [VIDEO-M3_MSGQ] ...
[host] 15: SYSTEM: Opening MsgQ [VPSS-M3_MSGQ] ...
[host] 16: SYSTEM: Notify register to [DSP] line 0, event 12 ...
[host] 16: SYSTEM: Notify register to [VIDEO-M3] line 0, event 12 ...
[host] 16: SYSTEM: Notify register to [VPSS-M3] line 0, event 12 ...
[host] 16: SYSTEM: IPC init DONE !!!:
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_OUT_29] in region 0 ...
[host] 18: SYSTEM: Creating ListMP [HOST_IPC_IN_29] in region 0 ...
[host] 18: SYSTEM: ListElem Shared Addr = 0xb5679180
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_OUT_30] in region 0 ...
[host] 19: SYSTEM: Creating ListMP [HOST_IPC_IN_30] in region 0 ...
[host] 19: SYSTEM: ListElem Shared Addr = 0xb5692e00
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_OUT_24] in region 0 ...
[host] 22: SYSTEM: Creating ListMP [HOST_IPC_IN_24] in region 0 ...
[host] 23: SYSTEM: ListElem Shared Addr = 0xb56aca80
[host] 23: SYSTEM: Creating ListMP [HOST_IPC_OUT_25] in region 0 ...
[host] 24: SYSTEM: Creating ListMP [HOST_IPC_IN_25] in region 0 ...
[host] 25: SYSTEM: ListElem Shared Addr = 0xb56cc480
[host] 27: SYSTEM: Creating ListMP [HOST_IPC_OUT_26] in region 0 ...
[host] 27: SYSTEM: Creating ListMP [HOST_IPC_IN_26] in region 0 ...
[host] 27: SYSTEM: ListElem Shared Addr = 0xb56ebe80
[host] 28: SYSTEM: System Common Init Done !!!
[host] Vsys_allocBuf - addr = 0xa7388000,size = 65011712
[ 51.970566] autorun-usecase.sh[113]: ##########pInfo->totalsize 63897600
[ 51.974958] autorun-usecase.sh[113]: queue id:0
[ 51.975538] autorun-usecase.sh[113]: queue id:32769
[host] MemMng_memcpy_open:OSA_dmaOpen passed with ch id = 4
[host] CacheMng_MemCpy_open:OSA_dmaOpen passed with ch id = 5
[host] MCFW_IPCFRAMES:App_ipcFramesSendRecvFxn:Entered...
[host] Vsys_allocBuf - addr = 0xb6f1b000,size = 33603
[host] DCC buffer allocated for size 33603
[host] DCC Default File Intialization Done
[host] Before System_linkControl SYSTEM_M3VPSS_CMD_GET_DISPLAYCTRL_INIT
[host]059390] autorun-usecase.sh[113]:
[ 52.060114] autorun-usecase.sh[113]: ********** FULL FEATURE USECASE ********
[host] ********* Entered Tri Streaming usecase - H264 1080p @60fps + H264 D1 @30fps + MJPEG 1080p @5fps ********
[host] 170: MCFW : CPU Revision [ES2.1] !!!
[host] 170: MCFW : Detected [UNKNOWN] Board !!!
[host] 170: MCFW : Base Board Revision [REV A] !!!
[ 52.413008] autorun-usecase.sh[113]: VPSS_01_00_01_37
[ 52.413655] autorun-usecase.sh[113]: [m3vpss ] 935: SYSTEM : FVID2 Init in progress !!!
[ 52.414197] autorun-usecase.sh[113]: [m3video] 961: SYSTEM : Initializing Links ... DONE !!!
[ 52.414779] autorun-usecase.sh[113]: [m3vpss ] PLATFORM: UNKNOWN CPU detected, defaulting to VPS_PLATFORM_CPU_REV_2_1
[ 52.415322] autorun-usecase.sh[113]: [m3video] 961: SYSTEM : System Video Init Done !!!
[ 52.415851] autorun-usecase.sh[113]: [m3vpss ] 1004: SYSTEM : FVID2 Init in progress DONE !!!
[ 52.416407] autorun-usecase.sh[113]: [m3vpss ] 1005: SYSTEM : Device Init in progress !!!
[ 52.416930] autorun-usecase.sh[113]: [m3vpss ] Iss_init called !!!!!!
[ 52.417485] autorun-usecase.sh[113]: [m3vpss ] CPIS_init DONE !!!!!!
[ 52.418008] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 52.418561] autorun-usecase.sh[113]: [m3vpss ] initPrms.isI2cInitReq = 1
[ 52.419086] autorun-usecase.sh[113]: [m3vpss ] Vps_deviceInit Daughter card not detected/connected!
[ 52.419635] autorun-usecase.sh[113]: [m3vpss ] I2C2: Passed for address 0x10 !!!
[ 52.420191] autorun-usecase.sh[113]: [m3vpss ] I2C2: Passed for address 0x2d !!!
[ 52.420753] autorun-usecase.sh[113]: [c6xdsp ] 2232: SYSTEM : System DSP Init in progress !!!
[ 52.421272] autorun-usecase.sh[113]: [c6xdsp ] 2238: SYSTEM: Creating ListMP [DSP_IPC_OUT_24] in region 0 ...
[ 52.421785] autorun-usecase.sh[113]: [c6xdsp ] 2238: SYSTEM: Creating ListMP [DSP_IPC_IN_24] in region 0 ...
[ 52.422338] autorun-usecase.sh[113]: [c6xdsp ] 2238: SYSTEM: ListElem Shared Addr = 0xbea5ea80
[ 52.422899] autorun-usecase.sh[113]: [c6xdsp ] 2239: SYSTEM: Creating ListMP [DSP_IPC_OUT_25] in region 0 ...
[ 52.423420] autorun-usecase.sh[113]: [c6xdsp ] 2239: SYSTEM: Creating ListMP [DSP_IPC_IN_25] in region 0 ...
[ 52.423933] autorun-usecase.sh[113]: [c6xdsp ] 2239: SYSTEM: ListElem Shared Addr = 0xbea7e480
[ 52.424527] autorun-usecase.sh[113]: [c6xdsp ] 2240: SYSTEM: Creating ListMP [DSP_IPC_OUT_26] in region 0 ...
[ 52.425092] autorun-usecase.sh[113]: [c6xdsp ] 2241: SYSTEM: Creating ListMP [DSP_IPC_IN_26] in region 0 ...
[ 52.425633] autorun-usecase.sh[113]: [c6xdsp ] 2241: SYSTEM: ListElem Shared Addr = 0xbea9de80
[ 52.426181] autorun-usecase.sh[113]: [c6xdsp ] 2242: SYSTEM: Creating ListMP [DSP_IPC_OUT_29] in region 0 ...
[ 52.426701] autorun-usecase.sh[113]: [c6xdsp ] 2242: SYSTEM: Creating ListMP [DSP_IPC_IN_29] in region 0 ...
[ 52.427216] autorun-usecase.sh[113]: [c6xdsp ] 2242: SYSTEM: ListElem Shared Addr = 0xbeabd880
[ 52.427786] autorun-usecase.sh[113]: [c6xdsp ] 2243: SYSTEM: Creating ListMP [DSP_IPC_OUT_30] in region 0 ...
[ 52.428335] autorun-usecase.sh[113]: [c6xdsp ] 2243: SYSTEM: Creating ListMP [DSP_IPC_IN_30] in region 0 ...
[ 52.428851] autorun-usecase.sh[113]: [c6xdsp ] 2243: SYSTEM: ListElem Shared Addr = 0xbead7500
[ 52.429410] autorun-usecase.sh[113]: [c6xdsp ] !!WARNING.Resource already registered:2
[ 52.429947] autorun-usecase.sh[113]: [c6xdsp ] 2243: SYSTEM : Initializing Links !!!
[ 52.430525] autorun-usecase.sh[113]: [c6xdsp ] 2245: SYSTEM : FREE SPACE : System Heap = 6282440 B, Mbx = 10240 msgs)
[ 52.431062] autorun-usecase.sh[113]: [c6xdsp ] 2249: SPOFLINK : INIT in progress !!!
[ 52.431699] autorun-usecase.sh[113]: [c6xdsp [ 52.725184] DMA: ChannelID allocated:6
] 2260: SYSTEM : Initializing Links ... DONE !!!
[ 52.43221[ 52.733578] DMA: ChannelID allocated:7
9] autorun-usecase.sh[113]: [c6xdsp ] 2260: SYSTEM : System DSP Init Done !!!
[ 52.432761] autorun-usecase.sh[113]: [m3vpss ] 3738: SYSTEM : Device Init in progress DONE !!!
[ 52.433343] autorun-usecase.sh[113]: [m3vpss ] DONE ar0331_lvds/src/issdrv_ar0331Api.c:AR0331_Transplant_DRV_imgsSetRegs:705 !!!
[ 52.433905] autorun-usecase.sh[113]: [m3vpss ] 8848: SYSTEM : System VPSS Init Done !!!
[ 52.434422] autorun-usecase.sh[113]: [m3vpss ] 8848: UTILS: DMA: HWI Create for INT62 !!!
[ 52.434981] autorun-usecase.sh[113]: [m3vpss ] 8849: SYSTEM : Initializing Links !!!
[ 52.435501] autorun-usecase.sh[113]: [m3vpss ] 8849: SYSTEM : FREE SPACE : System Heap = 1677496 B, Mbx = 10240 msgs)
[ 52.436061] autorun-usecase.sh[113]: [m3vpss ] 8849: SYSTEM : FREE SPACE : SR0 Heap = 1[ 52.812027] DMA: ChannelID allocated:14
4742656 B (14 MB)
[ 52.774670] autorun-usecase.sh[113]: [m3vpss ] 8849: SYSTEM : FREE SPACE : Frame Buffer = 105790336 B (100 MB)
[ 52.775260] autorun-usecase.sh[113]: [m3vpss ] 8850: SYSTEM : FREE SPACE : Bitstream Buffer = 61865856 B (58 MB)
[ 52.775813] autorun-usecase.sh[113]: [m3vpss ] 8850: SYSTEM : FREE SPACE : Tiler Buffer = 128 B (0 MB) - TILER OFF
[ 52.776348] autorun-usecase.sh[113]: [m3vpss ] 8983: SYSTEM : Initializing Links ... DONE !!!
[ 52.776910] autorun-usecase.sh[113]: [m3vpss ] VPS_DCTRL_INST_0
[ 52.777434] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_DVO2
[ 52.777990] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_HDMI
[ 52.778518] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_OUTPUT SYSTEM_DC_VENC_SD
[ 52.779070] autorun-usecase.sh[113]: [m3vpss ] IOCTL_VPS_DCTRL_SET_VENC_CLK_SRC VPS_DC_VENC_HDMI | VPS_DC_VENC_DVO2
[ 52.779593] autorun-usecase.sh[113]: [m3vpss ] 10327: CAMERA: Create in progress !!!
[ 52.780244] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 0 Ch 0 ChannelNum 0
[ 52.780793] autorun-usecase.sh[113]: [m3vpss ] Channel Num Stream 1 Ch 0 ChannelNum 1
[ 52.781509] autorun-usecase.sh[113]: [m3vpss ] 10328: CAMERA: VIP0 PortA camera mode is [ 8-bit, Non-mux Embedded Sync] !!!
[ 52.782044] autorun-usecase.sh[113]: [m3vpss ] 10328: CAMERA: VIP 0: VID DEC 268436737 (0x10): 0002:20202020:20202020, AUD_STATUS 538976288
[ 52.782616] autorun-usecase.sh[113]: [m3vpss ] Iss_captCreate:1661
[ 52.783138] autorun-usecase.sh[113]: [m3vpss ] 10542: CAMERA: Create Done !!!
[ 52.783703] autorun-usecase.sh[113]: [m3vpss ] 10631: CAMERA: Detect video in progress !!!
[ 52.784222] autorun-usecase.sh[113]: [m3vpss ] 10631: CAMERA: Detect video Done !!!
[ 52.784791] autorun-usecase.sh[113]: [m3vpss ] 10705: DUP : Create Done !!!
[ 52.785348] autorun-usecase.sh[113]: [m3vpss ] 10639: VNF:
[ 52.785921] autorun-usecase.sh[113]: [m3vpss ] Create in progress ... !!!
[ 52.786523] autorun-usecase.sh[113]: [m3vpss ] 10639: VNF:
[ 52.787125] autorun-usecase.sh[113]: [m3vpss ] Input Channel CH0 of 1952 x 1112, pitch = (1984, 1984) [0,0][PROGRESSIVE] [7] ...
[ 52.787671] autorun-usecase.sh[113]: [m3vpss ] 10640: VNF:
[ 52.791978] autorun-usecase.sh[113]: [m3vpss ] [VNF] eOperateMode=6 [6-TNF3,7-NSF2]chVnfCreateParams->ulStartX = 0
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 6
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 7
[host] Vsys_eventHandler:OSA_dmaOpen passed with ch id = 14
[host] IpcBitsInLink_tskMain:Entered]:
[host] 1225: IPC_BITS_IN : Create in progress !!!
[host] 1225: IPC_BITS_IN : ListMPOpen start !!!
[host] 1225: SYSTEM: Opening ListMP [VIDEO-M3_IPC_OUT_29] ...
[host] 1225: SYSTEM: Opening ListMP [VIDEO-M3_IPC_IN_29] ...
[host] 1226: IPC_BITS_IN : ListMPOpen done !!!
[host] 1226: IPC_BITS_IN : System_linkGetInfo done !!!
[host] 1227: IPC_BITS_IN : Create Done !!!
[host] USECASE SETUP DONEcase.sh[113]:
[host]325102] autorun-usecase.sh[113]:
[ 53.325699] autorun-usecase.sh[113]: Application Run Completed
[host] ITT server task running !!!13]:
[host]426722] autorun-usecase.sh[113]:
[ 53.427252] autorun-usecase.sh[113]: ITT ittServer_run
[host] ITT Server Message initialization successful
[host]428380] autorun-usecase.sh[113]:
[ 53.428940] autorun-usecase.sh[113]: ITT capture task created
[host] DCC server Message ques is open succefully
[host] Setting cmd <1> in message <b5493100>
[host] Posting message <b5493100> in QId <20002>
[host] Response from M3 is : 1sh[113]:
[ 53.462322] autorun-usecase.sh[113]: chVnfCreateParams->ulStartY = 0 chVnfCreateParams->ulInputStride = 1984 chVnfCreateParams->ulInputWidth=1952,chVnfCreateParams->ulInputHeight=1112
[ 53.462898] autorun-usecase.sh[113]: [m3vpss ] 10812: VNF:
[ 53.463482] autorun-usecase.sh[113]: [m3vpss ] [VNF] outChInfo->StartX = 0 outChInfo->startY = 0 outChInfo->pitch[0] = 1952 outChInfo->width=1920,outChInfo->height=1080
[ 53.464138] autorun-usecase.sh[113]: [m3vpss ] 10814: VNF:
[ 53.464724] autorun-usecase.sh[113]: [m3vpss ] Create ... DONE !!!
[ 53.465256] autorun-usecase.sh[113]: [m3vpss ] 10881: NSF: Create in progress !!!
[ 53.465828] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:0 USED:128
[ 53.466355] autorun-usecase.sh[113]: [m3vpss ] NSF::HEAPID:1 USED:4928
[ 53.466947] autorun-usecase.sh[113]: [m3vpss ] 11012: NSF: Create Done !!!
[ 53.467473] autorun-usecase.sh[113]: [m3vpss ] DCC server task running
[ 53.468037] autorun-usecase.sh[113]: [m3vpss ] 11015: Mux : Creating... !!!
[ 53.468560] autorun-usecase.sh[113]: [m3vpss ] 11017: WARNING MUX Link : Ignoring channel no 0 of Input Q ID 0. As this channel was not mapped !!!
[ 53.469126] autorun-usecase.sh[113]: [m3vpss ] 11017: Mux : Create Done !!!
[ 53.469674] autorun-usecase.sh[113]: [m3vpss ] 11024: DUP : Create Done !!!
[ 53.470294] autorun-usecase.sh[113]: [m3vpss ] 11031: DUP : Create Done !!!
[ 53.470826] autorun-usecase.sh[113]: [m3vpss ] 11031: Mux : Creating... !!!
[ 53.471405] autorun-usecase.sh[113]: [m3vpss ] 11033: Mux : Create Done !!!
[ 53.472131] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 36
[ 53.472687] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 36
[ 53.473238] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 37
[ 53.473768] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 37
[ 53.474324] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->tccVal = 38
[ 53.474856] autorun-usecase.sh[113]: [m3vpss ] {SWOSD} edma3Handle->chId = 38
[ 53.475418] autorun-usecase.sh[113]: [m3vpss ] 11043: SYSTEM: Opening MsgQ [HOST_MSGQ] ...
[ 53.475970] autorun-usecase.sh[113]: [m3vpss ] 11046: SWOSD : Create Done !!!
[ 53.476524] autorun-usecase.sh[113]: [m3vpss ] 11120: DUP : Create Done !!!
[ 53.477057] autorun-usecase.sh[113]: [m3vpss ] 11120: SCLR: Create in progress !!!
[ 53.477617] autorun-usecase.sh[113]: [m3vpss ] 11126: SCLR : Loading Up-scaling Co-effs ...
[ 53.478179] autorun-usecase.sh[113]: [m3vpss ] 11126: SCLR : Co-effs Loading ... DONE !!!
[ 53.478738] autorun-usecase.sh[113]: [m3video] 11142: IPC_IN_M3 : Create in progress !!!
[ 53.479263] autorun-usecase.sh[113]: [m3video] 11142: SYSTEM: Opening ListMP [VPSS-M3_IPC_OUT_0] ...
[ 53.479816] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:0 USED:64
[ 53.480821] autorun-usecase.sh[113]: [m3video] 11143: SYSTEM: Opening ListMP [VPSS-M3_IPC_IN_0] ...
[ 53.481414] autorun-usecase.sh[113]: [m3vpss ] SCLR:HEAPID:1 USED:5952
[ 53.482037] autorun-usecase.sh[113]: [m3video] 11146: IPC_IN_M3 : Create Done !!!
[ 53.482585] autorun-usecase.sh[113]: [m3vpss ] 11126: SCLR: Create Done !!!
[ 53.483139] autorun-usecase.sh[113]: [m3video] 11146: ENCODE: Create in progress ... !!!
[ 53.483683] autorun-usecase.sh[113]: [m3vpss ] 11073: FD : Alg Create Done !!!
[ 53.484236] autorun-usecase.sh[113]: [m3vpss ] 11073: FD : Create Done !!!
[ 53.484817] autorun-usecase.sh[113]: [m3vpss ] 11140: IPC_OUT_M3 : Create in progress !!!
[ 53.485388] autorun-usecase.sh[113]: [m3vpss ] 11141: IPC_OUT_M3 : Create Done !!!
[ 53.485917] autorun-usecase.sh[113]: [m3video] 11272: ENCODE: Creating CH0 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 53.486498] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:13272
[ 53.487028] autorun-usecase.sh[113]: [m3video] 11355: ENCODE: Creating CH1 of 720 x 480, pitch = (720, 720) [PROGRESSIVE] [NON-TILED ], bitrate = 8000 Kbps ...
[ 53.819492] autorun-usecase.sh[113]: [m3vpss ] 11451: DISPLAY: Create in progress !!!
[ 53.820189] autorun-usecase.sh[113]: [m3video] ENCLINK_H264:HEAPID:0 USED:11720
[ 53.820766] autorun-usecase.sh[113]: [m3vpss ] DisplayId = 1,DataFormat = 7
[ 53.821346] autorun-usecase.sh[113]: [m3video] 11441: ENCODE: Creating CH2 of 1920 x 1080, pitch = (1952, 1952) [PROGRESSIVE] [NON-TILED ], bitrate = 100 Kbps ...
[ 53.821905] autorun-usecase.sh[113]: [m3vpss ] SC2 displayInstId = 6
[ 53.822480] autorun-usecase.sh[113]: [m3vpss ] 11452: DISPLAY: Create Done !!!
[ 53.823007] autorun-usecase.sh[113]: [m3vpss ] 11453: DISPLAY: Create in progress !!!
[ 53.823560] autorun-usecase.sh[113]: [m3video] ENCLINK_JPEG:HEAPID:0 USED:4376
[ 53.824089] autorun-usecase.sh[113]: [m3vpss ] DisplayId = 4,DataFormat = 7
[ 53.824714] autorun-usecase.sh[113]: [m3video] 11442: ENCODE: All CH Create ... DONE !!!
[ 53.825242] autorun-usecase.sh[113]: [m3vpss ] SD displayInstId = 2
[ 53.825799] autorun-usecase.sh[113]: [m3vpss ] 11454: DISPLAY: Create Done !!!
[ 53.826350] autorun-usecase.sh[113]: [m3vpss ] 11455: DISPLAY: Start in progress !!!
[ 53.827387] autorun-usecase.sh[113]: [m3video] ENCLINK:HEAPID:0 USED:29696
[ 53.827968] autorun-usecase.sh[113]: [m3video] 11445: ENCODE: Create ... DONE !!!
[ 53.828506] autorun-usecase.sh[113]: [m3video] 11318: VSTAB : Alg Create Done !!!
[ 53.829067] autorun-usecase.sh[113]: [m3video] 11318: VSTAB : Create Done !!!
[ 53.829593] autorun-usecase.sh[113]: [m3video] 11446: IPC_BITS_OUT : Create in progress !!!
[ 53.830191] autorun-usecase.sh[113]: [m3video] 11448: IPC_BITS_OUT : Create Done !!!
[ 53.830724] autorun-usecase.sh[113]: [m3vpss ] 11491: DISPLAY: Start Done !!!
[ 53.831282] autorun-usecase.sh[113]: [m3vpss ] 11492: DISPLAY: AUX PATH: 54 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[ 53.831811] autorun-usecase.sh[113]: [m3vpss ] 11492: DISPLAY: Start in progress !!!
[ 53.832392] autorun-usecase.sh[113]: [m3vpss ] 11554: DISPLAY: Start Done !!!
[ 53.832931] autorun-usecase.sh[113]: [m3vpss ] 11554: DISPLAY: SDDAC(SEC1): 16 fps, Latency (Min / Max) = ( 255 / 0 ), Callback Interval (Min / Max) = ( 255 / 0 ) !!!
[ 53.833493] autorun-usecase.sh[113]: [m3vpss ] 11489: CAMERA: Start in progress !!!
[ 53.834023] autorun-usecase.sh[113]: [m3vpss ] 11489: CAMERA: Start Done !!!
[ 53.834738] autorun-usecase.sh[113]: [m3vpss ] CT: 1000, 3dlut index:0
[ 53.835288] autorun-usecase.sh[113]: [m3vpss ] 11613: CAMERA: Fields = 2 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
[ 53.835894] autorun-usecase.sh[113]: [m3vpss ] Command 1 recived from HOST A8
[ 53.836774] autorun-usecase.sh[113]: [m3vpss ] Command 2 recived from HOST A8
[ 53.837416] autorun-usecase.sh[113]: [m3vpss ] New DCC data of size <3360
[host] Default parameters were sent sucessfully
[host] Server Socket created with ID <22>
[ 54.620320] autorun-usecase.sh[113]: Venc not supported!!
[host] VNF MESSAGE RECIEVED: (Enable:0) (Mode:5) (Strength:0) (EnableTNF:0) (EnableSNF:0)
[host]625339] autorun-usecase.sh[113]:
[ 54.626561] autorun-usecase.sh[113]: Channel Selected: 0
[host]627379] autorun-usecase.sh[113]:
[ 54.655976] autorun-usecase.sh[113]: Channel Selected: 0,rate control = 0
[host]656823] autorun-usecase.sh[113]:
[ 54.657303] autorun-usecase.sh[113]: ========== Stream FrameRate1 = 30 =================
[host]661731] autorun-usecase.sh[113]:
[ 54.664612] autorun-usecase.sh[113]: Channel Selected: 0
[host]665404] autorun-usecase.sh[113]:
[ 54.665955] autorun-usecase.sh[113]: Channel Selected: 0
[host]666531] autorun-usecase.sh[113]:
[ 54.667057] autorun-usecase.sh[113]: Channel Selected: 0
[host]668390] autorun-usecase.sh[113]:
[ 54.669135] autorun-usecase.sh[113]: Channel Selected: 0,packet size = 100
[host]669685] autorun-usecase.sh[113]:
[ 54.670262] autorun-usecase.sh[113]: Channel Selected: 0,encPreset = 0
[host]670906] autorun-usecase.sh[113]:
[ 54.671446] autorun-usecase.sh[113]: Channel Selected: 0,enable = 0
[host]671980] autorun-usecase.sh[113]:
[ 54.672619] autorun-usecase.sh[113]: Channel Selected: 1
[host]673422] autorun-usecase.sh[113]:
[ 54.675240] autorun-usecase.sh[113]: Channel Selected: 1,rate control = 0
[host]676302] autorun-usecase.sh[113]:
[ 54.677333] autorun-usecase.sh[113]: Channel Selected: 1
[host]682655] autorun-usecase.sh[113]:
[ 54.684956] autorun-usecase.sh[113]: Channel Selected: 1
[host]685727] autorun-usecase.sh[113]:
[ 54.686295] autorun-usecase.sh[113]: Channel Selected: 1
[host]687731] autorun-usecase.sh[113]:
[ 54.688329] autorun-usecase.sh[113]: Channel Selected: 1,packet size = 100
[host]688876] autorun-usecase.sh[113]:
[ 54.693249] autorun-usecase.sh[113]: Channel Selected: 1,encPreset = 0
[host]693911] autorun-usecase.sh[113]:
[ 54.694451] autorun-usecase.sh[113]: Channel Selected: 1,enable = 0
[host]699991] autorun-usecase.sh[113]:
[ 54.703668] autorun-usecase.sh[113]: Channel Selected: 2
[host]704854] autorun-usecase.sh[113]:
[ 54.706185] autorun-usecase.sh[113]: Channel Selected: 2,rate control = 2
[host] MJPEG in Rate Control OFF Mode:
[ 54.803549] autorun-usecase.sh[113]: Simple mixer control 'PGA',0
[ 54.804269] autorun-usecase.sh[113]: Capabilities: cvolume cswitch
[ 54.805088] autorun-usecase.sh[113]: Capture channels: Front Left - Front Right
[ 54.805650] autorun-usecase.sh[113]: Limits: Capture 0 - 119
[ 54.806196] autorun-usecase.sh[113]: Front Left: Capture 95 [80%] [47.50dB] [on]
[ 54.813261] autorun-usecase.sh[113]: Front Right: Capture 95 [80%] [47.50dB] [on]
[ 56.394723] autorun-usecase.sh[113]: Simple mixer control 'PCM',0
[ 56.395534] autorun-usecase.sh[113]: Capabilities: pvolume
[ 56.396018] autorun-usecase.sh[113]: Playback channels: Front Left - Front Right
[ 56.396545] autorun-usecase.sh[113]: Limits: Playback 0 - 127
[ 56.396996] autorun-usecase.sh[113]: Mono:
[ 56.397445] autorun-usecase.sh[113]: Front Left: Playback 101 [80%] [-13.00dB]
[ 56.397889] autorun-usecase.sh[113]: Front Right: Playback 101 [80%] [-13.00dB]
[host]406164] autorun-usecase.sh[113]:
[ 56.407047] autorun-usecase.sh[113]: Force IDR on Channel: 0
[host]407669] autorun-usecase.sh[113]:
[ 56.528888] sh (365): drop_caches: 1
[ 56.719193] autorun-usecase.sh[113]: Force IDR on Channel: 1umount: can't unmount /mnt/mmc: Invalid argument
[ 58.350088] autorun-usecase.sh[113]: mount: /dev/mmcblk0 is already mounted or /mnt/mmc busy
[ 58.397425] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 58.708027] autorun-usecase.sh[113]: killall: dhcpcd: no process killed
[ 61.409307] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 61.409972] autorun-usecase.sh[113]: Program exit.
[ 66.032940] autorun-usecase.sh[113]: TimeOut occure in boot_proc.
[ 66.033569] autorun-usecase.sh[113]: Program exit.
[host]527950] autorun-usecase.sh[113]:
[ 83.528567] autorun-usecase.sh[113]: Usecase is Active !!!
