使用dm365,dvsdk4。电路图是按照瑞泰创新的图画的,但是有个不一样的地方
(1)买芯片的时候不知道有tvp5146m2pfp和tvp5146pfp,用了tvp5146pfp。
(2)因为莲花头放在面板上,所以使用的是莲花头进来之后用大约2跟15cm的线引到到的电路板上。
现在问题是tvp5146无法检测到视频输入,出错相关信息如下:
(1)正常启动encode的出错信息
./encode -v test.264 -y 2 -r 352x288
Encode demo started.
Failed to detect video standard, video input connected?
对应的源代码如下:
if (Capture_detectVideoStd(NULL, &videoStd, &cAttrs) < 0) {
ERR("Failed to detect video standard, video input connected?\n");
cleanup(THREAD_FAILURE);
(2)加入DMAI_DEBUG之后的出错信息
DMAI_DEBUG=2 ./encode -v test.264 -y 2 -r 352x288
@0x000e5cdc:[T:0x4001f800] ti.sdo.dmai - [Dmai] Dmai log level set to '2'. Note that calling CERuntime_init after this point may cause unexpected change to .
@0x000e6cc8:[T:0x40c29490] ti.sdo.dmai - [Capture] Composite input selected
@0x0025d0dc:[T:0x40c29490] ti.sdo.dmai - [Capture] ERRNO (22) 《《出错
@0x0025d65d:[T:0x40c29490] ti.sdo.dmai - [Capture] Failed to set video input to 0 (Invalid argument)
(3)内核启动的相关信息:
root@dm365-evm:~/dm365# dmesg
Linux video capture interface: v2.00
vpfe_init
vpfe-capture: vpss clock vpss_master enabled
vpfe-capture vpfe-capture: v4l2 device registered
vpfe-capture vpfe-capture: video device registered
EVM: switch to tvp5146 SD video input
tvp514x 1-005d: tvp514x 1-005d decoder driver registered !!
vpfe-capture vpfe-capture: v4l2 sub device tvp5146 registered
vpfe_register_ccdc_device: DM365 ISIF
DM365 ISIF is registered with vpfe.
af major#: 251, minor# 0
AF Driver initialized
aew major#: 250, minor# 0
AEW Driver initialized
<davinci_display_init>
(4)系统调用的相关信息
root@dm365-evm:~/dm365# cat /proc/kallsyms|grep tvp
c001cfb8 t tvp514x_init
c0025160 t __initcall_tvp514x_init6
c022ce64 t tvp514x_remove
c022ce90 t tvp514x_g_fmt_cap
c022cf18 t tvp514x_g_ctrl
c022d030 t tvp514x_enum_fmt_cap
c022d0d0 t tvp514x_read_reg
c022d138 t tvp514x_get_current_std
c022d190 t tvp514x_s_parm
c022d1f0 t tvp514x_try_fmt_cap
c022d320 t tvp514x_s_fmt_cap
c022d3ac t tvp514x_g_parm
c022d428 t tvp514x_write_reg
c022d494 t tvp514x_s_std
c022d564 t tvp514x_s_ctrl
c022d764 t tvp514x_write_regs
c022d7ec t tvp514x_s_stream
c022dba8 t tvp514x_querystd
c022dcdc t tvp514x_s_routing
c022deb4 t tvp514x_queryctrl
c022dfd4 t tvp514x_probe
c031d460 t tvp514x_dev
c031d6e8 t tvp514x_ops
c031d708 t tvp514x_id
c031d780 t tvp514x_fmt_list
c031d7c0 t tvp514x_core_ops
c031d800 t tvp514x_video_ops
c031d854 t tvp5146_init_reg_seq
c031d8b4 t tvp514xm_init_reg_seq
c031d8cc t tvp5147_init_reg_seq
