* do_resize_422.c
* Example showing how to use Resizer in One shot mode to do Resize and
* also format conversion from UYVY to YUV420 Semi planar format (aka
* NV12 in v4l2 API)
* The following IP configuration used for this use case
* SDRAM -> IPIPEIF -> Resizer -> SDRAM
* Copyright (C) 2009 Texas Instruments Incorporated - http://www.ti.com/
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <sys/types.h>
#include <sys/ioctl.h>
#include <fcntl.h>
#include <unistd.h>
#include <stdlib.h>
#include <string.h>
#include <sys/mman.h>
#include <getopt.h>
#include <sys/time.h>
#include <media/davinci/imp_previewer.h>
#include <media/davinci/imp_resizer.h>
#include <media/davinci/dm365_ipipe.h>
#include "cmem.h"
char dev_name_prev[1][30] = {"/dev/davinci_previewer"};
char dev_name_rsz[1][30] = {"/dev/davinci_resizer"};
void usage()
printf("Usage: do_resize [OPTIONS]\n");
printf("Options:\n");
printf("\t-i\t1280x720 UYVY input file\n");
printf("\t-w\tWidth of the output image (stored in output1.yuv)\n");
printf("\t-h\tHeight of the output image (stored in output1.yuv)\n");
printf("\t-x\tCreate a second output image of 640x480 resolution\n");
printf("\t\t\t0 => Do not create second image [DEFAULT without -x]\n");
printf("\t\t\t1 => Create a second image\n");
printf("\t-t\tFormat of the output file\n");
printf("\t\t\t0 => UYVY format [DEFAULT without -t]\n");
printf("\t\t\t1 => YUV 420 Semi-Planar format\n");
#define MAX_WIDTH 1920
#define MAX_HEIGHT 1080
#define BYTESPERLINE 2
#define INPUT_HEIGHT 720
#define INPUT_WIDTH 1280
#define BUF_SIZE ((1280*720) + (1280*360) + 32)
char in_buf[MAX_WIDTH*MAX_HEIGHT*BYTESPERLINE];
#define OUTPUT1_FILE "./output1.yuv"
#define OUTPUT2_FILE "./output2.yuv"
#define ALIGN(x, y) (((x + (y-1))/y)*y)
struct buf_info {
void *user_addr;
unsigned long phy_addr;
/* For input and output frame */
struct buf_info input_buffer;
struct buf_info output1_buffer;
struct buf_info output2_buffer;
* allocate_user_buffers() allocate buffer using CMEM
int allocate_user_buffers(int in_buf_size, int out1_buf_size, int out2_buf_size)
void *pool;
int i;
CMEM_AllocParams alloc_params;
printf("calling cmem utilities for allocating frame buffers\n");
CMEM_init();
alloc_params.type = CMEM_POOL;
alloc_params.flags = CMEM_NONCACHED;
alloc_params.alignment = 32;
pool = CMEM_allocPool(0, &alloc_params);
if (NULL == pool) {
printf("Failed to allocate cmem pool\n");
return -1;
printf("Allocating input buffer :buf size = %d \n", in_buf_size);
input_buffer.user_addr = CMEM_alloc(ALIGN(in_buf_size,4096), &alloc_params);
if (input_buffer.user_addr) {
input_buffer.phy_addr = CMEM_getPhys(input_buffer.user_addr);
if (0 == input_buffer.phy_addr) {
printf("Failed to get phy cmem buffer address\n");
return -1;
} else {
printf("Failed to allocate cmem buffer\n");
return -1;
printf("Got %p from CMEM, phy = %p\n", input_buffer.user_addr,
(void *)input_buffer.phy_addr);
printf("Allocating output1 buffer :buf size = %d \n", out1_buf_size);
output1_buffer.user_addr = CMEM_alloc(ALIGN(out1_buf_size, 4096), &alloc_params);
if (output1_buffer.user_addr) {
output1_buffer.phy_addr = CMEM_getPhys(output1_buffer.user_addr);
if (0 == output1_buffer.phy_addr) {
return -1;
} else {
return -1;
printf("Got %p from CMEM, phy = %p\n", output1_buffer.user_addr,
(void *)output1_buffer.phy_addr);
printf("Allocating output2 buffer :buf size = %d \n", out2_buf_size);
output2_buffer.user_addr = CMEM_alloc(ALIGN(out2_buf_size,4096), &alloc_params);
if (output2_buffer.user_addr) {
output2_buffer.phy_addr = CMEM_getPhys(output2_buffer.user_addr);
if (0 == output2_buffer.phy_addr) {
return -1;
} else {
return -1;
printf("Got %p from CMEM, phy = %p\n", output2_buffer.user_addr,
(void *)output2_buffer.phy_addr);
return 0;
int main(int argc, char *argp[])
char shortoptions[] = "i:w:h:t:x:";
int mode = O_RDWR,c,ret = 0,index;
int preview_fd, resizer_fd = 0, dev_idx;
unsigned long oper_mode, user_mode, driver_mode;
struct prev_channel_config prev_chan_config;
struct prev_single_shot_config prev_ss_config; // single shot mode configuration
struct rsz_channel_config rsz_chan_config; // resizer channel config
struct rsz_single_shot_config rsz_ss_config; // single shot mode configuration
struct prev_cap cap;
struct prev_module_param mod_param;
struct prev_wb wb_params;
struct imp_reqbufs req_buf;
struct imp_buffer buf_in[3];
struct imp_buffer buf_out1[3];
struct imp_buffer buf_out2[3];
struct imp_convert convert;
int i,j;
char in_file[100] = "";
FILE *inp_f = NULL, *outp1_f = NULL, *outp2_f = NULL;
int width = INPUT_WIDTH, height = INPUT_HEIGHT, size;
int out_format=0;
unsigned long level;
short byte=0;
char out420_buf[BUF_SIZE];
char *src, *dest;
int second_output = 0;
int output1_size, output2_size;
for(;;) {
c = getopt_long(argc, argp, shortoptions, NULL, (void *)&index);
if(-1 == c)
break;
switch(c) {
case 'i':
strcpy(in_file,optarg);
break;
case 'w':
width = atoi(optarg);
break;
case 'h':
height = atoi(optarg);
break;
case 'x':
second_output = atoi(optarg);
break;
case 't':
out_format = atoi(optarg);
break;
default:
usage();
exit(1);
if (!strcmp(in_file, "")) {
printf("Use -i option to provide an 1280x720 UYVY input file\n"
"An example input is located with the sources: "
"video_720p\n");
usage();
exit(1);
printf("doing resize on in_file = %s and writing out to out_file1 = %s out_file2 = %s\n",
in_file,OUTPUT1_FILE, OUTPUT2_FILE);
oper_mode = IMP_MODE_SINGLE_SHOT;
printf("starting\n");
inp_f = fopen(in_file, "rb");
if (inp_f == NULL) {
perror("Error in opening input file \n");
ret = -1;
goto out;
outp1_f = fopen(OUTPUT1_FILE, "wb");
if (outp1_f == NULL) {
perror("Error in opening output file \n");
ret = -1;
goto out;
if (second_output) {
outp2_f = fopen(OUTPUT2_FILE, "wb");
if (outp2_f == NULL) {
ret = -1;
goto out;
size = fread(in_buf,1, (INPUT_WIDTH * INPUT_HEIGHT * BYTESPERLINE), inp_f);
output1_size = width * height * 2;
output2_size = 640 * 480 * 2;
if (out_format) {
output1_size = width * height * 1.5;
output2_size = 640 * 480 * 1.5;
if (size != (INPUT_WIDTH * INPUT_HEIGHT * BYTESPERLINE)) {
perror("mismatch between file size and INPUT_WIDTH * INPUT_HEIGHT * 2\n");
ret = -1;
goto out;
/* Open the resizer */
printf("Configuring resizer in the chain mode\n");
printf("Opening resizer device, %s\n",dev_name_rsz[0]);
resizer_fd = open((const char *)dev_name_rsz[0], mode);
if(resizer_fd <= 0) {
printf("Cannot open resizer device\n");
ret = -1;
goto out;
if (ioctl(resizer_fd,RSZ_S_OPER_MODE, &oper_mode) < 0) {
perror("Can't set operation mode\n");
ret = -1;
goto out;
if (ioctl(resizer_fd,RSZ_G_OPER_MODE, &oper_mode) < 0) {
perror("Can't get operation mode\n");
ret = -1;
goto out;
printf("RESIZER: Operating mode changed successfully to");
if (oper_mode == IMP_MODE_SINGLE_SHOT)
printf(" %s", "Single Shot\n");
else
printf(" %s", "Continuous\n");
printf("Setting default configuration in Resizer\n");
bzero(&rsz_ss_config, sizeof(struct rsz_single_shot_config));
rsz_chan_config.oper_mode = IMP_MODE_SINGLE_SHOT;
rsz_chan_config.chain = 0;
rsz_chan_config.len = 0;
rsz_chan_config.config = NULL; /* to set defaults in driver */
if (ioctl(resizer_fd, RSZ_S_CONFIG, &rsz_chan_config) < 0) {
perror("Error in setting default configuration for single shot mode\n");
ret = -1;
goto out;
printf("default configuration setting in Resizer successfull\n");
rsz_chan_config.len = sizeof(struct rsz_single_shot_config);
rsz_chan_config.config = &rsz_ss_config;
if (ioctl(resizer_fd, RSZ_G_CONFIG, &rsz_chan_config) < 0) {
perror("Error in getting resizer channel configuration from driver\n");
ret = -1;
goto out;
// in the chain mode only output configurations are valid
// input params are set at the previewer
rsz_ss_config.input.image_width = INPUT_WIDTH;
rsz_ss_config.input.image_height = INPUT_HEIGHT;
rsz_ss_config.input.ppln = rsz_ss_config.input.image_width + 8;
rsz_ss_config.input.lpfr = rsz_ss_config.input.image_height + 10;
rsz_ss_config.input.pix_fmt = IPIPE_UYVY;
if (out_format)
rsz_ss_config.output1.pix_fmt = IPIPE_YUV420SP;
else
rsz_ss_config.output1.pix_fmt = IPIPE_UYVY;
rsz_ss_config.output1.enable = 1;
rsz_ss_config.output1.width = width;
rsz_ss_config.output1.height = height;
rsz_ss_config.output2.enable = 0;
rsz_ss_config.output2.enable = 1;
rsz_ss_config.output2.width = 640;
rsz_ss_config.output2.height = 480;
if (out_format)
rsz_ss_config.output2.pix_fmt = IPIPE_YUV420SP;
else
rsz_ss_config.output2.pix_fmt = IPIPE_UYVY;
ret = -1;
goto out;
// read again and verify
perror("Error in getting configuration from driver\n");
ret = -1;
goto out;
if (allocate_user_buffers(size, output1_size, output2_size) < 0) {
perror("Error in allocating user buffers\n");
ret = -1;
goto out;
bzero(&convert,sizeof(convert));
bzero(output1_buffer.user_addr, output1_size);
memcpy(input_buffer.user_addr, in_buf, size);
convert.in_buff.buf_type = IMP_BUF_IN;
convert.in_buff.index = -1;
convert.in_buff.offset = (unsigned int)input_buffer.user_addr;
convert.in_buff.size = size;
convert.out_buff1.buf_type = IMP_BUF_OUT1;
convert.out_buff1.index = -1;
convert.out_buff1.offset = (unsigned int)output1_buffer.user_addr;
convert.out_buff1.size = output1_size;
bzero(output2_buffer.user_addr, output2_size);
convert.out_buff2.buf_type = IMP_BUF_OUT2;
convert.out_buff2.index = -1;
convert.out_buff2.offset = (unsigned int)output2_buffer.user_addr;
convert.out_buff2.size = output2_size;
if (ioctl(resizer_fd, RSZ_RESIZE, &convert) < 0) {
perror("Error in doing preview\n");
ret = -1;
goto out;
if (out_format)
else
printf("size = %d\n", size);
if (fwrite(output1_buffer.user_addr,1,size,outp1_f) != (
size)) {
perror("Error in doing resize\n");
ret = -1;
goto out;
if (fwrite(output2_buffer.user_addr, 1, output2_size, outp2_f) != output2_size)
perror("Error in writing to file\n");
out:
if (resizer_fd) {
if (!close(resizer_fd))
printf("resizer closed successfully\n");
else
printf("Error in closing resizer\n");
if (inp_f)
fclose(inp_f);
if (outp1_f)
fclose(outp1_f);
if (outp2_f)
fclose(outp2_f);
return ret;
