下面是dm6446 超级终端打打印的信息
root@192:/opt/workshop# ./loadmodules.sh
cmemk: module license '(c) Texas Instruments' taints kernel.
cmem initialized 3 pools between 0x87800000 and 0x88000000
dsplinkk: no version for "struct_module" found: kernel tainted.
DDR_START 0x8fa00000 DDR_SIZE 0x400000
root@192:/opt/workshop# CE_DEBUG=1 ./app_debug.x470MV
Debug: Creating audio thread
Debug: thread priority = 99
Debug: Initializing mixer device: /dev/mixer
Debug: Line input enabled to mixer (record mask: 0x40)
Debug: Initializing input sound device: /dev/dsp
Debug: Sound device opened with file descriptor: 4
Debug: Format set to AFMT_S16_LE (0x10)
Debug: Number of channels set to 2
Debug: Sample rate set to 44100 Hz.
Debug: Allocated input audio buffer of size 3072 to address 0x41148000
Debug: Initializing output sound device: /dev/dsp
Debug: Sound device opened with file descriptor: 5
Debug: Allocated output audio buffer of size 3072 to address 0x41149000
Debug: The following engines were located:lss
Unable to handle kernel paging request at virtual address 022c0302
pgd = cf2f0000
[022c0302] *pgd=00000000
Internal error: Oops: 1 [#1]
Modules linked in: dsplinkk cmemk
CPU: 0
PC is at sys_poll+0x204/0x3c8
LR is at sys_poll+0x1e8/0x3c8
pc : [<c0093504>] lr : [<c00934e8>] Tainted: PF
sp : cf2eff48 ip : cf2eff48 fp : cf2effa4
r10: 00000000 r9 : cff5ee68 r8 : 00000001
r7 : cf2ee000 r6 : cfa0caa0 r5 : cff5ee60 r4 : 00000145
r3 : 022c02e6 r2 : 00000000 r1 : cf2ee000 r0 : cfa0caa0
Flags: nzCv IRQs on FIQs on Mode SVC_32 Segment user
Control: 5317F Table: 8F2F0000 DAC: 00000015
Process mvltd (pid: 989, stack limit = 0xcf2ee1a0)
Stack: (0xcf2eff48 to 0xcf2f0000)
ff40: c003b2b0 cff5ee68 00000001 cff5ee60 fffffff4 befffb10
ff60: 00000000 00000000 c00929c4 cf307000 00000000 00900072 cf2effa4 00000bb8
ff80: 00000001 befffb10 000000a8 c002b154 cf2ee000 009000a8 00000000 cf2effa8
ffa0: c002a9c0 c0093310 00000bb8 00000001 befffb10 00000001 00000bb8 00000000
ffc0: 00000bb8 00000001 befffb10 00000000 000152e8 401625c4 0001510c befffb4c
ffe0: 00000000 befffae8 40111e20 400fd548 60000010 befffb10 00000000 00000000
Backtrace:
[<c0093300>] (sys_poll+0x0/0x3c8) from [<c002a9c0>] (ret_fast_syscall+0x0/0x2c)
Code: e5963010 e3530000 e59f41c0 0a000005 (e593301c)
prev->state: 2 != TASK_RUNNING??
mvltd/989: BUG in __schedule at kernel/sched.c:2902
Unable to handle kernel paging request at virtual address 27f1c8e6
pgd = c0004000
[27f1c8e6] *pgd=00000000
Internal error: Oops: 801 [#2]
CPU: 0
PC is at free_block+0x5c/0x124
LR is at drain_array_locked+0x88/0xa8
pc : [<c006662c>] lr : [<c006677c>] Tainted: PF
sp : cfc45ed0 ip : cfc45ef8 fp : cfc45ef4
r10: c02c1c00 r9 : c02c1c10 r8 : cfc036d0
r7 : 00000000 r6 : 00000004 r5 : cfc05340 r4 : cfa10000
r3 : f609fbe7 r2 : 27f1c8e6 r1 : cfa10560 r0 : cfc05340
Flags: Nzcv IRQs off FIQs on Mode SVC_32 Segment kernel
Control: 5317F Table: 8EC04000 DAC: 00000017
Process events/0 (pid: 4, stack limit = 0xcfc441a0)
Stack: (0xcfc45ed0 to 0xcfc46000)
5ec0: c02b9dd0 00000004 cfc036c0 00000006
5ee0: cfc036d0 cfc05340 cfc45f1c cfc45ef8 c006677c c00665e0 00000000 00000000
5f00: cfc05340 cfc44000 cfc053b0 00000001 cfc45f54 cfc45f20 c0067564 c0066704
5f20: cfe8bc00 cfc0ff28 cfc45f54 c02c1c20 c02c1c1c cfc44000 00000000 cfc0ff20
5f40: 00000000 cfc0ff28 cfc45fc4 cfc45f58 c0050e48 c00674c8 cfc29f2c c00674b8
5f60: ffffffff ffffffff 00000001 00000000 c003b2b0 00010000 00000000 cfc44000
5f80: 00000000 cfc11540 c003b2b0 00100100 00200200 00000000 cfc45fc4 cfc0ff20
5fa0: cfc44000 cfc29f20 c0050c44 fffffffc 00000000 00000000 cfc45ff4 cfc45fc8
5fc0: c00563e4 c0050c54 ffffffff ffffffff 00000000 00000000 00000000 00000000
5fe0: 00000000 00000000 00000000 cfc45ff8 c0041808 c0056314 10000000 00002004
Backtrace:
[<c00665d0>] (free_block+0x0/0x124) from [<c006677c>] (drain_array_locked+0x88/0xa8)
r8 = CFC05340 r7 = CFC036D0 r6 = 00000006 r5 = CFC036C0
r4 = 00000004
[<c00666f4>] (drain_array_locked+0x0/0xa8) from [<c0067564>] (cache_reap+0xac/0x248)
r8 = 00000001 r7 = CFC053B0 r6 = CFC44000 r5 = CFC05340
r4 = 00000000
[<c00674b8>] (cache_reap+0x0/0x248) from [<c0050e48>] (worker_thread+0x204/0x2c0)
[<c0050c44>] (worker_thread+0x0/0x2c0) from [<c00563e4>] (kthread+0xe0/0x114)
[<c0056304>] (kthread+0x0/0x114) from [<c0041808>] (do_exit+0x0/0xda0)
r8 = 00000000 r7 = 00000000 r6 = 00000000 r5 = 00000000
r4 = 00000000
Code: e28224ff e592401c e5942004 e5943000 (e5823000)
<6>note: events/0[4] exited with preempt_count 1
BUG: scheduling while atomic: events/0/0x00000001/4
caller is do_exit+0xd3c/0xda0
Debug: Creating video thread
Debug: priority = 0
Debug: OSD device /dev/fb/0 opened with file descriptor 8
Debug: Attribute device /dev/fb/2 opened with file descriptor 9
Debug: Mapped osd window to location 0x419bb000, size 691200 (0xa8c00)
Debug: Filled OSD window with pattern: 0x0
Debug: Mapped attribute window to location 0x41a64000, size 184320 (0x2d000)
Debug: Filled attribute window with pattern: 0
Debug: Opened file osd.r16 with FILE pointer 0x2b2c0
Error: Failed to open engine encodedecode with error code:
Error: Engine_EDSPLOAD: can't load the DSP
Error: engine_setup failed in audio_thread_fxn
Debug: Exited audio_thread_fxn processing loop
Debug: Starting audio thread cleanup to return resources to system
Debug: Closed audio output device (file descriptor 5)
Debug: Freed audio output buffer at location 0x41149000
Debug: Closed audio input device (file descriptor 4)
Debug: Freed audio input buffer at location 0x41148000
Debug: Audio thread cleanup complete. Exiting audio_thread_fxn
Debug: OSD Picture read successful, placing picture
Debug: Initializing display device: /dev/fb/3
Debug: Display device opened with file descriptor: 4
Debug: Mapped display buffer 0, size 691200 to location 0x41a91000
Debug: Mapped display buffer 1, size 691200 to location 0x41b39c00
Debug: Display set to 720x480 resolution
Debug: Zoom factor set to 1x
Debug: Initializing video capture device: /dev/video0
Debug: Video capture device opened with file descriptor: 5
Debug: Capturing 720x480 video
Debug: 3 capture buffers were successfully allocated.
Debug: Capture buffer 0, size 884736 mapped to address 0x41be3000
Debug: Capture buffer 1, size 884736 mapped to address 0x41cbb000
Debug: Capture buffer 2, size 8AUDDEC_process> Local end (0x%x)
AUDDEC_process> Exit (handle=0x%x, retVal=0x%x)All application threads started
Press Ctrl-C to exit
Debug: audio thread exited with FAILURE status
Error: engine_setup failed in video_thread_fxn
Debug: Exited video_thread_fxn processing loop
Debug: Starting video thread cleanup
Debug: Closing FILE ptr 0x2b2c0
Debug: Entering osd window cleanup
Debug: Closed osd window (file descriptor: 8)
Debug: Unmapped osd window memory (0x419bb000)
Debug: Entering attribute window cleanup
Debug: Closed attribute window (file descriptor: 9)
Debug: Unmapped attribute window memory (0x41a64000)
Debug: Halted video capture stream on file descriptor 5
Debug: unmapped video capture frame, size 884736 located at 0x41be3000
Debug: unmapped video capture frame, size 884736 located at 0x41cbb000
Debug: unmapped video capture frame, size 884736 located at 0x41d93000
Debug: Closed video capture device (file descriptor 5)
Debug: unmapped contiguous display buffer block of
Debug: size 1382400 at location 0x41a91000
Debug: Closed video display device (file descriptor 4)
Debug: Video thread cleanup complete. Exiting video_thread_fxn
Debug: video thread exited with FAILURE status
还有一种情况
root@192:/opt/workshop# ./app_debug.x470MV
Debug: priority = 0
Debug: Opened file osd.r16 with FILE pointer 0x2b2d0
Debug: Display device opened with file descriptor: 10
Debug: Video capture device opened with file descriptor: 11
Debug: Capture buffer 2, size 884736 mapped to address 0x41d93000
Unable to handle kernel paging request at virtual address 300a4120
pgd = c0004000
[300a4120] *pgd=00000000
Internal error: Oops: 805 [#1]
CPU: 0
r7 : 00000000 r6 : 00000001 r5 : cfc05340 r4 : cfa0f000
r3 : cff13020 r2 : 300a4120 r1 : cfa0f040 r0 : cfc05340
Control: 5317F Table: 8FFE4000 DAC: 00000017
5ec0: ceca3000 00000001 cfc036c0 00000001
5fe0: 00000000 00000000 00000000 cfc45ff8 c0041808 c0056314 00000000 00000004
Backtrace:
r8 = CFC05340 r7 = CFC036D0 r6 = 00000001 r5 = CFC036C0
r4 = 00000001
r4 = 00000000
r4 = 00000000
Alignment trap: init (1) PC=0x40033660 Instr=0xe7801002 Address=0xad334567 FSR 0x801
初步确定是ce模块出问题,但不知道问题处在哪
