对k1开发包的多核导航器例程进行了debug,出现错误,仿真器连不上,而其他例程则可以顺利debug。
提示信息:
C66x_2: Error connecting to the target :connect to PRSC failed.
C66x_1: Encountered Illegal Op-code.
C66x_0: Power Failure on Target CPU.
C66x_0: Failed to remove the debug state from the target before disconnecting. It is recommanded that you reset the emulator before you connect and reload your program before you conting debugging.
期间试着重新连接仿真器也不管用。
