emmc在linux系统中识别
Other Parts Discussed in Thread: AM3352
芯片用的是AM3352,在uboot中可以识别板载emmc,但是进入内核后无法识别,打印信息如下
[    2.145859] clock: disabling unused clocks to save power
[    2.157817] Detected MACID=ec:11:27:cf:69:89
[    2.164518] cpsw: Detected MACID = ec:11:27:cf:69:8b
[    2.177536] input: gpio-keys as /devices/platform/gpio-keys/input/input1
[    2.186170] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    2.193573] Waiting for root device /dev/mmcblk0p2...
[    2.249808] mmc0: host does not support reading read-only switch. assuming write-enable.
[    2.264256] mmc0: new high speed SDHC card at address aaaa
[    2.271335] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[    2.282765]  mmcblk0: p1 p2
[    2.365717] kjournald starting.  Commit interval 5 seconds
[    2.375739] EXT3-fs (mmcblk0p2): using internal journal
[    2.381299] EXT3-fs (mmcblk0p2): recovery complete
[    2.390321] EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
[    2.397762] VFS: Mounted root (ext3 filesystem) on device 179:2.
[    2.408939] devtmpfs: mounted
[    2.413376] Freeing init memory: 388K
只能识别用于启动的SD卡,无法识别emmc
