各位大神你们好 :
最近在做gpmc驱动时 遇到在dts里配置gpmc设置.
* Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
/dts-v1/;
#include "am33xx.dtsi"
#include <dt-bindings/interrupt-controller/irq.h>
model = "MYIR MYD C335x";
compatible = "ti,myd_c335x", "ti,am33xx";
cpus {
cpu@0 {
cpu0-supply = <&vdd_core>;
memory {
device_type = "memory";
reg = <0x80000000 0x20000000>; /* 512 MB */
vbat: fixedregulator@0 {
compatible = "regulator-fixed";
regulator-name = "vbat";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-boot-on;
regulator-always-on;
vdd_3v3: fixedregulator@1{
regulator-name = "vdd_3v3";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&vbat>;
regulator-boot-on;
vdd_1v8: fixedregulator@2{
regulator-name = "vdd_1v8";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vin-supply = <&vdd_3v3>;
regulator-boot-on;
vdd_core: fixedregulator@4{
regulator-name = "vdd_core";
regulator-boot-on;
vdd_mpu: fixedregulator@5{
regulator-name = "vdd_mpu";
regulator-boot-on;
vdd_adc: fixedregulator@6{
regulator-name = "vdd_adc";
vin-supply = <&vdd_1v8>;
regulator-boot-on;
vdd_rtc: fixedregulator@7{
regulator-name = "vdd_rtc";
regulator-boot-on;
gpio_keys: volume_keys@0 {
compatible = "gpio-keys";
#address-cells = <1>;
#size-cells = <0>;
autorepeat;
switch@9 {
label = "volume-up";
linux,code = <115>;
gpios = <&gpio3 0 GPIO_ACTIVE_LOW>;
gpio-key,wakeup;
switch@10 {
label = "volume-down";
linux,code = <114>;
gpios = <&gpio0 29 GPIO_ACTIVE_LOW>;
gpio-key,wakeup;
gpio-leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&leds_pins>;
D3 {
label = "myc:green:user1";
gpios = <&gpio3 18 GPIO_ACTIVE_LOW>;
linux,default-trigger = "cpu0";
default-state = "off";
D39 {
label = "myd:green:user2";
gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
D40 {
label = "myd:green:user3";
gpios = <&gpio0 27 GPIO_ACTIVE_LOW>;
backlight {
compatible = "pwm-backlight";
pwms = <&ehrpwm0 0 50000 0>;
brightness-levels = <0 51 53 56 62 75 101 152 255>;
default-brightness-level = <8>;
panel {
compatible = "ti,tilcdc,panel";
status = "okay";
panel-info {
ac-bias = <255>;
ac-bias-intrpt = <0>;
dma-burst-sz = <16>;
bpp = <16>;
fdd = <0x80>;
sync-edge = <0>;
sync-ctrl = <1>;
raster-order = <0>;
fifo-th = <0>;
display-timings {
800x480p62 {
clock-frequency = <30000000>;
hactive = <800>;
vactive = <480>;
hfront-porch = <39>;
hback-porch = <39>;
hsync-len = <47>;
vback-porch = <29>;
vfront-porch = <13>;
vsync-len = <2>;
hsync-active = <1>;
vsync-active = <1>;
sound {
compatible = "ti,sgtl5000-myd-audio";
ti,model = "AM335x-MYD";
ti,audio-codec = <&sgtl5000>;
ti,mcasp-controller = <&mcasp0>;
ti,codec-clock-rate = <12000000>;
ti,audio-routing =
"MIC_IN", "Mic Jack",
"Mic Jack", "Mic Bias",
"Headphone Jack", "HP_OUT";
&am33xx_pinmux {
pinctrl-0 = <&volume_keys_s0>;
volume_keys_s0: volume_keys_s0 {
pinctrl-single,pins = <
0x108 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* (H16) gmii1_col.gpio3[0] */
0x144 (PIN_INPUT | MUX_MODE7 ) /* (H18) rmii1_refclk.gpio0[29] */
leds_pins: pinmux_leds_pins {
0x154 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* spio_d0.gpio0_03 */
0x2C (PIN_OUTPUT_PULLDOWN | MUX_MODE7)
0x1A0 (PIN_OUTPUT_PULLDOWN | MUX_MODE7)
i2c0_pins: pinmux_i2c0_pins {
0x188 (PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_sda.i2c0_sda */
0x18c (PIN_INPUT_PULLUP | MUX_MODE0) /* i2c0_scl.i2c0_scl */
i2c1_pins_default: pinmux_i2c1_pins {
0x158 (PIN_INPUT_PULLUP | MUX_MODE2) /* spi0_d1.i2c1_sda */
0x15c (PIN_INPUT_PULLUP | MUX_MODE2) /* spi0_cs0.i2c1_scl */
i2c1_pins_sleep: i2c1_pins_sleep {
0x158 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* spi0_d1.i2c1_sda */
0x15c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* spi0_cs0.i2c1_scl */
uart0_pins: pinmux_uart0_pins {
0x170 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart0_rxd.uart0_rxd */
0x174 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart0_txd.uart0_txd */
uart1_pins_default: pinmux_uart1_pins_default {
0x180 (PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rxd.uart1_rxd */
0x184 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* uart1_txd.uart1_txd */
uart1_pins_sleep: pinmux_uart1_pins_sleep {
0x180 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x184 (PIN_INPUT_PULLDOWN | MUX_MODE7)
uart2_pins_default: pinmux_uart2_pins_default {
0x10c ( PIN_INPUT | MUX_MODE6 ) /* (H17) gmii1_crs.uart2_rxd */
0x110 ( PIN_OUTPUT | MUX_MODE6 ) /* (J15) gmii1_rxer.uart2_txd */
uart2_pins_sleep: pinmux_uart2_pins_sleep {
0x10C (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x110 (PIN_INPUT_PULLDOWN | MUX_MODE7)
nandflash_pins_default: nandflash_pins_default {
0x0 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */
0x4 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */
0x8 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */
0xc (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */
0x10 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */
0x14 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */
0x18 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */
0x1c (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */
0x70 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */
0x74 (PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpio0_30 */
0x7c (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */
0x90 (PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */
0x94 (PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */
0x98 (PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */
0x9c (PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */
nandflash_pins_sleep: nandflash_pins_sleep {
0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0xc (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x70 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x7c (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x90 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x9c (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x6c ( PIN_OUTPUT | MUX_MODE0 ) /* (V17) gpmc_a11.gpmc_a11 */
0x68 ( PIN_OUTPUT | MUX_MODE0 ) /* (T16) gpmc_a10.gpmc_a10 */
0x64 ( PIN_OUTPUT | MUX_MODE0 ) /* (U16) gpmc_a9.gpmc_a9 */
0x60 ( PIN_OUTPUT | MUX_MODE0 ) /* (V16) gpmc_a8.gpmc_a8 */
0x5c ( PIN_OUTPUT | MUX_MODE0 ) /* (T15) gpmc_a7.gpmc_a7 */
0x58 ( PIN_OUTPUT | MUX_MODE0 ) /* (U15) gpmc_a6.gpmc_a6 */
0x54 ( PIN_OUTPUT | MUX_MODE0 ) /* (V15) gpmc_a5.gpmc_a5 */
0x50 ( PIN_OUTPUT | MUX_MODE0 ) /* (R14) gpmc_a4.gpmc_a4 */
0x4c ( PIN_OUTPUT | MUX_MODE0 ) /* (T14) gpmc_a3.gpmc_a3 */
0x48 ( PIN_OUTPUT | MUX_MODE0 ) /* (U14) gpmc_a2.gpmc_a2 */
0x44 ( PIN_OUTPUT | MUX_MODE0 ) /* (V14) gpmc_a1.gpmc_a1 */
0x40 ( PIN_OUTPUT | MUX_MODE0 ) /* (R13) gpmc_a0.gpmc_a0 */
0x3c ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (U13) gpmc_ad15.gpmc_ad15 */
0x38 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (V13) gpmc_ad14.gpmc_ad14 */
0x34 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (R12) gpmc_ad13.gpmc_ad13 */
0x30 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (T12) gpmc_ad12.gpmc_ad12 */
0x2c ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (U12) gpmc_ad11.gpmc_ad11 */
0x28 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (T11) gpmc_ad10.gpmc_ad10 */
0x24 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (T10) gpmc_ad9.gpmc_ad9 */
0x20 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (U10) gpmc_ad8.gpmc_ad8 */
0x1c ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (T9) gpmc_ad7.gpmc_ad7 */
0x18 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (R9) gpmc_ad6.gpmc_ad6 */
0x14 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (V8) gpmc_ad5.gpmc_ad5 */
0x10 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (U8) gpmc_ad4.gpmc_ad4 */
0xc ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (T8) gpmc_ad3.gpmc_ad3 */
0x8 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (R8) gpmc_ad2.gpmc_ad2 */
0x4 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (V7) gpmc_ad1.gpmc_ad1 */
0x0 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (U7) gpmc_ad0.gpmc_ad0 */
0x70 ( PIN_INPUT_PULLUP | MUX_MODE0 ) /* (T17) gpmc_wait0.gpmc_wait0 */
0x74 ( PIN_INPUT_PULLUP | MUX_MODE7 ) /* (U17) gpmc_wpn.gpmc_wpn */
0x7c ( PIN_OUTPUT | MUX_MODE0 ) /* gpmc_csn0.gpmc_csn0 */
0x80 ( PIN_OUTPUT | MUX_MODE0 ) /* (U9) gpmc_csn1.gpmc_csn1 */
0x84 ( PIN_OUTPUT | MUX_MODE0 ) /* (V9) gpmc_csn2.gpmc_csn2 */
0x88 ( PIN_OUTPUT | MUX_MODE0 ) /* (T13) gpmc_csn3.gpmc_csn3 */
0x8c ( PIN_OUTPUT | MUX_MODE0 ) /* (V12) gpmc_clk.gpmc_clk */
0x90 ( PIN_OUTPUT | MUX_MODE0 ) /* (R7) gpmc_advn_ale.gpmc_advn_ale */
0x94 ( PIN_OUTPUT | MUX_MODE0 ) /* (T7) gpmc_oen_ren.gpmc_oen_ren */
0x98 ( PIN_OUTPUT | MUX_MODE0 ) /* (U6) gpmc_wen.gpmc_wen */
0x9c ( PIN_OUTPUT | MUX_MODE0 ) /* (T6) gpmc_be0n_cle.gpmc_be0n_cle */
0x6c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V17) gpmc_a11.gpmc_a11 */
0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T16) gpmc_a10.gpmc_a10 */
0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U16) gpmc_a9.gpmc_a9 */
0x60 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V16) gpmc_a8.gpmc_a8 */
0x5c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T15) gpmc_a7.gpmc_a7 */
0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U15) gpmc_a6.gpmc_a6 */
0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V15) gpmc_a5.gpmc_a5 */
0x50 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (R14) gpmc_a4.gpmc_a4 */
0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T14) gpmc_a3.gpmc_a3 */
0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U14) gpmc_a2.gpmc_a2 */
0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V14) gpmc_a1.gpmc_a1 */
0x40 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (R13) gpmc_a0.gpmc_a0 */
0x3c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U13) gpmc_ad15.gpmc_ad15 */
0x38 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V13) gpmc_ad14.gpmc_ad14 */
0x34 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (R12) gpmc_ad13.gpmc_ad13 */
0x30 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T12) gpmc_ad12.gpmc_ad12 */
0x2c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U12) gpmc_ad11.gpmc_ad11 */
0x28 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T11) gpmc_ad10.gpmc_ad10 */
0x24 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T10) gpmc_ad9.gpmc_ad9 */
0x20 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U10) gpmc_ad8.gpmc_ad8 */
0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T9) gpmc_ad7.gpmc_ad7 */
0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (R9) gpmc_ad6.gpmc_ad6 */
0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V8) gpmc_ad5.gpmc_ad5 */
0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U8) gpmc_ad4.gpmc_ad4 */
0xc (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T8) gpmc_ad3.gpmc_ad3 */
0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (R8) gpmc_ad2.gpmc_ad2 */
0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V7) gpmc_ad1.gpmc_ad1 */
0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U7) gpmc_ad0.gpmc_ad0 */
0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7 )
0x70 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T17) gpmc_wait0.gpmc_wait0 */
0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U17) gpmc_wpn.gpmc_wpn */
0x80 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U9) gpmc_csn1.gpmc_csn1 */
0x84 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V9) gpmc_csn2.gpmc_csn2 */
0x88 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T13) gpmc_csn3.gpmc_csn3 */
0x8c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (V12) gpmc_clk.gpmc_clk */
0x90 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (R7) gpmc_advn_ale.gpmc_advn_ale */
0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T7) gpmc_oen_ren.gpmc_oen_ren */
0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (U6) gpmc_wen.gpmc_wen */
0x9c (PIN_INPUT_PULLDOWN | MUX_MODE7 ) /* (T6) gpmc_be0n_cle.gpmc_be0n_cle */
ehrpwm0_pins_default: backlight_pins {
0x150 0x3 /* (A17) spi0_sclk.ehrpwm0A */
ehrpwm0_pins_sleep: ehrpwm0_pins_sleep {
0x150 (PIN_INPUT_PULLDOWN | MUX_MODE3) /* (A17) spi0_sclk.ehrpwm0A */
cpsw_default: cpsw_default {
/* Slave 1 */
0x114 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txen.rgmii1_tctl */
0x118 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxdv.rgmii1_rctl */
0x11c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd3.rgmii1_td3 */
0x120 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd2.rgmii1_td2 */
0x124 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd1.rgmii1_td1 */
0x128 (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txd0.rgmii1_td0 */
0x12c (PIN_OUTPUT_PULLDOWN | MUX_MODE2) /* mii1_txclk.rgmii1_tclk */
0x130 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxclk.rgmii1_rclk */
0x134 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd3.rgmii1_rd3 */
0x138 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd2.rgmii1_rd2 */
0x13c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd1.rgmii1_rd1 */
0x140 (PIN_INPUT_PULLDOWN | MUX_MODE2) /* mii1_rxd0.rgmii1_rd0 */
/* Slave 2 */
0x40 (MUX_MODE2 | PIN_OUTPUT_PULLDOWN) /* gpmc_a0.rgmii2_tctl */
0x44 (MUX_MODE2 | PIN_INPUT_PULLDOWN) /* gpmc_a1.rgmii2_rctl */
0x48 (MUX_MODE2 | PIN_OUTPUT_PULLDOWN) /* gpmc_a2.rgmii2_td3 */
0x4c (MUX_MODE2 | PIN_OUTPUT_PULLDOWN) /* gpmc_a3.rgmii2_td2 */
0x50 (MUX_MODE2 | PIN_OUTPUT_PULLDOWN) /* gpmc_a4.rgmii2_td1 */
0x54 (MUX_MODE2 | PIN_OUTPUT_PULLDOWN) /* gpmc_a5.rgmii2_td0 */
0x58 (MUX_MODE2 | PIN_OUTPUT_PULLDOWN) /* gpmc_a6.rgmii2_tclk */
0x5c (MUX_MODE2 | PIN_INPUT_PULLDOWN) /* gpmc_a7.rgmii2_rclk */
0x60 (MUX_MODE2 | PIN_INPUT_PULLDOWN) /* gpmc_a8.rgmii2_rd3 */
0x64 (MUX_MODE2 | PIN_INPUT_PULLDOWN) /* gpmc_a9.rgmii2_rd2 */
0x68 (MUX_MODE2 | PIN_INPUT_PULLDOWN) /* gpmc_a10.rgmii2_rd1 */
0x6c (MUX_MODE2 | PIN_INPUT_PULLDOWN) /* gpmc_a11.rgmii2_rd0 */
cpsw_sleep: cpsw_sleep {
/* Slave 1 reset value */
0x114 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x118 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x11c (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x120 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x124 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x128 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x12c (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x130 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x134 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x138 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x13c (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x140 (PIN_INPUT_PULLDOWN | MUX_MODE7)
/* Slave 2 reset value */
0x40 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a0.rgmii2_tctl */
0x44 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a1.rgmii2_rctl */
0x48 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a2.rgmii2_td3 */
0x4c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a3.rgmii2_td2 */
0x50 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a4.rgmii2_td1 */
0x54 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a5.rgmii2_td0 */
0x58 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a6.rgmii2_tclk */
0x5c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a7.rgmii2_rclk */
0x60 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a8.rgmii2_rd3 */
0x64 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a9.rgmii2_rd2 */
0x68 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a10.rgmii2_rd1 */
0x6c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_a11.rgmii2_rd0 */
davinci_mdio_default: davinci_mdio_default {
/* MDIO */
0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */
0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */
davinci_mdio_sleep: davinci_mdio_sleep {
/* MDIO reset value */
0x148 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x14c (PIN_INPUT_PULLDOWN | MUX_MODE7)
mmc1_pins_default: pinmux_mmc1_pins {
0x0F0 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat3.mmc0_dat3 */
0x0F4 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat2.mmc0_dat2 */
0x0F8 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat1.mmc0_dat1 */
0x0FC (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_dat0.mmc0_dat0 */
0x100 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_clk.mmc0_clk */
0x104 (PIN_INPUT_PULLUP | MUX_MODE0) /* mmc0_cmd.mmc0_cmd */
0x1AC (PIN_INPUT_PULLUP | MUX_MODE7) /* mcasp0_ahclkx.gpio3_21 */
mmc1_pins_sleep: pinmux_mmc1_pins_sleep {
0x0F0 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0F4 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0F8 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x0FC (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x100 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x104 (PIN_INPUT_PULLDOWN | MUX_MODE7)
0x1AC (PIN_INPUT_PULLDOWN | MUX_MODE7)
/* wl12xx/wl18xx card on mmc3 */
mmc3_pins: pinmux_mmc3_pins {
0x30 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a12.mmc2_dat0, INPUT_PULLUP | MODE3 */
0x34 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a13.mmc2_dat1, INPUT_PULLUP | MODE3 */
0x38 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a14.mmc2_dat2, INPUT_PULLUP | MODE3 */
0x3c (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_a15.mmc2_dat3, INPUT_PULLUP | MODE3 */
0x88 (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_csn3.mmc2_cmd, INPUT_PULLUP | MODE3 */
0x8C (PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_clk.mmc2_clk, INPUT_PULLUP | MODE3 */
/* wl12xx/wl18xx card enable/irq GPIOs. */
wlan_pins: pinmux_wlan_pins {
0x20 (PIN_OUTPUT_PULLDOWN | MUX_MODE7) /* WLAN_EN gpmc_ad7.gpio0_22 */
0x24 (PIN_INPUT | MUX_MODE7) /* BT_EN gpmc_ad9.gpio0_23 */
lcd_pins_default: lcd_pins_default {
// 0x20 (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad8.lcd_data23 */
// 0x24 (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad9.lcd_data22 */
// 0x28 (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad10.lcd_data21 */
// 0x2c (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad11.lcd_data20 */
// 0x30 (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad12.lcd_data19 */
// 0x34 (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad13.lcd_data18 */
// 0x38 (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad14.lcd_data17 */
// 0x3c (PIN_OUTPUT | MUX_MODE1) /* gpmc_ad15.lcd_data16 */
0xa0 (PIN_OUTPUT | MUX_MODE0) /* lcd_data0.lcd_data0 */
0xa4 (PIN_OUTPUT | MUX_MODE0) /* lcd_data1.lcd_data1 */
0xa8 (PIN_OUTPUT | MUX_MODE0) /* lcd_data2.lcd_data2 */
0xac (PIN_OUTPUT | MUX_MODE0) /* lcd_data3.lcd_data3 */
0xb0 (PIN_OUTPUT | MUX_MODE0) /* lcd_data4.lcd_data4 */
0xb4 (PIN_OUTPUT | MUX_MODE0) /* lcd_data5.lcd_data5 */
0xb8 (PIN_OUTPUT | MUX_MODE0) /* lcd_data6.lcd_data6 */
0xbc (PIN_OUTPUT | MUX_MODE0) /* lcd_data7.lcd_data7 */
0xc0 (PIN_OUTPUT | MUX_MODE0) /* lcd_data8.lcd_data8 */
0xc4 (PIN_OUTPUT | MUX_MODE0) /* lcd_data9.lcd_data9 */
0xc8 (PIN_OUTPUT | MUX_MODE0) /* lcd_data10.lcd_data10 */
0xcc (PIN_OUTPUT | MUX_MODE0) /* lcd_data11.lcd_data11 */
0xd0 (PIN_OUTPUT | MUX_MODE0) /* lcd_data12.lcd_data12 */
0xd4 (PIN_OUTPUT | MUX_MODE0) /* lcd_data13.lcd_data13 */
0xd8 (PIN_OUTPUT | MUX_MODE0) /* lcd_data14.lcd_data14 */
0xdc (PIN_OUTPUT | MUX_MODE0) /* lcd_data15.lcd_data15 */
0xe0 (PIN_OUTPUT | MUX_MODE0) /* lcd_vsync.lcd_vsync */
0xe4 (PIN_OUTPUT | MUX_MODE0) /* lcd_hsync.lcd_hsync */
0xe8 (PIN_OUTPUT | MUX_MODE0) /* lcd_pclk.lcd_pclk */
0xec (PIN_OUTPUT | MUX_MODE0) /* lcd_ac_bias_en.lcd_ac_bias_en */
lcd_pins_sleep: lcd_pins_sleep {
// 0x20 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad8.lcd_data16 */
// 0x24 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad9.lcd_data17 */
// 0x28 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad10.lcd_data18 */
// 0x2c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad11.lcd_data19 */
// 0x30 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad12.lcd_data20 */
// 0x34 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad13.lcd_data21 */
// 0x38 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad14.lcd_data22 */
// 0x3c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* gpmc_ad15.lcd_data23 */
0xa0 (PULL_DISABLE | MUX_MODE7) /* lcd_data0.lcd_data0 */
0xa4 (PULL_DISABLE | MUX_MODE7) /* lcd_data1.lcd_data1 */
0xa8 (PULL_DISABLE | MUX_MODE7) /* lcd_data2.lcd_data2 */
0xac (PULL_DISABLE | MUX_MODE7) /* lcd_data3.lcd_data3 */
0xb0 (PULL_DISABLE | MUX_MODE7) /* lcd_data4.lcd_data4 */
0xb4 (PULL_DISABLE | MUX_MODE7) /* lcd_data5.lcd_data5 */
0xb8 (PULL_DISABLE | MUX_MODE7) /* lcd_data6.lcd_data6 */
0xbc (PULL_DISABLE | MUX_MODE7) /* lcd_data7.lcd_data7 */
0xc0 (PULL_DISABLE | MUX_MODE7) /* lcd_data8.lcd_data8 */
0xc4 (PULL_DISABLE | MUX_MODE7) /* lcd_data9.lcd_data9 */
0xc8 (PULL_DISABLE | MUX_MODE7) /* lcd_data10.lcd_data10 */
0xcc (PULL_DISABLE | MUX_MODE7) /* lcd_data11.lcd_data11 */
0xd0 (PULL_DISABLE | MUX_MODE7) /* lcd_data12.lcd_data12 */
0xd4 (PULL_DISABLE | MUX_MODE7) /* lcd_data13.lcd_data13 */
0xd8 (PULL_DISABLE | MUX_MODE7) /* lcd_data14.lcd_data14 */
0xdc (PULL_DISABLE | MUX_MODE7) /* lcd_data15.lcd_data15 */
0xe0 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_vsync.lcd_vsync, OUTPUT | MODE0 */
0xe4 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_hsync.lcd_hsync */
0xe8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_pclk.lcd_pclk */
0xec (PIN_INPUT_PULLDOWN | MUX_MODE7) /* lcd_ac_bias_en.lcd_ac_bias_en */
am335x_evm_audio_pins: am335x_evm_audio_pins {
0x190 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* A13 "mcasp0_aclkx.mcasp0_aclkx" */
0x194 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* B13 "mcasp0_fsx.mcasp0_fsx" */
0x19c (PIN_INPUT_PULLDOWN | MUX_MODE2) /* C12 "mcasp0_ahclkr.mcasp0_axr2" */
0x1a8 (PIN_INPUT_PULLDOWN | MUX_MODE0) /* D13 "mcasp0_axr1.mcasp0_axr1" */
am335x_evm_audio_pins_sleep: am335x_evm_audio_pins_sleep {
0x190 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* A13 "mcasp0_aclkx.mcasp0_aclkx" */
0x194 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* B13 "mcasp0_fsx.mcasp0_fsx" */
0x19c (PIN_INPUT_PULLDOWN | MUX_MODE7) /* C12 "mcasp0_ahclkr.mcasp0_axr2" */
0x1a8 (PIN_INPUT_PULLDOWN | MUX_MODE7) /* D13 "mcasp0_axr1.mcasp0_axr1" */
dcan0_pins_default: dcan0_pins_default {
0x178 (PIN_OUTPUT_PULLUP | MUX_MODE2) /* uart1_ctsn.d_can0_tx */
0x17c (PIN_INPUT_PULLUP | MUX_MODE2) /* uart1_rtsn.d_can0_rx */
dcan1_pins_default: dcan1_pins_default {
0x168 (PIN_OUTPUT_PULLUP | MUX_MODE2) /* uart0_ctsn.d_can1_tx */
0x16c (PIN_INPUT_PULLUP | MUX_MODE2) /* uart0_rtsn.d_can1_rx */
&uart0 {
pinctrl-0 = <&uart0_pins>;
status = "okay";
&uart1 {
pinctrl-names = "default", "sleep";
pinctrl-0 = <&uart1_pins_default>;
pinctrl-1 = <&uart1_pins_sleep>;
// rts-gpio = <&gpio3 2 GPIO_ACTIVE_HIGH>;
// rs485-rx-during-tx;
// rs485-rts-delay = <1 1>;
linux,rs485-enabled-at-boot-time;
status = "okay";
&uart2 {
pinctrl-0 = <&uart2_pins_default>;
pinctrl-1 = <&uart2_pins_sleep>;
status = "okay";
&i2c0 {
pinctrl-0 = <&i2c0_pins>;
status = "okay";
clock-frequency = <400000>;
tps: tps@2d {
reg = <0x24>;
&usb {
status = "okay";
&usb_ctrl_mod {
status = "okay";
&usb0_phy {
status = "okay";
&usb1_phy {
status = "okay";
&usb0 {
status = "okay";
&usb1 {
status = "okay";
dr_mode = "host";
&cppi41dma {
status = "okay";
&i2c1 {
pinctrl-0 = <&i2c1_pins_default>;
pinctrl-1 = <&i2c1_pins_sleep>;
status = "okay";
clock-frequency = <100000>;
sgtl5000: sgtl5000@0a {
compatible = "fsl,sgtl5000";
clocks=<&mcasp0_fck>;
reg =<0x0a>;
micbias-resistor-k-ohms = <4>;
micbias-voltage-m-volts = <2250>;
status = "okay";
/* Regulators */
VDDA-supply = <&vdd_3v3>;
VDDIO-supply = <&vdd_3v3>;
&lcdc {
status = "okay";
pinctrl-0 = <&lcd_pins_default>;
pinctrl-1 = <&lcd_pins_sleep>;
&elm {
status = "okay";
&epwmss0 {
status = "okay";
ehrpwm0: ehrpwm@48300200 {
status = "okay";
pinctrl-0 = <&ehrpwm0_pins_default>;
pinctrl-1 = <&ehrpwm0_pins_sleep>;
&gpmc {
status = "okay";
pinctrl-0 = <&nandflash_pins_default>;
pinctrl-1 = <&nandflash_pins_sleep>;
ranges = <0 0 0x08000000 0x1000000>, /* CSn0: 16MB for NAND */
<1 0 0x09000000 0x1000000>; /* CSn1: 16MB for fpga */
nand@0,0 {
compatible = "ti,omap2-nand";
reg = <0 0 4>; /* CS0, offset 0, IO size 4 每个寄存器地址偏移4个字节*/
interrupt-parent = <&intc>;
interrupts = <100>;
ready-gpio = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */
ti,nand-ecc-opt = "bch8";
ti,elm-id = <&elm>;
nand-bus-width = <8>;
gpmc,device-width = <1>;
gpmc,sync-clk-ps = <0>;
gpmc,cs-on-ns = <0>;
gpmc,cs-rd-off-ns = <44>;
gpmc,cs-wr-off-ns = <44>;
gpmc,adv-on-ns = <6>;
gpmc,adv-rd-off-ns = <34>;
gpmc,adv-wr-off-ns = <44>;
gpmc,we-on-ns = <0>;
gpmc,we-off-ns = <40>;
gpmc,oe-on-ns = <0>;
gpmc,oe-off-ns = <54>;
gpmc,access-ns = <64>;
gpmc,rd-cycle-ns = <82>;
gpmc,wr-cycle-ns = <82>;
gpmc,bus-turnaround-ns = <0>;
gpmc,cycle2cycle-delay-ns = <0>;
gpmc,clk-activation-ns = <0>;
gpmc,wr-access-ns = <40>;
gpmc,wr-data-mux-bus-ns = <0>;
/* MTD partition table */
/* All SPL-* partitions are sized to minimal length
* which can be independently programmable. For
* NAND flash this is equal to size of erase-block */
#size-cells = <1>;
partition@0 {
label = "NAND.SPL";
reg = <0x00000000 0x000020000>;
partition@1 {
label = "NAND.SPL.backup1";
reg = <0x00020000 0x00020000>;
partition@2 {
label = "NAND.SPL.backup2";
reg = <0x00040000 0x00020000>;
partition@3 {
label = "NAND.SPL.backup3";
reg = <0x00060000 0x00020000>;
partition@4 {
label = "NAND.u-boot-spl-os";
reg = <0x00080000 0x00040000>;
partition@5 {
label = "NAND.u-boot";
reg = <0x000C0000 0x00100000>;
partition@6 {
label = "NAND.u-boot-env";
reg = <0x001C0000 0x00020000>;
partition@7 {
label = "NAND.u-boot-env.backup1";
reg = <0x001E0000 0x00020000>;
partition@8 {
label = "NAND.kernel";
reg = <0x00200000 0x00800000>;
partition@9 {
label = "NAND.rootfs";
reg = <0x00A00000 0x07600000>;
partition@10 {
label = "NAND.userdata";
reg = <0x08000000 0x08000000>;
fpga@1,0 {
compatible = "fpga";
status = "okay";
reg = <1 0 0x1000000>; //第一个是片选 第二个是相对该片选的基地址 ,第三个是length容量
bank-width = <2>; /* GPMC_CONFIG1_DEVICESIZE(1) */
gpmc,sync-read; /* GPMC_CONFIG1_READTYPE_ASYNC */
gpmc,sync-write; /* GPMC_CONFIG1_WRITETYPE_ASYNC */
gpmc,clk-activation-ns = <0>; /* GPMC_CONFIG1_CLKACTIVATIONTIME(2) */
// gpmc,burst-length = <16>; /* GPMC_CONFIG1_PAGE_LEN(2) */
// gpmc,mux-add-data = <2>; /* GPMC_CONFIG1_MUXTYPE(2) */
gpmc,mux-add-data = <0>; /* GPMC_CONFIG1_MUXTYPE(2) */
gpmc,sync-clk-ps = <20000>; /* CONFIG2 */
gpmc,cs-rd-off-ns = <100>;
gpmc,cs-wr-off-ns = <40>;
gpmc,adv-on-ns = <0>; /* CONFIG3 */
gpmc,oe-on-ns = <20>;
gpmc,oe-off-ns = <100>;
gpmc,we-on-ns = <20>; /* CONFIG4 */
gpmc,access-ns = <80>;
gpmc,rd-cycle-ns = <120>;
gpmc,wr-cycle-ns = <60>;
gpmc,adv-rd-off-ns = <20>;
gpmc,adv-wr-off-ns = <20>;
gpmc,page-burst-access-ns = <20>; /* CONFIG 5 */
gpmc,wr-access-ns = <40>; /* CONFIG 6 */
gpmc,wr-data-mux-bus-ns = <20>;
/*gpmc,bus-turnaround-ns = <40>;*/ /* CONFIG6:3:0 = 4 */
//gpmc,cycle2cycle-samecsen; /* CONFIG6:7 = 1 */
//gpmc,cycle2cycle-delay-ns = <20>; /* CONFIG6:11:8 = 4 */
/* not using dma engine yet, but we can get the channel number here */
&mcasp0 {
pinctrl-0 = <&am335x_evm_audio_pins>;
pinctrl-1 = <&am335x_evm_audio_pins_sleep>;
status = "okay";
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializers */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
0 1 2 0
0 0 0 0
0 0 0 0
0 0 0 0
tx-num-evt = <1>;
rx-num-evt = <1>;
&mac {
slaves = <2>;
pinctrl-0 = <&cpsw_default>;
pinctrl-1 = <&cpsw_sleep>;
dual_emac = <1>;
// active_slave = <1>;
status = "okay";
&davinci_mdio {
pinctrl-0 = <&davinci_mdio_default>;
pinctrl-1 = <&davinci_mdio_sleep>;
status = "okay";
&cpsw_emac0 {
phy_id = <&davinci_mdio>, <4>;
phy-mode = "rgmii-txid";
// dual_emac_res_vlan=<0>;
&cpsw_emac1 {
phy_id = <&davinci_mdio>, <6>;
// dual_emac_res_vlan=<1>;
&tscadc {
status = "okay";
tsc {
ti,wires = <4>;
ti,x-plate-resistance = <200>;
ti,coordinate-readouts = <5>;
ti,wire-config = <0x00 0x11 0x22 0x33>;
ti,charge-delay = <0x400>;
adc {
ti,adc-channels = <0 1 2 3>;
&mmc1 {
status = "okay";
vmmc-supply = <&vdd_3v3>;
bus-width = <4>;
pinctrl-0 = <&mmc1_pins_default>;
pinctrl-1 = <&mmc1_pins_sleep>;
cd-gpios = <&gpio3 21 GPIO_ACTIVE_HIGH>;
&mmc3 {
/* these are on the crossbar and are outlined in the
xbar-event-map element */
dmas = <&edma_xbar 12 0 1
&edma_xbar 13 0 2>;
dma-names = "tx", "rx";
status = "okay";
bus-width = <4>;
max-frequency = <25000000>;
pinctrl-0 = <&mmc3_pins>;
ti,non-removable;
ti,needs-special-hs-handling;
cap-power-off-card;
keep-power-in-suspend;
&sham {
status = "okay";
&aes {
status = "okay";
&dcan0 {
status = "okay";
pinctrl-0 = <&dcan0_pins_default>;
&dcan1 {
status = "okay";
pinctrl-0 = <&dcan1_pins_default>;
&wkup_m3_ipc {
ti,scale-data-fw = "am335x-evm-scale-data.bin";
&rtc {
system-power-controller;
&sgx {
status = "disabled";
在&gpmc挂点下 nand 配置里有一个reg<0 0 4>/* CS0, offset 0, IO size 4/ IO size 4是什么意思
