am335x + qt5.4.1 + tslib1.4的触摸屏问题
我这边出现的情况是,我触摸屏校准完之后运行ts_test非常的准。然后我断电之后在上电,在运行ts_test,结果有时候准有时候不准。请问一下这个是什么问题。
qt环境变量如下。
export QTDIR=/usr/local/arm_qt5.4.1
export LD_LIBRARY_PATH=$QTDIR/lib:$LD_LIBRARY_PATH
export TSLIB_ROOT=/usr/local/arm_qt5.4.1/tslib
export TSLIB_TSDEVICE=/dev/input/touchscreen0
#export TSLIB_TSDEVICE=/dev/input/event1
export TSLIB_CALIBFILE=/etc/pointercal
export TSLIB_CONFFILE=$TSLIB_ROOT/etc/ts.conf
export TSLIB_PLUGINDIR=$TSLIB_ROOT/lib/ts
export TSLIB_FBDEVICE=/dev/fb0
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$TSLIB_ROOT/lib
export QT_QPA_PLATFORM=linuxfb:fb=/dev/fb0
#export QT_QPA_PLATFORM_PLUGIN_PATH=/usr/lib/qt5/plugins/platforms
export TSLIB_CONSOLEDEVICE=none
export QT_QPA_PLATFORM_PLUGIN_PATH=/usr/local/arm_qt5.4.1/plugins
export QT_QPA_GENERIC_PLUGINS=tslib,evdevkeyboard
#export QT_QPA_EVDEV_TOUCHSCREEN_PARAMETERS=/dev/input/touchscreen0:rotate=90
#export QT_QPA_PLATFORM=linuxfb:fb=/dev/fb0:rotation=90
export QT_QPA_FONTDIR=/usr/local/arm_qt5.4.1/lib/fonts
export QT_QPA_EVDEV_TOUCHSCREEN_PARAMETERS=inverty
