TMDXEVM6678LE恢复出厂设置失败!
hi,everyone!
我的板子之前做过从nand flash boot设置,现在想恢复出厂设置,遇到一些问题,请教高手。
软件版本:CCS5.2.1.00018_win32    和mcsdk_2_01_01_04(之前安装过bios_mcsdk_02_00_00_beta2_setup.exe,后来卸载了)
按照program_evm_userguide.pdf,选择no boot,设置$DSS_SCRIPT_DIR环境变量
执行脚本%DSS_SCRIPT_DIR%\dss.bat program_evm.js tmdxevm6678le -le
显示如下:
C:\Program Files\Texas Instruments\mcsdk_2_01_01_04\tools\program_evm>%DSS_SCRIP
board: evm6678l
endian: Little
emulation: XDS560 mezzanine
binaries: C:\Program Files\Texas Instruments\mcsdk_2_01_01_04\tools\program_evm/
binaries/evm6678l/
ccxml: C:\Program Files\Texas Instruments\mcsdk_2_01_01_04\tools\program_evm/con
figs/evm6678l/evm6678le.ccxml
C66xx_0: GEL Output:
Connecting Target...
C66xx_0: GEL Output: DSP core #0
C66xx_0: GEL Output: C6678L GEL file Ver is 2.004
C66xx_0: GEL Output: Global Default Setup...
C66xx_0: GEL Output: Setup Cache...
C66xx_0: GEL Output: L1P = 32K
C66xx_0: GEL Output: L1D = 32K
C66xx_0: GEL Output: L2 = ALL SRAM
C66xx_0: GEL Output: Setup Cache... Done.
C66xx_0: GEL Output: Main PLL (PLL1) Setup ...
C66xx_0: GEL Output: PLL in Bypass ...
C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz.
C66xx_0: GEL Output: SYSCLK2 = 333.3333 MHz, SYSCLK5 = 200.0 MHz.
C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz.
C66xx_0: GEL Output: PLL1 Setup... Done.
C66xx_0: GEL Output: Power on all PSC modules and DSP domains...
C66xx_0: GEL Output: Security Accelerator disabled!
C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done.
C66xx_0: GEL Output: PA PLL (PLL3) Setup ...
C66xx_0: GEL Output: PA PLL Setup... Done.
C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ...
C66xx_0: GEL Output: DDR3 PLL Setup... Done.
C66xx_0: GEL Output: DDR begin (1333 auto)
C66xx_0: GEL Output: XMC Setup ... Done
DDR3 initialization is complete.
C66xx_0: GEL Output: DDR done
C66xx_0: GEL Output: DDR3 memory test... Started
C66xx_0: GEL Output: DDR3 memory test... Passed
C66xx_0: GEL Output: PLL and DDR Initialization completed(0) ...
C66xx_0: GEL Output: configSGMIISerdes Setup... Begin
SGMII SERDES has been configured.
C66xx_0: GEL Output: Enabling EDC ...
C66xx_0: GEL Output: L1P error detection logic is enabled.
C66xx_0: GEL Output: L2 error detection/correction logic is enabled.
C66xx_0: GEL Output: MSMC error detection/correction logic is enabled.
C66xx_0: GEL Output: Enabling EDC ...Done
C66xx_0: GEL Output: Configuring CPSW ...
C66xx_0: GEL Output: Configuring CPSW ...Done
C66xx_0: GEL Output: Global Default Setup... Done.
Global Default Setup... Done.后就直接退出了,不知道怎么回事,试了好几次都这样,如何解决?
