为什么我的6467板子编译过程找不到头文件
Other Parts Discussed in Thread: CCSTUDIO
"D:\CCStudio_v3.3\C6000\cgtools\bin\cl6x" -g -fr"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H264_1080P/h264fhdvenc/app/Client/Build/Obj" -i"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H264_1080P/h264fhdvenc/app/Client/Build/../Test/jpegenc" -i"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H264_1080P/h264fhdvenc/app/Client/Build/../Test/Inc" -i"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H264_1080P/h264fhdvenc/app/Client/Build/../../Inc" -i"D:/CCStudio_v3.3/bios_5_31_02/packages" -i"D:/CCStudio_v3.3/bios_5_31_02/packages/ti/bios/include" -i"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H264_1080P/h264fhdvenc/app/Client/Build/../../Lib" -i"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H264_1080P/h264fhdvenc/app/Client/Build/../../Csp/CSL/include" -i"D:/CCStudio_v3.3/MyProjects/Multi_Ch_Enc_4xHalfD1-2016-0601/DSP_Prog/DM6467_H
264_1080P/h264fhdvenc/app/Client/Build/../../Csp/c6x/include" -i"/packages" -i"/packages/ti/sdo/fc/utils/api" -i"D:/CCStudio_v3.3/bios_5_31_02/xdctools/packages" -d"_PROFILE" -u"_DEBUG" -u"_QT_TEST" -u"_QT_OUTPUT_DUMP" -mr1 -mv6400+ -@"../../Build/Debug.lkf" "jpegenc.c"
"idmjpge.h", line 6: fatal error: could not open source file "ti/xdais/xdas.h"
1 fatal error detected in the compilation of "jpegenc.c".
Compilation terminated.
>> Compilation failure
[bios_rts.c]
264_1080P/h264fhdvenc/app/Client/Build/../../Csp/c6x/include" -i"/packages" -i"/packages/ti/sdo/fc/utils/api" -i"D:/CCStudio_v3.3/bios_5_31_02/xdctools/packages" -d"_PROFILE" -d"_RTS_MODE" -u"_DEBUG" -u"_QT_TEST" -u"_QT_OUTPUT_DUMP" -mr1 -mv6400+ -@"../../Build/Debug.lkf" "bios_rts.c"
[edma3_rm_gbl_data.c]
264_1080P/h264fhdvenc/app/Client/Build/../../Csp/c6x/include" -i"/packages" -i"/packages/ti/sdo/fc/utils/api" -i"D:/CCStudio_v3.3/bios_5_31_02/xdctools/packages" -d"_PROFILE" -u"_DEBUG" -u"_QT_TEST" -u"_QT_OUTPUT_DUMP" -mr1 -mv6400+ -@"../../Build/Debug.lkf" "edma3_rm_gbl_data.c"
"edma3_rm_gbl_data.c", line 42: fatal error: could not open source file "ti/sdo/edma3/rm/src/edma3resmgr.h"
1 fatal error detected in the compilation of "edma3_rm_gbl_data.c".
  • 请检查一下ccs编译选项里头文件设置的路径对不对?设置的路径下有没有该头文件?
  • $(Proj_dir)\..\Test\jpegenc;$(Proj_dir)\..\Test\Inc;$(Proj_dir)\..\..\Inc;%BIOS_INSTALL_DIR%\packages;%BIOS_INSTALL_DIR%\packages\ti\bios\include;$(Proj_dir)\..\..\Lib;$(Proj_dir)\..\..\Csp\CSL\include;$(Proj_dir)\..\..\Csp\c6x\include;%FC_INSTALL_DIR%\packages;%FC_INSTALL_DIR%\packages\ti\sdo\fc\utils\api;%XDAIS_INSTALL_DIR%;%BIOS_INSTALL_DIR%\xdctools\packages
    这是头文件设置路径,找不到的头文件我从其他地方找到后复制到这些文件夹内了,还是找不到。在include里面有显示但是打不开。
    这是怎么回事
  • 那应该还是路径设置不对,你可以设置个绝对路径试试,注意ccs编译选项里的路径不要和c代码里设置的路径重复。
