IPC自带example中的.cfg文件使用XGCONF方式打开出错
Other Parts Discussed in Thread: AM5728
我使用的开发环境为win7_64,CCS版本6.1.3,使用的sdk为processor_sdk_rtos_am57xx_3_01_00_06,ipc版本为ipc_3_43_02_04(安装sdk时自带的),开发板为AM5728;
现在遇到的问题是:我按照目录ipc_3_43_02_04->examples->DDA7XX_bios_elf->ex01_hello->dsp1找的了dsp端的.cfg文件“Dsp1.cfg”然后把它复制到我创建的C66x的BIOS工程中,双击进行打开(默认的打开方式为XGCONF),这时出现如下错误提示:
Failed to create the part's controls
详细信息为:
java.lang.NullPointerException
at org.eclipse.rtsc.xdctools.model.parser.ConfigScriptFile.addDocPositions(Unknown Source)
at org.eclipse.rtsc.xdctools.model.parser.ConfigScriptFile.parseConfigFile(Unknown Source)
at org.eclipse.rtsc.xdctools.model.ui.editors.ProgramConfigurationEditor.createSourcePage(Unknown Source)
at org.eclipse.rtsc.xdctools.model.ui.editors.ProgramConfigurationEditor.createPages(Unknown Source)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:363)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:151)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:99)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:341)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:898)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:879)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:121)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:345)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:264)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:104)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:73)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:55)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:971)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:640)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:746)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:717)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:711)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:695)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:99)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:186)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4761)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:85)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:59)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:494)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:458)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:724)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:396)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1166)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3234)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3149)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3131)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3126)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3090)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3080)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:541)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:500)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:100)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:100)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:229)
at org.eclipse.ui.navigator.CommonNavigatorManager$2.open(CommonNavigatorManager.java:191)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:854)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:173)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:851)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1168)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:449)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1275)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:278)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:272)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:313)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4362)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1113)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4180)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3769)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1127)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:337)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1018)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:156)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:654)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:598)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:139)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:669)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:608)
at org.eclipse.equinox.launcher.Main.run(Main.java:1515)
不过使用XDCscript editor是可以正常打开的,在DDA7XX_bios_elf文件夹下的所有.cfg文件都是同样的情况。
而在DDA7XX_linux_elf文件夹下的所有.cfg都能正常打开。
出现这种问题的原因我没有查明白,论坛上有说清理workspace或者建立新的workspace,我尝试后仍然存在这个问题。
请问对于这种情况有什么建议吗?谢谢!
  • 请问是否是通过ccs->File > New > RTSC Configuration File添加到工程文件里的?
    2.2 Adding SYS/BIOS Support to an Existing Project
    www.ti.com/.../spruex3t.pdf
  • 您好!
    感谢您的回答!
    我按照您说的方式进行了尝试,也阅读了所指出的章节内容。我发现这都是向一个工程中添加一个新的.cfg文件的方式,添加进去的是一个空文件。
    我的问题不是说我在CCS里添加不了.cfg文件,正常创建的工程中对.cfg的使用没有问题。只是当对安装的sdk所给的ipc的源文件里,‘DDA7XX_bios_elf’文件下的所有.cfg文件添加到工程后,使用XGCONF方式打开会出现上述错误。而通过您说的方式无法添加已存在的.cfg文件。
    这与我的CCS版本有关系吗?
  • 可能打开这个文件的时候会做一些创建其他文件的工作,你打开这个文件做什么呢
  • 您好!
    我在进行BIOS to BIOS的ipc通信。首先通过ipc包中的Makefile文件成功生成可执行文件,然后在开发板上运行通过,成功进行两个DSP的通信。
    现在我想使用这里面给的对应的源码(因为没有工程的例程),来创建一个工程实现上述功能。
    所以在直接使用所给的.cfg文件时,就需要打开这个文件。
