Dear TI:
用示波器测量I2S2 RX管脚是有波形的,仿真的时候查看I2S 2S2 Receive Left/Right Data Register寄存器里面的数据全是0;
我的代码设置如下,请帮查看一下问题出在哪里了:
/** Open the device with instance 0 */
hI2s = I2S_open(I2S_INSTANCE0, DMA_POLLED, I2S_CHAN_STEREO);
if(NULL == hI2s)
status = CSL_TEST_FAILED;
return (status);
else
printf ("I2S Module Instance opened successfully\n");
hI2s2 = I2S_open(I2S_INSTANCE2, DMA_POLLED, I2S_CHAN_STEREO);
if(NULL == hI2s2)
return (status);
else
/** Set the value for the configure structure */
hwConfig.dataType = I2S_STEREO_ENABLE;
hwConfig.loopBackMode = I2S_LOOPBACK_ENABLE;
hwConfig.fsPol = I2S_FSPOL_LOW;
hwConfig.clkPol = I2S_FALLING_EDGE;
hwConfig.datadelay = I2S_DATADELAY_ONEBIT;
hwConfig.datapack = I2S_DATAPACK_ENABLE;
hwConfig.signext = I2S_SIGNEXT_DISABLE;
hwConfig.wordLen = I2S_WORDLEN_16;
hwConfig.i2sMode = I2S_MASTER;
hwConfig.clkDiv = I2S_CLKDIV128;
hwConfig.fsDiv = I2S_FSDIV32;
hwConfig.FError = I2S_FSERROR_DISABLE;
hwConfig.OuError = I2S_OUERROR_DISABLE;
/** Configure hardware registers */
result = I2S_setup(hI2s, &hwConfig);
if(result != CSL_SOK)
return (status);
else
printf ("I2S Module Configured successfully\n");
result = I2S_setup(hI2s2, &hwConfig);
return (status);
else
