我按照DeveloperGuide上的步骤编译 最后写入sd ,然后用sd卡启动8148demo板子屏幕没反应是怎么回事?哪位大师知道啊,请不吝赐教。
我是在software-dl.ti.com/.../index_FDS.html 这个网址下载的源码 是81XX的 我用的板子就是他们的demo板
U-Boot 2010.06 (Oct 10 2012 - 14:09:17)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0
Using default environment
The 2nd stage U-Boot will now be auto-loaded
Please do not interrupt the countdown till TI8148_EVM prompt if 2nd stage is already flashed
Hit any key to stop autoboot: 0
reading u-boot.bin
210400 bytes read
## Starting application at 0x80800000 ...
U-Boot 2010.06 (Oct 10 2012 - 14:05:13)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
I2C: ready
DRAM: 2 GiB
NAND: HW ECC BCH8 Selected
No NAND device found!!!
0 MiB
MMC: OMAP SD/MMC: 0
*** Warning - bad CRC or NAND, using default environment
.:;rrr;;.
,5#@@@@#####@@@@@@#2,
,A@@@hi;;;r5;;;;r;rrSG@@@A,
r@@#i;:;s222hG;rrsrrrrrr;ri#@@r
:@@hr:r;SG3ssrr2r;rrsrsrsrsrr;rh@@:
B@H;;rr;3Hs;rrr;sr;;rrsrsrsrsrsr;;H@B
@@s:rrs;5#;;rrrr;r#@H:;;rrsrsrsrsrr:s@@
@@;;srs&X#9;r;r;;,2@@@rrr:;;rrsrsrsrr;;@@
@@;;rrsrrs@MB#@@@@@###@@@@@@#rsrsrsrsrr;;@@
G@r;rrsrsr;#X;SX25Ss#@@#M@#9H9rrsrsrsrsrs;r@G
@9:srsrsrs;2@;:;;:.X@@@@@H::;rrsrsrsrsrsrr:3@
X@;rrsrsrsrr;XAi;;:&@@#@Bs:rrsrsrsrsrsrsrsrr;@X
@#;rsrsrsrsrr;r2ir@@@###::rrsrsrsrsrsrsrsrsr:@@
@A:rrsrsrsrr;:2@29@@M@@@;:;rrrrsrsrsrsrsrsrs;H@
@&;rsrsrsrr;A@@@@@@###@@@s::;:;;rrsrsrsrsrsr;G@
@#:rrsrsrsr;G@5Hr25@@@#@@@#9XG9s:rrrrsrsrsrs:#@
M@;rsrsrsrs;r@&#;::S@@@@@@@M@@@@Grr:;rsrsrsr;@#
:@s;rsrsrsrr:M#Msrr;;&#@@@@@@@@@@H@@5;rsrsr;s@,
@@:rrsrsrsr;S@rrrsr;:;r3MH@@#@M5,S@@irrsrr:@@
@A:rrsrsrsrrrrrsrsrrr;::;@##@r:;rH@h;srr:H@
;@9:rrsrsrsrrrsrsrsrsr;,S@Hi@i:;s;MX;rr:h@;
r@B:rrrrsrsrsrsrsrr;;sA@#i,i@h;r;S5;r:H@r
,@@r;rrrsrsrsrsrr;2BM3r:;r:G@:rrr;;r@@,
B@Mr;rrrrsrsrsr@@S;;;rrr:5M;rr;rM@H
.@@@i;;rrrrsrs2i;rrrrr;r@M:;i@@@.
.A@@#5r;;;r;;;rrr;r:r#AsM@@H.
;&@@@@MhXS5i5SX9B@@@@G;
:ihM#@@@@@##hs,
Net: <ethaddr> not set. Reading from E-fuse
Detected MACID:40:5f:c2:26:23:80
cpsw
reading boot.scr
437 bytes read
Running bootscript from MMC/SD to set the ENV...
## Executing script at 80900000
reading uImage
2528792 bytes read
***** Kernel: /dev/mmcblk0p1/uImage *****
***** RootFS: /dev/mmcblk0p2 *****
## Booting kernel from Legacy Image at 81000000 ...
Image Name: Linux-2.6.37+
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2528728 Bytes = 2.4 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.37+ (root@ubuntu) (gcc version 4.4.0 (GCC) ) #1 Tue Nov 13 18:15:32 PST 2012
CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: ti8148evm
vram size = 52428800 at 0
reserved size = 52428800 at 0
FB: Reserving 52428800 bytes SDRAM for VRAM
Memory policy: ECC disabled, Data cache writeback
Ignoring RAM at c0000000-cfffffff (vmalloc region overlap).
OMAP chip is TI8148
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 42164
Kernel command line: mem=166M@0x80000000 mem=256M@0xc0000000 console=ttyO0,115200n8 androidboot.console=ttyO0 root=/dev/mmcblk0p2 rw rootfstype=ext3 rootdelay=1 init=/init ip=off vram=50M
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 166MB 206MB = 372MB total
Memory: 162632k/162632k available, 7352k reserved, 0K highmem
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
DMA : 0xffc00000 - 0xffe00000 ( 2 MB)
vmalloc : 0xca800000 - 0xf8000000 ( 728 MB)
lowmem : 0xc0000000 - 0xca600000 ( 166 MB)
modules : 0xbf000000 - 0xc0000000 ( 16 MB)
.init : 0xc0008000 - 0xc0035000 ( 180 kB)
.text : 0xc0035000 - 0xc04ba000 (4628 kB)
.data : 0xc04ba000 - 0xc04f86a0 ( 250 kB)
SLUB: Genslabs=11, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:375
IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
Total of 128 interrupts on 1 active controller
GPMC revision 6.0
Trying to install interrupt handler for IRQ368
Trying to install interrupt handler for IRQ369
Trying to install interrupt handler for IRQ370
Trying to install interrupt handler for IRQ371
Trying to install interrupt handler for IRQ372
Trying to install interrupt handler for IRQ373
Trying to install interrupt handler for IRQ374
Trying to install type control for IRQ375
Trying to set irq flags for IRQ375
OMAP clockevent source: GPTIMER1 at 20000000 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 599.65 BogoMIPS (lpj=2998272)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
devtmpfs: initialized
omap_voltage_early_init: voltage driver support not added
regulator: core version 0.5
regulator: dummy:
NET: Registered protocol family 16
registered ti814x_vpss device
pm_dbg_init: only OMAP3 supported
Registered ti81xx_fb device
Could not look up wd_timer-1 hwmod
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
omap_i2c omap_i2c.1: bus 1 rev4.0 at 100 kHz
Advanced Linux Sound Architecture Driver Version 1.0.23.
Switching to clocksource gp timer
musb-hdrc: version 6.0, host, debug=0
musb-hdrc musb-hdrc.0: dma type: dma-cppi41
registerd cppi-dma Intr @ IRQ 17
Cppi41 Init Done
musb-hdrc musb-hdrc.0: MUSB HDRC host driver
musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb1: SerialNumber: musb-hdrc.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
musb-hdrc musb-hdrc.0: USB Host mode controller at ca80c000 using DMA, IRQ 18
musb-hdrc musb-hdrc.1: dma type: dma-cppi41
musb-hdrc musb-hdrc.1: MUSB HDRC host driver
musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: MUSB HDRC host driver
usb usb2: Manufacturer: Linux 2.6.37+ musb-hcd
usb usb2: SerialNumber: musb-hdrc.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
musb-hdrc musb-hdrc.1: USB Host mode controller at ca81e800 using DMA, IRQ 19
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
NetWinder Floating Point Emulator V0.97 (double precision)
omap-iommu omap-iommu.0: ducati registered
omap-iommu omap-iommu.1: sys registered
ashmem: initialized
JFFS2 version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
msgmni has been set to 317
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
omap_uart.0: ttyO0 at MMIO 0x48020000 (irq = 72) is a OMAP UART0
console [ttyO0] enabled
omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
brd: module loaded
loop: module loaded
ahci ahci.0: forcing PORTS_IMPL to 0x1
ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
ahci ahci.0: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
scsi0 : ahci_platform
ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a150fff] port 0x100 irq 16
omap2-nand driver initializing
No NAND device found.
davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
davinci_mdio davinci_mdio.0: detected phy mask fffffffc
davinci_mdio.0: probed
davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver unknown
davinci_mdio davinci_mdio.0: phy[1]: device 0:01, driver unknown
usbcore: registered new interface driver cdc_ether
usbcore: registered new interface driver dm9601
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
i2c /dev entries driver
Linux video capture interface: v2.00
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v1.0.0)
device-mapper: ioctl: 4.18.0-ioctl (2010-06-29) initialised: dm-devel@redhat.com
PSTATE 1f70000
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
logger: created 64K log 'log_main'
logger: created 256K log 'log_events'
logger: created 64K log 'log_radio'
logger: created 64K log 'log_system'
usbcore: registered new interface driver snd-usb-audio
1-0018 supply IOVDD not found, using dummy regulator
1-0018 supply DVDD not found, using dummy regulator
1-0018 supply AVDD not found, using dummy regulator
1-0018 supply DRVDD not found, using dummy regulator
asoc: tlv320aic3x-hifi <-> davinci-mcasp.2 mapping ok
ALSA device list:
#0: TI81XX EVM
TCP cubic registered
NET: Registered protocol family 17
Registering the dns_resolver key type
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
omap_voltage_late_init: Voltage driver support not added
Detected MACID=0:0:0:0:0:0
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Waiting 1sec before mounting root device...
ata1: SATA link down (SStatus 0 SControl 300)
Root-NFS: no NFS server address
VFS: Unable to mount root fs via NFS, trying floppy.
VFS: Cannot open root device "mmcblk0p2" or unknown-block(2,0)
Please append a correct "root=" boot option; here are the available partitions:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0)
Backtrace:
[<c004418c>] (dump_backtrace+0x0/0x110) from [<c038ce9c>] (dump_stack+0x18/0x1c)
r7:c0442415 r6:00008000 r5:c04f8d58 r4:c04f8d58
[<c038ce84>] (dump_stack+0x0/0x1c) from [<c038cf04>] (panic+0x64/0x178)
[<c038cea0>] (panic+0x0/0x178) from [<c0008f90>] (mount_block_root+0x1dc/0x21c)
r3:00000000 r2:00000000 r1:ca029f50 r0:c04424bc
[<c0008db4>] (mount_block_root+0x0/0x21c) from [<c000907c>] (mount_root+0xac/0xcc)
[<c0008fd0>] (mount_root+0x0/0xcc) from [<c0009208>] (prepare_namespace+0x16c/0x1d0)
r4:c04f8724
[<c000909c>] (prepare_namespace+0x0/0x1d0) from [<c00084c0>] (kernel_init+0x118/0x158)
r5:c002af3c r4:c04f86c0
[<c00083a8>] (kernel_init+0x0/0x158) from [<c0061cc4>] (do_exit+0x0/0x5e4)
r5:c00083a8 r4:00000000
有谁知道 下面的是出什么问题了吗?
U-Boot 2010.06 (Nov 29 2012 - 17:52:56)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
DRAM: 2 GiB
MMC: OMAP SD/MMC: 0
reading u-boot.bin
211336 bytes read
U-Boot 2010.06 (Nov 29 2012 - 17:55:38)
TI8148-GP rev 2.1
ARM clk: 600MHz
DDR clk: 400MHz
I2C: ready
DRAM: 2 GiB
0 MiB
MMC: OMAP SD/MMC: 0
.:;rrr;;.
:ihM#@@@@@##hs,
cpsw
reading boot.scr
504 bytes read
reading uImage
2586760 bytes read
Data Size: 2586696 Bytes = 2.5 MiB
OK
Starting kernel ...
Linux version 2.6.37 (song@ubuntu) (gcc version 4.4.0 (GCC) ) #1 Wed Dec 5 00:00:42 PST 2012
Machine: ti8148evm
OMAP chip is TI8148 2.0
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 161670
Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 rootwait noinitrd init=/init rw mem=364M mem=324M@0x9f900000 earlyprintk notifyk.vpssm3_sva=0xBF900000 vram=50M ti814xfb.vram=0:24M,1:16M,2:6M root=/dev/mmcblk0p2 rootfstype=ext3 ip=off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 364MB 274MB = 638MB total
Memory: 641024k/641024k available, 63488k reserved, 11264K highmem
vmalloc : 0xf0800000 - 0xf8000000 ( 120 MB)
lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.init : 0xc0008000 - 0xc0038000 ( 192 kB)
.text : 0xc0038000 - 0xc04d7000 (4732 kB)
.data : 0xc04d8000 - 0xc051be60 ( 272 kB)
NR_IRQS:375
GPMC revision 6.0
regulator: dummy:
OMAP GPIO hardware version 0.1
omap_mux_init: Add partition: #1: core, flags: 4
registered TI814x on-chip HDMI device
pcf857x 1-0021: gpios 128..143 on a pcf8575
i2c i2c-1: Failed to register i2c client PCF_8575 at 0x21 (-16)
i2c i2c-1: Can't create device at 0x21
Cppi41 Init Done
usb usb1: Manufacturer: Linux 2.6.37 musb-hcd
musb-hdrc musb-hdrc.0: USB Host mode controller at f080c000 using DMA, IRQ 18
usb usb2: Manufacturer: Linux 2.6.37 musb-hcd
musb-hdrc musb-hdrc.1: USB Host mode controller at f081e800 using DMA, IRQ 19
IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
TCP reno registered
UDP hash table entries: 512 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
PMU: registered new PMU device of type 0
highmem bounce pool size: 64 pages
ashmem: initialized
msgmni has been set to 1230
brd: module loaded
loop: module loaded
qt602240_ts 1-004a: Family ID: 128 Variant ID: 1 Version: 22 Build: 171
qt602240_ts 1-004a: Matrix X Size: 18 Matrix Y Size: 12 Object Num: 17
input: AT42QT602240/ATMXT224 Touchscreen as /devices/platform/omap/omap_i2c.1/i2c-1/1-004a/input/input0
OMAP Watchdog Timer Rev 0x00: initial timeout 60 sec
notify_init : notify drivercreated for remote proc id 2 at physical Address 0xbf900000
ALSA device list:
#0: TI81XX EVM
Waiting for root device /dev/mmcblk0p2...
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SD08G 7.40 GiB
mmcblk0: p1 p2 p3
EXT3-fs: barriers not enabled
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): 1 truncate cleaned up
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing init memory: 192K
init (1): /proc/1/oom_adj is deprecated, please use /proc/1/oom_score_adj instead.
init: cannot find '/system/etc/install-recovery.sh', disabling 'flash_recovery'
# syslink: disagrees about version of symbol clk_set_rate
syslink: Unknown symbol clk_set_rate (err -22)
syslink: disagrees about version of symbol clk_get_rate
syslink: Unknown symbol clk_get_rate (err -22)
syslink: disagrees about version of symbol clk_disable
syslink: Unknown symbol clk_disable (err -22)
syslink: disagrees about version of symbol clk_enable
syslink: Unknown symbol clk_enable (err -22)
vpss: Unknown symbol Notify_sendEvent (err 0)
vpss: Unknown symbol MultiProc_getId (err 0)
vpss: Unknown symbol Notify_unregisterEvent (err 0)
vpss: Unknown symbol Notify_registerEvent (err 0)
pvrsrvkm: disagrees about version of symbol contig_page_data
pvrsrvkm: Unknown symbol contig_page_data (err -22)
pvrsrvkm: disagrees about version of symbol __alloc_pages_nodemask
pvrsrvkm: Unknown symbol __alloc_pages_nodemask (err -22)
ti81xxfb: disagrees about version of symbol ti81xx_vram_alloc
ti81xxfb: Unknown symbol ti81xx_vram_alloc (err -22)
ti81xxfb: Unknown symbol vps_fvid2_queue (err 0)
ti81xxfb: Unknown symbol vps_grpx_get_num_grpx (err 0)
ti81xxfb: Unknown symbol vps_grpx_get_ctrl (err 0)
omaplfb: Unknown symbol PVRGetDisplayClassJTable (err 0)
PLL Not Getting Locked!!!
warning: `zygote' uses 32-bit capabilities (legacy support in use)
alarm_set_rtc: no RTC, time will be lost on reboot
request_suspend_state: wakeup (3->0) at 10410439902 (1970-01-02 00:00:00.842015200 UTC)
init: untracked pid 62 exited
request_suspend_state: wakeup (0->0) at 15576673702 (1970-01-02 00:00:06.008248250 UTC)
init: untracked pid 107 exited
request_suspend_state: wakeup (0->0) at 20725401052 (1970-01-02 00:00:11.156975100 UTC)
init: untracked pid 131 exited
