下面是demo里面的代码,我应该怎么改才能将视频转换为灰度在输出,刚开始学这个还不太懂,主要是里面的那个YCbCr不能直接转换为RGB再处理。
* Copyright 2007 by Spectrum Digital Incorporated.
* All rights reserved. Property of Spectrum Digital Incorporated.
* Video Test Case
#define DM6467_FIELDORFRAM 288
#include "vpif.h"
* Video Buffers *
#pragma DATA_SECTION ( bt656NtscYT, ".ddr2_video" );
#pragma DATA_ALIGN(bt656NtscYT,32);
Uint8 bt656NtscYT[720 * DM6467_FIELDORFRAM];
#pragma DATA_SECTION ( bt656NtscCT, ".ddr2_video" );
Uint8 bt656NtscCT[720 * DM6467_FIELDORFRAM];
#pragma DATA_SECTION ( bt656NtscYB, ".ddr2_video" );
Uint8 bt656NtscYB[720 * DM6467_FIELDORFRAM];
#pragma DATA_SECTION ( bt656NtscCB, ".ddr2_video" );
Uint8 bt656NtscCB[720 * DM6467_FIELDORFRAM];
* VPIF Handles *
static VPIF_CAP_Handle channel0 = ( VPIF_CAP_Handle )&VPIF_MODULE_0;
static VPIF_CAP_Handle channel1 = ( VPIF_CAP_Handle )&VPIF_MODULE_1;
static VPIF_DIS_Handle channel2 = ( VPIF_DIS_Handle )&VPIF_MODULE_2;
//static VPIF_DIS_Handle channel3 = ( VPIF_DIS_Handle )&VPIF_MODULE_3;
* vpif_sd_display( mode ) *
Int16 vpif_sd_display( Int16 mode )
* Setup VPIF controls *
VPIF_DMA_SIZE = 32; // DMA request size
VPIF_EMU_CTRL = 1; // Free from Emulation
VPIF_CHCTRL2 = 0; // Disable Display Channel 2
/* Clear Channel 2 */
channel2->regs->FLD0_Y_STRTADR = 0;
channel2->regs->FLD1_Y_STRTADR = 0;
channel2->regs->FLD0_C_STRTADR = 0;
channel2->regs->FLD1_C_STRTADR = 0;
channel2->regs->IMG_LINE_OFFSET = 0;
channel2->regs->HSIZE_CFG = 0;
channel2->regs->VSIZE_CFG0 = 0;
channel2->regs->VSIZE_CFG1 = 0;
channel2->regs->VSIZE_CFG2 = 0;
channel2->regs->VSIZE_CFG3 = 0;
/* Disable Interrupts */
VPIF_INTEN &= ~VPIF_INT_CH2;
/* Output Video Clocks - 27 MHz */
SYS_VSCLKDIS &= ~(7<<8);
SYS_VSCLKDIS &= (3<<8);
* Setup Display Channel 2 -> [YCbCr] *
channel2->regs->FLD0_Y_STRTADR = ( ( Uint32 )bt656NtscYT );
channel2->regs->FLD0_C_STRTADR = ( ( Uint32 )bt656NtscCT );
channel2->regs->FLD1_Y_STRTADR = ( ( Uint32 )bt656NtscYB );
channel2->regs->FLD1_C_STRTADR = ( ( Uint32 )bt656NtscCB );
/* 480I */
VPIF_CHCTRL2 = 0
| ( 0 << 12 ) // Output Field
| ( 0 << 11 ) // Interlaced Format
| ( 1 << 10 ) // Pixel Data
| ( 0 << 9 ) // No Vertical Ancillary
| ( 0 << 8 ) // No Horizontal Ancillary
| ( 1 << 6 ) // [2] Interrupt on Bottom Field
| ( 0 << 4 ) // Raster
| ( 1 << 3 ) // Y/C on same byte stream
| ( 0 << 0 ); // Channel Disabled
channel2->regs->IMG_LINE_OFFSET = 720;
channel2->regs->HSIZE_CFG = ( 280 << 16 ) | ( 1440 << 0 );
channel2->regs->VSIZE_CFG0 = ( 1 << 16 ) | ( 23 << 0 );
channel2->regs->VSIZE_CFG1 = ( 311 << 16 ) | ( 313 << 0 );
channel2->regs->VSIZE_CFG2 = ( 336 << 16 ) | ( 624 << 0 );
channel2->regs->VSIZE_CFG3 = ( 625 );
* Synchronize : Channel 2 *
VPIF_INTEN |= VPIF_INT_CH2; // Enable Interrupts
VPIF_INTENSET |= VPIF_INT_CH2; // Set Interrupts
VPIF_INTENCLR |= VPIF_INT_CH2; // Clear Interrupts
/* Wait for Channel 0/1 frame sync */
VPIF_INTENCLR = ( VPIF_INT_CH0 | VPIF_INT_CH1 );
if ( VPIF_INTEN & ( VPIF_INT_CH0 | VPIF_INT_CH1 ) )
while ( ( VPIF_INTSTAT & ( VPIF_INT_CH0 | VPIF_INT_CH1 ) ) == 0 );
* Start Output: Channel 2 *
VPIF_CHCTRL2 |= 3;
return 0;
* vpif_sd_capture( mode, connector ) *
Int16 vpif_sd_capture( Int16 mode, Int16 connector )
VPIF_DMA_SIZE = 128; // DMA request size
VPIF_CHCTRL0 = 0; // Disable Capture Channel 0
VPIF_CHCTRL1 = 0; // Disable Capture Channel 1
/* Clear Channel 0 */
channel0->regs->FLD0_Y_STRTADR = 0;
channel0->regs->FLD1_Y_STRTADR = 0;
channel0->regs->FLD0_C_STRTADR = 0;
channel0->regs->FLD1_C_STRTADR = 0;
channel0->regs->IMG_LINE_OFFSET = 0;
channel0->regs->HSIZE_CFG = 0;
channel0->regs->VSIZE_CFG0 = 0;
channel0->regs->VSIZE_CFG1 = 0;
channel0->regs->VSIZE_CFG2 = 0;
channel0->regs->VSIZE_CFG3 = 0;
/* Clear Channel 1 */
channel1->regs->FLD0_Y_STRTADR = 0;
channel1->regs->FLD1_Y_STRTADR = 0;
channel1->regs->FLD0_C_STRTADR = 0;
channel1->regs->FLD1_C_STRTADR = 0;
channel1->regs->IMG_LINE_OFFSET = 0;
channel1->regs->HSIZE_CFG = 0;
channel1->regs->VSIZE_CFG0 = 0;
channel1->regs->VSIZE_CFG1 = 0;
channel1->regs->VSIZE_CFG2 = 0;
channel1->regs->VSIZE_CFG3 = 0;
VPIF_INTEN &= ~VPIF_INT_CH0;
VPIF_INTEN &= ~VPIF_INT_CH1;
/* Clear Interrupt */
VPIF_INTENCLR |= VPIF_INT_CH0;
VPIF_INTENCLR |= VPIF_INT_CH1;
/* Input Video Clocks */
vpif_clock_setup( VCH0CLK, 0 ); // from TVP5147_1
// Top Y's field start address
channel0->regs->FLD0_Y_STRTADR = ( ( Uint32 )bt656NtscYT );
// Top C's field start adress
channel0->regs->FLD0_C_STRTADR = ( ( Uint32 )bt656NtscCT );
// Bottom Y's field start address
channel0->regs->FLD1_Y_STRTADR = ( ( Uint32 )bt656NtscYB );
// BOttom C's field start address
channel0->regs->FLD1_C_STRTADR = ( ( Uint32 )bt656NtscCB );
// set flied mode ,offset for line store is 720 pixes
channel0->regs->IMG_LINE_OFFSET =720;
channel0->regs->HSIZE_CFG = ( 280 << 16 ) | ( 1440 << 0 );
channel0->regs->VSIZE_CFG0 = ( 1 << 16 ) | ( 23 << 0 );
channel0->regs->VSIZE_CFG1 = ( 311 << 16 ) | ( 313 << 0 );
channel0->regs->VSIZE_CFG2 = ( 336 << 16 ) | ( 624 << 0 );
channel0->regs->VSIZE_CFG3 = 625;
/* 480I */
VPIF_CHCTRL0 = 0
| ( 0 << 12 ) // Input Field mode
| ( 0 << 10 ) // Interlaced Format
| ( 0 << 5 ) // FID top field
| ( 1 << 1 ) // FORMAT BT Video
* Start Input: Channel 0 *
VPIF_INTEN |= VPIF_INT_CH0; // Enable Interrupt
VPIF_INTENSET |= VPIF_INT_CH0; // Set Interrupt
VPIF_INTENCLR |= VPIF_INT_CH0; // Clear Interrupt
VPIF_CHCTRL0 |= 1; // Start Channel 0
return 0;
* vpif_sd_generate_pattern( mode ) *
Int16 vpif_sd_generate_pattern( Int16 mode )
Int16 i, j, k;
Int16 hor_incr, ver_incr;
Uint8 ycrcb[8][3] = {
0xeb, 0x80, 0x80, // white *[cr=cb]
0x10, 0x80, 0x80, // black *[cr=cb]
0x51, 0xf0, 0x5a, // red
0x91, 0x22, 0x36, // green
0x29, 0x6e, 0xf0, // blue
0xd2, 0x92, 0x10, // yellow
0xaa, 0x10, 0xa6, // cyan
0x6a, 0xde, 0xca // magenta
Uint8 y, cr, cb;
Uint32 y32, cbcr32;
Uint32* ptrYT = ( Uint32* )bt656NtscYT;
Uint32* ptrYB = ( Uint32* )bt656NtscYB;
Uint32* ptrCT = ( Uint32* )bt656NtscCT;
Uint32* ptrCB = ( Uint32* )bt656NtscCB;
if ( mode == MODE_SDTV_480I )
hor_incr = 720;
ver_incr = 244;
else
return -1;
i = 0;
y = ycrcb[i][0];
y32 = ( y << 24 ) | ( y << 16 ) | ( y << 8 ) | ( y << 0 );
cr = ycrcb[i][1];
cb = ycrcb[i][2];
cbcr32 = ( cr << 24 ) | ( cb << 16 ) | ( cr << 8 ) | ( cb << 0 );
/* Color Bars */
for ( k = 0 ; k < ver_incr ; k++ )
for ( j = 0 ; j < hor_incr ; j++ )
*ptrYT++ = y32;
*ptrYB++ = y32;
*ptrCT++ = cbcr32;
*ptrCB++ = cbcr32;
return 0;
