在工程目录哪里能看到使用的platform文件,并且以文本的方式查看或编辑
  • 请看SYS/BIOS user guide。
    To view the memory map for your platform, you can open the platform wizard by choosing Project > RTSC Tools > Platform > Edit/View. Select the packages repository in your SYS/BIOS installation (that is, your <bios_install_dir>\packages directory). Then, choose the Package you are using and click Next.
    www.ti.com/.../spruex3t.pdf
