工程警告
Description Resource Path Location Type
#10373-D library "../Source/imgproc/ocrlib/SerialNumLib.lib" contains TI-COFF object files which are incompatible with the ELF output file.  Ensure you are using the proper library. main_billacceptor    C/C++ Problem
目标库文件已选择输出文件格式为ELF格式,为何还一直报次警告
