请教大家,DSP28335运行程序一段时间后,程序突然卡在了malloc和free函数里的while循环里,跳不出来,这种情况是不是由于内存溢出的情况,还是逻辑上的问题?
/*  MALLOC - Allocate a packet of a given size, and return pointer to it.    */
void *malloc(size_t size)
    memsz_t allocsize;
    PACKET *current, *next, *prev;
    if (check_alloc_size(size) == 0) return 0;
    allocsize = (memsz_t)size;
    if (allocsize == 0) return 0;
    /* We may need to adjust the size of the allocation request to ensure    */
    /* that the address of the field "next_free" remains strictly aligned    */
    /* in all packets on the free list.      */
    if ((allocsize ^ OVERHEAD) & 1) ++allocsize;
    _lock();
    if (first_call) minit();
    current = sys_free;
    prev = 0;
    /* Find the first block large enough to hold the requested allocation    */
    while (current != LIMIT && -current->packet_size < allocsize)
prev = current;
current = current->next_free;
    if (current == LIMIT)
        /* No block large enough was found, so return NULL.      */
_unlock();
return 0;
    if (-current->packet_size > (allocsize + OVERHEAD + MINSIZE))
        /* The packet is larger than needed; split the block and mark the    */
        /* smaller-addressed block as used.  The smaller-addressed block     */
        /* was chosen as a way to ensure that freed blocks get recycled      */
        /* before allocations are made from the large original free block.   */
        /* However, this may tend to increase the length of the free list    */
        /* search for a large enough block.      */
        /* Knuth's algorithm 2.5a instead allocates the larger-addressed     */
        /* block to the user.  This tends to leave the largest free blocks   */
        /* at the beginning of the free list.  Knuth's 2.5a' uses a "rover"  */
        /* pointer to prevent small free blocks from being concentrated in   */
        /* any part of the list.      */
next = (PACKET *)((char *)current + allocsize + OVERHEAD);
next->packet_size=current->packet_size+allocsize+OVERHEAD;/*NEG==FREE*/
#ifdef DEBUG
next->guard = GUARDWORD;
#endif
current->packet_size = allocsize; /* POSITIVE==IN USE */
if (prev) prev->next_free = next;
else      sys_free        = next;
next->next_free = current->next_free;
    else
        /* Allocate the whole block and remove it from the free list.      */
if (prev) prev->next_free = current->next_free;
else      sys_free        = current->next_free;
current->packet_size = -current->packet_size; /* POSITIVE==IN USE */
    _unlock();
    return &(current->next_free);
/*  FREE - Return a packet allocated by malloc to free memory pool.      */
void free(void *userptr)
    PACKET *sysblock, *next, *prev;
    if (userptr == 0) return; /* HANDLE NULL POINTER */
    _lock();
    next = sys_free;
    prev = 0;
    sysblock = (PACKET *)((char *)userptr - OVERHEAD);
    /* Search the free list for the *free* packets physically closest to     */
    /* the packet to be freed.  PREV is the closest free packet with a      */
    /* smaller address, and NEXT is the closest free packet with a larger    */
    /* address.      */
    while (next < sysblock)
prev = next;
next = next->next_free;
    /* Coallesce with next block if possible.      */
    if ((char *)sysblock + sysblock->packet_size + OVERHEAD == (char *)next)
sysblock->next_free = next->next_free;
sysblock->packet_size += -next->packet_size + OVERHEAD; /* POS==USED */
#ifdef DEBUG
next->guard = 0;
#endif
    else sysblock->next_free = next; /* START TO PUT INTO LIST */
    if (prev) /* ARE WE THE NEW HEAD OF THE LIST */
        /* sysblock is not the head of the free list; try to coallesce with  */
        /* prev      */
if ((char *)prev - prev->packet_size + OVERHEAD == (char *)sysblock)
    prev->next_free = sysblock->next_free;
    prev->packet_size += -sysblock->packet_size - OVERHEAD;/*NEG==FREE*/
#ifdef DEBUG
    sysblock->guard = 0;
#endif
else
    prev->next_free = sysblock;
    sysblock->packet_size = -sysblock->packet_size; /* NEGATIVE==FREE */
    else
sys_free = sysblock;
    _unlock();
