尊敬的TI工程师你们好,我现在想把两个基于SYS/BIOS的工程合并,其中一个是双核的PCIE采集信号程序,另一个是单核网口程序。我把网口程序复制进PCIE程序后编译不通过,几乎所有网口程序中调用的函数都出现了Unresolved symbol错误,请问这是什么原因?两个工程单独运行时都没问题。
您好,这是我报的错误:
#10010 errors encountered during linking; "xcorr_ipc_project_pcie.out" not built xcorr_ipc_project_pcie C/C++ Problem
<a href="file:/C:/ti/ccsv5/tools/compiler/dmed/HTML/10234.html">#10234-D</a> unresolved symbols remain xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_get_info, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_get_coreid, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_init, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_get_switch_state, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_uart_init, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_led, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_write, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_uart_set_baudrate, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol qmssLObj, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_write_configure, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol NDK_setsockopt, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Pa_create, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Pa_downloadImage, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Pa_getBufferReq, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Pa_resetControl, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Qmss_init, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Qmss_insertMemoryRegion, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Qmss_queueClose, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Qmss_start, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol TaskSleep, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol _oscfg, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol fdClose, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol fdError, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol inet_addr, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol mmZeroInit, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol platform_delay, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_channelEnable, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_channelClose, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Convert_CoreLocal2GlobalAddr, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol CfgNew, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_rxChannelOpen, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_open, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_initDescriptor, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_init, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol DaemonNew, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol DaemonFree, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_txChannelOpen, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol Cppi_setCpdmaLoopback, first referenced in ./src/resourcemgr.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol NDK_send, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol NC_SystemOpen, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol NC_SystemClose, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol NC_NetStart, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol CfgAddEntry, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
unresolved symbol CfgFree, first referenced in ./main.obj xcorr_ipc_project_pcie C/C++ Problem
