在TRM文档里有说明。
11.2.4.13 DISPC LCD Outputs
The LCD1, LCD2, LCD3 output paths consist of several processing blocks (see Figure 11-73):
• Overlay manager
• Gamma correction unit
• Color phase rotation (CPR) block, also used for RGB-to-YUV color space conversion (CSC)
• Active matrix dithering with TDM
• BT.656
• BT.1120
• Synchronization buffer
• Timing generator www.ti.com/.../spruhz6j.pdf
