gv7601解码视频输入DM8127导致出错
硬件平台:1080p SDI视频 --> gv7601 --> dm8127 vin0[15:0]
软件平台:ipnc rdk3.5
问题:
1)系统启动变慢。如果在dm8127上电的同时也有SDI视频信号输入,会导致a8核的linux启动很慢。从Starting udev开始变慢,由下图可以看到这个地方卡了大概55秒,系统最后的启动花了180秒。上电启动过程如果把SDI视频断开,那么启动过程正常,只需要二十多秒。
2)系统启动以后,可以正确收到视频几十帧左右,然后就接不到视频了,从打印信息看是m3vpss这个核的程序崩溃了。
请问专家这是什么原因!
  • 你好,
    没有看到你贴的图。
    具体m3vpss有报什么错误么?log能贴一下么?
  • m3vpss没有报错,是我自己加的打印图像接收的信息中断了。 [m3vpss ] CaptureLink_getFullFrames: Utils_bufGetFull() status = 0
    [m3vpss ] DupLink_drvProcessFrames() : numFrames = 1 表示可以收到图像,而且如果把图像保存下来验证,解码确实是正确的。但是过一会以后,接收就中断了。
    打印信息如下,接收中断的地方用红色标出来了:
    [host]
    Application Run Completed
    after App_runDemo()
    [m3vpss ] CaptureLink_drvProcessData: pObj->captureDequeuedFrameCount =  0 !!!
    [m3vpss ]  71033: CAPTURE: Fields = 0 (fps = 0), Total Resets = 0 (Avg 0 ms per reset)
    [m3video]  Channel:0 inputframerate:50 targetfps:60
    [m3vpss ] DupLink_drvProcessFrames() : Entering ...
    [host] ITT server task running !!!
    [host]
    ITT ittServer_run
    [host] ITT Server Message initialization successful
    [host]
    ITT capture task created
    [host] DCC server Message ques is open succefully
    [host] Setting cmd <1> in message <40485100>
    [host] Posting message <40485100> in QId <20002>
    [host] Response from M3 is : 1
    [m3vpss ] Command 1 recived from HOST A8
    Entering XFD_B_A_uartTxd()
    res=51
    Txd :  9f  e4  2  3  4  5  6  7  8  9  a  b  c  d  e  f  10  11  12  13  14  15  16  17  18  19  1a  1b  1c  1d  1e  1f  20  21  22  23  24  25  26  27  28  29  2a  2b  2c  2d  2e  2f  30  31  83
    End of XFD_B_A_uartTxd()
    [m3vpss ] Command 2 recived from HOST A8
    [m3vpss ] New DCC data of size <33603>
    [m3vpss ] Call to VNF_LINK_CMD_UPDATE_DCC -1
    [host] Default parameters were sent sucessfully
    [host] Server Socket created with ID <23>
    [host] App_ipcBitsRecvStreamFxn(): Closing file [/opt/encFile.h264] for writing !!!  [m3vpss ] DupLink_drvProcessFrames() : Entering ...
    ApproDrvExit: 7
    Error: WaitStreamReady Fail.
    Error: SemWait: Invalid Semaphore handler
    Error: SemRelease: Invalid Semaphore handler
    [host]
    Force IDR on Channel: 0
    [host]
    Force IDR on Channel: 1 [m3vpss ] DupLink_drvProcessFrames() : Entering ...
    [host] MCFW_IPCBITS: Callback function:App_ipcBitsInCbFxn
    [host] MCFW_IPCBITS:App_ipcBitsRecvStreamFxn:INFO: periodic print.. [m3vpss ] DupLink_drvProcessFrames() : Entering ...
    SystemInit success
    Schedule manager init success
    Dmva Schedule manager init success
    umount: can't umount /mnt/mmc: Invalid argument
    StartNetwork(): entering ...
    StartNetwork() 334: gPlatform = 1
    StartNetwork() 336: dhcp = 0
    StartNetwork() 337: before SetDhcpEnable() ...
    SetDhcpEnable() 1615: entering
    SetDhcpEnable() 1616: enable =  0
    SetDhcpEnable() 1618: enable =  0
    SetDhcpEnable(): before net_disable_dhcpcd() ..
    net_config.c(): before killall -9
    before killall -9
    before killall -9 ...
    killall: dhcpcd: no process killed
    net_disable_dhcpcd(): before rm /var/run/dhcpcd-eth0.pid
    res=51
    rm: cannot remove '/var/run/dhcpcd-eth0.pid': No such file or directory
    net_disable_dhcpcd(): after rm /var/run/dhcpcd-eth0.pid
    SetDhcpEnable(): after net_disable_dhcpcd() ..
     net_search_gateway:eth0, FDA8C0, 0, 1
    dns=192.168.253.1
    WriteConfigFile 2678: before net_get_netmask(ETH_NAME)
    net_get_netmask 275: sys_server
    net_get_netmask 276: before ioctl(skfd, SIOCGIFNETMASK)
    net_search_gateway:eth0, 0, FEFDA8C0, 3
    dns=192.168.253.1
    res=51
    [host] Before Device_Gv7601RegRead() ...
    [host] spidev_read16_multi(): status = 0
    [host] ////************ regValue_current **************////
    [host] regAddr: 0x  0   regValue: 0x   0
    [host] regAddr: 0x  8   regValue: 0x 820
    [host] regAddr: 0x  9   regValue: 0x1883
    [host] regAddr: 0x  a   regValue: 0x   0
    [host] regAddr: 0x  b   regValue: 0x   0
    [host] regAddr: 0x  c   regValue: 0x   0
    [host] regAddr: 0x  2   regValue: 0x   0
    [host] regAddr: 0x  4   regValue: 0x   0
    [host] regAddr: 0x  5   regValue: 0x4210
    [host] regAddr: 0x  6   regValue: 0x d66
    [host] regAddr: 0x 22   regValue: 0x1438
    [host] regAddr: 0x 23   regValue: 0x   3
    [host] regAddr: 0x 24   regValue: 0x   6
    [host] regAddr: 0x 25   regValue: 0x  21
    [host] regAddr: 0x 26   regValue: 0x   0
    [host] regAddr: 0x 37   regValue: 0x   0
    [host] regAddr: 0x 39   regValue: 0x   0
    [host]
    [host] leaving Device_gv7601Control ...
    [host]
    Usecase is Active !!!
  • 你好,
    你好像加了很多的打印,能否去掉大部分后,看看?
