DDR初始化不成功导致掉仿真器
我不加GEL(不做DDR初始化),可以正常连接器仿真器,但是加上GEL后,DDR3出事化不过,会导致仿真器掉了,哪位高手指点一下,不胜感激!!!
C66xx_1: GEL Output: Setup_Memory_Map...
C66xx_1: GEL Output: Setup_Memory_Map... Done.
Connecting Target...
C66xx_1: GEL Output: DSP core #1
C66xx_1: GEL Output: C6678L GEL file Ver is 2.002
C66xx_1: GEL Output: Global Default Setup...
C66xx_1: GEL Output: Setup Cache...
C66xx_1: GEL Output: L1P = 32K
C66xx_1: GEL Output: L1D = 32K
C66xx_1: GEL Output: L2 = ALL SRAM
C66xx_1: GEL Output: Setup Cache... Done.
C66xx_1: GEL Output: Global Default Setup... Done.
C66xx_1: GEL Output: Invalidate All Cache...
C66xx_1: GEL Output: Invalidate All Cache... Done.
C66xx_1: GEL Output: GEL Reset...
C66xx_1: GEL Output: GEL Reset... Done.
C66xx_0: GEL Output:
C66xx_0: GEL Output: DSP core #0
C66xx_0: GEL Output: C6678L GEL file Ver is 2.002
C66xx_0: GEL Output: Global Default Setup...
C66xx_0: GEL Output: Setup Cache...
C66xx_0: GEL Output: L1P = 32K
C66xx_0: GEL Output: L1D = 32K
C66xx_0: GEL Output: L2 = ALL SRAM
C66xx_0: GEL Output: Setup Cache... Done.
C66xx_0: GEL Output: Main PLL (PLL1) Setup ...
C66xx_0: GEL Output: PLL in Bypass ...
C66xx_0: GEL Output: PLL1 Setup for DSP @ 1000.0 MHz.
C66xx_0: GEL Output: SYSCLK2 = 333.3333 MHz, SYSCLK5 = 200.0 MHz.
C66xx_0: GEL Output: SYSCLK8 = 15.625 MHz.
C66xx_0: GEL Output: PLL1 Setup... Done.
C66xx_0: GEL Output: Power on all PSC modules and DSP domains...
C66xx_0: GEL Output: Security Accelerator disabled!
C66xx_0: GEL Output: Power on all PSC modules and DSP domains... Done.
C66xx_0: GEL Output: PA PLL (PLL3) Setup ...
C66xx_0: GEL Output: PA PLL Setup... Done.
C66xx_0: GEL Output: DDR3 PLL (PLL2) Setup ...
C66xx_0: GEL Output: DDR3 PLL Setup... Done.
C66xx_0: GEL Output: DDR begin (1333 auto)
C66xx_0: GEL Output: XMC Setup ... Done
C66xx_0: Trouble Reading Memory Block at 0x210000e4 on Page 0 of Length 0x4: (Error -1178 @ 0x210000E4) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
C66xx_0: GEL: Error while executing OnTargetConnect(): target access failed at (*((unsigned int *) (0x21000000+0x000000E4))&=~(0x00008000)) [evmc6678l_cgs.gel:261] at ddr3_setup_auto_lvl_1333(0) [evmc6678l_cgs.gel:879] at Global_Default_Setup_Silent() [evmc6678l_cgs.gel:577] at OnTargetConnect() .
C66xx_0: Trouble Reading Register ControlRegisters_CSR: (Error -1178 @ 0x41) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
C66xx_0: Trouble Reading Memory Block at 0x80000000 on Page 0 of Length 0x348: (Error -1178 @ 0x80000000) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
C66xx_0: Trouble Reading Memory Block at 0x1840020 on Page 0 of Length 0x4: (Error -1178 @ 0x1840020) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
C66xx_0: Trouble Reading Memory Block at 0x1840040 on Page 0 of Length 0x4: (Error -1178 @ 0x1840040) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
C66xx_0: Trouble Reading Memory Block at 0x1840000 on Page 0 of Length 0x4: (Error -1178 @ 0x1840000) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
C66xx_0: Trouble Reading Register ControlRegisters_DNUM: (Error -1178 @ 0x50) Device functional clock appears to be off. Power-cycle the board. If error persists, confirm configuration and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.747.0)
