Please install the C6000v7.6 compiler
See details below.
Error: Import failed for project 'Test_SRIO' because its compiler definition is not available. Please install the C6000v7.6 compiler before importing this project - click 'View > CCS App Center' to check if compiler updates are available, or install the compiler manually and register it with CCS through 'Preferences > CCS > Build > Compilers'
重新安装了许多次,也在CCS里选择了update,在TI官网搜索了complier,但根本没有7.6的版本。
求助
