在对程序进行疲劳测试时,编译器总是很频繁的出现以下错误:
674X_0: Error: (Error -183 @ 0x0) The controller has detected a cable break far-from itself. The user must connect the cable/pod to the target. (Emulation package 5.1.232.0)
C674X_0: JTAG Communication Error
C674X_0: Failed to remove the debug state from the target before disconnecting. There may still be breakpoint op-codes embedded in program memory. It is recommended that you
reset the emulator before you connect and reload your program before you continue debugging
C674X_0: Power Failure on Target CPU
请问是我仿真器的问题,还是程序内存的问题,用的是XDS200ISO仿真器
