有关6678以太网 编译报错
大家好 问一下
编译6678下的K1_STK_v1.1\GE 有报错
提示如下:
error #10056: symbol "vectors" redefined: first defined in "./common/INT_vectors.obj"; redefined in "./src/GE_vectors.obj"
"../KeyStone.cmd", line 21: error #10099-D: program will not fit into available memory. placement with alignment fails for section "vecs" size 0x400 .
Available memory ranges:
VECTORS size: 0x200 unused: 0x200 max hole: 0x200
error #10010: errors encountered during linking; "SGMI_6678.out" not built
这个错误是如何引起的???
