DM8127 -V3.8版本,接两路sensor,25帧,1080p。分别经过缩放,抽帧,输出一路15帧720p,一路12帧,D1。
接rtsp流,用VLC播放卡顿延时;
另外,不抽帧,25帧输出,rtsp流用VLC播放则不卡顿,目前该怎么定位和改善问题,请各位不吝赐教。
你好,
你可以尝试调整一下VLC的缓冲时间,具体方法见下:
Launch VLC and open Tools > Preferences or press the keyboard shortcut (Ctrl + P). At the bottom-left of the Settings window click the All bullet to display additional settings. Now scroll down to Stream Output and change the caching to a larger number. It's 1500 milliseconds by default which is equal to 1.5 seconds
