* @file loopbackDioIsr.c
* @brief
* This is an example application which shows how DIO transfer
* completion interrupts can be registered and serviced.
* \par
* NOTE:
* (C) Copyright 2010-2012 Texas Instruments, Inc.
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
* \par
#include <xdc/std.h>
#include <string.h>
#include <c6x.h>
#include <xdc/runtime/IHeap.h>
#include <xdc/runtime/System.h>
#include <xdc/runtime/Error.h>
#include <xdc/runtime/Memory.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
#include <ti/sysbios/heaps/HeapBuf.h>
#include <ti/sysbios/heaps/HeapMem.h>
#include <ti/sysbios/family/c64p/Hwi.h>
#include <ti/sysbios/family/c64p/EventCombiner.h>
#include <ti/sysbios/family/c66/tci66xx/CpIntc.h>
/* IPC includes */
#include <ti/ipc/GateMP.h>
#include <ti/ipc/Ipc.h>
#include <ti/ipc/ListMP.h>
#include <ti/ipc/SharedRegion.h>
#include <ti/ipc/MultiProc.h>
#include <xdc/cfg/global.h>
/* SRIO Driver Include File. */
#include <ti/drv/srio/srio_drv.h>
#include <ti/drv/srio/srio_osal.h>
/* CPPI/QMSS Include Files. */
#include <ti/drv/cppi/cppi_drv.h>
#include <ti/drv/qmss/qmss_drv.h>
#include <ti/drv/qmss/qmss_firmware.h>
/* CSL Chip Functional Layer */
#include <ti/csl/csl_chip.h>
/* CSL Cache Functional Layer */
#include <ti/csl/csl_cacheAux.h>
/* PSC CSL Include Files */
#include <ti/csl/csl_psc.h>
#include <ti/csl/csl_pscAux.h>
/* CSL SRIO Functional Layer */
#include <ti/csl/csl_srio.h>
#include <ti/csl/csl_srioAux.h>
/* CSL CPINTC Include Files. */
#include<ti/csl/csl_cpIntc.h>
************************** LOCAL Definitions *************************
/* This is the Number of host descriptors which are available & configured
* in the memory region for this example. */
#define NUM_HOST_DESC 128
/* This is the size of each descriptor. */
#define SIZE_HOST_DESC 48
/* MTU of the SRIO Driver. We are currently operating @ MTU of 256 bytes. */
#define SRIO_MAX_MTU 256
/* This is the size of the data buffer which is used for DIO Sockets. */
#define SIZE_DIO_PACKET 128
/* Defines the core number responsible for system initialization. */
#define CORE_SYS_INIT 0
/* Defines number of DIO sockets used in this example */
#define SRIO_DIO_LSU_ISR_NUM_SOCKETS 3
/* Defines number of transfers done by DIO sockets in this example */
#define SRIO_DIO_LSU_ISR_NUM_TRANSFERS 3
/* ISR timeout value (in cycles) used in this example */
#define SRIO_DIO_LSU_ISR_TIMEOUT 100000
************************** Global Variables **************************
/* Memory allocated for the descriptors. This is 16 bit aligned. */
#pragma DATA_ALIGN (host_region, 16)
Uint8 host_region[NUM_HOST_DESC * SIZE_HOST_DESC];
/* Memory used for the accumulator list. */
#pragma DATA_ALIGN (gHiPriAccumList, 16)
UInt32 gHiPriAccumList[64];
/* Global SRIO and QMSS Configuration */
Qmss_InitCfg qmssInitConfig;
/* Global Varialble which keeps track of the core number executing the
* application. */
UInt32 coreNum = 0xFFFF;
/* Shared Memory Variable to ensure synchronizing SRIO initialization
* with all the other cores. */
/* Created an array to pad the cache line with SRIO_MAX_CACHE_ALIGN size */
#pragma DATA_ALIGN (isSRIOInitialized, 128)
#pragma DATA_SECTION (isSRIOInitialized, ".srioSharedMem");
volatile Uint32 isSRIOInitialized[(SRIO_MAX_CACHE_ALIGN / sizeof(Uint32))] = { 0 };
Srio_DrvHandle hDrvManagedSrioDrv;
CSL_SrioHandle hSrioCSL;
/* These are the device identifiers used in the Example Application */
const uint32_t DEVICE_ID1_16BIT = 0xBEEF;
const uint32_t DEVICE_ID1_8BIT = 0xAB;
const uint32_t DEVICE_ID2_16BIT = 0x4560;
const uint32_t DEVICE_ID2_8BIT = 0xCD;
const uint32_t DEVICE_ID3_16BIT = 0x1234;
const uint32_t DEVICE_ID3_8BIT = 0x12;
const uint32_t DEVICE_ID4_16BIT = 0x5678;
const uint32_t DEVICE_ID4_8BIT = 0x56;
/* Array containing SRIO socket handles */
Srio_SockHandle srioSocket[SRIO_DIO_LSU_ISR_NUM_SOCKETS];
/* Source and Destination Data Buffers (payload buffers) */
UInt8* srcDataBuffer[SRIO_DIO_LSU_ISR_NUM_SOCKETS * SRIO_DIO_LSU_ISR_NUM_TRANSFERS];
UInt8* dstDataBuffer[SRIO_DIO_LSU_ISR_NUM_SOCKETS * SRIO_DIO_LSU_ISR_NUM_TRANSFERS];
/* Global debug variable to track number of ISRs raised */
volatile UInt32 srioDbgDioIsrCnt = 0;
/* Global variable to indicate completion of ISR processing */
volatile UInt32 srioLsuIsrServiced = 0;
/* Global variables to count good and bad transfers */
volatile UInt32 srioDioLsuGoodTransfers = 0;
volatile UInt32 srioDioLsuBadTransfers = 0;
************************* Extern Definitions *************************
extern UInt32 malloc_counter;
extern UInt32 free_counter;
extern int32_t SrioDevice_init (void);
/* QMSS device specific configuration */
extern Qmss_GlobalConfigParams qmssGblCfgParams;
/* CPPI device specific configuration */
extern Cppi_GlobalConfigParams cppiGblCfgParams;
/* OSAL Data Buffer Memory Initialization. */
extern int32_t Osal_dataBufferInitMemory(uint32_t dataBufferSize);
/* Enable Time Stamp Counter */
extern void CSL_tscEnable(void);
************************ SRIO EXAMPLE FUNCTIONS **********************
* @b Description
* @n
* Utility function which converts a local address to global.
* @param[in] addr
* Local address to be converted
* @retval
* Global Address
static UInt32 l2_global_address (Uint32 addr)
UInt32 corenum;
/* Get the core number. */
corenum = CSL_chipReadReg(CSL_CHIP_DNUM);
/* Compute the global address. */
return (addr + (0x10000000 + (corenum*0x1000000)));
* @b Description
* @n
* Utility function that is required by the IPC module to set the proc Id.
* The proc Id is set via this function instead of hard coding it in the .cfg file
* @retval
* Not Applicable.
Void myStartupFxn (Void)
MultiProc_setLocalId (CSL_chipReadReg (CSL_CHIP_DNUM));
* @b Description
* @n
* This function enables the power/clock domains for SRIO.
* @retval
* Not Applicable.
static Int32 enable_srio (void)
#ifndef SIMULATOR_SUPPORT
/* SRIO power domain is turned OFF by default. It needs to be turned on before doing any
* SRIO device register access. This not required for the simulator. */
/* Set SRIO Power domain to ON */
CSL_PSC_enablePowerDomain (CSL_PSC_PD_SRIO);
/* Enable the clocks too for SRIO */
CSL_PSC_setModuleNextState (CSL_PSC_LPSC_SRIO, PSC_MODSTATE_ENABLE);
/* Start the state transition */
CSL_PSC_startStateTransition (CSL_PSC_PD_SRIO);
/* Wait until the state transition process is completed. */
while (!CSL_PSC_isStateTransitionDone (CSL_PSC_PD_SRIO));
/* Return SRIO PSC status */
if ((CSL_PSC_getPowerDomainState(CSL_PSC_PD_SRIO) == PSC_PDSTATE_ON) &&
(CSL_PSC_getModuleState (CSL_PSC_LPSC_SRIO) == PSC_MODSTATE_ENABLE))
/* SRIO ON. Ready for use */
return 0;
else
/* SRIO Power on failed. Return error */
return -1;
#else
/* PSC is not supported on simulator. Return success always */
return 0;
#endif
* @b Description
* @n
* This function is application registered SRIO DIO LSU interrupt
* handler (ISR) which is used to process the pending DIO Interrupts.
* SRIO Driver users need to ensure that this ISR is plugged with
* their OS Interrupt Management API. The function expects the
* Interrupt Destination information to be passed along to the
* API because the DIO interrupt destination mapping is configurable
* during SRIO device initialization.
* @param[in] argument
* SRIO Driver Handle
* @retval
* Not Applicable
static void myDioTxCompletionIsr
UArg argument
/* Pass the control to the driver DIO Tx Completion ISR handler */
Srio_dioTxCompletionIsr ((Srio_DrvHandle)argument, hSrioCSL);
/* Wake up the pending task */
srioLsuIsrServiced = 1;
/* Debug: Increment the ISR count */
srioDbgDioIsrCnt++;
return;
* @b Description
* @n
* The function demonstrates usage of interrupts to indicate
* the end of DIO transfers
* @param[in] hSrioDrv
* Handle to the SRIO driver
* @retval
* Success - 0
* @retval
* Error - <0
static Int32 dioSocketsWithISR (Srio_DrvHandle hSrioDrv, uint8_t dio_ftype, uint8_t dio_ttype)
Srio_SockBindAddrInfo bindInfo;
Srio_SockAddrInfo to;
uint16_t sockIdx, i;
uint16_t counter, srcDstBufIdx = 0;
int32_t eventId, startTime;
UInt8 **srcDataBufPtr = NULL, **dstDataBufPtr = NULL;
uint8_t compCode;
System_printf ("*************************************************************\n");
System_printf ("******* DIO Socket Example with Interrupts (Core %d) ********\n", coreNum);
/* Get the CSL SRIO Handle. */
hSrioCSL = CSL_SRIO_Open (0);
if (hSrioCSL == NULL)
return -1;
/* SRIO DIO Interrupts need to be routed from the CPINTC0 to GEM Event.
* - We have configured DIO Interrupts to get routed to Interrupt Destination 0
* (Refer to the CSL_SRIO_RouteLSUInterrupts API configuration in the SRIO Initialization)
* - We want this System Interrupt to mapped to Host Interrupt 8 */
/* Disable Interrupt Pacing for INTDST0 */
CSL_SRIO_DisableInterruptPacing (hSrioCSL, 0);
/* Route LSU0 ICR0 to INTDST0 */
CSL_SRIO_RouteLSUInterrupts (hSrioCSL, 0, 0);
/* Route LSU0 ICR1 to INTDST0 */
CSL_SRIO_RouteLSUInterrupts (hSrioCSL, 1, 0);
/* Route LSU0 ICR2 to INTDST0 */
CSL_SRIO_RouteLSUInterrupts (hSrioCSL, 2, 0);
/* Map the System Interrupt i.e. the Interrupt Destination 0 interrupt to the DIO ISR Handler. */
CpIntc_dispatchPlug(CSL_INTC0_INTDST0, (CpIntc_FuncPtr)myDioTxCompletionIsr, (UArg)hSrioDrv, TRUE);
/* The configuration is for CPINTC0. We map system interrupt 112 to Host Interrupt 8. */
CpIntc_mapSysIntToHostInt(0, CSL_INTC0_INTDST0, 8);
/* Enable the Host Interrupt. */
CpIntc_enableHostInt(0, 8);
/* Enable the System Interrupt */
CpIntc_enableSysInt(0, CSL_INTC0_INTDST0);
/* Get the event id associated with the host interrupt. */
eventId = CpIntc_getEventId(8);
/* Plug the CPINTC Dispatcher. */
EventCombiner_dispatchPlug (eventId, CpIntc_dispatch, 8, TRUE);
for (sockIdx = 0; sockIdx < SRIO_DIO_LSU_ISR_NUM_SOCKETS; sockIdx++)
/* Open DIO SRIO Non-Blocking Socket */
srioSocket[sockIdx] = Srio_sockOpen (hSrioDrv, Srio_SocketType_DIO, FALSE);
if (srioSocket[sockIdx] == NULL)
System_printf ("Error: Unable to open the DIO socket - %d\n", sockIdx);
return -1;
/* DIO Binding Information: Use 16 bit identifiers and we are bound to the first source id.
* and we are using 16 bit device identifiers. */
bindInfo.dio.doorbellValid = 0;
bindInfo.dio.intrRequest = 1;
bindInfo.dio.supInt = 0;
bindInfo.dio.xambs = 0;
bindInfo.dio.priority = 0;
bindInfo.dio.outPortID = 0;
bindInfo.dio.idSize = 1;
bindInfo.dio.srcIDMap = sockIdx;
bindInfo.dio.hopCount = 0;
bindInfo.dio.doorbellReg = 0;
bindInfo.dio.doorbellBit = 0;
/* Bind the SRIO socket: DIO sockets do not need any binding information. */
if (Srio_sockBind_DIO (srioSocket[sockIdx], &bindInfo) < 0)
System_printf ("Error: Binding the SIO socket failed.\n");
return -1;
/* Allocate memory for the Source and Destination Buffers */
for (i = 0; i < (SRIO_DIO_LSU_ISR_NUM_SOCKETS * SRIO_DIO_LSU_ISR_NUM_TRANSFERS); i++)
srcDataBuffer[i] = (uint8_t*)Osal_srioDataBufferMalloc(SIZE_DIO_PACKET);
if (srcDataBuffer[i] == NULL)
System_printf ("Error: Source Buffer (%d) Memory Allocation Failed\n", i);
return -1;
dstDataBuffer[i] = (uint8_t*)Osal_srioDataBufferMalloc(SIZE_DIO_PACKET);
if (dstDataBuffer[i] == NULL)
System_printf ("Error: Destination Buffer (%d) Memory Allocation Failed\n", i);
return -1;
/* Initialize the data buffers */
for (counter = 0; counter < SIZE_DIO_PACKET; counter++)
srcDataBuffer[i][counter] = 0x30 + (i * 5);
dstDataBuffer[i][counter] = 0;
/* Debug Message: */
System_printf ("Debug(Core %d): Starting the DIO Data Transfer - Src(%d) 0x%p Dst(%d) 0x%p\n",
coreNum, i, srcDataBuffer[i], i, dstDataBuffer[i]);
if ((dio_ftype == Srio_Ftype_WRITE) && (dio_ttype == Srio_Ttype_Write_NWRITE_R))
/* DIO Write operation */
srcDataBufPtr = &srcDataBuffer[0];
dstDataBufPtr = &dstDataBuffer[0];
else if ((dio_ftype == Srio_Ftype_REQUEST) && (dio_ttype == Srio_Ttype_Request_NREAD))
/* DIO Read operation */
srcDataBufPtr = &dstDataBuffer[0];
dstDataBufPtr = &srcDataBuffer[0];
else
System_printf ("Debug(Core %d): Unexpected combination of FTYPE and TTYPE. Example couldn't run. Exiting!!!\n",
coreNum);
return -1;
* Run multiple iterations of the example to ensure multiple data transfers work
for (counter = 0; counter < SRIO_DIO_LSU_ISR_NUM_TRANSFERS; counter++)
/* Populate the DIO Address Information where the data is to be sent. */
to.dio.rapidIOMSB = 0x0;
to.dio.rapidIOLSB = (uint32_t)&dstDataBufPtr[srcDstBufIdx][0];
to.dio.dstID = DEVICE_ID2_16BIT;
to.dio.ttype = dio_ttype;
to.dio.ftype = dio_ftype;
/* Send the DIO Information. */
if (Srio_sockSend_DIO (srioSocket[sockIdx], srcDataBufPtr[srcDstBufIdx], SIZE_DIO_PACKET, (Srio_SockAddrInfo*)&to) < 0)
System_printf ("Debug(Core %d): DIO Socket Example Failed\n", coreNum);
return -1;
/* Wait for the interrupt to occur without touching the peripheral. */
/* Other useful work could be done here such as by invoking a scheduler */
startTime = TSCL;
while((! srioLsuIsrServiced) && ((TSCL - startTime) < SRIO_DIO_LSU_ISR_TIMEOUT));
if (! srioLsuIsrServiced) {
System_printf ("ISR didn't happen within set time - %d cycles. Example failed !!!\n", SRIO_DIO_LSU_ISR_TIMEOUT);
return -1;
/* Debug Message: Data Transfer was completed successfully. */
System_printf ("Debug(Core %d): DIO Socket (%d) Send for iteration %d\n", coreNum, sockIdx, counter);
/* Read the completion code filled by the ISR */
compCode = 0xFF;
if (Srio_getSockOpt(srioSocket[sockIdx], Srio_Opt_DIO_READ_SOCK_COMP_CODE, &compCode, sizeof(uint8_t)) < 0)
System_printf ("Error: Unable to read the completion code in socket\n");
return -1;
/* Was the transfer good. */
if (compCode == 0)
srioDioLsuGoodTransfers++;
else
srioDioLsuBadTransfers++;
/* Clear the LSU pending interrupt (ICCx) */
CSL_SRIO_ClearLSUPendingInterrupt (hSrioCSL, 0xFFFFFFFF, 0xFFFFFFFF);
/* Debug Message: Display ISR count */
System_printf ("Debug(Core %d): ISR Count: %d\n", coreNum, srioDbgDioIsrCnt);
/* Load next set of payload buffers */
srcDstBufIdx++;
if (srcDstBufIdx > (SRIO_DIO_LSU_ISR_NUM_SOCKETS * SRIO_DIO_LSU_ISR_NUM_TRANSFERS))
System_printf ("Debug(Core %d): DIO Socket Example --- Out of SRC and DST buffers\n", coreNum);
return -1;
/* Validate the received buffer. */
if (dstDataBufPtr[i][counter] != srcDataBufPtr[i][counter])
System_printf ("Error(Core %d): Data Validation error. Buffer Number (%d): Expected 0x%x got 0x%x @ index %d\n",
coreNum, i, srcDataBufPtr[i][counter], dstDataBufPtr[i][counter], counter);
return -1;
/* Debug Message: Print error counters */
System_printf ("Debug(Core %d): Transfer Completion without Errors - %d\n", coreNum, srioDioLsuGoodTransfers);
System_printf ("Debug(Core %d): Transfer Completion with Errors - %d\n", coreNum, srioDioLsuBadTransfers);
/* Cleanup the source & destination buffers. */
for (srcDstBufIdx = 0; srcDstBufIdx < (SRIO_DIO_LSU_ISR_NUM_SOCKETS * SRIO_DIO_LSU_ISR_NUM_TRANSFERS); srcDstBufIdx++)
Osal_srioDataBufferFree ((Void*)srcDataBufPtr[srcDstBufIdx], SIZE_DIO_PACKET);
Osal_srioDataBufferFree ((Void*)dstDataBufPtr[srcDstBufIdx], SIZE_DIO_PACKET);
/* Close the sockets */
Srio_sockClose_DIO (srioSocket[sockIdx]);
if (srioDioLsuBadTransfers > 0)
System_printf ("Debug(Core %d): DIO Transfer Data NOT completed successfully !!! \n", coreNum);
return -1;
/* Debug Message: Data was validated */
System_printf ("Debug(Core %d): DIO Transfer Data Validated for all iterations\n", coreNum);
/* Debug Message: Example completed */
System_printf ("Debug(Core %d): DIO Data Transfer (WRITE) with Interrupts Example Passed\n", coreNum);
System_printf ("Debug(Core %d): DIO Data Transfer (READ) with Interrupts Example Passed\n", coreNum);
return 0;
* @b Description
* @n
* System Initialization Code. This is added here only for illustrative
* purposes and needs to be invoked once during initialization at
* system startup.
* @retval
* Success - 0
* @retval
* Error - <0
static Int32 system_init (Void)
Int32 result;
Qmss_MemRegInfo memRegInfo;
/* Initialize the QMSS Configuration block. */
memset (&qmssInitConfig, 0, sizeof (Qmss_InitCfg));
/* Initialize the Host Region. */
memset ((void *)&host_region, 0, sizeof(host_region));
/* Set up the linking RAM. Use the internal Linking RAM.
* LLD will configure the internal linking RAM address and maximum internal linking RAM size if
* a value of zero is specified. Linking RAM1 is not used */
qmssInitConfig.linkingRAM0Base = 0;
qmssInitConfig.linkingRAM0Size = 0;
qmssInitConfig.linkingRAM1Base = 0;
qmssInitConfig.maxDescNum = NUM_HOST_DESC;
#ifdef xdc_target__bigEndian
/* PDSP Configuration: Big Endian */
qmssInitConfig.pdspFirmware[0].pdspId = Qmss_PdspId_PDSP1;
qmssInitConfig.pdspFirmware[0].firmware = &acc48_be;
qmssInitConfig.pdspFirmware[0].size = sizeof (acc48_be);
#else
/* PDSP Configuration: Little Endian */
qmssInitConfig.pdspFirmware[0].firmware = &acc48_le;
qmssInitConfig.pdspFirmware[0].size = sizeof (acc48_le);
#endif
/* Initialize Queue Manager Sub System */
result = Qmss_init (&qmssInitConfig, &qmssGblCfgParams);
if (result != QMSS_SOK)
System_printf ("Error initializing Queue Manager SubSystem error code : %d\n", result);
return -1;
/* Start the QMSS. */
if (Qmss_start() != QMSS_SOK)
System_printf ("Error: Unable to start the QMSS\n");
return -1;
/* Memory Region 0 Configuration */
memRegInfo.descBase = (UInt32 *)l2_global_address((UInt32)host_region);
memRegInfo.descSize = SIZE_HOST_DESC;
memRegInfo.descNum = NUM_HOST_DESC;
memRegInfo.manageDescFlag = Qmss_ManageDesc_MANAGE_DESCRIPTOR;
memRegInfo.memRegion = Qmss_MemRegion_MEMORY_REGION_NOT_SPECIFIED;
/* Initialize and inset the memory region. */
result = Qmss_insertMemoryRegion (&memRegInfo);
if (result < QMSS_SOK)
System_printf ("Error inserting memory region: %d\n", result);
return -1;
/* Initialize CPPI CPDMA */
result = Cppi_init (&cppiGblCfgParams);
if (result != CPPI_SOK)
return -1;
/* CPPI and Queue Manager are initialized. */
System_printf ("Debug(Core %d): Queue Manager and CPPI are initialized.\n", coreNum);
System_printf ("Debug(Core %d): Host Region 0x%x\n", coreNum, host_region);
return 0;
* @b Description
* @n
* This is the main DIO Example Task
* @retval
* Not Applicable.
static Void dioExampleTask(UArg arg0, UArg arg1)
UInt8 isAllocated;
Srio_DrvConfig drvCfg;
/* Initialize the SRIO Driver Configuration. */
memset ((Void *)&drvCfg, 0, sizeof(Srio_DrvConfig));
/* Initialize the OSAL */
if (Osal_dataBufferInitMemory(SRIO_MAX_MTU) < 0)
System_printf ("Error: Unable to initialize the OSAL. \n");
return;
* The SRIO Driver Instance is going to be created with the following properties:
* - Driver Managed
* - Interrupt Support (Pass the Rx Completion Queue as NULL)
/* Setup the SRIO Driver Managed Configuration. */
drvCfg.bAppManagedConfig = FALSE;
/* Driver Managed: Receive Configuration */
drvCfg.u.drvManagedCfg.bIsRxCfgValid = 1;
drvCfg.u.drvManagedCfg.rxCfg.rxMemRegion = Qmss_MemRegion_MEMORY_REGION0;
drvCfg.u.drvManagedCfg.rxCfg.numRxBuffers = 4;
drvCfg.u.drvManagedCfg.rxCfg.rxMTU = SRIO_MAX_MTU;
/* Accumulator Configuration. */
int32_t coreToQueueSelector[4];
/* This is the table which maps the core to a specific receive queue. */
coreToQueueSelector[0] = 704;
coreToQueueSelector[1] = 705;
coreToQueueSelector[2] = 706;
coreToQueueSelector[3] = 707;
/* Since we are programming the accumulator we want this queue to be a HIGH PRIORITY Queue */
drvCfg.u.drvManagedCfg.rxCfg.rxCompletionQueue = Qmss_queueOpen (Qmss_QueueType_HIGH_PRIORITY_QUEUE,
coreToQueueSelector[coreNum], &isAllocated);
if (drvCfg.u.drvManagedCfg.rxCfg.rxCompletionQueue < 0)
System_printf ("Error: Unable to open the SRIO Receive Completion Queue\n");
return;
/* Accumulator Configuration is VALID. */
drvCfg.u.drvManagedCfg.rxCfg.bIsAccumlatorCfgValid = 1;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.channel = coreNum;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.command = Qmss_AccCmd_ENABLE_CHANNEL;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.queueEnMask = 0;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.queMgrIndex = coreToQueueSelector[coreNum];
drvCfg.u.drvManagedCfg.rxCfg.accCfg.maxPageEntries = 2;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.timerLoadCount = 0;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.interruptPacingMode = Qmss_AccPacingMode_LAST_INTERRUPT;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.listEntrySize = Qmss_AccEntrySize_REG_D;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.listCountMode = Qmss_AccCountMode_ENTRY_COUNT;
drvCfg.u.drvManagedCfg.rxCfg.accCfg.multiQueueMode = Qmss_AccQueueMode_SINGLE_QUEUE;
/* Initialize the accumulator list memory */
memset ((Void *)&gHiPriAccumList[0], 0, sizeof(gHiPriAccumList));
drvCfg.u.drvManagedCfg.rxCfg.accCfg.listAddress = l2_global_address((UInt32)&gHiPriAccumList[0]);
/* Driver Managed: Transmit Configuration */
drvCfg.u.drvManagedCfg.bIsTxCfgValid = 1;
drvCfg.u.drvManagedCfg.txCfg.txMemRegion = Qmss_MemRegion_MEMORY_REGION0;
drvCfg.u.drvManagedCfg.txCfg.numTxBuffers = 4;
drvCfg.u.drvManagedCfg.txCfg.txMTU = SRIO_MAX_MTU;
/* Start the Driver Managed SRIO Driver. */
hDrvManagedSrioDrv = Srio_start(&drvCfg);
if (hDrvManagedSrioDrv == NULL)
System_printf ("Error(Core %d): SRIO Driver failed to start\n", coreNum);
return;
/* Hook up the SRIO interrupts with the core. */
EventCombiner_dispatchPlug (48, (EventCombiner_FuncPtr)Srio_rxCompletionIsr, (UArg)hDrvManagedSrioDrv, TRUE);
EventCombiner_enableEvent(48);
CSL_tscEnable();
/* Run the loopback data transfers on the system initialization core. */
if (coreNum == CORE_SYS_INIT)
/* DIO Write Operation */
if (dioSocketsWithISR (hDrvManagedSrioDrv, Srio_Ftype_WRITE, Srio_Ttype_Write_NWRITE_R) < 0)
System_printf ("Error: Loopback DIO ISR example for Write operation failed\n");
Task_exit();
/* Reset global counters before next run */
/* DIO Read Operation */
if (dioSocketsWithISR (hDrvManagedSrioDrv, Srio_Ftype_REQUEST, Srio_Ttype_Request_NREAD) < 0)
System_printf ("Error: Loopback DIO ISR example for Read operation failed\n");
Task_exit();
/* Print out the Malloc & Free Counter */
System_printf ("Debug(Core %d): Allocation Counter : %d\n", coreNum, malloc_counter);
System_printf ("Debug(Core %d): Free Counter : %d\n", coreNum, free_counter);
/* Check if there is a memory leak? Since we dont implement a 'deinit' API we need to
* be careful in these calculations
* - For the Application Managed Driver Instance
* There will be 'numRxBuffers' + 1 (Driver Instance)
* - For the Driver Managed Driver Instance
* There will be 'numRxBuffers' + 'numTxBuffers' + 1 (Driver Instance)
* Take these into account while checking for memory leaks. */
if (free_counter +
(drvCfg.u.drvManagedCfg.rxCfg.numRxBuffers + drvCfg.u.drvManagedCfg.txCfg.numTxBuffers + 1) != malloc_counter)
System_printf ("Error: Memory Leak Detected\n");
Task_exit();
/* Control comes here implies that example passed. */
System_printf ("Debug(Core %d): DIO with Interrupts example completed successfully.\n", coreNum);
Task_exit();
* @b Description
* @n
* Entry point for the example
* @retval
* Not Applicable.
Void main(Void)
Task_Params taskParams;
coreNum = CSL_chipReadReg (CSL_CHIP_DNUM);
#ifdef SIMULATOR_SUPPORT
#warn SRIO DIO LSU ISR example is not supported on SIMULATOR !!!
System_printf ("SRIO DIO LSU ISR example is not supported on SIMULATOR. Exiting!\n");
return;
#else
System_printf ("Executing the SRIO DIO example on the DEVICE\n");
#endif
/* Initialize the system only if the core was configured to do so. */
System_printf ("Debug(Core %d): System Initialization for CPPI & QMSS\n", coreNum);
/* System Initialization */
if (system_init() < 0)
return;
/* Power on SRIO peripheral before using it */
if (enable_srio () < 0)
System_printf ("Error: SRIO PSC Initialization Failed\n");
return;
/* Device Specific SRIO Initializations: This should always be called before
* initializing the SRIO Driver. */
if (SrioDevice_init() < 0)
return;
/* Initialize the SRIO Driver */
if (Srio_init () < 0)
System_printf ("Error: SRIO Driver Initialization Failed\n");
return;
/* SRIO Driver is operational at this time. */
System_printf ("Debug(Core %d): SRIO Driver has been initialized\n", coreNum);
/* Write to the SHARED memory location at this point in time. The other cores cannot execute
* till the SRIO Driver is up and running. */
isSRIOInitialized[0] = 1;
/* The SRIO IP block has been initialized. We need to writeback the cache here because it will
* ensure that the rest of the cores which are waiting for SRIO to be initialized would now be
* woken up. */
CACHE_wbL1d ((void *) &isSRIOInitialized[0], 128, CACHE_WAIT);
else
/* All other cores need to wait for the SRIO to be initialized before they proceed. */
System_printf ("Debug(Core %d): Waiting for SRIO to be initialized.\n", coreNum);
/* All other cores loop around forever till the SRIO is up and running.
* We need to invalidate the cache so that we always read this from the memory. */
while (isSRIOInitialized[0] == 0)
CACHE_invL1d ((void *) &isSRIOInitialized[0], 128, CACHE_WAIT);
return;
System_printf ("Debug(Core %d): SRIO can now be used.\n", coreNum);
/* Create the DIO Example Task.*/
Task_Params_init(&taskParams);
Task_create(dioExampleTask, &taskParams, NULL);
/* Start the BIOS */
BIOS_start();
