CortxA8: Trouble Writing Memory Block at 0x4c0000e4 on Page 0 of Length 0x4: (Error -1065 @ 0x4C0000E4) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.872.0)
CortxA8: GEL: Error while executing OnTargetConnect(): target access failed at *((unsigned int *) (0x4C000000+0x0E4))=(unsigned int) 0x07 [AM335X_beagleboneblack.gel:265] at DDR3_EMIF_Config() [AM335X_beagleboneblack.gel:354] at AM335x_BeagleBlack_Initialization() [AM335X_beagleboneblack.gel:339] at OnTargetConnect() .
CortxA8: Trouble Reading Register CP15_CONTROL_REGISTER: (Error -2131 @ 0x20013F00) Unable to access device register. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.0.872.0)
