我需要AM4378 接 高清屏,65MHZ时钟,1280*800分辨率,是否可以修改DTS文件就可以?
lcd0: display {
compatible = "osddisplays,osd070t1718-19ts", "panel-dpi";
label = "lcd";
backlight = <&lcd_bl>;
panel-timing {
clock-frequency = <33000000>;
hactive = <800>;
vactive = <480>;
hfront-porch = <210>;
hback-porch = <16>;
hsync-len = <30>;
vback-porch = <10>;
vfront-porch = <22>;
vsync-len = <13>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
port {
lcd_in: endpoint {
remote-endpoint = <&dpi_out>;
我修改了DTS中的clock-frequency = <65000000>;也修改了hactive = <1280>;vactive = <800>;但是我测量下发现输出的PCLK似乎还是33MHZ,我的版本是最新的6的版本。
还是需要自己写driver?
如果自己写,有否相应的参考模板,谢谢!
